288浏览
查看: 288|回复: 5
[项目] 【花雕动手做】基于 Kitronik 可编程开发板之叠羊罗汉
【花雕动手做】基于 Kitronik 可编程开发板之叠羊罗汉图1
【花雕动手做】基于 Kitronik 可编程开发板之叠羊罗汉图2
发表于 2025-9-16 08:43:09
作为学习、练习与尝试,这里创建一个叠羊罗汉的小游戏。
打开网页版:https://arcade.makecode.com/,设置项目名称:叠羊罗汉
MicroPython实验代码
  1. @namespace
  2. class SpriteKind:
  3.     Mountain = SpriteKind.create()
  4.     Goat = SpriteKind.create()
  5. def drop_goat():
  6.     moving_goat.ay = 300
  7.     moving_goat.vx = 0
  8.     moving_goat.set_flag(SpriteFlag.BOUNCE_ON_WALL, False)
  9. def on_a_pressed():
  10.     drop_goat()
  11. controller.A.on_event(ControllerButtonEvent.PRESSED, on_a_pressed)
  12. # calculate new center of gravity
  13. def will_the_stack_fall_down_():
  14.     global mountain_goats, center_of_gravity
  15.     mountain_goats = sprites.all_of_kind(SpriteKind.Mountain)
  16.     center_of_gravity = 0
  17.     for value in mountain_goats:
  18.         center_of_gravity += value.x
  19.     if center_of_gravity / len(mountain_goats) < bottom_goat.left or center_of_gravity / len(mountain_goats) > bottom_goat.right:
  20.         return True
  21.     return False
  22. def will_the_goat_fall_off(falling_goat: Sprite, mountain_goat: Sprite):
  23.     if falling_goat.x > mountain_goat.right:
  24.         falling_goat.set_velocity(50, -50)
  25.         falling_goat.set_flag(SpriteFlag.GHOST, True)
  26.         falling_goat.set_flag(SpriteFlag.AUTO_DESTROY, True)
  27.         info.change_life_by(-1)
  28.         return True
  29.     elif falling_goat.x < mountain_goat.left:
  30.         falling_goat.set_velocity(-50, 50)
  31.         falling_goat.set_flag(SpriteFlag.GHOST, True)
  32.         falling_goat.set_flag(SpriteFlag.AUTO_DESTROY, True)
  33.         info.change_life_by(-1)
  34.         return True
  35.     else:
  36.         return False
  37. def on_hit_wall(sprite, location):
  38.     if sprite.is_hitting_tile(CollisionDirection.BOTTOM):
  39.         game.over(False)
  40. scene.on_hit_wall(SpriteKind.Goat, on_hit_wall)
  41. def explode_goats():
  42.     global current_goat
  43.     current_goat = bottom_goat
  44.     while current_goat:
  45.         current_goat.set_flag(SpriteFlag.GHOST, True)
  46.         current_goat.set_velocity(randint(-200, 200), randint(-200, 200))
  47.         current_goat = sprites.read_data_sprite(current_goat, "goat on top of me")
  48.         scene.camera_follow_sprite(None)
  49. def on_on_overlap(sprite2, otherSprite):
  50.     global goat_fell_off, top_goat
  51.     sprite2.vy = 0
  52.     sprite2.ay = 0
  53.     sprite2.set_kind(SpriteKind.Mountain)
  54.     goat_fell_off = will_the_goat_fall_off(sprite2, otherSprite)
  55.     if goat_fell_off:
  56.         sprite2.start_effect(effects.fire)
  57.     elif will_the_stack_fall_down_():
  58.         sprites.set_data_sprite(otherSprite, "goat on top of me", sprite2)
  59.         explode_goats()
  60.         pause(1000)
  61.         game.over(False)
  62.     else:
  63.         top_goat = sprite2
  64.         scene.camera_follow_sprite(sprite2)
  65.         sprites.set_data_sprite(otherSprite, "goat on top of me", sprite2)
  66.     make_a_new_goat()
  67. sprites.on_overlap(SpriteKind.Goat, SpriteKind.Mountain, on_on_overlap)
  68. def make_a_new_goat():
  69.     global moving_goat
  70.     moving_goat = sprites.create(goat_species[randint(0, len(goat_species) - 1)],
  71.         SpriteKind.Goat)
  72.     moving_goat.set_position(80, top_goat.y - 30)
  73.     moving_goat.set_flag(SpriteFlag.BOUNCE_ON_WALL, True)
  74.     moving_goat.vx = 40
  75. goat_fell_off = False
  76. current_goat: Sprite = None
  77. center_of_gravity = 0
  78. mountain_goats: List[Sprite] = []
  79. moving_goat: Sprite = None
  80. bottom_goat: Sprite = None
  81. top_goat: Sprite = None
  82. goat_species: List[Image] = []
  83. goat_species = [img("""
  84.         . . . . . . . . . . . . f e e .
