17291| 5
求大神,arduino的驱动装不上,setupapi.dev文件是这样的 |
[Device Install Log] OS Version = 6.1.7601 Service Pack = 1.0 Suite = 0x0100 ProductType = 1 Architecture = x86 [BeginLog] [Boot Session: 2014/11/03 19:04:59.109] >>> [Device Install (Hardware initiated) - USB\VID_2341&PID_8036&MI_00\7&26ca06b6&0&0000] >>> Section start 2014/11/03 19:24:11.848 ump: Creating Install Process: DrvInst.exe 19:24:11.989 ndv: Retrieving device info... ndv: Setting device parameters... ndv: Searching just Driver Store... dvi: {Build Driver List} 19:24:15.842 dvi: Searching for hardware ID(s): dvi: usb\vid_2341&pid_8036&rev_0100&mi_00 dvi: usb\vid_2341&pid_8036&mi_00 dvi: Searching for compatible ID(s): dvi: usb\class_02&subclass_02&prot_01 dvi: usb\class_02&subclass_02 dvi: usb\class_02 cpy: Policy is set to make all digital signatures equal. dvi: Enumerating INFs from path list 'C:\Windows\INF' inf: Opened PNF: 'C:\Windows\System32\DriverStore\FileRepository\Arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) sig: {_VERIFY_FILE_SIGNATURE} 19:24:15.889 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat ! sig: Verifying file against specific (valid) catalog failed! (0x800b0109) ! sig: Error 0x800b0109: A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider. sig: {_VERIFY_FILE_SIGNATURE exit(0x800b0109)} 19:24:16.092 sig: {_VERIFY_FILE_SIGNATURE} 19:24:16.092 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat sig: Success: File is signed in Authenticode(tm) catalog. sig: Error 0xe0000241: The INF was signed with an Authenticode(tm) catalog from a trusted publisher. sig: {_VERIFY_FILE_SIGNATURE exit(0xe0000241)} 19:24:16.138 dvi: Created Driver Node: dvi: HardwareID - USB\VID_2341&PID_8036&MI_00 dvi: InfName - C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf dvi: DevDesc - Arduino Leonardo dvi: DrvDesc - Arduino Leonardo dvi: Provider - Arduino LLC (www.arduino.cc) dvi: Mfg - Arduino LLC (www.arduino.cc) dvi: ModelsSec - DeviceList dvi: InstallSec - DriverInstall dvi: ActualSec - DriverInstall dvi: Rank - 0x00ff0001 dvi: Signer - Arduino LLC dvi: Signer Score - Authenticode dvi: DrvDate - 01/04/2013 dvi: Version - 1.0.0.0 inf: Searched 1 potential matches in published INF directory inf: Searched 38 INFs in directory: 'C:\Windows\INF' dvi: {Build Driver List - exit(0x00000000)} 19:24:16.279 ndv: Selecting best match from just Driver Store... dvi: {DIF_SELECTBESTCOMPATDRV} 19:24:16.279 dvi: Using exported function 'PortsClassInstaller' in module 'C:\Windows\system32\MsPorts.Dll'. dvi: Class installer == MsPorts.Dll,PortsClassInstaller dvi: No CoInstallers found dvi: Class installer: Enter 19:24:16.544 dvi: Class installer: Exit dvi: Default installer: Enter 19:24:16.544 dvi: {Select Best Driver} dvi: Selected driver installs from section [DriverInstall] in 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf'. dvi: Class GUID of device remains: {4d36e978-e325-11ce-bfc1-08002be10318}. dvi: Set selected driver complete. dvi: Selected: dvi: Description - [Arduino Leonardo] dvi: InfFile - [c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf] dvi: Section - [DriverInstall] dvi: Signer - [Arduino LLC] dvi: Rank - [0x00ff0001] dvi: {Select Best Driver - exit(0x00000000)} dvi: Default installer: Exit dvi: {DIF_SELECTBESTCOMPATDRV - exit(0x00000000)} 19:24:16.560 inf: Opened PNF: 'C:\Windows\INF\oem32.inf' ([strings]) ndv: Searching Windows Update for drivers... 19:24:16.996 ndv: Acquired WU search serialization mutex. 19:24:17.012 ndv: About to release WU search serialization mutex. 19:25:06.121 ndv: No driver found on Windows Update. 19:25:06.121 ndv: Searching Driver Store and Device Path... dvi: {Build Driver List} 19:25:06.136 dvi: Searching for hardware ID(s): dvi: usb\vid_2341&pid_8036&rev_0100&mi_00 dvi: usb\vid_2341&pid_8036&mi_00 dvi: Searching for compatible ID(s): dvi: usb\class_02&subclass_02&prot_01 dvi: usb\class_02&subclass_02 dvi: usb\class_02 cpy: Policy is set to make all digital signatures equal. dvi: Enumerating INFs from path list 'C:\Windows\Inf' inf: Opened PNF: 'C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) sig: {_VERIFY_FILE_SIGNATURE} 19:25:06.152 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat ! sig: Verifying file against specific (valid) catalog failed! (0x800b0109) ! sig: Error 0x800b0109: A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider. sig: {_VERIFY_FILE_SIGNATURE exit(0x800b0109)} 19:25:06.183 sig: {_VERIFY_FILE_SIGNATURE} 19:25:06.183 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat sig: Success: File is signed in Authenticode(tm) catalog. sig: Error 0xe0000241: The INF was signed with an Authenticode(tm) catalog from a trusted publisher. sig: {_VERIFY_FILE_SIGNATURE exit(0xe0000241)} 19:25:06.230 dvi: Created Driver Node: dvi: HardwareID - USB\VID_2341&PID_8036&MI_00 dvi: InfName - C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf dvi: DevDesc - Arduino Leonardo dvi: DrvDesc - Arduino Leonardo dvi: Provider - Arduino LLC (www.arduino.cc) dvi: Mfg - Arduino LLC (www.arduino.cc) dvi: ModelsSec - DeviceList dvi: InstallSec - DriverInstall dvi: ActualSec - DriverInstall dvi: Rank - 0x00ff0001 dvi: Signer - Arduino LLC dvi: Signer Score - Authenticode dvi: DrvDate - 01/04/2013 dvi: Version - 1.0.0.0 inf: Searched 1 potential matches in published INF directory inf: Searched 38 INFs in directory: 'C:\Windows\Inf' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Board\Intel\M\10.6.0.1002' inf: Searched 50 INFs in directory: 'C:\Windows\Drivers\Board\Intel\C\WIN7_9.2.3.1020' inf: Searched 3 INFs in directory: 'C:\Windows\Drivers\NoteBook\Card\JMicron' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\Intel1\HD\HDMI' inf: Searched 45 INFs in directory: 'C:\Windows\Drivers\Audio\Realtek\HDA' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Wlan\TP-Link\851N' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Wlan\Atheros\AR5xxx_9.2.0.412' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Lan\Broadcom\57xx' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Wlan\Atheros\Atheros_9.2.0.427' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Board\Intel\MEI\2' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\NoteBook\Acpi\Lenovo_Power' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\Intel1\HD' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\Intel1\HD\HDMI' inf: Searched 46 INFs in directory: 'C:\Windows\Drivers\Video\nVIDIA\Notebook' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\nVIDIA\Notebook\HDAudio' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\nVIDIA\Notebook\NV3DVisionUSB.Driver' dvi: {Build Driver List - exit(0x00000000)} 19:25:12.813 ndv: Selecting best match from Driver Store (including Device Path)... dvi: {DIF_SELECTBESTCOMPATDRV} 19:25:12.813 dvi: Class installer: Enter 19:25:12.813 dvi: Class installer: Exit dvi: Default installer: Enter 19:25:12.813 dvi: {Select Best Driver} dvi: Selected driver installs from section [DriverInstall] in 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf'. dvi: Class GUID of device remains: {4d36e978-e325-11ce-bfc1-08002be10318}. dvi: Set selected driver complete. dvi: Selected: dvi: Description - [Arduino Leonardo] dvi: InfFile - [c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf] dvi: Section - [DriverInstall] dvi: Signer - [Arduino LLC] dvi: Rank - [0x00ff0001] dvi: {Select Best Driver - exit(0x00000000)} dvi: Default installer: Exit dvi: {DIF_SELECTBESTCOMPATDRV - exit(0x00000000)} 19:25:12.829 inf: {SetupCopyOEMInf: C:\Windows\INF\oem32.inf} 19:25:12.829 inf: Driver Store location: C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf inf: Published Inf Path: C:\Windows\INF\oem32.inf inf: {SetupCopyOEMInf exit (0x00000050)} 19:25:12.829 dvi: Searching for hardware ID(s): dvi: usb\vid_2341&pid_8036&rev_0100&mi_00 dvi: usb\vid_2341&pid_8036&mi_00 dvi: Searching for compatible ID(s): dvi: usb\class_02&subclass_02&prot_01 dvi: usb\class_02&subclass_02 dvi: usb\class_02 inf: Opened PNF: 'C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) sig: {_VERIFY_FILE_SIGNATURE} 19:25:12.844 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat ! sig: Verifying file against specific (valid) catalog failed! (0x800b0109) ! sig: Error 0x800b0109: A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider. sig: {_VERIFY_FILE_SIGNATURE exit(0x800b0109)} 19:25:12.860 sig: {_VERIFY_FILE_SIGNATURE} 19:25:12.860 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat sig: Success: File is signed in Authenticode(tm) catalog. sig: Error 0xe0000241: The INF was signed with an Authenticode(tm) catalog from a trusted publisher. sig: {_VERIFY_FILE_SIGNATURE exit(0xe0000241)} 19:25:12.922 dvi: Selected driver installs from section [DriverInstall] in 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf'. dvi: Class GUID of device remains: {4d36e978-e325-11ce-bfc1-08002be10318}. dvi: Set selected driver complete. ndv: Driver selected, now performing install... ndv: {Core Device Install} 19:25:12.922 inf: Opened PNF: 'C:\Windows\INF\oem32.inf' ([strings]) inf: Opened PNF: 'C:\Windows\INF\oem32.inf' ([strings]) dvi: {DIF_ALLOW_INSTALL} 19:25:12.969 dvi: Class installer: Enter 19:25:12.969 dvi: Class installer: Exit dvi: Default installer: Enter 19:25:12.969 dvi: Default installer: Exit dvi: {DIF_ALLOW_INSTALL - exit(0xe000020e)} 19:25:12.969 ndv: Installing files... dvi: {DIF_INSTALLDEVICEFILES} 19:25:13.032 dvi: Class installer: Enter 19:25:13.032 dvi: Class installer: Exit dvi: Default installer: Enter 19:25:13.032 dvi: {Install FILES} inf: Opened PNF: 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) inf: Opened PNF: 'C:\Windows\INF\usb.inf' ([strings]) inf: {Install Inf Section [DriverInstall]} inf: CopyFiles=FakeModemCopyFileSection (arduino.inf line 128) ! inf: Empty Section! [FakeModemCopyFileSection] inf: {Install Inf Section [DriverInstall] exit (0x00000000)} dvi: Processing co-installer registration section [DriverInstall.CoInstallers]. inf: {Install Inf Section [DriverInstall.CoInstallers]} inf: {Install Inf Section [DriverInstall.CoInstallers] exit (0x00000000)} dvi: Co-installers registered. dvi: {Install INTERFACES} dvi: Installing section [DriverInstall.Interfaces] dvi: {Install INTERFACES exit 00000000} dvi: {Install FILES exit (0x00000000)} dvi: Default installer: Exit dvi: {DIF_INSTALLDEVICEFILES - exit(0x00000000)} 19:25:13.063 ndv: Pruning file queue... dvi: {_SCAN_FILE_QUEUE} flq: ScanQ flags=620 flq: SPQ_SCAN_PRUNE_COPY_QUEUE flq: SPQ_SCAN_FILE_COMPARISON flq: SPQ_SCAN_ACTIVATE_DRP flq: ScanQ number of copy nodes=0 flq: ScanQ action=200 DoPruning=32 flq: ScanQ end Validity flags=620 CopyNodes=0 dvi: {_SCAN_FILE_QUEUE exit(0, 0x00000000)} ndv: Committing file queue... flq: {_commit_file_queue} flq: CommitQ DelNodes=0 RenNodes=0 CopyNodes=0 flq: CommitQ early exit: No nodes are queued flq: {_commit_file_queue exit OK} ndv: Registering CoInstallers... dvi: {DIF_REGISTER_COINSTALLERS} 19:25:13.094 dvi: Class installer: Enter 19:25:13.094 dvi: Class installer: Exit dvi: Default installer: Enter 19:25:13.110 inf: Opened PNF: 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) inf: {Install Inf Section [DriverInstall.CoInstallers]} inf: {Install Inf Section [DriverInstall.CoInstallers] exit (0x00000000)} dvi: Co-installers registered. dvi: Default installer: Exit dvi: {DIF_REGISTER_COINSTALLERS - exit(0x00000000)} 19:25:13.110 ndv: Installing interfaces... dvi: {DIF_INSTALLINTERFACES} 19:25:13.110 dvi: No CoInstallers found dvi: Class installer: Enter 19:25:13.110 dvi: Class installer: Exit dvi: Default installer: Enter 19:25:13.110 dvi: {Install INTERFACES} inf: Opened PNF: 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) dvi: Installing section [DriverInstall.Interfaces] dvi: {Install INTERFACES exit 00000000} dvi: Default installer: Exit dvi: {DIF_INSTALLINTERFACES - exit(0x00000000)} 19:25:13.125 ndv: Installing device... dvi: {DIF_INSTALLDEVICE} 19:25:13.125 dvi: Class installer: Enter 19:25:13.125 inf: Opened PNF: 'C:\Windows\INF\oem32.inf' ([strings]) inf: AddReg=DriverAddReg (oem32.inf line 129) dvi: {Install DEVICE} inf: Opened PNF: 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) inf: Opened PNF: 'C:\Windows\INF\usb.inf' ([strings]) dvi: Processing Registry/Property directives... inf: {Install Inf Section [DriverInstall]} inf: AddReg=DriverAddReg (arduino.inf line 129) inf: {Install Inf Section [DriverInstall] exit (0x00000000)} inf: {Install Inf Section [DriverInstall.Hw]} inf: Empty section inf: {Install Inf Section [DriverInstall.Hw] exit (0x00000000)} dvi: {Writing Device Properties} dvi: Provider name=Arduino LLC (www.arduino.cc) dvi: DriverDate 01/04/2013 dvi: DriverVersion=1.0.0.0 dvi: Class name=Ports dvi: Manufacturer=Arduino LLC (www.arduino.cc) dvi: Matching DeviceID=usb\vid_2341&pid_8036&mi_00 dvi: Strong Name=oem32.inf:DeviceList:DriverInstall:1.0.0.0:usb\vid_2341&pid_8036&mi_00 dvi: {Writing Device Properties - Complete} inf: {Install Inf Section [DriverInstall.Services]} inf: AddService=usbser,0x00000002,DriverService (arduino.inf line 138) inf: ServiceType=1 (arduino.inf line 142) inf: StartType=3 (arduino.inf line 143) inf: ErrorControl=1 (arduino.inf line 144) inf: ServiceBinary=C:\Windows\system32\DRIVERS\usbser.sys (arduino.inf line 145) !!! dvi: Add Service: Binary 'C:\Windows\system32\DRIVERS\usbser.sys' for service 'usbser' is not present. !!! inf: {Install Inf Section [DriverInstall.Services] exit(0xe0000217)} !!! inf: Error 0xe0000217: A service installation section in this INF is invalid. !!! dvi: Error while installing services. !!! dvi: Error 0xe0000217: A service installation section in this INF is invalid. !!! dvi: Cleaning up failed installation !!! dvi: Error 0xe0000217: A service installation section in this INF is invalid. dvi: {Install DEVICE exit (0xe0000217)} !!! dvi: Cleaning up failed installation (e0000217) !!! dvi: Class installer: failed(0xe0000217)! !!! dvi: Error 0xe0000217: A service installation section in this INF is invalid. dvi: {DIF_INSTALLDEVICE - exit(0xe0000217)} 19:25:13.266 !!! ndv: Error(e0000217) installing device! ndv: Device install status=0xe0000217 ndv: Performing device install final cleanup... ! ndv: Queueing up error report since device installation failed... ndv: {Core Device Install - exit(0xe0000217)} 19:25:13.297 dvi: {DIF_DESTROYPRIVATEDATA} 19:25:13.297 dvi: Class installer: Enter 19:25:13.297 dvi: Class installer: Exit dvi: Default installer: Enter 19:25:13.297 dvi: Default installer: Exit dvi: {DIF_DESTROYPRIVATEDATA - exit(0xe000020e)} 19:25:13.297 ump: Server install process exited with code 0xe0000217 19:25:13.297 <<< Section end 2014/11/03 19:25:13.328 <<< [Exit status: FAILURE(0xe0000217)] >>> [Device Install (Hardware initiated) - USB\VID_2341&PID_8036&MI_00\7&26ca06b6&0&0000] >>> Section start 2014/11/03 19:31:04.022 ump: Creating Install Process: DrvInst.exe 19:31:04.024 ndv: Retrieving device info... ndv: Setting device parameters... ndv: Searching just Driver Store... dvi: {Build Driver List} 19:31:04.972 dvi: Searching for hardware ID(s): dvi: usb\vid_2341&pid_8036&rev_0100&mi_00 dvi: usb\vid_2341&pid_8036&mi_00 dvi: Searching for compatible ID(s): dvi: usb\class_02&subclass_02&prot_01 dvi: usb\class_02&subclass_02 dvi: usb\class_02 cpy: Policy is set to make all digital signatures equal. dvi: Enumerating INFs from path list 'C:\Windows\INF' inf: Opened PNF: 'C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) sig: {_VERIFY_FILE_SIGNATURE} 19:31:04.997 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat ! sig: Verifying file against specific (valid) catalog failed! (0x800b0109) ! sig: Error 0x800b0109: A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider. sig: {_VERIFY_FILE_SIGNATURE exit(0x800b0109)} 19:31:05.235 sig: {_VERIFY_FILE_SIGNATURE} 19:31:05.241 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat sig: Success: File is signed in Authenticode(tm) catalog. sig: Error 0xe0000241: The INF was signed with an Authenticode(tm) catalog from a trusted publisher. sig: {_VERIFY_FILE_SIGNATURE exit(0xe0000241)} 19:31:05.350 dvi: Created Driver Node: dvi: HardwareID - USB\VID_2341&PID_8036&MI_00 dvi: InfName - C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf dvi: DevDesc - Arduino Leonardo dvi: DrvDesc - Arduino Leonardo dvi: Provider - Arduino LLC (www.arduino.cc) dvi: Mfg - Arduino LLC (www.arduino.cc) dvi: ModelsSec - DeviceList dvi: InstallSec - DriverInstall dvi: ActualSec - DriverInstall dvi: Rank - 0x00ff0001 dvi: Signer - Arduino LLC dvi: Signer Score - Authenticode dvi: DrvDate - 01/04/2013 dvi: Version - 1.0.0.0 inf: Searched 1 potential matches in published INF directory inf: Searched 38 INFs in directory: 'C:\Windows\INF' dvi: {Build Driver List - exit(0x00000000)} 19:31:05.608 ndv: Selecting best match from just Driver Store... dvi: {DIF_SELECTBESTCOMPATDRV} 19:31:05.609 dvi: Using exported function 'PortsClassInstaller' in module 'C:\Windows\system32\MsPorts.Dll'. dvi: Class installer == MsPorts.Dll,PortsClassInstaller dvi: No CoInstallers found dvi: Class installer: Enter 19:31:05.626 dvi: Class installer: Exit dvi: Default installer: Enter 19:31:05.628 dvi: {Select Best Driver} dvi: Selected driver installs from section [DriverInstall] in 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf'. dvi: Class GUID of device remains: {4d36e978-e325-11ce-bfc1-08002be10318}. dvi: Set selected driver complete. dvi: Selected: dvi: Description - [Arduino Leonardo] dvi: InfFile - [c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf] dvi: Section - [DriverInstall] dvi: Signer - [Arduino LLC] dvi: Rank - [0x00ff0001] dvi: {Select Best Driver - exit(0x00000000)} dvi: Default installer: Exit dvi: {DIF_SELECTBESTCOMPATDRV - exit(0x00000000)} 19:31:05.639 inf: Opened PNF: 'C:\Windows\INF\oem32.inf' ([strings]) ndv: Searching Windows Update for drivers... 19:31:05.683 ndv: Acquired WU search serialization mutex. 19:31:05.685 ndv: About to release WU search serialization mutex. 19:31:43.264 ndv: No driver found on Windows Update. 19:31:43.264 ndv: Searching Driver Store and Device Path... dvi: {Build Driver List} 19:31:43.266 dvi: Searching for hardware ID(s): dvi: usb\vid_2341&pid_8036&rev_0100&mi_00 dvi: usb\vid_2341&pid_8036&mi_00 dvi: Searching for compatible ID(s): dvi: usb\class_02&subclass_02&prot_01 dvi: usb\class_02&subclass_02 dvi: usb\class_02 cpy: Policy is set to make all digital signatures equal. dvi: Enumerating INFs from path list 'C:\Windows\Inf' inf: Opened PNF: 'C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) sig: {_VERIFY_FILE_SIGNATURE} 19:31:43.280 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat ! sig: Verifying file against specific (valid) catalog failed! (0x800b0109) ! sig: Error 0x800b0109: A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider. sig: {_VERIFY_FILE_SIGNATURE exit(0x800b0109)} 19:31:43.301 sig: {_VERIFY_FILE_SIGNATURE} 19:31:43.302 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat sig: Success: File is signed in Authenticode(tm) catalog. sig: Error 0xe0000241: The INF was signed with an Authenticode(tm) catalog from a trusted publisher. sig: {_VERIFY_FILE_SIGNATURE exit(0xe0000241)} 19:31:43.360 dvi: Created Driver Node: dvi: HardwareID - USB\VID_2341&PID_8036&MI_00 dvi: InfName - C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf dvi: DevDesc - Arduino Leonardo dvi: DrvDesc - Arduino Leonardo dvi: Provider - Arduino LLC (www.arduino.cc) dvi: Mfg - Arduino LLC (www.arduino.cc) dvi: ModelsSec - DeviceList dvi: InstallSec - DriverInstall dvi: ActualSec - DriverInstall dvi: Rank - 0x00ff0001 dvi: Signer - Arduino LLC dvi: Signer Score - Authenticode dvi: DrvDate - 01/04/2013 dvi: Version - 1.0.0.0 inf: Searched 1 potential matches in published INF directory inf: Searched 38 INFs in directory: 'C:\Windows\Inf' inf: Searched 1 INFs in directory: 'C:\Windows\Inf\mdmcpq.inf_amd64_neutral_fbc4a14a6a13d0c8' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Board\Intel\M\10.6.0.1002' inf: Searched 50 INFs in directory: 'C:\Windows\Drivers\Board\Intel\C\WIN7_9.2.3.1020' inf: Searched 3 INFs in directory: 'C:\Windows\Drivers\NoteBook\Card\JMicron' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\Intel1\HD\HDMI' inf: Searched 45 INFs in directory: 