8977| 2
[进阶] 七彩雷电云 |
大大们求救啊,我想做一盏雷电云,人不来的时候是7彩的,有人靠近了就打雷闪电。 这是7彩灯带的代码(灯带是): [mw_shl_code=applescript,true]#include <Adafruit_NeoPixel.h> #define PIN 6 #define LED_COUNT 60 Adafruit_NeoPixel leds = Adafruit_NeoPixel(LED_COUNT, PIN, NEO_GRB + NEO_KHZ800); void setup() { leds.begin(); clearLEDs(); leds.show(); } void loop() { for (int i=0; i<LED_COUNT; i++) { rainbow(i); delay(50); } } void clearLEDs() { for (int i=0; i<LED_COUNT; i++) { leds.setPixelColor(i, 0); } } void rainbow(byte startPosition) { int rainbowScale = 192 / LED_COUNT; for (int i=0; i<LED_COUNT; i++) { leds.setPixelColor(i, rainbowOrder((rainbowScale * (i + startPosition)) % 192)); } leds.show(); } uint32_t rainbowOrder(byte position) { if (position < 31) { return leds.Color(0xFF, position * 8, 0); } else if (position < 63) { position -= 31; return leds.Color(0xFF - position * 8, 0xFF, 0); } else if (position < 95) { position -= 63; return leds.Color(0, 0xFF, position * 8); } else if (position < 127) { position -= 95; return leds.Color(0, 0xFF - position * 8, 0xFF); } else if (position < 159) { position -= 127; return leds.Color(position * 8, 0, 0xFF); } else { position -= 159; return leds.Color(0xFF, 0x00, 0xFF - position * 8); } }[/mw_shl_code] 这是雷电云的代码,df下载的: [mw_shl_code=applescript,true]/* A total of 48 lights, 8 sections of each of the 6 lights ByFree Time2015.10.14 */ #include <SoftwareSerial.h> #include <DFPlayer_Mini_Mp3.h> #include <Adafruit_NeoPixel.h> #include <avr/power.h> // Which pin on the Arduino is connected to the Neoled? // On a Trinket or Gemma we suggest changing this to 1 #define PIN 6 // How many Neoled are attached to the Arduino? #define LED_COUNT 50 int lednum = 6; // When we setup the NeoPixel library, we tell it how many led, and which pin to use to send signals. // Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest // example for more information on possible values. Adafruit_NeoPixel led = Adafruit_NeoPixel(LED_COUNT, PIN, NEO_GRB + NEO_KHZ800); int delayval = 0; // delay for half a second void setup() { Serial.begin(9600); pinMode(6, OUTPUT); mp3_set_serial (Serial); //set Serial for DFPlayer-mini mp3 module mp3_set_volume (30); pinMode(3, INPUT); // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket #if defined (__AVR_ATtiny85__) if (F_CPU == 16000000) clock_prescale_set(clock_div_1); #endif // End of trinket special code led.begin(); // This initializes the NeoPixel library. } void loop() { if (digitalRead(3) == 1) { /* First lightning..........................*/ for (int z = 0; z < 1; z++) // Overall cycle number { for (int j = 0; j < 4; j++) // A number of circular lights { // For a set of Neoled the first NeoPixel is 0, second is 1, all the way up to the count of led minus one. for (int i = 0 + j * lednum; i < 6 + j * lednum; i++) { // led.Color takes RGB values, from 0,0,0 up to 255,255,255 led.setPixelColor(i, led.Color(255, 255, 255)); //white led.show(); // This sends the updated pixel color to the hardware. delay(delayval); // Delay for a period of time (in milliseconds). } delay(10); for (int i = 0 + j * lednum; i < 6 + j * lednum; i++) { // led.Color takes RGB values, from 0,0,0 up to 255,255,255 led.setPixelColor(i, led.Color(0, 0, 0)); led.show(); // This sends the updated pixel color to the hardware. delay(delayval); // Delay for a period of time (in milliseconds). } delay(200);// Each light interval } delay(500); //Each cycle of the interval } delay(2000); /* play mp3..........................*/ mp3_play (1); delay(3000); //for light /* 2 lightning-------all light..........................