192浏览
查看: 192|回复: 3
[项目] 【花雕动手做】基于Kitronik可编程开发板之四人赛马游戏
【花雕动手做】基于Kitronik可编程开发板之四人赛马游戏图1
【花雕动手做】基于Kitronik可编程开发板之四人赛马游戏图2
【花雕动手做】基于Kitronik可编程开发板之四人赛马游戏图3
发表于 2025-9-24 06:44:41
作为学习、练习与尝试,这里创建一个四人赛马的小游戏。
打开网页版:https://arcade.makecode.com/,设置项目名称:四人赛马
MicroPython实验代码
  1. @namespace
  2. class SpriteKind:
  3.     Finish = SpriteKind.create()
  4. def on_on_overlap(sprite, otherSprite):
  5.     carnival.on_game_over_expanded(winTypes.MULTI)
  6. sprites.on_overlap(SpriteKind.player, SpriteKind.Finish, on_on_overlap)
  7. def on_player1_button_a_pressed():
  8.     myHorse1.x += 1.5
  9.     myHorse1.start_effect(effects.spray, 100)
  10.     info.player1.change_score_by(1)
  11. controller.player1.on_button_event(ControllerButton.A,
  12.     ControllerButtonEvent.PRESSED,
  13.     on_player1_button_a_pressed)
  14. def on_player4_button_a_pressed():
  15.     myHorse4.x += 1.5
  16.     myHorse4.start_effect(effects.fountain, 100)
  17.     info.player4.change_score_by(1)
  18. controller.player4.on_button_event(ControllerButton.A,
  19.     ControllerButtonEvent.PRESSED,
  20.     on_player4_button_a_pressed)
  21. def on_player2_button_a_pressed():
  22.     myHorse2.x += 1.5
  23.     myHorse2.start_effect(effects.hearts, 100)
  24.     info.player2.change_score_by(1)
  25. controller.player2.on_button_event(ControllerButton.A,
  26.     ControllerButtonEvent.PRESSED,
  27.     on_player2_button_a_pressed)
  28. def on_player3_button_a_pressed():
  29.     myHorse3.x += 1.5
  30.     myHorse3.start_effect(effects.confetti, 100)
  31.     info.player3.change_score_by(1)
  32. controller.player3.on_button_event(ControllerButton.A,
  33.     ControllerButtonEvent.PRESSED,
  34.     on_player3_button_a_pressed)
  35. myHorse4: Sprite = None
  36. myHorse3: Sprite = None
  37. myHorse2: Sprite = None
  38. myHorse1: Sprite = None
  39. scene.set_background_color(1)
  40. scene.set_background_image(assets.image("""
  41.     bgFrame
  42.     """))
  43. myHorse1 = sprites.create(img("""
  44.         ........................bc....
  45.         ......................bcccc...
  46.         ......................cccccc..
  47.         ....................cccccccc..
  48.         .........cccccb....cccccccccc.
  49.         .......bccccccccccccccccc.bccc
  50.         .....ccccccccccccccccccc...bbc
  51.         ...bccbcccccccccccccccc.......
  52.         ccccc...ccccccccccccccb.......
  53.         .ccc....bcccccccccccccc.......
  54.         .........bccc..ccccccccc......
  55.         ..........ccc....cccccccc.....
  56.         ..........bccc.....ccc..bc....
  57.         ..........cbcc......cc...cb...
  58.         ..........b.bcc...ccc....bcb..
  59.         ..............cc..bc..........
  60.         """),
  61.     SpriteKind.player)
  62. myHorse1.set_position(20, 15)
  63. myHorse2 = sprites.create(img("""
  64.         ........................42....
  65.         ......................42222...
  66.         ......................222222..
  67.         ....................22222222..
  68.         .........222224....2222222222.
  69.         .......422222222222222222.4222
  70.         .....2222222222222222222...442
  71.         ...42242222222222222222.......
  72.         22222...222222222222224.......
  73.         .222....422222222222222.......
  74.         .........4222..222222222......
  75.         ..........222....22222222.....
  76.         ..........4222.....222..42....
  77.         ..........2422......22...24...
  78.         ..........4.422...222....424..
  79.         ..............22..42..........