  85.         . . . . . . . . . . . . . e e .
  86.         . . . . . . . . . . . . d c d c
  87.         . . . . . . . . . . . . d d d d
  88.         e d d d d d d d d d d d d a d d
  89.         . d d d d d d d d d d d d d a a
  90.         . d d d d d d d d d d d d . . .
  91.         . d d d d d d d d d d d d . . .
  92.         . . d d d d d d d d d d . . . .
  93.         . . . d . d . . d . d . . . . .
  94.         . . . d . d . . d . d . . . . .
  95.         . . . e . e . . e . e . . . . .
  96.         """),
  97.     img("""
  98.         . . . . f f . . . . . . . . . . . . .
  99.         . . d f f d f . . . . . . . . . . . .
  100.         . 4 4 4 4 4 4 4 . . . . . . . . . . .
  101.         . . 1 4 4 1 . . . . . . . . . . . . .
  102.         . 4 4 4 4 4 4 . . . . . . . . . . . .
  103.         . 4 4 4 4 4 4 . . . . . . . . . . . .
  104.         4 4 4 2 4 4 4 4 4 4 4 4 4 4 4 4 4 . .
  105.         . 4 2 2 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4
  106.         . . 2 . . 4 4 4 4 4 4 4 4 4 4 4 4 4 .
  107.         . . . . . 4 4 4 4 4 4 4 4 4 4 4 4 4 .
  108.         . . . . . 4 2 4 2 2 2 2 2 2 2 2 2 . .
  109.         . . . . . 4 . 4 . . . . . 2 . 4 . . .
  110.         . . . . . 4 . 4 . . . . . 2 . 4 . . .
  111.         . . . . . 4 . 4 . . . . . 2 . 4 . . .
  112.         """),
  113.     img("""
  114.         . . . . . . . . b b d . . d d b . . .
  115.         . . . . . . . . b b b b b b b b . . .
  116.         . . . . . . . . . b b d b b d . . . .
  117.         . . . . . . . . . . b b b b b c . . .
  118.         . b . . . . . . . b b b b b b b . . .
  119.         . b . . . . b b b b b b b b b b . . .
  120.         . c b b b b b b b b b b . . . . . . .
  121.         . c b b b b b b b b b b . . . . . . .
  122.         . . c b b b b b b b b b . . . . . . .
  123.         . . c c b b b b b b b c . . . . . . .
  124.         . . c c c c c c c c c c . . . . . . .
  125.         . . c . b . . . c c c c . . . . . . .
  126.         . . c . b . . . . b . c . . . . . . .
  127.         . . c . b . . . . b . c . . . . . . .
  128.         """),
  129.     img("""
  130.         . . . . . . . . . . . . e . . e . . .
  131.         . . . . . . . . . . . e e e e e e . .
  132.         . . . . . . . . . . e e e e e e e e .
  133.         . . . . . . . . . e e e e c c c e e e
  134.         . . . . . . . . . . . . c c b c . . .
  135.         . . . c c c c c c c c c c f b f c . .