*/ for (int z = 0; z < 2; z++) // Overall cycle number { for (int j = 0; j < 8; j++) // A number of circular lights { // For a set of Neoled the first NeoPixel is 0, second is 1, all the way up to the count of led minus one. for (int i = 0 + j * lednum; i < 6 + j * lednum; i++) { // led.Color takes RGB values, from 0,0,0 up to 255,255,255 led.setPixelColor(i, led.Color(255, 255, 255)); //white led.show(); // This sends the updated pixel color to the hardware. delay(delayval); // Delay for a period of time (in milliseconds). } } delay(50);// ALL light interval for (int j = 0; j < 8; j++) // A number of circular lights { // For a set of Neoled the first NeoPixel is 0, second is 1, all the way up to the count of led minus one. for (int i = 0 + j * lednum; i < 6 + j * lednum; i++) { // led.Color takes RGB values, from 0,0,0 up to 255,255,255 led.setPixelColor(i, led.Color(0, 0, 0)); //white led.show(); // This sends the updated pixel color to the hardware. delay(delayval); // Delay for a period of time (in milliseconds). } } delay(100); //Each cycle of the interval } delay(3000); /* 3 lightning..........................*/ for (int z = 0; z < 1; z++) // for cycle times { for (int j = 0; j < 8; j++) // for number everytime { // For a set of Neoled the first NeoPixel is 0, second is 1, all the way up to the count of led minus one. for (int i = 0 + j * lednum; i < 6 + j * lednum; i++) { // led.Color takes RGB values, from 0,0,0 up to 255,255,255 led.setPixelColor(i, led.Color(255, 255, 255)); // Moderately bright green color. led.show(); // This sends the updated pixel color to the hardware. delay(delayval); // Delay for a period of time (in milliseconds). } delay(10); for (int i = 0 + j * lednum; i < 6 + j * lednum; i++) { // led.Color takes RGB values, from 0,0,0 up to 255,255,255 led.setPixelColor(i, led.Color(0, 0, 0)); // Moderately bright green color. led.show(); // This sends the updated pixel color to the hardware. delay(delayval); // Delay for a period of time (in milliseconds). } delay(500); } delay(500); } delay(2000); /* 4 lightning-------all light..........................*/ for (int z = 0; z < 2; z++) // Overall cycle number { for (int j = 0; j < 8; j++) // A number of circular lights { // For a set of Neoled the first NeoPixel is 0, second is 1, all the way up to the count of led minus one. for (int i = 0 + j * lednum; i < 6 + j * lednum; i++) { // led.Color takes RGB values, from 0,0,0 up to 255,255,255 led.setPixelColor(i, led.Color(255, 255, 255)); //white led.show(); // This sends the updated pixel color to the hardware. delay(delayval); // Delay for a period of time (in milliseconds). } delay(10); } delay(10);// ALL light interval for (int j = 0; j < 8; j++) // A number of circular lights { // For a set of Neoled the first NeoPixel is 0, second is 1, all the way up to the count of led minus one. for (int i = 0 + j * lednum; i < 6 + j * lednum; i++) { // led.Color takes RGB values, from 0,0,0 up to 255,255,255 led.setPixelColor(i, led.Color(0, 0, 0)); //white led.show(); // This sends the updated pixel color to the hardware. delay(delayval); // Delay for a period of time (in milliseconds). } delay(10); } delay(500); //Each cycle of the interval } } else for (int i = 0; i < LED_COUNT; i++) { // led.Color takes RGB values, from 0,0,0 up to 255,255,255 led.setPixelColor(i, led.Color(0, 0, 0)); // Moderately bright green color. led.show(); // This sends the updated pixel color to the hardware. delay(delayval); // Delay for a period of time (in