198浏览
查看: 198|回复: 4
[项目] 【花雕动手做】基于Kitronik可编程开发板之板条箱地牢
【花雕动手做】基于Kitronik可编程开发板之板条箱地牢图1
【花雕动手做】基于Kitronik可编程开发板之板条箱地牢图2
【花雕动手做】基于Kitronik可编程开发板之板条箱地牢图3
发表于 2025-9-23 17:11:05
作为学习、练习与尝试,这里创建一个板条箱地牢的小游戏。
打开网页版:https://arcade.makecode.com/,设置项目名称:板条箱地牢
MicroPython实验代码
  1. @namespace
  2. class SpriteKind:
  3.     Stupid = SpriteKind.create()
  4.     PlaceHolder = SpriteKind.create()
  5.     Box = SpriteKind.create()
  6.     Item = SpriteKind.create()
  7.     Book = SpriteKind.create()
  8. def on_overlap_tile(sprite, location):
  9.     tiles.set_tile_at(location, assets.tile("""
  10.         transparency8
  11.         """))
  12.     tiles.set_wall_at(location, False)
  13. scene.on_overlap_tile(SpriteKind.food,
  14.     assets.tile("""
  15.         breakible wall0
  16.         """),
  17.     on_overlap_tile)
  18. # WALLS ARE BUGGY FIX LTR
  19. def PushTiles(Pusher: Sprite, Pushing: Sprite):
  20.     characterAnimations.clear_character_state(Pushing)
  21.     sprites.set_data_boolean(Pushing, "RecentlyPushed", True)
  22.     if characterAnimations.matches_rule(Pusher, characterAnimations.rule(Predicate.MOVING_LEFT)):
  23.         if not (tiles.tile_at_location_is_wall(grid.add(grid.get_location(Pushing), -1, 0))):
  24.             characterAnimations.set_character_state(Pushing, characterAnimations.rule(Predicate.MOVING_LEFT))
  25.             grid.move(Pushing, -1, 0)
  26.         else:
  27.             grid.move(sprites.read_data_sprite(Something, "S-Control"), 1, 0)
  28.             if Pusher.kind() == SpriteKind.Box:
  29.                 characterAnimations.set_character_state(Pusher, characterAnimations.rule(Predicate.MOVING_RIGHT))
  30.                 grid.move(Pusher, 1, 0)
  31.     if characterAnimations.matches_rule(Pusher, characterAnimations.rule(Predicate.MOVING_RIGHT)):
  32.         if not (tiles.tile_at_location_is_wall(grid.add(grid.get_location(Pushing), 1, 0))):
  33.             characterAnimations.set_character_state(Pushing, characterAnimations.rule(Predicate.MOVING_RIGHT))
  34.             grid.move(Pushing, 1, 0)
  35.         else:
  36.             grid.move(sprites.read_data_sprite(Something, "S-Control"), -1, 0)
  37.             if Pusher.kind() == SpriteKind.Box:
  38.                 characterAnimations.set_character_state(Pusher, characterAnimations.rule(Predicate.MOVING_LEFT))
  39.                 grid.move(Pusher, -1, 0)
  40.     if characterAnimations.matches_rule(Pusher, characterAnimations.rule(Predicate.MOVING_DOWN)):
  41.         if not (tiles.tile_at_location_is_wall(grid.add(grid.get_location(Pushing), 0, 1))):
  42.             characterAnimations.set_character_state(Pushing, characterAnimations.rule(Predicate.MOVING_DOWN))
  43.             grid.move(Pushing, 0, 1)
  44.         else:
  45.             grid.move(sprites.read_data_sprite(Something, "S-Control"), 0, -1)
  46.             if Pusher.kind() == SpriteKind.Box:
  47.                 characterAnimations.set_character_state(Pusher, characterAnimations.rule(Predicate.MOVING_UP))
  48.                 grid.move(Pusher, 0, -1)
  49.     if characterAnimations.matches_rule(Pusher, characterAnimations.rule(Predicate.MOVING_UP)):
  50.         if not (tiles.tile_at_location_is_wall(grid.add(grid.get_location(Pushing), 0, -1))):
  51.             characterAnimations.set_character_state(Pushing, characterAnimations.rule(Predicate.MOVING_UP))
  52.             grid.move(Pushing, 0, -1)
  53.         else:
  54.             grid.move(sprites.read_data_sprite(Something, "S-Control"), 0, 1)
  55.             if Pusher.kind() == SpriteKind.Box:
  56.                 characterAnimations.set_character_state(Pusher, characterAnimations.rule(Predicate.MOVING_DOWN))
  57.                 grid.move(Pusher, 0, 1)
  58.
  59.     def on_after():
  60.         sprites.set_data_boolean(Pushing, "RecentlyPushed", False)
  61.     timer.after(100, on_after)
  62.
  63.
  64.     def on_background():
  65.         pass
  66.     timer.background(on_background)
  67.
  68. def on_create_renderable(screen2):
  69.     if lvl >= 17 and not (lvl == 99):
  70.         screen2.replace(11, 8)
  71.         screen2.replace(15, 12)
  72. spriteutils.create_renderable(0, on_create_renderable)
  73. def on_overlap_tile2(sprite2, location2):
  74.     Customeffects("Fall", sprite2, True, 1, 1, 100)
  75.     sprites.destroy(sprite2)
  76.     tiles.set_tile_at(location2, assets.tile("""
  77.         BoxCovering Pit
  78.         """))
  79. scene.on_overlap_tile(SpriteKind.Box,
  80.     assets.tile("""
  81.         Pit
  82.         """),
  83.     on_overlap_tile2)
  84. def on_overlap_tile3(sprite3, location3):
  85.     if sprites.read_data_string(sprites.read_data_sprite(sprites.read_data_sprite(Something, "S-Control"), "H-Hand"),
  86.         "I-Type") == "Key":
  87.         tiles.set_tile_at(location3, assets.tile("""
  88.             transparency8
  89.             """))
  90.         Customeffects("Twinkle", sprite3, True, 1, 1, 200)
  91.         sprites.set_data_string(sprites.read_data_sprite(sprites.read_data_sprite(Something, "S-Control"), "H-Hand"),
  92.             "I-Type",
  93.             "Null")
  94.         sprites.destroy(sprites.read_data_sprite(sprites.read_data_sprite(Something, "S-Control"), "H-Hand"))
  95.     else:
  96.         if characterAnimations.matches_rule(sprites.read_data_sprite(Something, "S-Control"),
  97.             characterAnimations.rule(Predicate.MOVING_LEFT)):
  98.             grid.move(sprites.read_data_sprite(Something, "S-Control"), 1, 0)
  99.         if characterAnimations.matches_rule(sprites.read_data_sprite(Something, "S-Control"),
  100.             characterAnimations.rule(SpriteKind.player)):
  101.             grid.move(sprites.read_data_sprite(Something, "S-Control"), -1, 0)
  102.         if characterAnimations.matches_rule(sprites.read_data_sprite(Something, "S-Control"),
  103.             characterAnimations.rule(Predicate.MOVING_UP)):
  104.             grid.move(sprites.read_data_sprite(Something, "S-Control"), 0, 1)
  105.         if characterAnimations.matches_rule(sprites.read_data_sprite(Something, "S-Control"),
  106.             characterAnimations.rule(Predicate.MOVING_DOWN)):
  107.             grid.move(sprites.read_data_sprite(Something, "S-Control"), 0, -1)
  108. scene.on_overlap_tile(SpriteKind.player,
  109.     assets.tile("""
  110.         Lock
  111.         """),
  112.     on_overlap_tile3)
  113. def on_on_overlap(sprite4, otherSprite):
  114.     if controller.A.is_pressed():
  115.         sprites.set_data_sprite(sprite4, "H-Hand", otherSprite)
  116.         music.play(music.create_sound_effect(WaveShape.NOISE,
  117.                 1,
  118.                 973,
  119.                 98,
  120.                 0,
  121.                 100,
  122.                 SoundExpressionEffect.VIBRATO,
  123.                 InterpolationCurve.LINEAR),
  124.             music.PlaybackMode.IN_BACKGROUND)
  125. sprites.on_overlap(SpriteKind.player, SpriteKind.Item, on_on_overlap)
  126. def on_overlap_tile4(sprite5, location4):
  127.     tiles.set_tile_at(location4, assets.tile("""
  128.         transparency8
  129.         """))
  130.     tiles.set_wall_at(location4, False)
  131. scene.on_overlap_tile(SpriteKind.food,
  132.     assets.tile("""
  133.         Cannon LR
  134.         """),
  135.     on_overlap_tile4)
  136. def on_overlap_tile5(sprite6, location5):
  137.     tiles.set_tile_at(location5, assets.tile("""
  138.         transparency8
  139.         """))
  140.     Customeffects("Twinkle", sprite6, True, 1, 1, 500)
  141.     SwapBlocks(1)
  142. scene.on_overlap_tile(SpriteKind.player,
  143.     assets.tile("""
  144.         RButton2
  145.         """),
  146.     on_overlap_tile5)
  147. def on_b_pressed():
  148.     global Placeholder
  149.     if sprites.read_data_sprite(sprites.read_data_sprite(Something, "S-Control"), "H-Hand") != spriteutils.null_consts(spriteutils.NullConsts.NULL):
  150.         sprites.read_data_sprite(sprites.read_data_sprite(Something, "S-Control"), "H-Hand").set_position(sprites.read_data_sprite(Something, "S-Control").x,
  151.             sprites.read_data_sprite(Something, "S-Control").y)
  152.         Placeholder = sprites.create(assets.image("""
  153.             Door Open
  154.             """), SpriteKind.Item)
  155.         sprites.set_data_sprite(sprites.read_data_sprite(Something, "S-Control"),
  156.             "H-Hand",
  157.             Placeholder)
  158.         sprites.destroy(Placeholder)
  159.         music.play(music.create_sound_effect(WaveShape.SQUARE,
  160.                 694,
  161.                 583,
  162.                 59,
  163.                 0,
  164.                 100,
  165.                 SoundExpressionEffect.NONE,
  166.                 InterpolationCurve.LINEAR),
  167.             music.PlaybackMode.IN_BACKGROUND)
  168. controller.B.on_event(ControllerButtonEvent.PRESSED, on_b_pressed)
  169. def on_menu_pressed():
  170.     Level(lvl)
  171. controller.menu.on_event(ControllerButtonEvent.PRESSED, on_menu_pressed)
  172. def ColorGrid(Color1: number, Color2: number):
  173.     global picture
  174.     picture = assets.image("""
  175.         BG
  176.         """)
  177.     picture.replace(1, Color1)
  178.     scene.set_background_image(picture)
  179.     scene.set_background_color(Color2)
  180. def on_a_pressed():
  181.     if mySprite:
  182.         if not (sprites.read_data_sprite(sprites.read_data_sprite(Something, "S-Control"), "H-Hand") == spriteutils.null_consts(spriteutils.NullConsts.NULL)):
  183.             Use_Item(sprites.read_data_string(sprites.read_data_sprite(sprites.read_data_sprite(Something, "S-Control"), "H-Hand"),
  184.                     "I-Type"))
  185. controller.A.on_event(ControllerButtonEvent.PRESSED, on_a_pressed)
  186. def on_overlap_tile6(sprite7, location6):
  187.     tiles.set_tile_at(location6, assets.tile("""
  188.         TeleporterOff
  189.         """))
  190.     sprite7.set_flag(SpriteFlag.GHOST_THROUGH_TILES, True)
  191.     tiles.place_on_random_tile(sprite7, assets.tile("""
  192.         Teleporter
  193.         """))
  194.     grid.place(sprite7, sprite7.tilemap_location())
  195.     tiles.set_tile_at(grid.get_location(sprite7),
  196.         assets.tile("""
  197.             TeleporterOff
  198.             """))
  199.     sprite7.set_flag(SpriteFlag.GHOST_THROUGH_TILES, False)
  200.
