2018-4-28 15:46:41 [显示全部楼层]
16287浏览
查看: 16287|回复: 6
[求助] 向大佬们求助~!步进电机与超声波传感器如何同时使用
我的步进电机用的是42步进电机FIT0349,型号为42BYGH40-18-22A-C5.18。使用了步进电机驱动扩展板DRI0023。
超声波传感器使用的是SRF05。
想要的效果是超声波测得的距离值,控制灯带亮度与步进电机转速。但发现无法将步进电机程序与超声波传感器编入一个文件中:'(向大佬们求助,看看我哪里代码错了。
超声波测距仪程序:(使用的是MODE2,trig与echo同pin)
[mw_shl_code=cpp,true]//import
#include <NewPing.h>    //sonar
#include <Adafruit_NeoPixel.h>    //LED
//define pins
#define N_TRIG_PIN  9    // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define N_ECHO_PIN  9    // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 400    // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
#define SONAR_NUM 1
#define PING_INTERVAL 33
#define LED_PIN 3    // Pin tied to LED
boolean human = 0;
int pingTimer; // Holds the times when the next ping should happen for each sensor.
int cm;         // Where the ping distances are stored.
uint8_t currentSensor = 0;          // Keeps track of which sensor is active.
//set
NewPing sonar =
  NewPing(N_TRIG_PIN, N_ECHO_PIN, MAX_DISTANCE);  // NewPing setup of pins and maximum distance.
Adafruit_NeoPixel strip = Adafruit_NeoPixel(20, LED_PIN, NEO_GRB + NEO_KHZ800);
void setup(){
  Serial.begin(115200);
  pinMode(LED_PIN, OUTPUT);
  pingTimer = millis() + 75;           // First ping starts at 75ms, gives time for the Arduino to chill before starting.
  strip.begin();
  strip.show();
void loop(){
    if (millis() >= pingTimer) {         // Is it this sensor's time to ping?
      pingTimer += PING_INTERVAL * SONAR_NUM;  // Set next time this sensor will be pinged.
      sonar.timer_stop();          // Make sure previous timer is canceled before starting a new ping (insurance).
      cm = 0;                      // Make distance zero in case there's no ping echo for this sensor.
      sonar.ping_timer(echoCheck); // Do the ping (processing continues, interrupt will call echoCheck to look for echo).
//handle functions
void echoCheck() { // If ping received, set the sensor distance to array.
  if (sonar.check_timer()) {
    cm = sonar.ping_result / US_ROUNDTRIP_CM;
    pingResult();
void pingResult() { // Sensor got a ping, do something with the result.
  // The following code would be replaced with your code that does something with the ping result.
  if(cm > 100){
    cm = 0;
  human = cm;
  Serial.println(human);
  if(human == 0) {
    for(int i=0;i<20;i++){
      strip.setPixelColor(i, 100, 100, 100);
      strip.show();
  else{
    for(int i=0;i<5;i++){
      int d = int(255 - cm*1.55);
      strip.setPixelColor(i, d, d, d);
      strip.show();
    for(int j=5;j<20;j++){
      if(cm < 3){
        cm = 0;
      strip.setPixelColor(j, cm, cm, cm);
      strip.show();
  Serial.println(cm);
[/mw_shl_code]
步进电机程序:
[mw_shl_code=cpp,true]int Mdirpin = 7;   //电机Y方向引脚
int Msteppin = 6;  //电机Y驱动引脚
int Men= 8;        //电机Y使能引脚
void setup()
  pinMode(Mdirpin,OUTPUT);
  pinMode(Msteppin,OUTPUT);
  pinMode(Men,OUTPUT);
  digitalWrite(Men, 0); //低电平使能
void loop()
stepper();
void stepper(){
  digitalWrite(Mdirpin, 1);
  for(int j=0;j<=10000;j++){
    digitalWrite(Msteppin, 1);  //上升沿步进
    digitalWrite(Msteppin, 0);
    delay(1);
}[/mw_shl_code]
将两个程序放在一起时,就会有个不运行。估计是因为delay的缘故,但不知道怎么改:'(再次求助大佬们!!多谢~~
步进电机
步进电机
步进电机拓展板
步进电机拓展板
超声波距离传感器
超声波距离传感器
Grey  中级技匠
发表于 2018-4-28 16:59:29
这几个引脚应该是X轴的,你看看连接图,有没有插错口?
love_comic  学徒
发表于 2018-4-28 18:12:39
应该没错,这个两个程序单独运行都是对的
love_comic  学徒
发表于 2018-4-28 18:16:02
在一个群里问的,有人说用状态机,是能把两个程序勉强放在一起。但是会出现步进电机噪音很大,会失步,有时还会跳过传感器的程序
青夏  NPC
发表于 2018-4-29 14:29:15
metro库了解一下
pATAq  版主
发表于 2018-5-1 16:37:18
凭直觉感觉不能用胶水粘起来,涉及优先级、抢占啊什么的,像楼上说的,参考以下多线程或者中断:
https://blog.csdn.net/ling3ye/article/details/73478534
Arduino 使用Metor库 简单实现多线程编程
