10747| 1
[讨论] 贝壳物联浇花 |
/* *注意 :Arduino IDE版本请使用1.6.5-1.8.2 */ #include <Wire.h> #include <LiquidCrystal_I2C.h> #include <dht.h> #include <SPI.h> #include <Ethernet.h> #include <aJSON.h> //============= 此处必须修改============ String APIKEY="770739091"; // 此处替换为你自己的API KEY String DEVICEID="1"; // 此处替换为你的设备编号 //======================================= const int LED = 3;// byte mac[] = {0x00, 0x1D, 0x72, 0x82, 0x35, 0x9D}; EthernetClient client ; IPAddress ip(192, 168, 0, 177);//local IP //IPAddress server(121,42,180,30); char server[] = "www.bigiot.net"; int port= 8181 ; aJsonStream serial_stream(&client); unsigned long lastCheckInTime = 0; const unsigned long postingInterval = 40000; // delay between 2 datapoints, 30s void setup() { pinMode(LED, OUTPUT); pinMode(13, OUTPUT); digitalWrite(13,HIGH); mylcd.init(); mylcd.backlight(); Serial.begin(9600); if (Ethernet.begin(mac) == 0) {// start the Ethernet connection with DHCP: Serial.println("Failed to configure Ethernet using DHCP"); Ethernet.begin(mac, ip); } else { Serial.println("Ethernet configuration OK"); } delay(10000); Serial.println("connecting..."); if(client.connect(server, port)){ Serial.println("connected"); }else{ Serial.println("connection failed"); } } void loop() { jiaoshui(); xianshi(); if(millis() - lastCheckInTime > postingInterval) { Serial.println("checking in"); checkIn(); } if (serial_stream.available()) { /* First, skip any accidental whitespace like newlines. */ serial_stream.skip(); } if (serial_stream.available()) { /* Something real on input, let's take a look. */ aJsonObject *msg = aJson.parse(&serial_stream); processMessage(msg); aJson.deleteItem(msg); } } void checkIn() { if (!client.connected()) { Serial.println("connection fiald"); client.stop(); client.connect(server, port); Serial.println("connecting..."); delay(10000); } else{ Serial.println("connection success"); client.print("{\"M\":\"checkin\",\"ID\":\""); client.print(DEVICEID); client.print("\",\"K\":\""); client.print(APIKEY); client.println("\"}"); lastCheckInTime = millis(); Serial.println("check in OK!"); } } void processMessage(aJsonObject *msg){ aJsonObject* method = aJson.getObjectItem(msg, "M"); aJsonObject* content = aJson.getObjectItem(msg, "C"); aJsonObject* client_id = aJson.getObjectItem(msg, "ID"); char* st = aJson.print(msg); if (st != NULL) { Serial.println(st); free(st); String M=method->valuestring; String C=content->valuestring; String F_C_ID=client_id->valuestring; if(M=="say" ){ if(C=="play"){ digitalWrite(LED, HIGH); delay(5000); digitalWrite(LED,LOW); delay(100); sayToClient(F_C_ID,"LED on!"); } if(C=="stop"){ digitalWrite(LED, LOW); sayToClient(F_C_ID,"LED off!"); } } } else { Serial.println( "wrong"); } } void sayToClient(String client_id, String content){ client.print("{\"M\":\"say\",\"ID\":\""); client.print(client_id); client.print("\",\"C\":\""); client.print(content); client.println("\"}"); lastCheckInTime = millis(); Serial.print("say to "); Serial.print(client_id); Serial.print(":"); Serial.println(content); } void jiaoshui() { if (analogRead(A0) < 300) { digitalWrite(3,HIGH); delay(5000); digitalWrite(3,LOW); delay(100); } } |