'C:\Windows\Drivers\Audio\Realtek\HDA' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Wlan\TP-Link\851N' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Wlan\Atheros\AR5xxx_9.2.0.412' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Lan\Broadcom\57xx' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Wlan\Atheros\Atheros_9.2.0.427' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Board\Intel\MEI\2' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\NoteBook\Acpi\Lenovo_Power' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\Intel1\HD' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\Intel1\HD\HDMI' inf: Searched 46 INFs in directory: 'C:\Windows\Drivers\Video\nVIDIA\Notebook' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\nVIDIA\Notebook\HDAudio' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\nVIDIA\Notebook\NV3DVisionUSB.Driver' dvi: {Build Driver List - exit(0x00000000)} 19:31:49.787 ndv: Selecting best match from Driver Store (including Device Path)... dvi: {DIF_SELECTBESTCOMPATDRV} 19:31:49.788 dvi: Class installer: Enter 19:31:49.789 dvi: Class installer: Exit dvi: Default installer: Enter 19:31:49.790 dvi: {Select Best Driver} dvi: Selected driver installs from section [DriverInstall] in 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf'. dvi: Class GUID of device remains: {4d36e978-e325-11ce-bfc1-08002be10318}. dvi: Set selected driver complete. dvi: Selected: dvi: Description - [Arduino Leonardo] dvi: InfFile - [c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf] dvi: Section - [DriverInstall] dvi: Signer - [Arduino LLC] dvi: Rank - [0x00ff0001] dvi: {Select Best Driver - exit(0x00000000)} dvi: Default installer: Exit dvi: {DIF_SELECTBESTCOMPATDRV - exit(0x00000000)} 19:31:49.799 inf: {SetupCopyOEMInf: C:\Windows\INF\oem32.inf} 19:31:49.802 inf: Driver Store location: C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf inf: Published Inf Path: C:\Windows\INF\oem32.inf inf: {SetupCopyOEMInf exit (0x00000050)} 19:31:49.841 dvi: Searching for hardware ID(s): dvi: usb\vid_2341&pid_8036&rev_0100&mi_00 dvi: usb\vid_2341&pid_8036&mi_00 dvi: Searching for compatible ID(s): dvi: usb\class_02&subclass_02&prot_01 dvi: usb\class_02&subclass_02 dvi: usb\class_02 inf: Opened PNF: 'C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) sig: {_VERIFY_FILE_SIGNATURE} 19:31:49.852 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat ! sig: Verifying file against specific (valid) catalog failed! (0x800b0109) ! sig: Error 0x800b0109: A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider. sig: {_VERIFY_FILE_SIGNATURE exit(0x800b0109)} 19:31:49.873 sig: {_VERIFY_FILE_SIGNATURE} 19:31:49.874 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat sig: Success: File is signed in Authenticode(tm) catalog. sig: Error 0xe0000241: The INF was signed with an Authenticode(tm) catalog from a trusted publisher. sig: {_VERIFY_FILE_SIGNATURE exit(0xe0000241)} 19:31:49.926 dvi: Selected driver installs from section [DriverInstall] in 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf'. dvi: Class GUID of device remains: {4d36e978-e325-11ce-bfc1-08002be10318}. dvi: Set selected driver complete. ndv: Driver selected, now performing install... ndv: {Core Device Install} 19:31:49.931 inf: Opened PNF: 'C:\Windows\INF\oem32.inf' ([strings]) inf: Opened PNF: 'C:\Windows\INF\oem32.inf' ([strings]) dvi: {DIF_ALLOW_INSTALL} 19:31:49.947 dvi: Class installer: Enter 19:31:49.948 dvi: Class installer: Exit dvi: Default installer: Enter 19:31:49.949 dvi: Default installer: Exit dvi: {DIF_ALLOW_INSTALL - exit(0xe000020e)} 19:31:49.950 ndv: Installing files... dvi: {DIF_INSTALLDEVICEFILES} 19:31:49.952 dvi: Class installer: Enter 19:31:49.953 dvi: Class installer: Exit dvi: Default installer: Enter 19:31:49.954 dvi: {Install FILES} inf: Opened PNF: 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) inf: Opened PNF: 'C:\Windows\INF\usb.inf' ([strings]) inf: {Install Inf Section [DriverInstall]} inf: CopyFiles=FakeModemCopyFileSection (arduino.inf line 128) ! inf: Empty Section! [FakeModemCopyFileSection] inf: {Install Inf Section [DriverInstall] exit (0x00000000)} dvi: Processing co-installer registration section [DriverInstall.CoInstallers]. inf: {Install Inf Section [DriverInstall.CoInstallers]} inf: {Install Inf Section [DriverInstall.CoInstallers] exit (0x00000000)} dvi: Co-installers registered. dvi: {Install INTERFACES} dvi: Installing section [DriverInstall.Interfaces] dvi: {Install INTERFACES exit 00000000} dvi: {Install FILES exit (0x00000000)} dvi: Default installer: Exit dvi: {DIF_INSTALLDEVICEFILES - exit(0x00000000)} 19:31:49.994 ndv: Pruning file queue... dvi: {_SCAN_FILE_QUEUE} flq: ScanQ flags=620 flq: SPQ_SCAN_PRUNE_COPY_QUEUE flq: SPQ_SCAN_FILE_COMPARISON flq: SPQ_SCAN_ACTIVATE_DRP flq: ScanQ number of copy nodes=0 flq: ScanQ action=200 DoPruning=32 flq: ScanQ end Validity flags=620 CopyNodes=0 dvi: {_SCAN_FILE_QUEUE exit(0, 0x00000000)} ndv: Committing file queue... flq: {_commit_file_queue} flq: CommitQ DelNodes=0 RenNodes=0 CopyNodes=0 flq: CommitQ early exit: No nodes are queued flq: {_commit_file_queue exit OK} ndv: Registering CoInstallers... dvi: {DIF_REGISTER_COINSTALLERS} 19:31:50.006 dvi: Class installer: Enter 19:31:50.022 dvi: Class installer: Exit dvi: Default installer: Enter 19:31:50.024 inf: Opened PNF: 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) inf: {Install Inf Section [DriverInstall.CoInstallers]} inf: {Install Inf Section [DriverInstall.CoInstallers] exit (0x00000000)} dvi: Co-installers registered. dvi: Default installer: Exit dvi: {DIF_REGISTER_COINSTALLERS - exit(0x00000000)} 19:31:50.032 ndv: Installing interfaces... dvi: {DIF_INSTALLINTERFACES} 19:31:50.033 dvi: No CoInstallers found dvi: Class installer: Enter 19:31:50.035 dvi: Class installer: Exit dvi: Default installer: Enter 19:31:50.036 dvi: {Install INTERFACES} inf: Opened PNF: 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) dvi: Installing section [DriverInstall.Interfaces] dvi: {Install INTERFACES exit 00000000} dvi: Default installer: Exit dvi: {DIF_INSTALLINTERFACES - exit(0x00000000)} 19:31:50.042 ndv: Installing device... dvi: {DIF_INSTALLDEVICE} 19:31:50.043 dvi: Class installer: Enter 19:31:50.044 inf: Opened PNF: 'C:\Windows\INF\oem32.inf' ([strings]) inf: AddReg=DriverAddReg (oem32.inf line 129) dvi: {Install DEVICE} inf: Opened PNF: 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) inf: Opened PNF: 'C:\Windows\INF\usb.inf' ([strings]) dvi: Processing Registry/Property directives... inf: {Install Inf Section [DriverInstall]} inf: AddReg=DriverAddReg (arduino.inf line 129) inf: {Install Inf Section [DriverInstall] exit (0x00000000)} inf: {Install Inf Section [DriverInstall.Hw]} inf: Empty section inf: {Install Inf Section [DriverInstall.Hw] exit (0x00000000)} dvi: {Writing Device Properties} dvi: Provider name=Arduino LLC (www.arduino.cc) dvi: DriverDate 01/04/2013 dvi: DriverVersion=1.0.0.0 dvi: Class name=Ports dvi: Manufacturer=Arduino LLC (www.arduino.cc) dvi: Matching DeviceID=usb\vid_2341&pid_8036&mi_00 dvi: Strong Name=oem32.inf:DeviceList:DriverInstall:1.0.0.0:usb\vid_2341&pid_8036&mi_00 dvi: {Writing Device Properties - Complete} inf: {Install Inf Section [DriverInstall.Services]} inf: AddService=usbser,0x00000002,DriverService (arduino.inf line 138) inf: ServiceType=1 (arduino.inf line 142) inf: StartType=3 (arduino.inf line 143) inf: ErrorControl=1 (arduino.inf line 144) inf: ServiceBinary=C:\Windows\system32\DRIVERS\usbser.sys (arduino.inf line 145) !!! dvi: Add Service: Binary 'C:\Windows\system32\DRIVERS\usbser.sys' for service 'usbser' is not present. !!! inf: {Install Inf Section [DriverInstall.Services] exit(0xe0000217)} !!! inf: Error 0xe0000217: A service installation section in this INF is invalid. !!! dvi: Error while installing services. !!! dvi: Error 0xe0000217: A service installation section in this INF is invalid. !!! dvi: Cleaning up failed installation !!! dvi: Error 0xe0000217: A service installation section in this INF is invalid. dvi: {Install DEVICE exit (0xe0000217)} !!! dvi: Cleaning up failed installation (e0000217) !!! dvi: Class installer: failed(0xe0000217)! !!! dvi: Error 0xe0000217: A service installation section in this INF is invalid. dvi: {DIF_INSTALLDEVICE - exit(0xe0000217)} 19:31:50.149 !!! ndv: Error(e0000217) installing device! ndv: Device install status=0xe0000217 ndv: Performing device install final cleanup... ! ndv: Queueing up error report since device installation failed... ndv: {Core Device Install - exit(0xe0000217)} 19:31:50.165 dvi: {DIF_DESTROYPRIVATEDATA} 19:31:50.166 dvi: Class installer: Enter 19:31:50.166 dvi: Class installer: Exit dvi: Default installer: Enter 19:31:50.168 dvi: Default installer: Exit dvi: {DIF_DESTROYPRIVATEDATA - exit(0xe000020e)} 19:31:50.169 ump: Server install process exited with code 0xe0000217 19:31:50.176 <<< Section end 2014/11/03 19:31:50.200 <<< [Exit status: FAILURE(0xe0000217)] >>> [Device Install (Hardware initiated) - USB\VID_2341&PID_8036&MI_00\7&26ca06b6&0&0000] >>> Section start 2014/11/03 19:31:50.204 ump: Creating Install Process: DrvInst.exe 19:31:50.206 ndv: Retrieving device info... ndv: Setting device parameters... ndv: Searching just Driver Store... dvi: {Build Driver List} 19:31:50.292 dvi: Searching for hardware ID(s): dvi: usb\vid_2341&pid_8036&rev_0100&mi_00 dvi: usb\vid_2341&pid_8036&mi_00 dvi: Searching for compatible ID(s): dvi: usb\class_02&subclass_02&prot_01 dvi: usb\class_02&subclass_02 dvi: usb\class_02 cpy: Policy is set to make all digital signatures equal. dvi: Enumerating INFs from path list 'C:\Windows\INF' inf: Opened PNF: 'C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) sig: {_VERIFY_FILE_SIGNATURE} 19:31:50.313 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat ! sig: Verifying file against specific (valid) catalog failed! (0x800b0109) ! sig: Error 0x800b0109: A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider. sig: {_VERIFY_FILE_SIGNATURE exit(0x800b0109)} 19:31:50.398 sig: {_VERIFY_FILE_SIGNATURE} 19:31:50.399 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat sig: Success: File is signed in