milliseconds). } } void clearLEDs() { for (int i = 0; i < LED_COUNT; i++) led.setPixelColor(i, 0); } [/mw_shl_code] 我回来了,人体红外感应不到人的时候显示七彩,感应到人的时候打雷闪电,但是会有杂音,外观做好了上视频 [mw_shl_code=applescript,true]/* A total of 48 lights, 8 sections of each of the 6 lights ByFree Time2015.10.14 */ #include <SoftwareSerial.h> #include <DFPlayer_Mini_Mp3.h> #include <Adafruit_NeoPixel.h> #include <avr/power.h> // Which pin on the Arduino is connected to the Neoled? // On a Trinket or Gemma we suggest changing this to 1 #define PIN 6 // How many Neoled are attached to the Arduino? #define LED_COUNT 180 int lednum = 24; // When we setup the NeoPixel library, we tell it how many led, and which pin to use to send signals. // Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest // example for more information on possible values. Adafruit_NeoPixel led = Adafruit_NeoPixel(LED_COUNT, PIN, NEO_GRB + NEO_KHZ800); int delayval = 0; // delay for half a second void clearLED() { for (int i = 0; i < LED_COUNT; i++) led.setPixelColor(i, 0); } void rainbow(byte startPosition) { int rainbowScale = 192 / LED_COUNT; for (int i=0; i<LED_COUNT; i++) { led.setPixelColor(i, rainbowOrder((rainbowScale * (i + startPosition)) % 192)); } led.show(); } uint32_t rainbowOrder(byte position) { if (position < 31) { return led.Color(0xFF, position * 8, 0); } else if (position < 63) { position -= 31; return led.Color(0xFF - position * 8, 0xFF, 0); } else if (position < 95) { position -= 63; return led.Color(0, 0xFF, position * 8); } else if (position < 127) { position -= 95; return led.Color(0, 0xFF - position * 8, 0xFF); } else if (position < 159) { position -= 127; return led.Color(position * 8, 0, 0xFF); } else { position -= 159; return led.Color(0xFF, 0x00, 0xFF - position * 8); } } void setup() { Serial.begin(9600); pinMode(6, OUTPUT); mp3_set_serial (Serial); //set Serial for DFPlayer-mini mp3 module mp3_set_volume (30); pinMode(3, INPUT); // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket #if defined (__AVR_ATtiny85__) if (F_CPU == 16000000) clock_prescale_set(clock_div_1); #endif // End of trinket special code led.begin(); // This initializes the NeoPixel library. clearLED(); led.show(); } void loop() { if (digitalRead(3) == 1) { /* First lightning..........................*/ for (int z = 0; z < 1; z++) // Overall cycle number { for (int j = 0; j < 4; j++) // A number of circular lights { // For a set of Neoled the first NeoPixel is 0, second is 1, all the way up to the count of led minus one. for (int i = 0 + j * lednum; i < 6 + j * lednum; i++) { // led.Color takes RGB values, from 0,0,0 up to 255,255,255 led.setPixelColor(i, led.Color(255, 255, 255)); //white led.show(); // This sends the updated pixel color to the hardware. delay(delayval); // Delay for a period of time (in milliseconds). } delay(10); for (int i = 0 + j * lednum; i < 6 + j * lednum; i++) { // led.Color takes RGB values, from 0,0,0 up to 255,255,255 led.setPixelColor(i, led.Color(0, 0, 0)); led.show(); // This sends the updated pixel color to the hardware. delay(delayval); // Delay for a period of time (in milliseconds). } delay(200);// Each light interval } delay(500); //Each cycle of the interval } delay(2000); /* play mp3..........................*/ mp3_play (1); delay(6000); //for light /* 2 lightning-------all light..........................