  80.         """),
  81.     SpriteKind.player)
  82. myHorse2.set_position(20, 34)
  83. myHorse3 = sprites.create(img("""
  84.         ........................67....
  85.         ......................67777...
  86.         ......................777777..
  87.         ....................77777777..
  88.         .........777776....7777777777.
  89.         .......677777777777777777.6777
  90.         .....7777777777777777777...667
  91.         ...67767777777777777777.......
  92.         77777...777777777777776.......
  93.         .777....677777777777777.......
  94.         .........6777..777777777......
  95.         ..........777....77777777.....
  96.         ..........6777.....777..67....
  97.         ..........7677......77...76...
  98.         ..........6.677...777....676..
  99.         ..............77..67..........
  100.         """),
  101.     SpriteKind.player)
  102. myHorse3.set_position(20, 57)
  103. myHorse4 = sprites.create(img("""
  104.         ........................54....
  105.         ......................54444...
  106.         ......................444444..
  107.         ....................44444444..
  108.         .........444445....4444444444.
  109.         .......544444444444444444.5444
  110.         .....4444444444444444444...554
  111.         ...54454444444444444444.......
  112.         44444...444444444444445.......
  113.         .444....544444444444444.......
  114.         .........5444..444444444......
  115.         ..........444....44444444.....
  116.         ..........5444.....444..54....
  117.         ..........4544......44...45...
  118.         ..........5.544...444....545..
  119.         ..............44..54..........
  120.         """),
  121.     SpriteKind.player)
  122. myHorse4.set_position(20, 77)
  123. finish = sprites.create(assets.image("""
  124.     finish
  125.     """), SpriteKind.Finish)
  126. finish.set_position(150, 50)
  127. textSprite2 = textsprite.create("Horse Race")
  128. textSprite2.set_position(80, 108)
发表于 2025-9-24 06:48:54
这段 Arcade MakeCode 的“四人赛马游戏”代码是一个多玩家竞速小游戏。
游戏目标
四位玩家各控制一匹马,通过不断按下 A 键让马向右移动,最先到达终点(Finish 精灵)者获胜。
核心逻辑解析
1、精灵种类定义
python
  1. @namespace
创建一个新的精灵种类 Finish,用于标记终点线。
2、胜利判定机制
python
  2.     carnival.on_game_over_expanded(winTypes.MULTI)
  3. sprites.on_overlap(SpriteKind.player, SpriteKind.Finish, on_on_overlap)
当任意玩家的马(SpriteKind.player)碰到终点线(SpriteKind.Finish)时,触发多人胜利界面。
3、玩家控制逻辑
每位玩家按下 A 键时,控制自己的马向右移动,并触发特效与加分:
python
  1. def on_player1_button_a_pressed():
  2.     myHorse1.x += 1.5
  3.     myHorse1.start_effect(effects.spray, 100)
  4.     info.player1.change_score_by(1)
  5. x += 1.5:马向右移动。
start_effect(...):播放特效(每匹马不同)。
change_score_by(1):玩家得分 +1。
其他玩家(player2、player3、player4)逻辑类似,只是马匹和特效不同:
player2: hearts
player3: confetti
player4: fountain
4、 马匹初始化与位置设置
python
  1. myHorse1 = sprites.create(img("""..."""), SpriteKind.player)
创建四匹马精灵,分别放置在不同的纵向位置(y = 15, 34, 57, 77),横向起点统一为 x = 20。
5、终点设置
python
  1. finish = sprites.create(assets.image("""finish"""), SpriteKind.Finish)
  2. finish.set_position(150, 50)
创建终点线精灵,放置在屏幕右侧中间位置。
6、背景与标题设置
python
  1. scene.set_background_color(1)
  2. scene.set_background_image(assets.image("""bgFrame"""))
  3. textSprite2 = textsprite.create("Horse Race")
  4. textSprite2.set_position(80, 108)
设置背景颜色与图像。
显示游戏标题 “Horse Race”。
发表于 2025-9-24 06:53:53
图形编程参考实验程序
通过模拟器,调试与模拟运行
实验场景记录
【花雕动手做】基于Kitronik可编程开发板之四人赛马游戏图4