Authenticode(tm) catalog. sig: Error 0xe0000241: The INF was signed with an Authenticode(tm) catalog from a trusted publisher. sig: {_VERIFY_FILE_SIGNATURE exit(0xe0000241)} 19:31:50.455 dvi: Created Driver Node: dvi: HardwareID - USB\VID_2341&PID_8036&MI_00 dvi: InfName - C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf dvi: DevDesc - Arduino Leonardo dvi: DrvDesc - Arduino Leonardo dvi: Provider - Arduino LLC (www.arduino.cc) dvi: Mfg - Arduino LLC (www.arduino.cc) dvi: ModelsSec - DeviceList dvi: InstallSec - DriverInstall dvi: ActualSec - DriverInstall dvi: Rank - 0x00ff0001 dvi: Signer - Arduino LLC dvi: Signer Score - Authenticode dvi: DrvDate - 01/04/2013 dvi: Version - 1.0.0.0 inf: Searched 1 potential matches in published INF directory inf: Searched 38 INFs in directory: 'C:\Windows\INF' dvi: {Build Driver List - exit(0x00000000)} 19:31:50.601 ndv: Selecting best match from just Driver Store... dvi: {DIF_SELECTBESTCOMPATDRV} 19:31:50.602 dvi: Using exported function 'PortsClassInstaller' in module 'C:\Windows\system32\MsPorts.Dll'. dvi: Class installer == MsPorts.Dll,PortsClassInstaller dvi: No CoInstallers found dvi: Class installer: Enter 19:31:50.608 dvi: Class installer: Exit dvi: Default installer: Enter 19:31:50.609 dvi: {Select Best Driver} dvi: Selected driver installs from section [DriverInstall] in 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf'. dvi: Class GUID of device remains: {4d36e978-e325-11ce-bfc1-08002be10318}. dvi: Set selected driver complete. dvi: Selected: dvi: Description - [Arduino Leonardo] dvi: InfFile - [c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf] dvi: Section - [DriverInstall] dvi: Signer - [Arduino LLC] dvi: Rank - [0x00ff0001] dvi: {Select Best Driver - exit(0x00000000)} dvi: Default installer: Exit dvi: {DIF_SELECTBESTCOMPATDRV - exit(0x00000000)} 19:31:50.622 inf: Opened PNF: 'C:\Windows\INF\oem32.inf' ([strings]) ndv: Searching Windows Update for drivers... 19:31:50.639 ndv: Acquired WU search serialization mutex. 19:31:50.640 ndv: Received request to cancel Windows Update search. ndv: About to release WU search serialization mutex. 19:32:10.621 ndv: Windows Update driver search cancelled. 19:32:10.622 ndv: Searching Driver Store and Device Path... dvi: {Build Driver List} 19:32:10.623 dvi: Searching for hardware ID(s): dvi: usb\vid_2341&pid_8036&rev_0100&mi_00 dvi: usb\vid_2341&pid_8036&mi_00 dvi: Searching for compatible ID(s): dvi: usb\class_02&subclass_02&prot_01 dvi: usb\class_02&subclass_02 dvi: usb\class_02 cpy: Policy is set to make all digital signatures equal. dvi: Enumerating INFs from path list 'C:\Windows\Inf' inf: Opened PNF: 'C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) sig: {_VERIFY_FILE_SIGNATURE} 19:32:10.641 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat ! sig: Verifying file against specific (valid) catalog failed! (0x800b0109) ! sig: Error 0x800b0109: A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider. sig: {_VERIFY_FILE_SIGNATURE exit(0x800b0109)} 19:32:10.661 sig: {_VERIFY_FILE_SIGNATURE} 19:32:10.662 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat sig: Success: File is signed in Authenticode(tm) catalog. sig: Error 0xe0000241: The INF was signed with an Authenticode(tm) catalog from a trusted publisher. sig: {_VERIFY_FILE_SIGNATURE exit(0xe0000241)} 19:32:10.716 dvi: Created Driver Node: dvi: HardwareID - USB\VID_2341&PID_8036&MI_00 dvi: InfName - C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf dvi: DevDesc - Arduino Leonardo dvi: DrvDesc - Arduino Leonardo dvi: Provider - Arduino LLC (www.arduino.cc) dvi: Mfg - Arduino LLC (www.arduino.cc) dvi: ModelsSec - DeviceList dvi: InstallSec - DriverInstall dvi: ActualSec - DriverInstall dvi: Rank - 0x00ff0001 dvi: Signer - Arduino LLC dvi: Signer Score - Authenticode dvi: DrvDate - 01/04/2013 dvi: Version - 1.0.0.0 inf: Searched 1 potential matches in published INF directory inf: Searched 38 INFs in directory: 'C:\Windows\Inf' inf: Searched 1 INFs in directory: 'C:\Windows\Inf\mdmcpq.inf_amd64_neutral_fbc4a14a6a13d0c8' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Board\Intel\M\10.6.0.1002' inf: Searched 50 INFs in directory: 'C:\Windows\Drivers\Board\Intel\C\WIN7_9.2.3.1020' inf: Searched 3 INFs in directory: 'C:\Windows\Drivers\NoteBook\Card\JMicron' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\Intel1\HD\HDMI' inf: Searched 45 INFs in directory: 'C:\Windows\Drivers\Audio\Realtek\HDA' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Wlan\TP-Link\851N' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Wlan\Atheros\AR5xxx_9.2.0.412' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Lan\Broadcom\57xx' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Wlan\Atheros\Atheros_9.2.0.427' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Board\Intel\MEI\2' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\NoteBook\Acpi\Lenovo_Power' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\Intel1\HD' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\Intel1\HD\HDMI' inf: Searched 46 INFs in directory: 'C:\Windows\Drivers\Video\nVIDIA\Notebook' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\nVIDIA\Notebook\HDAudio' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\nVIDIA\Notebook\NV3DVisionUSB.Driver' dvi: {Build Driver List - exit(0x00000000)} 19:32:17.306 ndv: Selecting best match from Driver Store (including Device Path)... dvi: {DIF_SELECTBESTCOMPATDRV} 19:32:17.308 dvi: Class installer: Enter 19:32:17.309 dvi: Class installer: Exit dvi: Default installer: Enter 19:32:17.310 dvi: {Select Best Driver} dvi: Selected driver installs from section [DriverInstall] in 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf'. dvi: Class GUID of device remains: {4d36e978-e325-11ce-bfc1-08002be10318}. dvi: Set selected driver complete. dvi: Selected: dvi: Description - [Arduino Leonardo] dvi: InfFile - [c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf] dvi: Section - [DriverInstall] dvi: Signer - [Arduino LLC] dvi: Rank - [0x00ff0001] dvi: {Select Best Driver - exit(0x00000000)} dvi: Default installer: Exit dvi: {DIF_SELECTBESTCOMPATDRV - exit(0x00000000)} 19:32:17.318 inf: {SetupCopyOEMInf: C:\Windows\INF\oem32.inf} 19:32:17.321 inf: Driver Store location: C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf inf: Published Inf Path: C:\Windows\INF\oem32.inf inf: {SetupCopyOEMInf exit (0x00000050)} 19:32:17.324 dvi: Searching for hardware ID(s): dvi: usb\vid_2341&pid_8036&rev_0100&mi_00 dvi: usb\vid_2341&pid_8036&mi_00 dvi: Searching for compatible ID(s): dvi: usb\class_02&subclass_02&prot_01 dvi: usb\class_02&subclass_02 dvi: usb\class_02 inf: Opened PNF: 'C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) sig: {_VERIFY_FILE_SIGNATURE} 19:32:17.334 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat ! sig: Verifying file against specific (valid) catalog failed! (0x800b0109) ! sig: Error 0x800b0109: A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider. sig: {_VERIFY_FILE_SIGNATURE exit(0x800b0109)} 19:32:17.354 sig: {_VERIFY_FILE_SIGNATURE} 19:32:17.355 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat sig: Success: File is signed in Authenticode(tm) catalog. sig: Error 0xe0000241: The INF was signed with an Authenticode(tm) catalog from a trusted publisher. sig: {_VERIFY_FILE_SIGNATURE exit(0xe0000241)} 19:32:17.408 dvi: Selected driver installs from section [DriverInstall] in 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf'. dvi: Class GUID of device remains: {4d36e978-e325-11ce-bfc1-08002be10318}. dvi: Set selected driver complete. ndv: Driver selected, now performing install... ndv: {Core Device Install} 19:32:17.413 inf: Opened PNF: 'C:\Windows\INF\oem32.inf' ([strings]) inf: Opened PNF: 'C:\Windows\INF\oem32.inf' ([strings]) dvi: {DIF_ALLOW_INSTALL} 19:32:17.429 dvi: Class installer: Enter 19:32:17.429 dvi: Class installer: Exit dvi: Default installer: Enter 19:32:17.431 dvi: Default installer: Exit dvi: {DIF_ALLOW_INSTALL - exit(0xe000020e)} 19:32:17.432 ndv: Installing files... dvi: {DIF_INSTALLDEVICEFILES} 19:32:17.435 dvi: Class installer: Enter 19:32:17.435 dvi: Class installer: Exit dvi: Default installer: Enter 19:32:17.437 dvi: {Install FILES} inf: Opened PNF: 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) inf: Opened PNF: 'C:\Windows\INF\usb.inf' ([strings]) inf: {Install Inf Section [DriverInstall]} inf: CopyFiles=FakeModemCopyFileSection (arduino.inf line 128) ! inf: Empty Section! [FakeModemCopyFileSection] inf: {Install Inf Section [DriverInstall] exit (0x00000000)} dvi: Processing co-installer registration section [DriverInstall.CoInstallers]. inf: {Install Inf Section [DriverInstall.CoInstallers]} inf: {Install Inf Section [DriverInstall.CoInstallers] exit (0x00000000)} dvi: Co-installers registered. dvi: {Install INTERFACES} dvi: Installing section [DriverInstall.Interfaces] dvi: {Install INTERFACES exit 00000000} dvi: {Install FILES exit (0x00000000)} dvi: Default installer: Exit dvi: {DIF_INSTALLDEVICEFILES - exit(0x00000000)} 19:32:17.453 ndv: Pruning file queue... dvi: {_SCAN_FILE_QUEUE} flq: ScanQ flags=620 flq: SPQ_SCAN_PRUNE_COPY_QUEUE flq: SPQ_SCAN_FILE_COMPARISON flq: SPQ_SCAN_ACTIVATE_DRP flq: ScanQ number of copy nodes=0 flq: ScanQ action=200 DoPruning=32 flq: ScanQ end Validity flags=620 CopyNodes=0 dvi: {_SCAN_FILE_QUEUE exit(0, 0x00000000)} ndv: Committing file queue... flq: {_commit_file_queue} flq: CommitQ DelNodes=0 RenNodes=0 CopyNodes=0 flq: CommitQ early exit: No nodes are queued flq: {_commit_file_queue exit OK} ndv: Registering CoInstallers... dvi: {DIF_REGISTER_COINSTALLERS} 19:32:17.464 dvi: Class installer: Enter 19:32:17.468 dvi: Class installer: Exit dvi: Default installer: Enter 19:32:17.469 inf: Opened PNF: 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) inf: {Install Inf Section [DriverInstall.CoInstallers]} inf: {Install Inf Section [DriverInstall.CoInstallers] exit (0x00000000)} dvi: Co-installers registered. dvi: Default installer: Exit dvi: {DIF_REGISTER_COINSTALLERS - exit(0x00000000)} 19:32:17.475 ndv: Installing interfaces... dvi: {DIF_INSTALLINTERFACES} 