*/ for (int z = 0; z < 2; z++) // Overall cycle number { for (int j = 0; j < 8; j++) // A number of circular lights { // For a set of Neoled the first NeoPixel is 0, second is 1, all the way up to the count of led minus one. for (int i = 0 + j * lednum; i < 6 + j * lednum; i++) { // led.Color takes RGB values, from 0,0,0 up to 255,255,255 led.setPixelColor(i, led.Color(255, 255, 255)); //white led.show(); // This sends the updated pixel color to the hardware. delay(delayval); // Delay for a period of time (in milliseconds). } } delay(50);// ALL light interval for (int j = 0; j < 8; j++) // A number of circular lights { // For a set of Neoled the first NeoPixel is 0, second is 1, all the way up to the count of led minus one. for (int i = 0 + j * lednum; i < 6 + j * lednum; i++) { // led.Color takes RGB values, from 0,0,0 up to 255,255,255 led.setPixelColor(i, led.Color(0, 0, 0)); //white led.show(); // This sends the updated pixel color to the hardware. delay(delayval); // Delay for a period of time (in milliseconds). } } delay(100); //Each cycle of the interval } delay(4000); /* 3 lightning..........................*/ mp3_play (2); delay(6000); //for light for (int z = 0; z < 1; z++) // for cycle times { for (int j = 0; j < 8; j++) // for number everytime { // For a set of Neoled the first NeoPixel is 0, second is 1, all the way up to the count of led minus one. for (int i = 0 + j * lednum; i < 6 + j * lednum; i++) { // led.Color takes RGB values, from 0,0,0 up to 255,255,255 led.setPixelColor(i, led.Color(255, 255, 255)); // Moderately bright green color. led.show(); // This sends the updated pixel color to the hardware. delay(delayval); // Delay for a period of time (in milliseconds). } delay(10); for (int i = 0 + j * lednum; i < 6 + j * lednum; i++) { // led.Color takes RGB values, from 0,0,0 up to 255,255,255 led.setPixelColor(i, led.Color(0, 0, 0)); // Moderately bright green color. led.show(); // This sends the updated pixel color to the hardware. delay(delayval); // Delay for a period of time (in milliseconds). } delay(500); } delay(500); } delay(2000); mp3_play (3); delay(6000); //for light /* 4 lightning-------all light..........................*/ for (int z = 0; z < 2; z++) // Overall cycle number { for (int j = 0; j < 8; j++) // A number of circular lights { // For a set of Neoled the first NeoPixel is 0, second is 1, all the way up to the count of led minus one. for (int i = 0 + j * lednum; i < 6 + j * lednum; i++) { // led.Color takes RGB values, from 0,0,0 up to 255,255,255 led.setPixelColor(i, led.Color(255, 255, 255)); //white led.show(); // This sends the updated pixel color to the hardware. delay(delayval); // Delay for a period of time (in milliseconds). } delay(10); } delay(10);// ALL light interval for (int j = 0; j < 8; j++) // A number of circular lights { // For a set of Neoled the first NeoPixel is 0, second is 1, all the way up to the count of led minus one. for (int i = 0 + j * lednum; i < 6 + j * lednum; i++) { // led.Color takes RGB values, from 0,0,0 up to 255,255,255 led.setPixelColor(i, led.Color(0, 0, 0)); //white led.show(); // This sends the updated pixel color to the hardware. delay(delayval); // Delay for a period of time (in milliseconds). } delay(10); } delay(500); //Each cycle of the interval } mp3_play (1); delay(6000); //for light } else { for (int i = 0; i < LED_COUNT; i++) { // led.Color takes RGB values, from 0,0,0 up to 255,255,255 //led.setPixelColor(i, led.Color(255, 255, 255)); // Moderately bright green color. //led.show(); // This sends the updated pixel color to the hardware. //delay(delayval); // Delay for a period of time (in milliseconds). rainbow(i); delay(50); } clearLED(); led.show(); } } [/mw_shl_code] 视频: 因为我人站的太近一直感应到人没有拍出七彩的效果 电路图我是按照df的来弄的 |