  201.     def on_background2():
  202.         tiles.set_tile_at(location6, assets.tile("""
  203.             Teleporter
  204.             """))
  205.
  206.         def on_pause_until():
  207.             pass
  208.         pause_until(on_pause_until)
  209.
  210.         for value in tiles.get_tiles_by_type(assets.tile("""
  211.             TeleporterOff
  212.             """)):
  213.             tiles.set_tile_at(value, assets.tile("""
  214.                 Teleporter
  215.                 """))
  216.     timer.background(on_background2)
  217.
  218. scene.on_overlap_tile(SpriteKind.Box,
  219.     assets.tile("""
  220.         Teleporter
  221.         """),
  222.     on_overlap_tile6)
  223. def on_overlap_tile7(sprite8, location7):
  224.     if sprites.read_data_string(sprites.read_data_sprite(sprites.read_data_sprite(Something, "S-Control"), "H-Hand"),
  225.         "I-Type") == "Key":
  226.         tiles.set_tile_at(location7, assets.tile("""
  227.             Exit
  228.             """))
  229.         Customeffects("Twinkle", sprite8, True, 1, 1, 200)
  230.         sprites.set_data_string(sprites.read_data_sprite(sprites.read_data_sprite(Something, "S-Control"), "H-Hand"),
  231.             "I-Type",
  232.             "Null")
  233.         sprites.destroy(sprites.read_data_sprite(sprites.read_data_sprite(Something, "S-Control"), "H-Hand"))
  234. scene.on_overlap_tile(SpriteKind.player,
  235.     assets.tile("""
  236.         Lock0
  237.         """),
  238.     on_overlap_tile7)
  239. def on_left_pressed():
  240.     if not (tiles.tile_at_location_is_wall(tiles.get_tile_location(-1 + sprites.read_data_sprite(Something, "S-Control").tilemap_location().column,
  241.             sprites.read_data_sprite(Something, "S-Control").tilemap_location().row))):
  242.         Customeffects("Steps",
  243.             sprites.read_data_sprite(Something, "S-Control"),
  244.             False,
  245.             sprites.read_data_sprite(Something, "S-Control").x,
  246.             sprites.read_data_sprite(Something, "S-Control").y,
  247.             400)
  248.         grid.move(sprites.read_data_sprite(Something, "S-Control"), -1, 0)
  249.         music.play(music.create_sound_effect(WaveShape.NOISE,
  250.                 randint(300, 350),
  251.                 0,
  252.                 127,
  253.                 0,
  254.                 100,
  255.                 SoundExpressionEffect.NONE,
  256.                 InterpolationCurve.LINEAR),
  257.             music.PlaybackMode.IN_BACKGROUND)
  258. controller.left.on_event(ControllerButtonEvent.PRESSED, on_left_pressed)
  259. def SwapBlocks(Stage: number):
  260.     if 1 == Stage:
  261.         tiles.replace_all_tiles(assets.tile("""
  262.                 RedTileOFF
  263.                 """),
  264.             assets.tile("""
  265.                 HiddenGem
  266.                 """))
  267.         tiles.replace_all_tiles(assets.tile("""
  268.                 RedTileOn0
  269.                 """),
  270.             assets.tile("""
  271.                 RedTileOFF
  272.                 """))
  273.         tiles.replace_all_tiles(assets.tile("""
  274.                 HiddenGem
  275.                 """),
  276.             assets.tile("""
  277.                 RedTileOn0
  278.                 """))
  279.         for value2 in tiles.get_tiles_by_type(assets.tile("""
  280.             RedTileOFF
  281.             """)):
  282.             Customeffects("Twinkle",
  283.                 mySprite,
  284.                 False,
  285.                 4 + 8 * value2.column,
  286.                 4 + 8 * value2.row,
  287.                 100)
  288.             tiles.set_wall_at(value2, False)
  289.         for value22 in tiles.get_tiles_by_type(assets.tile("""
  290.             RedTileOn0
  291.             """)):
  292.             Customeffects("Twinkle",
  293.                 mySprite,
  294.                 False,
  295.                 4 + 8 * value22.column,
  296.                 4 + 8 * value22.row,
  297.                 100)
  298.             tiles.set_wall_at(value22, True)
  299.         music.play(music.create_sound_effect(WaveShape.NOISE,
  300.                 839,
  301.                 0,
  302.                 255,
  303.                 0,
  304.                 200,
  305.                 SoundExpressionEffect.NONE,
  306.                 InterpolationCurve.LINEAR),
  307.             music.PlaybackMode.IN_BACKGROUND)
  308.     elif 2 == Stage:
  309.         music.play(music.create_sound_effect(WaveShape.TRIANGLE,
  310.                 692,
  311.                 1,
  312.                 131,
  313.                 0,
  314.                 200,
  315.                 SoundExpressionEffect.NONE,
  316.                 InterpolationCurve.LINEAR),
  317.             music.PlaybackMode.IN_BACKGROUND)
  318.         tiles.replace_all_tiles(assets.tile("""
  319.                 BlueTileOFF
  320.                 """),
  321.             assets.tile("""
  322.                 HiddenGem
  323.                 """))
  324.         tiles.replace_all_tiles(assets.tile("""
  325.                 BlueTileOn
  326.                 """),
  327.             assets.tile("""
  328.                 BlueTileOFF
  329.                 """))
  330.         tiles.replace_all_tiles(assets.tile("""
  331.                 HiddenGem
  332.                 """),
  333.             assets.tile("""
  334.                 BlueTileOn
  335.                 """))
  336.         for value3 in tiles.get_tiles_by_type(assets.tile("""
  337.             BlueTileOFF
  338.             """)):
  339.             Customeffects("Wand",
  340.                 mySprite,
  341.                 False,
  342.                 4 + 8 * value3.column,
  343.                 4 + 8 * value3.row,
  344.                 100)
  345.             tiles.set_wall_at(value3, False)
  346.         for value23 in tiles.get_tiles_by_type(assets.tile("""
  347.             BlueTileOn
  348.             """)):
  349.             Customeffects("Wand",
  350.                 mySprite,
  351.                 False,
  352.                 4 + 8 * value23.column,
  353.                 4 + 8 * value23.row,
  354.                 100)
  355.             tiles.set_wall_at(value23, True)
  356.     else:
  357.         pass
  358. def on_on_overlap2(sprite9, otherSprite2):
  359.     if sprites.read_data_boolean(otherSprite2, "RecentlyPushed"):
  360.         PushTiles(otherSprite2, sprite9)
  361.         sprites.set_data_boolean(otherSprite2, "RecentlyPushed", False)
  362.     elif sprites.read_data_boolean(sprite9, "RecentlyPushed"):
  363.         PushTiles(sprite9, otherSprite2)
  364.         sprites.set_data_boolean(sprite9, "RecentlyPushed", False)
  365. sprites.on_overlap(SpriteKind.Box, SpriteKind.Box, on_on_overlap2)
  366. def Use_Item(Text: str):
  367.     global Placeholder, PlayCutScene
  368.     if Text == "Sword":
  369.         Placeholder = sprites.create(img("""
  370.                 . . . . . . . . . . . . . . . .
  371.                 . . . . . . . . . . . . . . . .
  372.                 . . . . . . . . . . . . . . . .
  373.                 . . . . . . . . . . . . . . . .
  374.                 . . . . . . . . . . . . . . . .
  375.                 . . . . . . . . . . . . . . . .
  376.                 . . . . . . . . . . . . . . . .
  377.                 . . . . . . . . . . . . . . . .
  378.                 . . . . . . . . . . . . . . . .
  379.                 . . . . . . . . . . . . . . . .
  380.                 . . . . . . . . . . . . . . . .
  381.                 . . . . . . . . . . . . . . . .
  382.                 . . . . . . . . . . . . . . . .
  383.                 . . . . . . . . . . . . . . . .
  384.                 . . . . . . . . . . . . . . . .
  385.                 . . . . . . . . . . . . . . . .
