2012-8-17 12:23:42 [显示全部楼层]
12642浏览
查看: 12642|回复: 0
inkshield
http://garyhodgson.com/reprap/2012/04/inkshield-trying-to-run-before-i-can-walk/
Arduino控制的打印墨盒
http://nicholasclewis.com/projects/inkshield/ (需要翻墙)
http://www.thingiverse.com/thing:11907
What is an InkShield?
This shield allows you to connect a HP C6602 inkjet cartridge to your Arduino turning it into a 96dpi print platform. It only uses 5 pins which can be jumper selected to avoid other shields. It is designed with an Arduino Mega footprint but fully supports both the Arduino and the Arduino Mega. It uses all through-hole components to make assembly easy even for beginners.
Features
Compatible with Arduino and Arduino Mega
Uses only 5 user selectable pins
Stackable (up to 11 Inkshields on Ardunio, 15 on Mega)
On-board 18.5V boost converter for Inkjet head
Accepts 9-12V input via optional power connector or from the Vin of the Arduino
Auxiliary input header offers support for other microcontrollers
Auxiliary output header supports an extension cable to the inkjet head
Power and Pulse activity LEDs
ISCP header and Reset button
All through-hole components
高级模式