  136.         . . c c b b b b b b b b b f b f . . .
  137.         . . c b b b c c c b b b b b b c . . .
  138.         . c c b b c b b b b b b f b b c . . .
  139.         c c b b c b b b b b b b b f f f . . .
  140.         c b b b b b b b b b b b c c c . . . .
  141.         c c c c c c c c c c c c c . . . . . .
  142.         . . . . c . c . . . c . c . . . . . .
  143.         . . . . c . c . . . c . c . . . . . .
  144.         """),
  145.     img("""
  146.         . . . 1 . . . . . . . . . . . . . .
  147.         . . 1 c c c . . . . . . . . . . . .
  148.         . 1 1 1 1 c c . . . . . . . . . . 1
  149.         1 1 f 1 c 1 c c . . . . . . . . . 1
  150.         1 1 1 c 1 1 c c 1 1 1 1 1 1 1 1 1 1
  151.         1 1 1 c c c c 1 1 1 1 1 1 1 1 1 1 .
  152.         . . . 1 c c 1 1 1 1 1 1 1 1 1 1 1 .
  153.         . . . . 1 1 1 1 1 1 1 1 1 1 1 1 1 .
  154.         . . . . 1 1 1 1 1 1 1 1 1 1 1 1 1 .
  155.         . . . . 1 1 1 1 1 1 1 1 1 1 1 1 1 .
  156.         . . . . 1 1 1 1 1 1 1 1 1 1 1 1 1 .
  157.         . . . . 1 . 1 . . . . . . . 1 . 1 .
  158.         . . . . 1 . 1 . . . . . . . 1 . 1 .
  159.         . . . . 1 . 1 . . . . . . . 1 . 1 .
  160.         . . . . 1 . 1 . . . . . . . 1 . 1 .
  161.         . . . . c . c . . . . . . . c . c .
  162.         """),
  163.     img("""
  164.         .........................
  165.         ff.............ff...ff...
  166.         .ff............ffffff....
  167.         ..ff............ff2f2ffff
  168.         ...f............fffffffff
  169.         ...f............ffffff...
  170.         ...ff2f2ffffffffffffff...
  171.         ....f2f22fffffffff.......
  172.         ....f2ff2fffffffff.......
  173.         ....ff22ffffffffff.......
  174.         ....ffffffffffffff.......
  175.         ....fffffffff222ff.......
  176.         ....ffffffff2ff2ff.......
  177.         ....ffffffff22f2ff.......
  178.         ....fffffffff222f........
  179.         .....f...f...f..f........
  180.         .....f...f...f..f........
  181.         .....f...f...f..f........
  182.         """)]
  183. scene.set_background_color(9)
  184. tiles.set_tilemap(tilemap("""
  185.     级别1
  186.     """))
  187. goat = sprites.create(img("""
  188.         . . . . f f . . . . . . . . . . . . .
  189.         . . d f f d f . . . . . . . . . . . .
  190.         . 4 4 4 4 4 4 4 . . . . . . . . . . .
  191.         . . 1 4 4 1 . . . . . . . . . . . . .
  192.         . 4 4 4 4 4 4 . . . . . . . . . . . .
  193.         . 4 4 4 4 4 4 . . . . . . . . . . . .
  194.         4 4 4 2 4 4 4 4 4 4 4 4 4 4 4 4 4 . .
  195.         . 4 2 2 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4
  196.         . . 2 . . 4 4 4 4 4 4 4 4 4 4 4 4 4 .
  197.         . . . . . 4 4 4 4 4 4 4 4 4 4 4 4 4 .
  198.         . . . . . 4 2 4 2 2 2 2 2 2 2 2 2 . .
  199.         . . . . . 4 . 4 . . . . . 2 . 4 . . .
  200.         . . . . . 4 . 4 . . . . . 2 . 4 . . .
  201.         . . . . . 4 . 4 . . . . . 2 . 4 . . .