  386.                 """),
  387.             SpriteKind.food)
  388.         Placeholder.set_flag(SpriteFlag.GHOST_THROUGH_WALLS, True)
  389.         Placeholder.set_position(sprites.read_data_sprite(Something, "S-Control").x,
  390.             sprites.read_data_sprite(Something, "S-Control").y)
  391.         animation.run_image_animation(Placeholder,
  392.             [img("""
  393.                     . . . . . . . . . . . . . .
  394.                     . . . 4 4 4 4 . . 4 4 . . .
  395.                     . . 4 1 1 1 . . 1 1 1 4 . .
  396.                     . 4 1 . . . . . . . . 1 4 .
  397.                     . 4 1 . . . . . . . . 1 4 .
  398.                     . . 1 . . . . . . . . 1 4 .
  399.                     . . . . . . . . . . . . 4 .
  400.                     . 4 . . . . . . . . . . . .
  401.                     . 4 1 . . . . . . . . 1 . .
  402.                     . 4 1 . . . . . . . . 1 4 .
  403.                     . 4 1 . . . . . . . . 1 4 .
  404.                     . . 4 1 1 1 . . 1 1 1 4 . .
  405.                     . . . 4 4 . . 4 4 4 4 . . .
  406.                     . . . . . . . . . . . . . .
  407.                     """),
  408.                 img("""
  409.                     . . . . . . . . . . . . . .
  410.                     . . . 4 4 4 4 4 . . 4 . . .
  411.                     . . 4 1 1 1 1 . . 1 1 4 . .
  412.                     . 4 1 . . . . . . . . 1 4 .
  413.                     . . 1 . . . . . . . . 1 4 .
  414.                     . . . . . . . . . . . 1 4 .
  415.                     . 4 . . . . . . . . . 1 4 .
  416.                     . 4 1 . . . . . . . . . 4 .
  417.                     . 4 1 . . . . . . . . . . .
  418.                     . 4 1 . . . . . . . . 1 . .
  419.                     . 4 1 . . . . . . . . 1 4 .
  420.                     . . 4 1 1 . . 1 1 1 1 4 . .
  421.                     . . . 4 . . 4 4 4 4 4 . . .
  422.                     . . . . . . . . . . . . . .
  423.                     """),
  424.                 img("""
  425.                     . . . . . . . . . . . . . .
  426.                     . . . . 4 4 4 4 4 4 4 . . .
  427.                     . . . 4 1 1 1 1 1 1 . . . .
  428.                     . 4 . . . . . . . . . 4 . .
  429.                     . 4 1 . . . . . . . . 1 4 .
  430.                     . 4 1 . . . . . . . . 1 4 .
  431.                     . 4 1 . . . . . . . . 1 4 .
  432.                     . 4 1 . . . . . . . . 1 4 .
  433.                     . 4 1 . . . . . . . . 1 4 .
  434.                     . 4 1 . . . . . . . . 1 4 .
  435.                     . . 4 . . . . . . . . . 4 .
  436.                     . . . . 1 1 1 1 1 1 4 . . .
  437.                     . . . 4 4 4 4 4 4 4 . . . .
  438.                     . . . . . . . . . . . . . .
  439.                     """),
  440.                 img("""
  441.                     . . . . . . . . . . . . . .
  442.                     . . . . 4 4 4 4 . . . . . .
  443.                     . . . 4 1 1 1 1 1 4 4 . . .
  444.                     . . 4 1 . . . . . . 1 4 . .
  445.                     . . 4 . . . . . . . . 1 4 .
  446.                     . . 1 . . . . . . . . 1 4 .
  447.                     . 4 1 . . . . . . . . 1 4 .
  448.                     . 4 1 . . . . . . . . 1 4 .
  449.                     . 4 1 . . . . . . . . 1 . .
  450.                     . 4 1 . . . . . . . . 4 . .
  451.                     . . 4 1 . . . . . . 1 4 . .
  452.                     . . . 4 4 1 1 1 1 1 4 . . .
  453.                     . . . . . . 4 4 4 4 . . . .
  454.                     . . . . . . . . . . . . . .
  455.                     """),
  456.                 img("""
  457.                     . . . . . . . . . . . . . .
  458.                     . . . . 4 . . . . . . . . .
  459.                     . . . 4 1 4 4 4 4 4 4 . . .
  460.                     . . 4 1 1 . 1 1 1 1 1 4 . .
  461.                     . . 4 1 . . . . . . 1 1 4 .
  462.                     . . 4 1 . . . . . . . 4 . .
  463.                     . . 4 1 . . . . . . 1 4 . .
  464.                     . . 4 1 . . . . . . 1 4 . .
  465.                     . . 4 . . . . . . . 1 4 . .
  466.                     . 4 1 1 . . . . . . 1 4 . .
  467.                     . . 4 1 1 1 1 1 . 1 1 4 . .
  468.                     . . . 4 4 4 4 4 4 1 4 . . .
  469.                     . . . . . . . . . 4 . . . .
  470.                     . . . . . . . . . . . . . .
  471.                     """),
  472.                 img("""
  473.                     . . . . . . . . . . . . . .
  474.                     . . . . . . . . . . . . . .
  475.                     . . . . 4 4 4 4 4 4 . . . .
  476.                     . . . 4 1 1 1 1 1 1 4 . . .
  477.                     . . 4 1 1 . . . . 1 1 4 . .
  478.                     . . 4 1 . . . . . . 1 4 . .
  479.                     . . 4 1 . . . . . . 1 4 . .
  480.                     . . 4 1 . . . . . . 1 4 . .
  481.                     . . 4 1 . . . . . . 1 4 . .
  482.                     . . 4 1 1 . . . . 1 1 4 . .
  483.                     . . . 4 1 1 1 1 1 1 4 . . .
  484.                     . . . . 4 4 4 4 4 4 . . . .
  485.                     . . . . . . . . . . . . . .
  486.                     . . . . . . . . . . . . . .
  487.                     """),
  488.                 img("""
  489.                     . . . . . . . . . . . . . .
  490.                     . . . . . . . . . . . . . .
  491.                     . . . . . . . . . . . . . .
  492.                     . . . . . 4 4 4 4 . . . . .
  493.                     . . . . 4 1 1 1 1 4 . . . .
  494.                     . . . 4 1 . . . . 1 4 . . .
  495.                     . . . 4 1 . . . . 1 4 . . .
  496.                     . . . 4 1 . . . . 1 4 . . .
  497.                     . . . 4 1 . . . . 1 4 . . .
  498.                     . . . . 4 1 1 1 1 4 . . . .
  499.                     . . . . . 4 4 4 4 . . . . .
  500.                     . . . . . . . . . . . . . .
  501.                     . . . . . . . . . . . . . .
  502.                     . . . . . . . . . . . . . .
  503.                     """)],
  504.             100,
  505.             False)
  506.         music.play(music.create_sound_effect(WaveShape.SAWTOOTH,
  507.                 randint(770, 800),
  508.                 0,
  509.                 98,
  510.                 0,
  511.                 100,
  512.                 SoundExpressionEffect.NONE,
  513.                 InterpolationCurve.LINEAR),
  514.             music.PlaybackMode.IN_BACKGROUND)
  515.         Placeholder.lifespan = 700
  516.     elif Text == "Book":
  517.         PlayCutScene = True
  518.         Level(99)
  519.     else:
  520.         pass
  521. def CutScene(Text1: str, Text2: str, Background: Image, Time: number):
  522.     global textSprite, textSprite2
  523.     if PlayCutScene:
  524.         mySprite.set_flag(SpriteFlag.INVISIBLE, True)
  525.         tiles.load_map(tiles.create_small_map(tilemap("""
  526.             EmptyTilemap
  527.             """)))
  528.         scene.set_background_image(Background)
  529.         scene.set_background_color(15)
  530.         textSprite = textsprite.create(Text1, 0, 15)
  531.         textSprite2 = textsprite.create(Text2, 0, 15)
  532.         textSprite.scale = 0
  533.         textSprite2.scale = 0
  534.         textSprite.set_outline(1, 1)
  535.         textSprite2.set_outline(1, 1)
  536.         textSprite.set_position(80, 50)
  537.         textSprite2.set_position(80, 70)
  538.         for index in range(10):
  539.             textSprite.scale += 0.1
  540.             textSprite2.scale += 0.1
  541.             pause(50)
  542.         pause(Time)
  543.         for index2 in range(10):
  544.             textSprite.scale += -0.1
  545.             textSprite2.scale += -0.1
  546.             pause(50)
  547.         sprites.destroy(textSprite)
  548.         sprites.destroy(textSprite2)
  549.         mySprite.set_flag(SpriteFlag.INVISIBLE, False)
  550.         scene.set_background_color(15)
  551. def on_overlap_tile8(sprite10, location8):
  552.     SwapBlocks(2)
  553.     tiles.set_tile_at(location8, assets.tile("""
  554.         BButtonPressed
  555.         """))
  556.     Customeffects("Wand", sprite10, True, 1, 1, 200)
  557.
  558.     def on_background3():
  559.
  560.         def on_pause_until2():
  561.             pass
  562.         pause_until(on_pause_until2)
  563.
  564.         tiles.set_tile_at(location8, assets.tile("""
  565.             BButton
  566.             """))
  567.     timer.background(on_background3)
  568.