19:32:17.476 dvi: No CoInstallers found dvi: Class installer: Enter 19:32:17.477 dvi: Class installer: Exit dvi: Default installer: Enter 19:32:17.479 dvi: {Install INTERFACES} inf: Opened PNF: 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) dvi: Installing section [DriverInstall.Interfaces] dvi: {Install INTERFACES exit 00000000} dvi: Default installer: Exit dvi: {DIF_INSTALLINTERFACES - exit(0x00000000)} 19:32:17.484 ndv: Installing device... dvi: {DIF_INSTALLDEVICE} 19:32:17.485 dvi: Class installer: Enter 19:32:17.486 inf: Opened PNF: 'C:\Windows\INF\oem32.inf' ([strings]) inf: AddReg=DriverAddReg (oem32.inf line 129) dvi: {Install DEVICE} inf: Opened PNF: 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) inf: Opened PNF: 'C:\Windows\INF\usb.inf' ([strings]) dvi: Processing Registry/Property directives... inf: {Install Inf Section [DriverInstall]} inf: AddReg=DriverAddReg (arduino.inf line 129) inf: {Install Inf Section [DriverInstall] exit (0x00000000)} inf: {Install Inf Section [DriverInstall.Hw]} inf: Empty section inf: {Install Inf Section [DriverInstall.Hw] exit (0x00000000)} dvi: {Writing Device Properties} dvi: Provider name=Arduino LLC (www.arduino.cc) dvi: DriverDate 01/04/2013 dvi: DriverVersion=1.0.0.0 dvi: Class name=Ports dvi: Manufacturer=Arduino LLC (www.arduino.cc) dvi: Matching DeviceID=usb\vid_2341&pid_8036&mi_00 dvi: Strong Name=oem32.inf:DeviceList:DriverInstall:1.0.0.0:usb\vid_2341&pid_8036&mi_00 dvi: {Writing Device Properties - Complete} inf: {Install Inf Section [DriverInstall.Services]} inf: AddService=usbser,0x00000002,DriverService (arduino.inf line 138) inf: ServiceType=1 (arduino.inf line 142) inf: StartType=3 (arduino.inf line 143) inf: ErrorControl=1 (arduino.inf line 144) inf: ServiceBinary=C:\Windows\system32\DRIVERS\usbser.sys (arduino.inf line 145) !!! dvi: Add Service: Binary 'C:\Windows\system32\DRIVERS\usbser.sys' for service 'usbser' is not present. !!! inf: {Install Inf Section [DriverInstall.Services] exit(0xe0000217)} !!! inf: Error 0xe0000217: A service installation section in this INF is invalid. !!! dvi: Error while installing services. !!! dvi: Error 0xe0000217: A service installation section in this INF is invalid. !!! dvi: Cleaning up failed installation !!! dvi: Error 0xe0000217: A service installation section in this INF is invalid. dvi: {Install DEVICE exit (0xe0000217)} !!! dvi: Cleaning up failed installation (e0000217) !!! dvi: Class installer: failed(0xe0000217)! !!! dvi: Error 0xe0000217: A service installation section in this INF is invalid. dvi: {DIF_INSTALLDEVICE - exit(0xe0000217)} 19:32:17.561 !!! ndv: Error(e0000217) installing device! ndv: Device install status=0xe0000217 ndv: Performing device install final cleanup... ! ndv: Queueing up error report since device installation failed... ndv: {Core Device Install - exit(0xe0000217)} 19:32:17.565 dvi: {DIF_DESTROYPRIVATEDATA} 19:32:17.566 dvi: Class installer: Enter 19:32:17.566 dvi: Class installer: Exit dvi: Default installer: Enter 19:32:17.568 dvi: Default installer: Exit dvi: {DIF_DESTROYPRIVATEDATA - exit(0xe000020e)} 19:32:17.569 ump: Server install process exited with code 0xe0000217 19:32:17.575 <<< Section end 2014/11/03 19:32:17.583 <<< [Exit status: FAILURE(0xe0000217)] >>> [Device Install (Hardware initiated) - USB\VID_2341&PID_8036&MI_00\7&26ca06b6&0&0000] >>> Section start 2014/11/03 19:32:17.587 ump: Creating Install Process: DrvInst.exe 19:32:17.595 ndv: Retrieving device info... ndv: Setting device parameters... ndv: Searching just Driver Store... dvi: {Build Driver List} 19:32:17.646 dvi: Searching for hardware ID(s): dvi: usb\vid_2341&pid_8036&rev_0100&mi_00 dvi: usb\vid_2341&pid_8036&mi_00 dvi: Searching for compatible ID(s): dvi: usb\class_02&subclass_02&prot_01 dvi: usb\class_02&subclass_02 dvi: usb\class_02 cpy: Policy is set to make all digital signatures equal. dvi: Enumerating INFs from path list 'C:\Windows\INF' inf: Opened PNF: 'C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) sig: {_VERIFY_FILE_SIGNATURE} 19:32:17.668 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat ! sig: Verifying file against specific (valid) catalog failed! (0x800b0109) ! sig: Error 0x800b0109: A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider. sig: {_VERIFY_FILE_SIGNATURE exit(0x800b0109)} 19:32:17.757 sig: {_VERIFY_FILE_SIGNATURE} 19:32:17.757 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat sig: Success: File is signed in Authenticode(tm) catalog. sig: Error 0xe0000241: The INF was signed with an Authenticode(tm) catalog from a trusted publisher. sig: {_VERIFY_FILE_SIGNATURE exit(0xe0000241)} 19:32:17.810 dvi: Created Driver Node: dvi: HardwareID - USB\VID_2341&PID_8036&MI_00 dvi: InfName - C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf dvi: DevDesc - Arduino Leonardo dvi: DrvDesc - Arduino Leonardo dvi: Provider - Arduino LLC (www.arduino.cc) dvi: Mfg - Arduino LLC (www.arduino.cc) dvi: ModelsSec - DeviceList dvi: InstallSec - DriverInstall dvi: ActualSec - DriverInstall dvi: Rank - 0x00ff0001 dvi: Signer - Arduino LLC dvi: Signer Score - Authenticode dvi: DrvDate - 01/04/2013 dvi: Version - 1.0.0.0 inf: Searched 1 potential matches in published INF directory inf: Searched 38 INFs in directory: 'C:\Windows\INF' dvi: {Build Driver List - exit(0x00000000)} 19:32:17.950 ndv: Selecting best match from just Driver Store... dvi: {DIF_SELECTBESTCOMPATDRV} 19:32:17.952 dvi: Using exported function 'PortsClassInstaller' in module 'C:\Windows\system32\MsPorts.Dll'. dvi: Class installer == MsPorts.Dll,PortsClassInstaller dvi: No CoInstallers found dvi: Class installer: Enter 19:32:17.957 dvi: Class installer: Exit dvi: Default installer: Enter 19:32:17.958 dvi: {Select Best Driver} dvi: Selected driver installs from section [DriverInstall] in 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf'. dvi: Class GUID of device remains: {4d36e978-e325-11ce-bfc1-08002be10318}. dvi: Set selected driver complete. dvi: Selected: dvi: Description - [Arduino Leonardo] dvi: InfFile - [c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf] dvi: Section - [DriverInstall] dvi: Signer - [Arduino LLC] dvi: Rank - [0x00ff0001] dvi: {Select Best Driver - exit(0x00000000)} dvi: Default installer: Exit dvi: {DIF_SELECTBESTCOMPATDRV - exit(0x00000000)} 19:32:17.967 inf: Opened PNF: 'C:\Windows\INF\oem32.inf' ([strings]) ndv: Searching Windows Update for drivers... 19:32:17.980 ndv: Windows Update driver search cancelled. 19:32:17.982 ndv: Searching Driver Store and Device Path... dvi: {Build Driver List} 19:32:17.983 dvi: Searching for hardware ID(s): dvi: usb\vid_2341&pid_8036&rev_0100&mi_00 dvi: usb\vid_2341&pid_8036&mi_00 dvi: Searching for compatible ID(s): dvi: usb\class_02&subclass_02&prot_01 dvi: usb\class_02&subclass_02 dvi: usb\class_02 cpy: Policy is set to make all digital signatures equal. dvi: Enumerating INFs from path list 'C:\Windows\Inf' inf: Opened PNF: 'C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) sig: {_VERIFY_FILE_SIGNATURE} 19:32:17.996 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat ! sig: Verifying file against specific (valid) catalog failed! (0x800b0109) ! sig: Error 0x800b0109: A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider. sig: {_VERIFY_FILE_SIGNATURE exit(0x800b0109)} 19:32:18.015 sig: {_VERIFY_FILE_SIGNATURE} 19:32:18.016 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat sig: Success: File is signed in Authenticode(tm) catalog. sig: Error 0xe0000241: The INF was signed with an Authenticode(tm) catalog from a trusted publisher. sig: {_VERIFY_FILE_SIGNATURE exit(0xe0000241)} 19:32:18.069 dvi: Created Driver Node: dvi: HardwareID - USB\VID_2341&PID_8036&MI_00 dvi: InfName - C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf dvi: DevDesc - Arduino Leonardo dvi: DrvDesc - Arduino Leonardo dvi: Provider - Arduino LLC (www.arduino.cc) dvi: Mfg - Arduino LLC (www.arduino.cc) dvi: ModelsSec - DeviceList dvi: InstallSec - DriverInstall dvi: ActualSec - DriverInstall dvi: Rank - 0x00ff0001 dvi: Signer - Arduino LLC dvi: Signer Score - Authenticode dvi: DrvDate - 01/04/2013 dvi: Version - 1.0.0.0 inf: Searched 1 potential matches in published INF directory inf: Searched 38 INFs in directory: 'C:\Windows\Inf' inf: Searched 1 INFs in directory: 'C:\Windows\Inf\mdmcpq.inf_amd64_neutral_fbc4a14a6a13d0c8' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Board\Intel\M\10.6.0.1002' inf: Searched 50 INFs in directory: 'C:\Windows\Drivers\Board\Intel\C\WIN7_9.2.3.1020' inf: Searched 3 INFs in directory: 'C:\Windows\Drivers\NoteBook\Card\JMicron' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\Intel1\HD\HDMI' inf: Searched 45 INFs in directory: 'C:\Windows\Drivers\Audio\Realtek\HDA' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Wlan\TP-Link\851N' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Wlan\Atheros\AR5xxx_9.2.0.412' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Lan\Broadcom\57xx' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Wlan\Atheros\Atheros_9.2.0.427' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Board\Intel\MEI\2' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\NoteBook\Acpi\Lenovo_Power' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\Intel1\HD' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\Intel1\HD\HDMI' inf: Searched 46 INFs in directory: 'C:\Windows\Drivers\Video\nVIDIA\Notebook' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\nVIDIA\Notebook\HDAudio' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\nVIDIA\Notebook\NV3DVisionUSB.Driver' dvi: {Build Driver List - exit(0x00000000)} 19:32:24.541 ndv: Selecting best match from Driver Store (including Device Path)... dvi: {DIF_SELECTBESTCOMPATDRV} 19:32:24.543 dvi: Class installer: Enter 19:32:24.543 dvi: Class installer: Exit dvi: Default installer: Enter 19:32:24.545 dvi: {Select Best Driver} dvi: Selected driver installs from section [DriverInstall] in 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf'. dvi: Class GUID of device remains: {4d36e978-e325-11ce-bfc1-08002be10318}. dvi: Set selected driver complete. dvi: Selected: dvi: Description - [Arduino Leonardo] dvi: InfFile - [c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf] dvi: Section - [DriverInstall] dvi: Signer - [Arduino LLC] dvi: Rank - [0x00ff0001] dvi: {Select Best Driver - exit(0x00000000)} dvi: Default installer: Exit dvi: {DIF_SELECTBESTCOMPATDRV - exit(0x00000000)} 19:32:24.553 inf: {SetupCopyOEMInf: C:\Windows\INF\oem32.inf} 19:32:24.555 inf: Driver Store location: C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf inf: Published Inf Path: C:\Windows\INF\oem32.inf inf: {SetupCopyOEMInf exit (0x00000050)} 19:32:24.558 dvi: Searching for hardware ID(s): dvi: usb\vid_2341&pid_8036&rev_0100&mi_00 dvi: usb\vid_2341&pid_8036&mi_00 dvi: Searching for compatible ID(s): dvi: usb\class_02&subclass_02&prot_01 dvi: usb\class_02&subclass_02 dvi: usb\class_02 inf: Opened PNF: 'C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) sig: {_VERIFY_FILE_SIGNATURE} 19:32:24.570 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat ! sig: Verifying file against specific (valid) catalog failed! (0x800b0109) ! sig: Error 0x800b0109: A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider. sig: {_VERIFY_FILE_SIGNATURE exit(0x800b0109)} 19:32:24.589 sig: {_VERIFY_FILE_SIGNATURE} 19:32:24.589 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat sig: Success: File is signed in Authenticode(tm) catalog. sig: Error 0xe0000241: The INF was signed with an Authenticode(tm) catalog from a trusted publisher. sig: {_VERIFY_FILE_SIGNATURE exit(0xe0000241)} 19:32:24.641 dvi: Selected driver installs from section [DriverInstall] in 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf'. dvi: Class GUID of device remains: {4d36e978-e325-11ce-bfc1-08002be10318}. dvi: Set selected driver complete. ndv: Driver selected, now performing install... ndv: {Core Device Install} 19:32:24.646 inf: Opened PNF: 'C:\Windows\INF\oem32.inf' ([strings]) inf: Opened PNF: 'C:\Windows\INF\oem32.inf' ([strings]) dvi: {DIF_ALLOW_INSTALL} 19:32:24.661 dvi: Class installer: Enter 19:32:24.662 dvi: Class installer: Exit dvi: Default installer: Enter 19:32:24.663 dvi: Default installer: Exit dvi: {DIF_ALLOW_INSTALL - exit(0xe000020e)} 19:32:24.664 ndv: Installing files... dvi: {DIF_INSTALLDEVICEFILES} 19:32:24.667 dvi: Class installer: Enter 19:32:24.667 dvi: Class installer: Exit dvi: Default installer: Enter 19:32:24.669 dvi: {Install FILES} inf: Opened PNF: 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) inf: Opened PNF: 'C:\Windows\INF\usb.inf' ([strings]) inf: {Install Inf Section [DriverInstall]} inf: CopyFiles=FakeModemCopyFileSection (arduino.inf line 128) ! inf: Empty Section! [FakeModemCopyFileSection] inf: {Install Inf Section [DriverInstall] exit (0x00000000)} dvi: Processing co-installer registration section [DriverInstall.CoInstallers]. inf: {Install Inf Section [DriverInstall.CoInstallers]} inf: {Install Inf Section [DriverInstall.CoInstallers] exit (0x00000000)} dvi: Co-installers registered. dvi: {Install INTERFACES} dvi: Installing section [DriverInstall.Interfaces] dvi: {Install INTERFACES exit 00000000} dvi: {Install FILES exit (0x00000000)} dvi: Default installer: Exit dvi: {DIF_INSTALLDEVICEFILES - exit(0x00000000)} 19:32:24.684 ndv: Pruning file queue... dvi: {_SCAN_FILE_QUEUE} flq: ScanQ flags=620 flq: SPQ_SCAN_PRUNE_COPY_QUEUE flq: SPQ_SCAN_FILE_COMPARISON flq: SPQ_SCAN_ACTIVATE_DRP flq: ScanQ number of copy nodes=0 flq: ScanQ action=200 DoPruning=32 flq: ScanQ end Validity flags=620 CopyNodes=0 dvi: {_SCAN_FILE_QUEUE exit(0, 0x00000000)} ndv: Committing file queue... flq: {_commit_file_queue} flq: CommitQ DelNodes=0 RenNodes=0 CopyNodes=0 flq: CommitQ early exit: No nodes are queued flq: {_commit_file_queue exit OK} ndv: Registering CoInstallers... dvi: {DIF_REGISTER_COINSTALLERS} 19:32:24.695 dvi: Class installer: Enter 19:32:24.698 dvi: Class installer: Exit dvi: Default installer: Enter 19:32:24.700 inf: Opened PNF: 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) inf: {Install Inf Section [DriverInstall.CoInstallers]} inf: {Install Inf Section [DriverInstall.CoInstallers] exit (0x00000000)} dvi: Co-installers registered. dvi: Default installer: Exit dvi: {DIF_REGISTER_COINSTALLERS - exit(0x00000000)} 19:32:24.707 ndv: Installing interfaces... dvi: {DIF_INSTALLINTERFACES} 19:32:24.709 dvi: No CoInstallers found dvi: Class installer: Enter 19:32:24.710 dvi: Class installer: Exit dvi: Default installer: Enter 19:32:24.712 dvi: {Install INTERFACES} inf: Opened PNF: 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) dvi: Installing section [DriverInstall.Interfaces] dvi: {Install INTERFACES exit 00000000} dvi: Default installer: Exit dvi: {DIF_INSTALLINTERFACES - exit(0x00000000)} 19:32:24.717 ndv: Installing device... dvi: {DIF_INSTALLDEVICE} 19:32:24.718 dvi: Class installer: Enter 19:32:24.719 inf: Opened PNF: 'C:\Windows\INF\oem32.inf' ([strings]) inf: AddReg=DriverAddReg (oem32.inf line 129) dvi: {Install DEVICE} inf: Opened PNF: 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) inf: Opened PNF: 'C:\Windows\INF\usb.inf' ([strings]) dvi: Processing Registry/Property directives... inf: {Install Inf Section [DriverInstall]} inf: AddReg=DriverAddReg (arduino.inf line 129) inf: {Install Inf Section [DriverInstall] exit (0x00000000)} inf: {Install Inf Section [DriverInstall.Hw]} inf: Empty section inf: {Install Inf Section [DriverInstall.Hw] exit (0x00000000)} dvi: {Writing Device Properties} dvi: Provider name=Arduino LLC (www.arduino.cc) dvi: DriverDate 01/04/2013 dvi: DriverVersion=1.0.0.0 dvi: Class name=Ports dvi: Manufacturer=Arduino LLC (www.arduino.cc) dvi: Matching DeviceID=usb\vid_2341&pid_8036&mi_00 dvi: Strong Name=oem32.inf:DeviceList:DriverInstall:1.0.0.0:usb\vid_2341&pid_8036&mi_00 dvi: {Writing Device Properties - Complete} inf: {Install Inf Section [DriverInstall.Services]} inf: AddService=usbser,0x00000002,DriverService (arduino.inf line 138) inf: ServiceType=1 (arduino.inf line 142) inf: StartType=3 (arduino.inf line 143) inf: ErrorControl=1 (arduino.inf line 144) inf: ServiceBinary=C:\Windows\system32\DRIVERS\usbser.sys (arduino.inf line 145) !!! dvi: Add Service: Binary 'C:\Windows\system32\DRIVERS\usbser.sys' for service 'usbser' is not present. !!! inf: {Install Inf Section [DriverInstall.Services] exit(0xe0000217)} !!! inf: Error 0xe0000217: A service installation section in this INF is invalid. !!! dvi: Error while installing services. !!! dvi: Error 0xe0000217: A service installation section in this INF is invalid. !!! dvi: Cleaning up failed installation !!! dvi: Error 0xe0000217: A service installation section in this INF is invalid. dvi: {Install DEVICE exit (0xe0000217)} !!! dvi: Cleaning up failed installation (e0000217) !!! dvi: Class installer: failed(0xe0000217)! !!! dvi: Error 0xe0000217: A service installation section in this INF is invalid. dvi: {DIF_INSTALLDEVICE - exit(0xe0000217)} 19:32:24.792 !!! ndv: Error(e0000217) installing device! ndv: Device install status=0xe0000217 ndv: Performing device install final cleanup... ! ndv: Queueing up error report since device installation failed... ndv: {Core Device Install - exit(0xe0000217)} 19:32:24.796 dvi: {DIF_DESTROYPRIVATEDATA} 19:32:24.797 dvi: Class installer: Enter 19:32:24.797 dvi: Class installer: Exit dvi: Default installer: Enter 19:32:24.799 dvi: Default installer: Exit dvi: {DIF_DESTROYPRIVATEDATA - exit(0xe000020e)} 19:32:24.800 ump: Server install process exited with code 0xe0000217 19:32:24.806 <<< Section end 2014/11/03 19:32:24.812 <<< [Exit status: FAILURE(0xe0000217)] >>> [Device Install (Hardware initiated) - USB\VID_2341&PID_8036&MI_00\7&26ca06b6&0&0000] >>> Section start 2014/11/03 19:32:24.815 ump: Creating Install Process: DrvInst.exe 19:32:24.816 ndv: Retrieving device info... ndv: Setting device parameters... ndv: Searching just Driver Store... dvi: {Build Driver List} 19:32:24.867 dvi: Searching for hardware ID(s): dvi: usb\vid_2341&pid_8036&rev_0100&mi_00 dvi: usb\vid_2341&pid_8036&mi_00 dvi: Searching for compatible ID(s): dvi: usb\class_02&subclass_02&prot_01 dvi: usb\class_02&subclass_02 dvi: usb\class_02 cpy: Policy is set to make all digital signatures equal. dvi: Enumerating INFs from path list 'C:\Windows\INF' inf: Opened PNF: 'C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) sig: {_VERIFY_FILE_SIGNATURE} 19:32:24.890 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat ! sig: Verifying file against specific (valid) catalog failed! (0x800b0109) ! sig: Error 0x800b0109: A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider. sig: {_VERIFY_FILE_SIGNATURE exit(0x800b0109)} 19:32:24.976 sig: {_VERIFY_FILE_SIGNATURE} 19:32:24.977 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat sig: Success: File is signed in Authenticode(tm) catalog. sig: Error 0xe0000241: The INF was signed with an Authenticode(tm) catalog from a trusted publisher. sig: {_VERIFY_FILE_SIGNATURE exit(0xe0000241)} 19:32:25.030 dvi: Created Driver Node: dvi: HardwareID - USB\VID_2341&PID_8036&MI_00 dvi: InfName - C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf dvi: DevDesc - Arduino Leonardo dvi: DrvDesc - Arduino Leonardo dvi: Provider - Arduino LLC (www.arduino.cc) dvi: Mfg - Arduino LLC (www.arduino.cc) dvi: ModelsSec - DeviceList dvi: InstallSec - DriverInstall dvi: ActualSec - DriverInstall dvi: Rank - 0x00ff0001 dvi: Signer - Arduino LLC dvi: Signer Score - Authenticode dvi: DrvDate - 01/04/2013 dvi: Version - 1.0.0.0 inf: Searched 1 potential matches in published INF directory inf: Searched 38 INFs in directory: 'C:\Windows\INF' dvi: {Build Driver List - exit(0x00000000)} 19:32:25.171 ndv: Selecting best match from just Driver Store... dvi: {DIF_SELECTBESTCOMPATDRV} 19:32:25.173 dvi: Using exported function 'PortsClassInstaller' in module 'C:\Windows\system32\MsPorts.Dll'. dvi: Class installer == MsPorts.Dll,PortsClassInstaller dvi: No CoInstallers found dvi: Class installer: Enter 19:32:25.178 dvi: Class installer: Exit dvi: Default installer: Enter 19:32:25.179 dvi: {Select Best Driver} dvi: Selected driver installs from section [DriverInstall] in 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf'. dvi: Class GUID of device remains: {4d36e978-e325-11ce-bfc1-08002be10318}. dvi: Set selected driver complete. dvi: Selected: dvi: Description - [Arduino Leonardo] dvi: InfFile - [c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf] dvi: Section - [DriverInstall] dvi: Signer - [Arduino LLC] dvi: Rank - [0x00ff0001] dvi: {Select Best Driver - exit(0x00000000)} dvi: Default installer: Exit dvi: {DIF_SELECTBESTCOMPATDRV - exit(0x00000000)} 19:32:25.188 inf: Opened PNF: 'C:\Windows\INF\oem32.inf' ([strings]) ndv: Searching Windows Update for drivers... 