  202.         """),
  203.     SpriteKind.Mountain)
  204. goat.ay = 300
  205. goat.set_position(80, 600)
  206. scene.camera_follow_sprite(goat)
  207. top_goat = goat
  208. make_a_new_goat()
  209. how_much_does_a_goat_weigh = 22
  210. info.set_life(3)
  211. bottom_goat = goat
发表于 2025-9-16 08:48:19
ARCADE MakeCode 之叠羊罗汉游戏代码解读
这是一个基于ARCADE MakeCode的"叠羊罗汉"平衡游戏,玩家需要控制山羊叠放在一起而不倒塌。解读代码如下:
1. 自定义精灵类型
python
  1. @namespace
  3.     Mountain = SpriteKind.create()  # 已经落下的山羊
  4.     Goat = SpriteKind.create()      # 正在移动的山羊
2. 放下山羊函数
python
  1. def drop_goat():
  2.     moving_goat.ay = 300          # 启用重力
  3.     moving_goat.vx = 0            # 停止水平移动
  4.     moving_goat.set_flag(SpriteFlag.BOUNCE_ON_WALL, False)  # 关闭墙壁反弹
  5. def on_a_pressed():
  6.     drop_goat()  # A键按下时放下当前山羊
  7. controller.A.on_event(ControllerButtonEvent.PRESSED, on_a_pressed)
3. 平衡检测函数
检查整个堆栈是否会倒塌
python
  1. def will_the_stack_fall_down_():
  2.     global mountain_goats, center_of_gravity
  3.     mountain_goats = sprites.all_of_kind(SpriteKind.Mountain)  # 获取所有已落下的山羊
  4.     center_of_gravity = 0
  5.     for value in mountain_goats:
  6.         center_of_gravity += value.x  # 计算所有山羊的x坐标总和
  7.
  8.     # 如果重心超出底部山羊的左右边界,则堆栈会倒塌
  10.         return True
  11.     return False
检查单个山羊是否会掉落
python
  1. def will_the_goat_fall_off(falling_goat: Sprite, mountain_goat: Sprite):
  2.     if falling_goat.x > mountain_goat.right:  # 山羊超出右侧边界
  3.         falling_goat.set_velocity(50, -50)    # 设置掉落速度和方向
  4.         falling_goat.set_flag(SpriteFlag.GHOST, True)      # 变为幽灵状态(可穿透)
  5.         falling_goat.set_flag(SpriteFlag.AUTO_DESTROY, True)  # 自动销毁
  6.         info.change_life_by(-1)               # 减少生命值
  7.         return True
  8.     elif falling_goat.x < mountain_goat.left:  # 山羊超出左侧边界
  9.         falling_goat.set_velocity(-50, 50)     # 设置掉落速度和方向
  10.         falling_goat.set_flag(SpriteFlag.GHOST, True)
  11.         falling_goat.set_flag(SpriteFlag.AUTO_DESTROY, True)
  12.         info.change_life_by(-1)
  13.         return True
  14.     else:
  15.         return False  # 山羊安全落在平台上
4. 碰撞检测
python
  1. def on_hit_wall(sprite, location):
  2.     if sprite.is_hitting_tile(CollisionDirection.BOTTOM):  # 如果山羊碰到底部墙壁
  3.         game.over(False)  # 游戏结束
  4. scene.on_hit_wall(SpriteKind.Goat, on_hit_wall)
5. 山羊堆栈**效果
python
  3.     current_goat = bottom_goat  # 从底部山羊开始
  5.         current_goat.set_flag(SpriteFlag.GHOST, True)  # 变为幽灵状态
  6.         # 设置随机速度,产生**效果
  7.         current_goat.set_velocity(randint(-200, 200), randint(-200, 200))
  8.         # 获取堆叠在上面的山羊
  9.         current_goat = sprites.read_data_sprite(current_goat, "goat on top of me")
  10.         scene.camera_follow_sprite(None)  # 取消相机跟随
6. 山羊重叠事件处理(核心逻辑)
python
  1. def on_on_overlap(sprite2, otherSprite):
  2.     global goat_fell_off, top_goat
  3.     sprite2.vy = 0      # 停止垂直移动
  4.     sprite2.ay = 0      # 取消重力
  5.     sprite2.set_kind(SpriteKind.Mountain)  # 变为已落下的山羊
  6.