  569. scene.on_overlap_tile(SpriteKind.player,
  570.     assets.tile("""
  571.         BButton
  572.         """),
  573.     on_overlap_tile8)
  574. def on_overlap_tile9(sprite11, location9):
  575.     global Placeholder
  576.     if sprites.read_data_sprite(sprites.read_data_sprite(Something, "S-Control"), "H-Hand") != spriteutils.null_consts(spriteutils.NullConsts.NULL):
  577.         sprites.read_data_sprite(sprites.read_data_sprite(Something, "S-Control"), "H-Hand").set_position(sprites.read_data_sprite(Something, "S-Control").x,
  578.             sprites.read_data_sprite(Something, "S-Control").y)
  579.         Placeholder = sprites.create(assets.image("""
  580.             Door Open
  581.             """), SpriteKind.Item)
  582.         sprites.set_data_sprite(sprites.read_data_sprite(Something, "S-Control"),
  583.             "H-Hand",
  584.             Placeholder)
  585.         sprites.destroy(Placeholder)
  586.         music.play(music.create_sound_effect(WaveShape.SQUARE,
  587.                 694,
  588.                 583,
  589.                 59,
  590.                 0,
  591.                 100,
  592.                 SoundExpressionEffect.NONE,
  593.                 InterpolationCurve.LINEAR),
  594.             music.PlaybackMode.IN_BACKGROUND)
  595.     tiles.set_tile_at(location9, assets.tile("""
  596.         TeleporterOff
  597.         """))
  598.     sprite11.set_flag(SpriteFlag.GHOST_THROUGH_TILES, True)
  599.     tiles.place_on_random_tile(sprite11, assets.tile("""
  600.         Teleporter
  601.         """))
  602.     grid.place(sprite11, sprite11.tilemap_location())
  603.     tiles.set_tile_at(grid.get_location(sprite11),
  604.         assets.tile("""
  605.             TeleporterOff
  606.             """))
  607.     sprite11.set_flag(SpriteFlag.GHOST_THROUGH_TILES, False)
  608.
  609.     def on_background4():
  610.         tiles.set_tile_at(location9, assets.tile("""
  611.             Teleporter
  612.             """))
  613.
  614.         def on_pause_until3():
  615.             pass
  616.         pause_until(on_pause_until3)
  617.
  618.         for value4 in tiles.get_tiles_by_type(assets.tile("""
  619.             TeleporterOff
  620.             """)):
  621.             tiles.set_tile_at(value4, assets.tile("""
  622.                 Teleporter
  623.                 """))
  624.     timer.background(on_background4)
  625.
  626. scene.on_overlap_tile(SpriteKind.player,
  627.     assets.tile("""
  628.         Teleporter
  629.         """),
  630.     on_overlap_tile9)
  631. def Customeffects(Type: str, Sprite2: Sprite, Onsprite: bool, X: number, Y: number, Time2: number):
  632.     global myEffect
  633.     myEffect.z = -5
  634.     if Type == "Steps":
  635.         myEffect = extraEffects.create_custom_spread_effect_data([1, 11],
  636.             True,
  637.             [3, 2, 1],
  638.             extraEffects.create_percentage_range(0, 0),
  639.             extraEffects.create_percentage_range(0, 0),
  640.             extraEffects.create_time_range(200, 300),
  641.             0,
  642.             0,
  643.             extraEffects.create_percentage_range(50, 100),
  644.             0,
  645.             0,
  646.             200)
  647.     elif Type == "Wand":
  648.         myEffect = extraEffects.create_custom_spread_effect_data([9, 8, 6],
  649.             False,
  650.             extraEffects.create_shrinking_size_table(8),
  651.             extraEffects.create_percentage_range(0, 0),
  652.             extraEffects.create_percentage_range(20, 20),
  653.             extraEffects.create_time_range(200, 600),
  654.             0,
  655.             0,
  656.             extraEffects.create_percentage_range(50, 100),
  657.             0,
  658.             0,
  659.             500)
  660.     elif Type == "Twinkle":
  661.         myEffect.z = 4
  662.         myEffect = extraEffects.create_custom_spread_effect_data([2, 4, 5],
  663.             True,
  664.             extraEffects.create_shrinking_size_table(8),
  665.             extraEffects.create_percentage_range(0, 0),
  666.             extraEffects.create_percentage_range(20, 20),
  667.             extraEffects.create_time_range(200, 600),
  668.             0,
  669.             0,
  670.             extraEffects.create_percentage_range(50, 100),
  671.             0,
  672.             0,
  673.             500)
  674.     elif Type == "Victory":
  675.         myEffect = extraEffects.create_custom_spread_effect_data([14, 14, 13, 13, 7],
  676.             False,
  677.             [1, 4, 8, 4, 1],
  678.             extraEffects.create_percentage_range(40, 40),
  679.             extraEffects.create_percentage_range(0, 0),
  680.             extraEffects.create_time_range(1000, 1000))
  681.     elif Type == "Fadeout":
  682.         myEffect.z = 4
  683.         myEffect = extraEffects.create_custom_spread_effect_data([15],
  684.             False,
  685.             extraEffects.create_growing_size_table(450),
  686.             extraEffects.create_percentage_range(0, 0),
  687.             extraEffects.create_percentage_range(0, 0),
  688.             extraEffects.create_time_range(1500, 1500))
  689.     elif Type == "Fadein":
  690.         myEffect.z = 5
  691.         myEffect = extraEffects.create_custom_spread_effect_data([15, 15, 15, 15, 15, 15, 1],
  692.             False,
  693.             extraEffects.create_shrinking_size_table(450),
  694.             extraEffects.create_percentage_range(0, 0),
  695.             extraEffects.create_percentage_range(0, 0),
  696.             extraEffects.create_time_range(1500, 1500))
  697.     elif Type == "fall":
  698.         myEffect = extraEffects.create_custom_spread_effect_data([0, 15, 15],
  699.             False,
  700.             extraEffects.create_shrinking_size_table(8),
  701.             extraEffects.create_percentage_range(0, 0),
  702.             extraEffects.create_percentage_range(0, 0),
  703.             extraEffects.create_time_range(500, 500))
  704.     elif Type == "Explode":
  705.         myEffect = extraEffects.create_custom_spread_effect_data([2, 5, 4, 0],
  706.             True,
  707.             extraEffects.create_shrinking_size_table(24),
  708.             extraEffects.create_percentage_range(0, 0),
  709.             extraEffects.create_percentage_range(30, 30),
  710.             extraEffects.create_time_range(500, 500))
  711.     else:
  712.         pass
  713.     if Onsprite:
  714.         extraEffects.create_spread_effect_on_anchor(Sprite2, myEffect, Time2)
  715.     else:
  716.         extraEffects.create_spread_effect_at(myEffect, X, Y, Time2)
  717. def on_overlap_tile10(sprite12, location10):
  718.     global lvl
  719.     tiles.set_tile_at(location10, assets.tile("""
  720.         transparency8
  721.         """))
  722.     Customeffects("Victory", sprite12, True, 1, 1, 1000)
  723.     Customeffects("Victory", sprite12, True, 1, 1, 1000)
  724.     music.play(music.string_playable("F - F E F G B - ", 320),
  725.         music.PlaybackMode.IN_BACKGROUND)
  726.     lvl += 1
  727.
  728.     def on_after2():
  729.         Customeffects("Fadeout", sprite12, True, 0, 0, 1000)
  730.         music.play(music.create_sound_effect(WaveShape.SINE,
  731.                 1,
  732.                 520,
  733.                 145,
  734.                 0,
  735.                 2000,
  736.                 SoundExpressionEffect.NONE,
  737.                 InterpolationCurve.LINEAR),
  738.             music.PlaybackMode.IN_BACKGROUND)
  739.     timer.after(2000, on_after2)
  740.
  741.
  742.     def on_after3():
  743.         global PlayCutScene
  744.         PlayCutScene = True
  745.         Level(lvl)
  746.     timer.after(3500, on_after3)
  747.
  748. scene.on_overlap_tile(SpriteKind.player,
  749.     assets.tile("""
  750.         Exit
  751.         """),
  752.     on_overlap_tile10)
  753. def Level(Lvl: number):
  754.     global textSprite, Placeholder, PlayCutScene, PlayerBoxes
  755.     mySprite.scale = 1
  756.     scene.set_background_color(15)
  757.     mySprite.set_flag(SpriteFlag.GHOST_THROUGH_TILES, False)
  758.     mySprite.set_flag(SpriteFlag.GHOST_THROUGH_SPRITES, False)
  759.     sprites.set_data_sprite(Something, "S-Control", mySprite)
  760.     sprites.destroy_all_sprites_of_kind(SpriteKind.Box)
  761.     sprites.destroy_all_sprites_of_kind(SpriteKind.text)
  762.     sprites.destroy_all_sprites_of_kind(SpriteKind.Item)
  763.     sprites.destroy_all_sprites_of_kind(SpriteKind.enemy)
  764.     for value32 in tiles.get_tiles_by_type(assets.tile("""
  765.         BButton
  766.         """)):
  767.         tiles.set_tile_at(value32, assets.tile("""
  768.             transparency8
  769.             """))
  770.     for value33 in tiles.get_tiles_by_type(assets.tile("""
  771.         BButtonPressed
  772.         """)):
  773.         tiles.set_tile_at(value33, assets.tile("""
  774.             transparency8
  775.             """))
  776.     if Lvl == 0:
  777.         tiles.load_map(tiles.create_small_map(tilemap("""
  778.             level3
  779.             """)))
  780.         textSprite = textsprite.create("Menu to reset", 0, 12)
  781.         textSprite.set_position(100, 10)
  782.     elif Lvl == 1:
  783.         textSprite = textsprite.create("Red is one time use", 0, 12)
  784.         textSprite.set_position(80, 110)
  785.         tiles.load_map(tiles.create_small_map(tilemap("""
  786.             level8
  787.             """)))
  788.     elif Lvl == 2:
  789.         tiles.load_map(tiles.create_small_map(tilemap("""
  790.             level12
  791.             """)))
  792.     elif Lvl == 3:
  793.         textSprite = textsprite.create("Blue toggles on and off", 0, 12)
  794.         textSprite.set_position(80, 20)
  795.         tiles.load_map(tiles.create_small_map(tilemap("""
  796.             level6
  797.             """)))
  798.     elif Lvl == 4:
  799.         CutScene("You have Done well",
  800.             "So far. . .",
  801.             img("""
  802.                 . . . . . . . . . . . . . . . .
  803.                 . . . . . . . . . . . . . . . .
  804.                 . . . . . . . . . . . . . . . .
  805.                 . . . . . . . . . . . . . . . .
  806.                 . . . . . . . . . . . . . . . .
  807.                 . . . . . . . . . . . . . . . .
  808.                 . . . . . . . . . . . . . . . .
  809.                 . . . . . . . . . . . . . . . .
  810.                 . . . . . . . . . . . . . . . .
  811.                 . . . . . . . . . . . . . . . .
  812.                 . . . . . . . . . . . . . . . .
  813.                 . . . . . . . . . . . . . . . .
  814.                 . . . . . . . . . . . . . . . .
  815.                 . . . . . . . . . . . . . . . .
  816.                 . . . . . . . . . . . . . . . .
  817.                 . . . . . . . . . . . . . . . .
  818.                 """),
  819.             2000)
  820.         tiles.load_map(tiles.create_small_map(tilemap("""
  821.             level25
  822.             """)))
  823.     elif Lvl == 5:
  824.         tiles.load_map(tiles.create_small_map(tilemap("""
  825.             level10
  826.             """)))
  827.     elif Lvl == 6:
  828.         tiles.load_map(tiles.create_small_map(tilemap("""
  829.             level23
  830.             """)))
  831.     elif Lvl == 7:
  832.         CutScene("To easy for you?",
  833.             "Lets make this intresting",
  834.             img("""
  835.                 . . . . . . . . . . . . . . . .
  836.                 . . . . . . . . . . . . . . . .
  837.                 . . . . . . . . . . . . . . . .
  838.                 . . . . . . . . . . . . . . . .
  839.                 . . . . . . . . . . . . . . . .
  840.                 . . . . . . . . . . . . . . . .
  841.                 . . . . . . . . . . . . . . . .
  842.                 . . . . . . . . . . . . . . . .
  843.                 . . . . . . . . . . . . . . . .
  844.                 . . . . . . . . . . . . . . . .
  845.                 . . . . . . . . . . . . . . . .
  846.                 . . . . . . . . . . . . . . . .
  847.                 . . . . . . . . . . . . . . . .
  848.                 . . . . . . . . . . . . . . . .
  849.                 . . . . . . . . . . . . . . . .
  850.                 . . . . . . . . . . . . . . . .
  851.                 """),
  852.             4000)
  853.         textSprite = textsprite.create("Boxes Can Cover Pits", 0, 12)
  854.         textSprite.set_position(80, 20)
  855.         tiles.load_map(tiles.create_small_map(tilemap("""
  856.             level15
  857.             """)))
  858.         textSprite = textsprite.create("Pick up With A", 0, 12)
  859.         textSprite.set_position(80, 100)
  860.     elif Lvl == 8:
  861.         tiles.load_map(tiles.create_small_map(tilemap("""
  862.             level27
  863.             """)))
  864.     elif Lvl == 9:
  865.         tiles.load_map(tiles.create_small_map(tilemap("""
  866.             level9
  867.             """)))
  868.     elif Lvl == 10:
  869.         CutScene("Not Bad ",
  870.             "Most make it this far",
  871.             img("""
  872.                 . . . . . . . . . . . . . . . .
  873.                 . . . . . . . . . . . . . . . .
  874.                 . . . . . . . . . . . . . . . .
  875.                 . . . . . . . . . . . . . . . .
  876.                 . . . . . . . . . . . . . . . .
  877.                 . . . . . . . . . . . . . . . .
  878.                 . . . . . . . . . . . . . . . .
  879.                 . . . . . . . . . . . . . . . .
  880.                 . . . . . . . . . . . . . . . .
  881.                 . . . . . . . . . . . . . . . .
  882.                 . . . . . . . . . . . . . . . .
  883.                 . . . . . . . . . . . . . . . .
  884.                 . . . . . . . . . . . . . . . .
  885.                 . . . . . . . . . . . . . . . .
  886.                 . . . . . . . . . . . . . . . .
  887.                 . . . . . . . . . . . . . . . .
  888.                 """),
  889.             3000)
  890.         CutScene("Then Again ",
  891.             "Your not most are you?",
  892.             img("""
  893.                 . . . . . . . . . . . . . . . .
  894.                 . . . . . . . . . . . . . . . .
  895.                 . . . . . . . . . . . . . . . .
  896.                 . . . . . . . . . . . . . . . .
  897.                 . . . . . . . . . . . . . . . .
  898.                 . . . . . . . . . . . . . . . .
  899.                 . . . . . . . . . . . . . . . .
  900.                 . . . . . . . . . . . . . . . .
  901.                 . . . . . . . . . . . . . . . .
  902.                 . . . . . . . . . . . . . . . .
  903.                 . . . . . . . . . . . . . . . .
  904.                 . . . . . . . . . . . . . . . .
  905.                 . . . . . . . . . . . . . . . .
  906.                 . . . . . . . . . . . . . . . .
  907.                 . . . . . . . . . . . . . . . .
  908.                 . . . . . . . . . . . . . . . .
  909.                 """),
  910.             3000)
  911.         tiles.load_map(tiles.create_small_map(tilemap("""
  912.             level17
  913.             """)))
  914.     elif Lvl == 11:
  915.         CutScene("A Knight Driven by Mind",
  916.             "Not War or battle",
  917.             img("""
  918.                 . . . . . . . . . . . . . . . .
  919.                 . . . . . . . . . . . . . . . .
  920.                 . . . . . . . . . . . . . . . .
  921.                 . . . . . . . . . . . . . . . .
  922.                 . . . . . . . . . . . . . . . .
  923.                 . . . . . . . . . . . . . . . .
  924.                 . . . . . . . . . . . . . . . .
  925.                 . . . . . . . . . . . . . . . .
  926.                 . . . . . . . . . . . . . . . .
  927.                 . . . . . . . . . . . . . . . .
  928.                 . . . . . . . . . . . . . . . .
  929.                 . . . . . . . . . . . . . . . .
  930.                 . . . . . . . . . . . . . . . .
  931.                 . . . . . . . . . . . . . . . .
  932.                 . . . . . . . . . . . . . . . .
  933.                 . . . . . . . . . . . . . . . .
  934.                 """),
  935.             3000)
  936.         CutScene("Maybe you are worthy",
  937.             "Only time will tell",
  938.             img("""
  939.                 . . . . . . . . . . . . . . . .
  940.                 . . . . . . . . . . . . . . . .
  941.                 . . . . . . . . . . . . . . . .
  942.                 . . . . . . . . . . . . . . . .
  943.                 . . . . . . . . . . . . . . . .
  944.                 . . . . . . . . . . . . . . . .
  945.                 . . . . . . . . . . . . . . . .
  946.                 . . . . . . . . . . . . . . . .
  947.                 . . . . . . . . . . . . . . . .
  948.                 . . . . . . . . . . . . . . . .
  949.                 . . . . . . . . . . . . . . . .
  950.                 . . . . . . . . . . . . . . . .
  951.                 . . . . . . . . . . . . . . . .
  952.                 . . . . . . . . . . . . . . . .
  953.                 . . . . . . . . . . . . . . . .
  954.                 . . . . . . . . . . . . . . . .
  955.                 """),
  956.             4000)
  957.         textSprite = textsprite.create("", 0, 12)
  958.         tiles.load_map(tiles.create_small_map(tilemap("""
  959.             level20
  960.             """)))
  961.     elif Lvl == 12:
  962.         tiles.load_map(tiles.create_small_map(tilemap("""
  963.             level21
  964.             """)))
  965.     elif Lvl == 13:
  966.         tiles.load_map(tiles.create_small_map(tilemap("""
  967.             level13
  968.             """)))
  969.     elif Lvl == 14:
  970.         textSprite = textsprite.create("Doors > Keys", 0, 12)
  971.         textSprite.set_position(80, 110)
  972.         tiles.load_map(tiles.create_small_map(tilemap("""
  973.             level26
  974.             """)))
  975.     elif Lvl == 15:
  976.         tiles.load_map(tiles.create_small_map(tilemap("""
  977.             level7
  978.             """)))
  979.     elif Lvl == 16:
  980.         CutScene("The last of our tricks",
  981.             "Now can you use them?",
  982.             img("""
  983.                 . . . . . . . . . . . . . . . .
  984.                 . . . . . . . . . . . . . . . .
  985.                 . . . . . . . . . . . . . . . .
  986.                 . . . . . . . . . . . . . . . .
  987.                 . . . . . . . . . . . . . . . .
  988.                 . . . . . . . . . . . . . . . .
  989.                 . . . . . . . . . . . . . . . .
  990.                 . . . . . . . . . . . . . . . .
  991.                 . . . . . . . . . . . . . . . .
  992.                 . . . . . . . . . . . . . . . .
  993.                 . . . . . . . . . . . . . . . .
  994.                 . . . . . . . . . . . . . . . .
  995.                 . . . . . . . . . . . . . . . .
  996.                 . . . . . . . . . . . . . . . .
  997.                 . . . . . . . . . . . . . . . .
  998.                 . . . . . . . . . . . . . . . .
  999.                 """),
  1000.             4000)
  1001.         textSprite = textsprite.create("Swords break Weak objects", 0, 12)
  1002.         textSprite.set_position(80, 100)
  1003.         textSprite = textsprite.create("B to Drop", 0, 12)
  1004.         textSprite.set_position(100, 15)
  1005.         tiles.load_map(tiles.create_small_map(tilemap("""
  1006.             level28
  1007.             """)))
  1008.     elif Lvl == 17:
  1009.         CutScene("The Final Stretch",
  1010.             "Only 5 More Floors",
  1011.             img("""
  1012.                 . . . . . . . . . . . . . . . .
  1013.                 . . . . . . . . . . . . . . . .
  1014.                 . . . . . . . . . . . . . . . .
  1015.                 . . . . . . . . . . . . . . . .
  1016.                 . . . . . . . . . . . . . . . .
  1017.                 . . . . . . . . . . . . . . . .
  1018.                 . . . . . . . . . . . . . . . .
  1019.                 . . . . . . . . . . . . . . . .
  1020.                 . . . . . . . . . . . . . . . .
  1021.                 . . . . . . . . . . . . . . . .