  7.     # 检查山羊是否会掉落
  8.     goat_fell_off = will_the_goat_fall_off(sprite2, otherSprite)
  9.     if goat_fell_off:
  10.         sprite2.start_effect(effects.fire)  # 播放火焰效果
  11.     elif will_the_stack_fall_down_():  # 检查整个堆栈是否会倒塌
  12.         # 记录山羊堆叠关系
  13.         sprites.set_data_sprite(otherSprite, "goat on top of me", sprite2)
  14.         explode_goats()  # **效果
  15.         pause(1000)
  16.         game.over(False)  # 游戏结束
  17.     else:
  18.         top_goat = sprite2  # 更新顶部山羊
  19.         scene.camera_follow_sprite(sprite2)  # 相机跟随新顶部山羊
  20.         # 记录山羊堆叠关系
  21.         sprites.set_data_sprite(otherSprite, "goat on top of me", sprite2)
  22.
  23.     make_a_new_goat()  # 创建新的山羊
  24. sprites.on_overlap(SpriteKind.Goat, SpriteKind.Mountain, on_on_overlap)
7. 创建新山羊函数
python
  1. def make_a_new_goat():
  2.     global moving_goat
  3.     # 随机选择山羊种类
  4.     moving_goat = sprites.create(goat_species[randint(0, len(goat_species) - 1)],
  5.         SpriteKind.Goat)
  6.     moving_goat.set_position(80, top_goat.y - 30)  # 放在顶部山羊上方
  7.     moving_goat.set_flag(SpriteFlag.BOUNCE_ON_WALL, True)  # 开启墙壁反弹
  8.     moving_goat.vx = 40  # 设置水平移动速度
8. 山羊种类定义
代码中定义了6种不同样式的山羊图像,增加了游戏的多样性。
9. 游戏初始化
python
  1. scene.set_background_color(9)  # 设置背景颜色
  2. tiles.set_tilemap(tilemap("级别1"))  # 设置地图
  3. # 创建初始山羊
  4. goat = sprites.create(..., SpriteKind.Mountain)
  5. goat.ay = 300  # 启用重力
  6. goat.set_position(80, 600)  # 设置位置
  7. scene.camera_follow_sprite(goat)  # 相机跟随
  8. top_goat = goat  # 设置顶部山羊
  9. make_a_new_goat()  # 创建新山羊
  10. how_much_does_a_goat_weigh = 22  # 山羊重量(可能用于后续扩展)
  11. info.set_life(3)  # 设置初始生命值
  12. bottom_goat = goat  # 设置底部山羊
游戏机制总结
控制方式:山羊左右移动,按A键放下
平衡系统:计算堆栈重心,如果超出底部山羊边界则倒塌
生命系统:山羊掉落减少生命值,生命值为0时游戏结束
堆叠关系:使用数据存储记录山羊之间的堆叠关系
视觉效果:掉落的山羊有火焰效果,倒塌时有**效果
相机跟随:相机始终跟随最顶部的山羊
这是一个有趣的物理平衡游戏,玩家需要精确控制放下山羊的时机和位置,以保持堆栈的平衡。游戏通过重心计算和物理效果实现了真实的堆叠体验。
发表于 2025-9-16 08:52:41
图形编程参考实验程序
发表于 2025-9-16 08:54:40
通过模拟器,调试与模拟运行
实验场景记录
【花雕动手做】基于 Kitronik 可编程开发板之叠羊罗汉图5
【花雕动手做】基于 Kitronik 可编程开发板之叠羊罗汉图3
【花雕动手做】基于 Kitronik 可编程开发板之叠羊罗汉图4
发表于 2025-9-16 08:57:33