  1022.                 . . . . . . . . . . . . . . . .
  1023.                 . . . . . . . . . . . . . . . .
  1024.                 . . . . . . . . . . . . . . . .
  1025.                 . . . . . . . . . . . . . . . .
  1026.                 . . . . . . . . . . . . . . . .
  1027.                 . . . . . . . . . . . . . . . .
  1028.                 """),
  1029.             3000)
  1030.         tiles.load_map(tiles.create_small_map(tilemap("""
  1031.             level22
  1032.             """)))
  1033.     elif Lvl == 18:
  1034.         tiles.load_map(tiles.create_small_map(tilemap("""
  1035.             level11
  1036.             """)))
  1037.     elif Lvl == 19:
  1038.         tiles.load_map(tiles.create_small_map(tilemap("""
  1039.             level29
  1040.             """)))
  1041.     elif Lvl == 20:
  1042.         tiles.load_map(tiles.create_small_map(tilemap("""
  1043.             level33
  1044.             """)))
  1045.     elif Lvl == 21:
  1046.         CutScene("The final Floor",
  1047.             "we watch with Anticipation",
  1048.             img("""
  1049.                 . . . . . . . . . . . . . . . .
  1050.                 . . . . . . . . . . . . . . . .
  1051.                 . . . . . . . . . . . . . . . .
  1052.                 . . . . . . . . . . . . . . . .
  1053.                 . . . . . . . . . . . . . . . .
  1054.                 . . . . . . . . . . . . . . . .
  1055.                 . . . . . . . . . . . . . . . .
  1056.                 . . . . . . . . . . . . . . . .
  1057.                 . . . . . . . . . . . . . . . .
  1058.                 . . . . . . . . . . . . . . . .
  1059.                 . . . . . . . . . . . . . . . .
  1060.                 . . . . . . . . . . . . . . . .
  1061.                 . . . . . . . . . . . . . . . .
  1062.                 . . . . . . . . . . . . . . . .
  1063.                 . . . . . . . . . . . . . . . .
  1064.                 . . . . . . . . . . . . . . . .
  1065.                 """),
  1066.             3000)
  1067.         tiles.load_map(tiles.create_small_map(tilemap("""
  1068.             level37
  1069.             """)))
  1070.     elif Lvl == 22:
  1071.         tiles.load_map(tiles.create_small_map(tilemap("""
  1072.             level41
  1073.             """)))
  1074.         Placeholder = sprites.create(img("""
  1075.                 . 6 2 2 2 2 2 .
  1076.                 . 6 2 c c c 2 .
  1077.                 . 6 2 c c c 2 .
  1078.                 . c b b 2 2 2 .
  1079.                 . c b c c c b .
  1080.                 . c b b b b b .
  1081.                 . c b b b b b .
  1082.                 . c b b b b b .
  1083.                 """),
  1084.             SpriteKind.Item)
  1085.         Placeholder.set_position(80, 30)
  1086.         sprites.set_data_string(Placeholder, "I-Type", "Book")
  1087.     elif Lvl == 99:
  1088.         CutScene("As You Open the book",
  1089.             "Your mind fills with knowledge",
  1090.             img("""
  1091.                 . . . . . . . . . . . . . . . .
  1092.                 . . . . . . . . . . . . . . . .
  1093.                 . . . . . . . . . . . . . . . .
  1094.                 . . . . . . . . . . . . . . . .
  1095.                 . . . . . . . . . . . . . . . .
  1096.                 . . . . . . . . . . . . . . . .
  1097.                 . . . . . . . . . . . . . . . .
  1098.                 . . . . . . . . . . . . . . . .
  1099.                 . . . . . . . . . . . . . . . .
  1100.                 . . . . . . . . . . . . . . . .
  1101.                 . . . . . . . . . . . . . . . .
  1102.                 . . . . . . . . . . . . . . . .
  1103.                 . . . . . . . . . . . . . . . .
  1104.                 . . . . . . . . . . . . . . . .
  1105.                 . . . . . . . . . . . . . . . .
  1106.                 . . . . . . . . . . . . . . . .
  1107.                 """),
  1108.             4000)
  1109.         game.set_dialog_frame(img("""
  1110.             ffffffffffffffffffffffff
  1111.             ffffffffffffffffffffffff
  1112.             fffbbbbbbbbbbbbbbbbbbfff
  1113.             ffbffffffffffffffffffbff
  1114.             ffbfbbbbbbbbbbbbbbbbfbff
  1115.             ffbfbbbbbbbbbbbbbbbbfbff
  1116.             ffbfbbbbbbbbbbbbbbbbfbff
  1117.             ffbfbbbbbbbbbbbbbbbbfbff
  1118.             ffbfbbbbbbbbbbbbbbbbfbff
  1119.             ffbfbbbbbbbbbbbbbbbbfbff
  1120.             ffbfbbbbbbbbbbbbbbbbfbff
  1121.             ffbfbbbbbbbbbbbbbbbbfbff
  1122.             ffbfbbbbbbbbbbbbbbbbfbff
  1123.             ffbfbbbbbbbbbbbbbbbbfbff
  1124.             ffbfbbbbbbbbbbbbbbbbfbff
  1125.             ffbfbbbbbbbbbbbbbbbbfbff
  1126.             ffbfbbbbbbbbbbbbbbbbfbff
  1127.             ffbfbbbbbbbbbbbbbbbbfbff
  1128.             ffbfbbbbbbbbbbbbbbbbfbff
  1129.             ffbfbbbbbbbbbbbbbbbbfbff
  1130.             ffbffffffffffffffffffbff
  1131.             fffbbbbbbbbbbbbbbbbbbfff
  1132.             ffffffffffffffffffffffff
  1133.             ffffffffffffffffffffffff
  1134.             """))
  1135.         game.show_long_text("As you Exit the dungeon Enlighted with knowledge you Wander the world spreading it with all",
  1136.             DialogLayout.FULL)
  1137.         game.show_long_text("Teaching people to understand there world and how to make it a better place for all ",
  1138.             DialogLayout.FULL)
  1139.         game.show_long_text("learning humanizes character and prevents it from being cruel So learn on Enlighted Warrior",
  1140.             DialogLayout.FULL)
  1141.         tiles.load_map(tiles.create_small_map(tilemap("""
  1142.             level46
  1143.             """)))
  1144.         textSprite = textsprite.create("Thank you for playing!", 0, 15)
  1145.         textSprite.set_outline(1, 1)
  1146.         textSprite.set_position(80, 10)
  1147.         textSprite = textsprite.create("I hope you enjoyed it", 0, 15)
  1148.         textSprite.set_position(80, 100)
  1149.         textSprite.set_outline(1, 1)
  1150.         textSprite = textsprite.create("-ADM_F", 0, 8)
  1151.         textSprite.set_outline(1, 9)
  1152.         textSprite.set_position(100, 110)
  1153.     else:
  1154.         tiles.load_map(tiles.create_small_map(tilemap("""
  1155.             level16
  1156.             """)))
  1157.     if Lvl < 17:
  1158.         ColorGrid(11, 1)
  1159.     if Lvl >= 17:
  1160.         ColorGrid(6, 8)
  1161.     if Lvl == 99:
  1162.         ColorGrid(11, 1)
  1163.     for value34 in tiles.get_tiles_by_type(assets.tile("""
  1164.         Box
  1165.         """)):
  1166.         Placeholder = sprites.create(assets.image("""
  1167.             BoxSprite
  1168.             """), SpriteKind.Box)
  1169.         grid.place(Placeholder,
  1170.             tiles.get_tile_location(value34.column, value34.row))
  1171.     for value35 in tiles.get_tiles_by_type(assets.tile("""
  1172.         Key
  1173.         """)):
  1174.         Placeholder = sprites.create(assets.image("""
  1175.             Key
  1176.             """), SpriteKind.Item)
  1177.         sprites.set_data_string(Placeholder, "I-Type", "Key")
  1178.         grid.place(Placeholder,
  1179.             tiles.get_tile_location(value35.column, value35.row))
  1180.         tiles.set_tile_at(value35, assets.tile("""
  1181.             transparency8
  1182.             """))
  1183.     for value36 in tiles.get_tiles_by_type(assets.tile("""
  1184.         SwordTile
  1185.         """)):
  1186.         Placeholder = sprites.create(assets.image("""
  1187.             Sword-
  1188.             """), SpriteKind.Item)
  1189.         sprites.set_data_string(Placeholder, "I-Type", "Sword")
  1190.         grid.place(Placeholder,
  1191.             tiles.get_tile_location(value36.column, value36.row))
  1192.         tiles.set_tile_at(value36, assets.tile("""
  1193.             transparency8
  1194.             """))
  1195.     tiles.replace_all_tiles(assets.tile("""
  1196.             Box
  1197.             """),
  1198.         assets.tile("""
  1199.             transparency8
  1200.             """))
  1201.     for value42 in tiles.get_tiles_by_type(assets.tile("""
  1202.         StartingPoint
  1203.         """)):
  1204.         grid.place(mySprite,
  1205.             tiles.get_tile_location(value42.column, value42.row))
  1206.         tiles.set_tile_at(value42, assets.tile("""
  1207.             transparency8
  1208.             """))
  1209.     Customeffects("Fadein", mySprite, True, 0, 0, 1000)
  1210.     music.play(music.create_sound_effect(WaveShape.SINE,
  1211.             520,
  1212.             1,
  1213.             145,
  1214.             0,
  1215.             2000,
  1216.             SoundExpressionEffect.NONE,
  1217.             InterpolationCurve.LINEAR),
  1218.         music.PlaybackMode.IN_BACKGROUND)
  1219.     PlayCutScene = False
  1220.     PlayerBoxes = []
  1221.     PlayerBoxes.append(mySprite)
  1222.     for value5 in sprites.all_of_kind(SpriteKind.Box):
  1223.         PlayerBoxes.append(value5)
  1224. def on_on_overlap3(sprite13, otherSprite3):
  1225.     sprites.set_data_sprite(Something, "S-Control", Something)
  1226.     mySprite.set_velocity(otherSprite3.vx * 2, otherSprite3.vy * 2)
  1227.     sprite13.set_flag(SpriteFlag.GHOST_THROUGH_TILES, True)
  1228.     sprite13.set_flag(SpriteFlag.GHOST_THROUGH_SPRITES, True)
  1229.
  1230.     def on_background5():
  1231.         Customeffects("Explode", sprite13, True, 1, 1, 600)
  1232.         sprite13.scale = 0
  1233.         scene.camera_shake(4, 200)
  1234.         music.play(music.melody_playable(music.big_crash),
  1235.             music.PlaybackMode.IN_BACKGROUND)
  1236.         pause(1000)
  1237.         Level(lvl)
  1238.     timer.background(on_background5)
  1239.
  1240. sprites.on_overlap(SpriteKind.player, SpriteKind.enemy, on_on_overlap3)
  1241. def on_on_overlap4(sprite14, otherSprite4):
  1242.     otherSprite4.set_velocity(0, 0)
  1243.     otherSprite4.set_flag(SpriteFlag.GHOST_THROUGH_SPRITES, True)
  1244. sprites.on_overlap(SpriteKind.Box, SpriteKind.enemy, on_on_overlap4)
  1245. def on_right_pressed():
  1246.     if Something:
  1247.         if not (tiles.tile_at_location_is_wall(tiles.get_tile_location(1 + sprites.read_data_sprite(Something, "S-Control").tilemap_location().column,
  1248.                 sprites.read_data_sprite(Something, "S-Control").tilemap_location().row))):
  1249.             Customeffects("Steps",
  1250.                 sprites.read_data_sprite(Something, "S-Control"),
  1251.                 False,
  1252.                 sprites.read_data_sprite(Something, "S-Control").x,
  1253.                 sprites.read_data_sprite(Something, "S-Control").y,
  1254.                 400)
  1255.             grid.move(sprites.read_data_sprite(Something, "S-Control"), 1, 0)
  1256.             music.play(music.create_sound_effect(WaveShape.NOISE,
  1257.                     randint(300, 350),
  1258.                     0,
  1259.                     104,
  1260.                     0,
  1261.                     100,
  1262.                     SoundExpressionEffect.NONE,
  1263.                     InterpolationCurve.LINEAR),
  1264.                 music.PlaybackMode.IN_BACKGROUND)
  1265. controller.right.on_event(ControllerButtonEvent.PRESSED, on_right_pressed)
  1266. def on_overlap_tile11(sprite15, location11):
  1267.     SwapBlocks(2)
  1268.     tiles.set_tile_at(location11, assets.tile("""
  1269.         BButtonPressed
  1270.         """))
  1271.     Customeffects("Wand", sprite15, True, 1, 1, 200)
  1272.
  1273.     def on_background6():
  1274.
  1275.         def on_pause_until4():
  1276.             pass
  1277.         pause_until(on_pause_until4)
  1278.
  1279.         tiles.set_tile_at(location11, assets.tile("""
  1280.             BButton
  1281.             """))
  1282.     timer.background(on_background6)
  1283.
  1284. scene.on_overlap_tile(SpriteKind.Box,
  1285.     assets.tile("""
  1286.         BButton
  1287.         """),
  1288.     on_overlap_tile11)
  1289. def on_overlap_tile12(sprite16, location12):
  1290.     tiles.set_tile_at(location12, assets.tile("""
  1291.         transparency8
  1292.         """))
  1293.     Customeffects("Twinkle", sprite16, True, 1, 1, 500)
  1294.     SwapBlocks(1)
  1295. scene.on_overlap_tile(SpriteKind.Box,
  1296.     assets.tile("""
  1297.         RButton
  1298.         """),
  1299.     on_overlap_tile12)
  1300. def on_overlap_tile13(sprite17, location13):
  1301.     mySprite.set_flag(SpriteFlag.GHOST_THROUGH_TILES, True)
  1302.     music.play(music.create_sound_effect(WaveShape.TRIANGLE,
  1303.             2954,
  1304.             0,
  1305.             122,
  1306.             0,
  1307.             1500,
  1308.             SoundExpressionEffect.NONE,
  1309.             InterpolationCurve.LOGARITHMIC),
  1310.         music.PlaybackMode.IN_BACKGROUND)
  1311.
  1312.     def on_background7():
  1313.         for index3 in range(10):
  1314.             pause(100)
  1315.             mySprite.scale += -0.1
  1316.         pause(1000)
  1317.         music.play(music.melody_playable(music.big_crash),
  1318.             music.PlaybackMode.IN_BACKGROUND)
  1319.         Level(lvl)
  1320.     timer.background(on_background7)
  1321.
  1322. scene.on_overlap_tile(SpriteKind.player,
  1323.     assets.tile("""
  1324.         Pit
  1325.         """),
  1326.     on_overlap_tile13)
  1327. def on_overlap_tile14(sprite18, location14):
  1328.     tiles.set_tile_at(location14, assets.tile("""
  1329.         transparency8
  1330.         """))
  1331.     tiles.set_wall_at(location14, False)
  1332. scene.on_overlap_tile(SpriteKind.food,
  1333.     assets.tile("""
  1334.         Cannon UD0
  1335.         """),
  1336.     on_overlap_tile14)
  1337. def on_up_pressed():
  1338.     if Something:
  1339.         if not (tiles.tile_at_location_is_wall(tiles.get_tile_location(sprites.read_data_sprite(Something, "S-Control").tilemap_location().column,
  1340.                 -1 + sprites.read_data_sprite(Something, "S-Control").tilemap_location().row))):
  1341.             Customeffects("Steps",
  1342.                 sprites.read_data_sprite(Something, "S-Control"),
  1343.                 False,
  1344.                 sprites.read_data_sprite(Something, "S-Control").x,
  1345.                 sprites.read_data_sprite(Something, "S-Control").y,
  1346.                 400)
  1347.             grid.move(sprites.read_data_sprite(Something, "S-Control"), 0, -1)
  1348.             music.play(music.create_sound_effect(WaveShape.NOISE,
  1349.                     randint(300, 350),
  1350.                     0,
  1351.                     127,
  1352.                     0,
  1353.                     100,
  1354.                     SoundExpressionEffect.NONE,
  1355.                     InterpolationCurve.LINEAR),
  1356.                 music.PlaybackMode.IN_BACKGROUND)
  1357. controller.up.on_event(ControllerButtonEvent.PRESSED, on_up_pressed)
  1358. def on_on_overlap5(sprite19, otherSprite5):
  1359.     PushTiles(sprite19, otherSprite5)
  1360. sprites.on_overlap(SpriteKind.player, SpriteKind.Box, on_on_overlap5)
  1361. def on_down_pressed():
  1362.     if not (tiles.tile_at_location_is_wall(tiles.get_tile_location(sprites.read_data_sprite(Something, "S-Control").tilemap_location().column,
  1363.             1 + sprites.read_data_sprite(Something, "S-Control").tilemap_location().row))):
  1364.         Customeffects("Steps",
  1365.             sprites.read_data_sprite(Something, "S-Control"),
  1366.             False,
  1367.             sprites.read_data_sprite(Something, "S-Control").x,
  1368.             sprites.read_data_sprite(Something, "S-Control").y,
  1369.             400)
  1370.         grid.move(sprites.read_data_sprite(Something, "S-Control"), 0, 1)
  1371.         music.play(music.create_sound_effect(WaveShape.NOISE,
  1372.                 randint(300, 350),
  1373.                 0,
  1374.                 113,
  1375.                 0,
  1376.                 100,
  1377.                 SoundExpressionEffect.NONE,
  1378.                 InterpolationCurve.LINEAR),
  1379.             music.PlaybackMode.IN_BACKGROUND)
  1380. controller.down.on_event(ControllerButtonEvent.PRESSED, on_down_pressed)
  1381. PlayerBoxes: List[Sprite] = []
  1382. picture: Image = None
  1383. myEffect: SpreadEffectData = None
  1384. mySprite: Sprite = None
  1385. Something: Sprite = None
  1386. textSprite2: TextSprite = None
  1387. textSprite: TextSprite = None
  1388. Placeholder: Sprite = None
  1389. lvl = 0
  1390. PlayCutScene = False
  1391. music.stop_all_sounds()
  1392. PlayCutScene = True
  1393. lvl = 0
  1394. scene.set_background_color(15)
  1395. Placeholder = sprites.create(assets.image("""
  1396.     Logo
  1397.     """), SpriteKind.PlaceHolder)
  1398. textSprite = textsprite.create("Press A to Start", 0, 1)
  1399. textSprite.set_position(80, 80)
  1400. textSprite2 = textsprite.create("Made by ADM_F", 0, 8)
  1401. textSprite2.set_position(100, 110)
  1402. def on_pause_until5():
  1403.     pass
  1404. pause_until(on_pause_until5)
  1405. if controller.right.is_pressed():
  1406.     Keybinds.set_simulator_keymap(Keybinds.PlayerNumber.ONE,
  1407.         Keybinds.CustomKey.W,
  1408.         Keybinds.CustomKey.S,
  1409.         Keybinds.CustomKey.A,
  1410.         Keybinds.CustomKey.D,
  1411.         Keybinds.CustomKey.F,
  1412.         Keybinds.CustomKey.G)
  1413. if controller.up.is_pressed():
  1414.     lvl = game.ask_for_number("Level Select ", 2)
  1415. sprites.destroy(textSprite2)
  1416. for index4 in range(10):
  1417.     Placeholder.scale += -0.1
  1418.     textSprite.scale += -0.1
  1419.     pause(50)
  1420. sprites.destroy(textSprite)
  1421. sprites.destroy(Placeholder)
  1422. Something = sprites.create(assets.image("""
  1423.     Empty
  1424.     """), SpriteKind.Stupid)
  1425. mySprite = sprites.create(assets.image("""
  1426.     Sir Blue
  1427.     """), SpriteKind.player)
  1428. sprites.set_data_sprite(Something, "S-Control", mySprite)
  1429. CurrentParty = [mySprite]
  1430. characterAnimations.loop_frames(mySprite,
  1431.     assets.animation("""
  1432.         BlueLeft
  1433.         """),
  1434.     300,
  1435.     characterAnimations.rule(Predicate.FACING_LEFT))
  1436. characterAnimations.loop_frames(mySprite,
  1437.     assets.animation("""
  1438.         BlueDown
  1439.         """),
  1440.     300,
  1441.     characterAnimations.rule(Predicate.FACING_DOWN))
  1442. characterAnimations.loop_frames(mySprite,
  1443.     assets.animation("""
  1444.         BlueUp
  1445.         """),
  1446.     300,
  1447.     characterAnimations.rule(Predicate.FACING_UP))
  1448. characterAnimations.loop_frames(mySprite,
  1449.     assets.animation("""
  1450.         BlueRight
  1451.         """),
  1452.     300,
  1453.     characterAnimations.rule(Predicate.FACING_RIGHT))
  1454. myEffect = extraEffects.create_custom_spread_effect_data([0, 0],
  1455.     False,
  1456.     extraEffects.create_preset_size_table(ExtraEffectPresetShape.SPARK),
  1457.     extraEffects.create_percentage_range(50, 100),
  1458.     extraEffects.create_percentage_range(50, 100),
  1459.     extraEffects.create_time_range(200, 400))
  1460. music.play(music.string_playable("G G F A B G A B ", 300),
  1461.     music.PlaybackMode.IN_BACKGROUND)
  1462. CutScene("Journey Onward",
  1463.     "Warrior Of Blue",
  1464.     img("""
  1465.         . . . . . . . . . . . . . . . .
  1466.         . . . . . . . . . . . . . . . .
  1467.         . . . . . . . . . . . . . . . .
  1468.         . . . . . . . . . . . . . . . .
  1469.         . . . . . . . . . . . . . . . .
  1470.         . . . . . . . . . . . . . . . .
  1471.         . . . . . . . . . . . . . . . .
  1472.         . . . . . . . . . . . . . . . .
  1473.         . . . . . . . . . . . . . . . .
  1474.         . . . . . . . . . . . . . . . .
  1475.         . . . . . . . . . . . . . . . .
  1476.         . . . . . . . . . . . . . . . .
  1477.         . . . . . . . . . . . . . . . .
  1478.         . . . . . . . . . . . . . . . .
  1479.         . . . . . . . . . . . . . . . .
  1480.         . . . . . . . . . . . . . . . .
  1481.         """),
  1482.     2000)
  1483. music.play(music.create_song(assets.song("""
  1484.         Song1
  1485.         """)),
  1486.     music.PlaybackMode.LOOPING_IN_BACKGROUND)
  1487. Level(lvl)
  1488. def on_update_interval():
  1489.     global Placeholder
  1490.     for value6 in tiles.get_tiles_by_type(assets.tile("""
  1491.         Cannon LR
  1492.         """)):
  1493.         Placeholder = sprites.create(assets.image("""
  1494.             LaserSIDE
  1495.             """), SpriteKind.enemy)
  1496.         tiles.place_on_tile(Placeholder, value6)
  1497.         Placeholder.lifespan = 800
  1498.         Placeholder.z = -5
  1499.         Placeholder.vx = 75
  1500.         Placeholder = sprites.create(assets.image("""
  1501.             LaserSIDE
  1502.             """), SpriteKind.enemy)
  1503.         tiles.place_on_tile(Placeholder, value6)
  1504.         Placeholder.z = -5
  1505.         Placeholder.lifespan = 800
  1506.         Placeholder.vx = -75
  1507.     for value7 in tiles.get_tiles_by_type(assets.tile("""
  1508.         Cannon UD0
  1509.         """)):
  1510.         Placeholder = sprites.create(assets.image("""
  1511.             Laser UPDOWN
  1512.             """), SpriteKind.enemy)
  1513.         tiles.place_on_tile(Placeholder, value7)
  1514.         Placeholder.lifespan = 800
  1515.         Placeholder.vy = 75
  1516.         Placeholder.z = -5
  1517.         Placeholder = sprites.create(assets.image("""
  1518.             Laser UPDOWN
  1519.             """), SpriteKind.enemy)
  1520.         tiles.place_on_tile(Placeholder, value7)
  1521.         Placeholder.z = -5
  1522.         Placeholder.lifespan = 800
  1523.         Placeholder.vy = -75
  1524. game.on_update_interval(100, on_update_interval)
  1525. def on_on_update():
  1526.     if Something:
  1527.         Something.set_position(sprites.read_data_sprite(Something, "S-Control").x,
  1528.             sprites.read_data_sprite(Something, "S-Control").y - 7)
  1529.         if (characterAnimations.matches_rule(sprites.read_data_sprite(Something, "S-Control"),
  1530.             characterAnimations.rule(Predicate.FACING_RIGHT)) or characterAnimations.matches_rule(sprites.read_data_sprite(Something, "S-Control"),
  1531.             characterAnimations.rule(Predicate.FACING_DOWN))) and sprites.read_data_sprite(sprites.read_data_sprite(Something, "S-Control"), "H-Hand") != spriteutils.null_consts(spriteutils.NullConsts.NULL):
  1532.             if sprites.read_data_sprite(sprites.read_data_sprite(Something, "S-Control"),
  1533.                 "H-Offhand") != spriteutils.null_consts(spriteutils.NullConsts.NULL):
  1534.                 sprites.read_data_sprite(sprites.read_data_sprite(Something, "S-Control"),
  1535.                     "H-Offhand").set_position(-1 + sprites.read_data_sprite(Something, "S-Control").x,
  1536.                     2 + sprites.read_data_sprite(Something, "S-Control").y)
  1537.             sprites.read_data_sprite(sprites.read_data_sprite(Something, "S-Control"), "H-Hand").set_position(4 + sprites.read_data_sprite(Something, "S-Control").x,
  1538.                 sprites.read_data_sprite(Something, "S-Control").y)
  1539.         elif (characterAnimations.matches_rule(sprites.read_data_sprite(Something, "S-Control"),
  1540.             characterAnimations.rule(Predicate.FACING_UP)) or characterAnimations.matches_rule(sprites.read_data_sprite(Something, "S-Control"),
  1541.             characterAnimations.rule(Predicate.FACING_LEFT))) and sprites.read_data_sprite(sprites.read_data_sprite(Something, "S-Control"), "H-Hand") != spriteutils.null_consts(spriteutils.NullConsts.NULL):
  1542.             sprites.read_data_sprite(sprites.read_data_sprite(Something, "S-Control"), "H-Hand").set_position(-3 + sprites.read_data_sprite(Something, "S-Control").x,
  1543.                 sprites.read_data_sprite(Something, "S-Control").y)
  1544.             if sprites.read_data_sprite(sprites.read_data_sprite(Something, "S-Control"),
  1545.                 "H-Offhand") != spriteutils.null_consts(spriteutils.NullConsts.NULL):
  1546.                 sprites.read_data_sprite(sprites.read_data_sprite(Something, "S-Control"),
  1547.                     "H-Offhand").set_position(3 + sprites.read_data_sprite(Something, "S-Control").x,
  1548.                     2 + sprites.read_data_sprite(Something, "S-Control").y)
  1549. game.on_update(on_on_update)
发表于 2025-9-23 17:16:11
这是一个基于MakeCode Arcade的"板条箱地牢"(Crate Dungeon)推箱子解谜游戏代码。
游戏概述
这是一个经典的推箱子解谜游戏,玩家控制蓝色骑士在地牢中移动箱子,解开各种机关谜题。
核心游戏机制
1. 角色控制与移动
python
  1. def on_left_pressed():
  2. def on_right_pressed():
  3. def on_up_pressed():
  4. def on_down_pressed():
网格化移动系统
移动时播放脚步声特效
碰撞检测防止穿墙
2. 箱子推动系统
python
  1. def PushTiles(Pusher: Sprite, Pushing: Sprite):
复杂的箱子推动逻辑
支持连锁推动(箱子推箱子)
防止推动到墙壁时的反弹机制
游戏特色功能
1. 机关系统
按钮机制:
红色按钮(RButton):一次性开关,改变红色地砖状态
蓝色按钮(BButton):切换开关,改变蓝色地砖状态
传送门:
家和箱子都可以通过传送门
自动传送并重置传送门状态
陷阱与障碍:
深坑(Pit):玩家掉落会重置关卡
激光炮台:定期发射激光障碍
可破坏墙壁:使用剑破坏
2. 物品系统
python
  1. def Use_Item(Text: str):
钥匙(Key):打开锁住的门
剑(Sword):破坏脆弱墙壁和物体
书(Book):触发剧情和结局
3. 特效系统
python
丰富的粒子特效:
Steps:移动脚步效果
Wand:魔法棒效果
Twinkle:闪烁星光
Victory:胜利效果
Explode:**效果
关卡设计
渐进式难度
游戏包含22+个关卡,难度逐渐增加:
1-3关:基础推箱子教学
4-10关:引入按钮机制和陷阱
11-16关:复杂机关组合
17-22关:最终挑战关卡
剧情系统
python
关卡间的剧情过渡
教育性主题:知识的力量
最终传达积极信息
技术实现亮点
1. 状态管理
python
使用精灵数据存储系统管理游戏状态
2. 关卡加载系统
python
  1. def Level(Lvl: number):
动态加载不同地图
自动生成箱子和物品
重置游戏状态
3. 物理系统
网格化碰撞检测
连锁推动物理
实时障碍物生成
发表于 2025-9-23 17:21:27
图形编程参考实验程序
通过模拟器,调试与模拟运行
实验场景记录
【花雕动手做】基于Kitronik可编程开发板之板条箱地牢图5
【花雕动手做】基于Kitronik可编程开发板之板条箱地牢图4
发表于 2025-9-23 17:23:23