19:32:25.201 ndv: Windows Update driver search cancelled. 19:32:25.202 ndv: Searching Driver Store and Device Path... dvi: {Build Driver List} 19:32:25.204 dvi: Searching for hardware ID(s): dvi: usb\vid_2341&pid_8036&rev_0100&mi_00 dvi: usb\vid_2341&pid_8036&mi_00 dvi: Searching for compatible ID(s): dvi: usb\class_02&subclass_02&prot_01 dvi: usb\class_02&subclass_02 dvi: usb\class_02 cpy: Policy is set to make all digital signatures equal. dvi: Enumerating INFs from path list 'C:\Windows\Inf' inf: Opened PNF: 'C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) sig: {_VERIFY_FILE_SIGNATURE} 19:32:25.216 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat ! sig: Verifying file against specific (valid) catalog failed! (0x800b0109) ! sig: Error 0x800b0109: A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider. sig: {_VERIFY_FILE_SIGNATURE exit(0x800b0109)} 19:32:25.235 sig: {_VERIFY_FILE_SIGNATURE} 19:32:25.236 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat sig: Success: File is signed in Authenticode(tm) catalog. sig: Error 0xe0000241: The INF was signed with an Authenticode(tm) catalog from a trusted publisher. sig: {_VERIFY_FILE_SIGNATURE exit(0xe0000241)} 19:32:25.286 dvi: Created Driver Node: dvi: HardwareID - USB\VID_2341&PID_8036&MI_00 dvi: InfName - C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf dvi: DevDesc - Arduino Leonardo dvi: DrvDesc - Arduino Leonardo dvi: Provider - Arduino LLC (www.arduino.cc) dvi: Mfg - Arduino LLC (www.arduino.cc) dvi: ModelsSec - DeviceList dvi: InstallSec - DriverInstall dvi: ActualSec - DriverInstall dvi: Rank - 0x00ff0001 dvi: Signer - Arduino LLC dvi: Signer Score - Authenticode dvi: DrvDate - 01/04/2013 dvi: Version - 1.0.0.0 inf: Searched 1 potential matches in published INF directory inf: Searched 38 INFs in directory: 'C:\Windows\Inf' inf: Searched 1 INFs in directory: 'C:\Windows\Inf\mdmcpq.inf_amd64_neutral_fbc4a14a6a13d0c8' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Board\Intel\M\10.6.0.1002' inf: Searched 50 INFs in directory: 'C:\Windows\Drivers\Board\Intel\C\WIN7_9.2.3.1020' inf: Searched 3 INFs in directory: 'C:\Windows\Drivers\NoteBook\Card\JMicron' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\Intel1\HD\HDMI' inf: Searched 45 INFs in directory: 'C:\Windows\Drivers\Audio\Realtek\HDA' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Wlan\TP-Link\851N' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Wlan\Atheros\AR5xxx_9.2.0.412' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Lan\Broadcom\57xx' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Wlan\Atheros\Atheros_9.2.0.427' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Board\Intel\MEI\2' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\NoteBook\Acpi\Lenovo_Power' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\Intel1\HD' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\Intel1\HD\HDMI' inf: Searched 46 INFs in directory: 'C:\Windows\Drivers\Video\nVIDIA\Notebook' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\nVIDIA\Notebook\HDAudio' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\nVIDIA\Notebook\NV3DVisionUSB.Driver' dvi: {Build Driver List - exit(0x00000000)} 19:32:31.867 ndv: Selecting best match from Driver Store (including Device Path)... dvi: {DIF_SELECTBESTCOMPATDRV} 19:32:31.869 dvi: Class installer: Enter 19:32:31.869 dvi: Class installer: Exit dvi: Default installer: Enter 19:32:31.871 dvi: {Select Best Driver} dvi: Selected driver installs from section [DriverInstall] in 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf'. dvi: Class GUID of device remains: {4d36e978-e325-11ce-bfc1-08002be10318}. dvi: Set selected driver complete. dvi: Selected: dvi: Description - [Arduino Leonardo] dvi: InfFile - [c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf] dvi: Section - [DriverInstall] dvi: Signer - [Arduino LLC] dvi: Rank - [0x00ff0001] dvi: {Select Best Driver - exit(0x00000000)} dvi: Default installer: Exit dvi: {DIF_SELECTBESTCOMPATDRV - exit(0x00000000)} 19:32:31.879 inf: {SetupCopyOEMInf: C:\Windows\INF\oem32.inf} 19:32:31.881 inf: Driver Store location: C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf inf: Published Inf Path: C:\Windows\INF\oem32.inf inf: {SetupCopyOEMInf exit (0x00000050)} 19:32:31.885 dvi: Searching for hardware ID(s): dvi: usb\vid_2341&pid_8036&rev_0100&mi_00 dvi: usb\vid_2341&pid_8036&mi_00 dvi: Searching for compatible ID(s): dvi: usb\class_02&subclass_02&prot_01 dvi: usb\class_02&subclass_02 dvi: usb\class_02 inf: Opened PNF: 'C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) sig: {_VERIFY_FILE_SIGNATURE} 19:32:31.896 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat ! sig: Verifying file against specific (valid) catalog failed! (0x800b0109) ! sig: Error 0x800b0109: A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider. sig: {_VERIFY_FILE_SIGNATURE exit(0x800b0109)} 19:32:31.916 sig: {_VERIFY_FILE_SIGNATURE} 19:32:31.916 sig: Key = arduino.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.cat sig: Success: File is signed in Authenticode(tm) catalog. sig: Error 0xe0000241: The INF was signed with an Authenticode(tm) catalog from a trusted publisher. sig: {_VERIFY_FILE_SIGNATURE exit(0xe0000241)} 19:32:31.968 dvi: Selected driver installs from section [DriverInstall] in 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf'. dvi: Class GUID of device remains: {4d36e978-e325-11ce-bfc1-08002be10318}. dvi: Set selected driver complete. ndv: Driver selected, now performing install... ndv: {Core Device Install} 19:32:31.974 inf: Opened PNF: 'C:\Windows\INF\oem32.inf' ([strings]) inf: Opened PNF: 'C:\Windows\INF\oem32.inf' ([strings]) dvi: {DIF_ALLOW_INSTALL} 19:32:31.991 dvi: Class installer: Enter 19:32:31.992 dvi: Class installer: Exit dvi: Default installer: Enter 19:32:31.993 dvi: Default installer: Exit dvi: {DIF_ALLOW_INSTALL - exit(0xe000020e)} 19:32:31.994 ndv: Installing files... dvi: {DIF_INSTALLDEVICEFILES} 19:32:31.997 dvi: Class installer: Enter 19:32:31.997 dvi: Class installer: Exit dvi: Default installer: Enter 19:32:31.999 dvi: {Install FILES} inf: Opened PNF: 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) inf: Opened PNF: 'C:\Windows\INF\usb.inf' ([strings]) inf: {Install Inf Section [DriverInstall]} inf: CopyFiles=FakeModemCopyFileSection (arduino.inf line 128) ! inf: Empty Section! [FakeModemCopyFileSection] inf: {Install Inf Section [DriverInstall] exit (0x00000000)} dvi: Processing co-installer registration section [DriverInstall.CoInstallers]. inf: {Install Inf Section [DriverInstall.CoInstallers]} inf: {Install Inf Section [DriverInstall.CoInstallers] exit (0x00000000)} dvi: Co-installers registered. dvi: {Install INTERFACES} dvi: Installing section [DriverInstall.Interfaces] dvi: {Install INTERFACES exit 00000000} dvi: {Install FILES exit (0x00000000)} dvi: Default installer: Exit dvi: {DIF_INSTALLDEVICEFILES - exit(0x00000000)} 19:32:32.015 ndv: Pruning file queue... dvi: {_SCAN_FILE_QUEUE} flq: ScanQ flags=620 flq: SPQ_SCAN_PRUNE_COPY_QUEUE flq: SPQ_SCAN_FILE_COMPARISON flq: SPQ_SCAN_ACTIVATE_DRP flq: ScanQ number of copy nodes=0 flq: ScanQ action=200 DoPruning=32 flq: ScanQ end Validity flags=620 CopyNodes=0 dvi: {_SCAN_FILE_QUEUE exit(0, 0x00000000)} ndv: Committing file queue... flq: {_commit_file_queue} flq: CommitQ DelNodes=0 RenNodes=0 CopyNodes=0 flq: CommitQ early exit: No nodes are queued flq: {_commit_file_queue exit OK} ndv: Registering CoInstallers... dvi: {DIF_REGISTER_COINSTALLERS} 19:32:32.026 dvi: Class installer: Enter 19:32:32.030 dvi: Class installer: Exit dvi: Default installer: Enter 19:32:32.031 inf: Opened PNF: 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) inf: {Install Inf Section [DriverInstall.CoInstallers]} inf: {Install Inf Section [DriverInstall.CoInstallers] exit (0x00000000)} dvi: Co-installers registered. dvi: Default installer: Exit dvi: {DIF_REGISTER_COINSTALLERS - exit(0x00000000)} 19:32:32.038 ndv: Installing interfaces... dvi: {DIF_INSTALLINTERFACES} 19:32:32.040 dvi: No CoInstallers found dvi: Class installer: Enter 19:32:32.041 dvi: Class installer: Exit dvi: Default installer: Enter 19:32:32.043 dvi: {Install INTERFACES} inf: Opened PNF: 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) dvi: Installing section [DriverInstall.Interfaces] dvi: {Install INTERFACES exit 00000000} dvi: Default installer: Exit dvi: {DIF_INSTALLINTERFACES - exit(0x00000000)} 19:32:32.048 ndv: Installing device... dvi: {DIF_INSTALLDEVICE} 19:32:32.049 dvi: Class installer: Enter 19:32:32.050 inf: Opened PNF: 'C:\Windows\INF\oem32.inf' ([strings]) inf: AddReg=DriverAddReg (oem32.inf line 129) dvi: {Install DEVICE} inf: Opened PNF: 'c:\windows\system32\driverstore\filerepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf' ([strings]) inf: Opened PNF: 'C:\Windows\INF\usb.inf' ([strings]) dvi: Processing Registry/Property directives... inf: {Install Inf Section [DriverInstall]} inf: AddReg=DriverAddReg (arduino.inf line 129) inf: {Install Inf Section [DriverInstall] exit (0x00000000)} inf: {Install Inf Section [DriverInstall.Hw]} inf: Empty section inf: {Install Inf Section [DriverInstall.Hw] exit (0x00000000)} dvi: {Writing Device Properties} dvi: Provider name=Arduino LLC (www.arduino.cc) dvi: DriverDate 01/04/2013 dvi: DriverVersion=1.0.0.0 dvi: Class name=Ports dvi: Manufacturer=Arduino LLC (www.arduino.cc) dvi: Matching DeviceID=usb\vid_2341&pid_8036&mi_00 dvi: Strong Name=oem32.inf:DeviceList:DriverInstall:1.0.0.0:usb\vid_2341&pid_8036&mi_00 dvi: {Writing Device Properties - Complete} inf: {Install Inf Section [DriverInstall.Services]} inf: AddService=usbser,0x00000002,DriverService (arduino.inf line 138) inf: ServiceType=1 (arduino.inf line 142) inf: StartType=3 (arduino.inf line 143) inf: ErrorControl=1 (arduino.inf line 144) inf: ServiceBinary=C:\Windows\system32\DRIVERS\usbser.sys (arduino.inf line 145) !!! dvi: Add Service: Binary 'C:\Windows\system32\DRIVERS\usbser.sys' for service 'usbser' is not present. !!! inf: {Install Inf Section [DriverInstall.Services] exit(0xe0000217)} !!! inf: Error 0xe0000217: A service installation section in this INF is invalid. !!! dvi: Error while installing services. !!! dvi: Error 0xe0000217: A service installation section in this INF is invalid. !!! dvi: Cleaning up failed installation !!! dvi: Error 0xe0000217: A service installation section in this INF is invalid. dvi: {Install DEVICE exit (0xe0000217)} !!! dvi: Cleaning up failed installation (e0000217) !!! dvi: Class installer: failed(0xe0000217)! !!! dvi: Error 0xe0000217: A service installation section in this INF is invalid. dvi: {DIF_INSTALLDEVICE - exit(0xe0000217)} 19:32:32.130 !!! ndv: Error(e0000217) installing device! ndv: Device install status=0xe0000217 ndv: Performing device install final cleanup... ! ndv: Queueing up error report since device installation failed... ndv: {Core Device Install - exit(0xe0000217)} 19:32:32.134 dvi: {DIF_DESTROYPRIVATEDATA} 19:32:32.135 dvi: Class installer: Enter 19:32:32.135 dvi: Class installer: Exit dvi: Default installer: Enter 19:32:32.137 dvi: Default installer: Exit dvi: {DIF_DESTROYPRIVATEDATA - exit(0xe000020e)} 19:32:32.138 ump: Server install process exited with code 0xe0000217 19:32:32.146 <<< Section end 2014/11/03 19:32:32.152 <<< [Exit status: FAILURE(0xe0000217)] >>> [Device Install (DiShowUpdateDevice) - USB\VID_2341&PID_8036&MI_00\7&26CA06B6&0&0000] >>> Section start 2014/11/03 19:32:37.089 cmd: "C:\Windows\system32\mmc.exe" C:\Windows\system32\devmgmt.msc dvi: {DIF_UPDATEDRIVER_UI} 19:32:37.090 dvi: Using exported function 'PortsClassInstaller' in module 'C:\Windows\system32\MsPorts.Dll'. dvi: Class installer == MsPorts.Dll,PortsClassInstaller dvi: No CoInstallers found dvi: Class installer: Enter 19:32:37.099 dvi: Class installer: Exit dvi: Default installer: Enter 19:32:37.101 dvi: Default installer: Exit dvi: {DIF_UPDATEDRIVER_UI - exit(0xe000020e)} 19:32:37.103 ndv: {Update Driver Software Wizard for USB\VID_2341&PID_8036&MI_00\7&26CA06B6&0&0000} inf: Opened PNF: 'C:\Windows\INF\oem32.inf' ([strings]) ndv: {Update Driver Software Wizard exit(00000000)} <<< Section end 2014/11/03 19:32:44.129 <<< [Exit status: SUCCESS] >>> [Device Install (DiShowUpdateDevice) - USB\VID_2341&PID_8036&MI_00\7&26CA06B6&0&0000] >>> Section start 2014/11/03 19:32:52.654 cmd: "C:\Windows\system32\mmc.exe" C:\Windows\system32\devmgmt.msc dvi: {DIF_UPDATEDRIVER_UI} 19:32:52.656 dvi: Using exported function 'PortsClassInstaller' in module 'C:\Windows\system32\MsPorts.Dll'. dvi: Class installer == MsPorts.Dll,PortsClassInstaller dvi: No CoInstallers found dvi: Class installer: Enter 19:32:52.667 dvi: Class installer: Exit dvi: Default installer: Enter 19:32:52.670 dvi: Default installer: Exit dvi: {DIF_UPDATEDRIVER_UI - exit(0xe000020e)} 19:32:52.673 ndv: {Update Driver Software Wizard for USB\VID_2341&PID_8036&MI_00\7&26CA06B6&0&0000} inf: Opened PNF: 'C:\Windows\INF\oem32.inf' ([strings]) ndv: {Update Driver Software Wizard exit(00000000)} <<< Section end 2014/11/03 19:34:51.241 <<< [Exit status: SUCCESS] >>> [Device Install (DiShowUpdateDevice) - USB\VID_2341&PID_8036&MI_00\7&26CA06B6&0&0000] >>> Section start 2014/11/03 19:44:07.517 cmd: "C:\Windows\system32\mmc.exe" C:\Windows\system32\devmgmt.msc dvi: {DIF_UPDATEDRIVER_UI} 19:44:07.519 dvi: Using exported function 'PortsClassInstaller' in module 'C:\Windows\system32\MsPorts.Dll'. dvi: Class installer == MsPorts.Dll,PortsClassInstaller dvi: No CoInstallers found dvi: Class installer: Enter 19:44:07.547 dvi: Class installer: Exit dvi: Default installer: Enter 19:44:07.549 dvi: Default installer: Exit dvi: {DIF_UPDATEDRIVER_UI - exit(0xe000020e)} 19:44:07.551 ndv: {Update Driver Software Wizard for USB\VID_2341&PID_8036&MI_00\7&26CA06B6&0&0000} inf: Opened PNF: 'C:\Windows\INF\oem32.inf' ([strings]) ndv: {Update Driver Software Wizard exit(00000000)} <<< Section end 2014/11/03 19:44:20.332 <<< [Exit status: SUCCESS] >>> [Device Uninstall (Device Manager) - USB\VID_2341&PID_8036&MI_00\7&26CA06B6&0&0000] >>> Section start 2014/11/03 19:45:15.814 cmd: "C:\Windows\system32\mmc.exe" C:\Windows\system32\devmgmt.msc inf: {SetupUninstallOEMInf: oem32.inf} inf: Driver Store location: C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sto: {Delete Driver Package: C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf} 19:45:15.863 sto: Deleting driver package from Driver Store: sto: Driver Store = C:\Windows\System32\DriverStore (Online | 6.1.7601) sto: Driver Package = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf sto: Flags = 0x00000000 pol: {Driver package policy check} 19:45:16.616 pol: {Driver package policy check - exit(0x00000000)} 19:45:16.617 sto: {Unstage Driver Package: C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe\arduino.inf} 19:45:16.618 idb: Published INF 'oem32.inf' deleted idb: Unpublished driver store entry 'arduino.inf_x86_neutral_844213a156728dfe'. sto: Published driver package INF 'oem32.inf' was deleted. idb: Unregistered driver store entry 'arduino.inf_x86_neutral_844213a156728dfe'. sto: {Delete Directory: C:\Windows\System32\DriverStore\FileRepository\arduino.inf_x86_neutral_844213a156728dfe} 19:45:16.734 sto: {Delete Directory: exit(0x00000000)} 19:45:16.741 sto: {Unstage Driver Package: exit(0x00000000)} 19:45:16.741 sto: Deleted driver package from Driver Store. Time = 874 ms sto: {Delete Driver Package: exit(0x00000000)} 19:45:16.746 inf: Uninstalling catalog: C:\Windows\INF\oem32.CAT inf: {SetupUninstallOEMInf exit (0x00000000)} dmg: Successfully uninstalled oem32.inf. dvi: {DIF_REMOVE} 19:45:17.099 dvi: Using exported function 'PortsClassInstaller' in module 'C:\Windows\system32\MsPorts.Dll'. dvi: Class installer == MsPorts.Dll,PortsClassInstaller dvi: No CoInstallers found dvi: Class installer: Enter 19:45:17.108 dvi: {Remove DEVICE} dvi: InstanceID = 'USB\VID_2341&PID_8036&MI_00\7&26CA06B6&0&0000' dvi: Devnode Status = 0x01802400 dvi: CM_Query_And_Remove_Subtree_Ex returns 0x00000000 dvi: Devnode Status after CM_Query_And_Remove_Subtree_Ex = 0x01802400 dvi: Query-and-Remove succeeded dvi: {Delete DEVICE} dvi: Device Instance uninstalled. dvi: {Delete DEVICE exit (0x00000000)} dvi: {Remove DEVICE exit (0x00000000)} dvi: Class installer: Exit dvi: {DIF_REMOVE - exit(0x00000000)} 19:45:17.310 <<< Section end 2014/11/03 19:45:17.312 <<< [Exit status: SUCCESS] >>> [Device Install (Hardware initiated) - USB\VID_2341&PID_8036&MI_00\7&26ca06b6&0&0000] >>> Section start 2014/11/03 19:45:25.029 ump: Creating Install Process: DrvInst.exe 19:45:25.111 ndv: Retrieving device info... ndv: Setting device parameters... ndv: Searching just Driver Store... dvi: {Build Driver List} 19:45:25.275 dvi: Searching for hardware ID(s): dvi: usb\vid_2341&pid_8036&rev_0100&mi_00 dvi: usb\vid_2341&pid_8036&mi_00 dvi: Searching for compatible ID(s): dvi: usb\class_02&subclass_02&prot_01 dvi: usb\class_02&subclass_02 dvi: usb\class_02 cpy: Policy is set to make all digital signatures equal. dvi: Enumerating INFs from path list 'C:\Windows\INF' inf: Searched 0 potential matches in published INF directory inf: Searched 38 INFs in directory: 'C:\Windows\INF' dvi: {Build Driver List - exit(0x00000000)} 19:45:25.714 ndv: Selecting best match from just Driver Store... dvi: {DIF_SELECTBESTCOMPATDRV} 19:45:25.716 dvi: No class installer for 'Arduino Leonardo' dvi: No CoInstallers found dvi: Default installer: Enter 19:45:25.719 dvi: {Select Best Driver} ! dvi: Selecting driver failed(0xe0000228) dvi: {Select Best Driver - exit(0xe0000228)} ! dvi: Default installer: failed! ! dvi: Error 0xe0000228: There are no compatible drivers for this device. dvi: {DIF_SELECTBESTCOMPATDRV - exit(0xe0000228)} 19:45:25.724 ndv: Searching Windows Update for drivers... 19:45:25.767 ndv: Acquired WU search serialization mutex. 19:45:25.768 ndv: About to release WU search serialization mutex. 19:46:01.777 ndv: No driver found on Windows Update. 19:46:01.779 ndv: Searching Driver Store and Device Path... dvi: {Build Driver List} 19:46:01.782 dvi: Searching for hardware ID(s): dvi: usb\vid_2341&pid_8036&rev_0100&mi_00 dvi: usb\vid_2341&pid_8036&mi_00 dvi: Searching for compatible ID(s): dvi: usb\class_02&subclass_02&prot_01 dvi: usb\class_02&subclass_02 dvi: usb\class_02 cpy: Policy is set to make all digital signatures equal. dvi: Enumerating INFs from path list 'C:\Windows\Inf' inf: Searched 0 potential matches in published INF directory inf: Searched 38 INFs in directory: 'C:\Windows\Inf' inf: Searched 1 INFs in directory: 'C:\Windows\Inf\mdmcpq.inf_amd64_neutral_fbc4a14a6a13d0c8' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Board\Intel\M\10.6.0.1002' inf: Searched 50 INFs in directory: 'C:\Windows\Drivers\Board\Intel\C\WIN7_9.2.3.1020' inf: Searched 3 INFs in directory: 'C:\Windows\Drivers\NoteBook\Card\JMicron' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\Intel1\HD\HDMI' inf: Searched 45 INFs in directory: 'C:\Windows\Drivers\Audio\Realtek\HDA' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Wlan\TP-Link\851N' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Wlan\Atheros\AR5xxx_9.2.0.412' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Lan\Broadcom\57xx' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Wlan\Atheros\Atheros_9.2.0.427' inf: Searched 2 INFs in directory: 'C:\Windows\Drivers\Board\Intel\MEI\2' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\NoteBook\Acpi\Lenovo_Power' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\Intel1\HD' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\Intel1\HD\HDMI' inf: Searched 46 INFs in directory: 'C:\Windows\Drivers\Video\nVIDIA\Notebook' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\nVIDIA\Notebook\HDAudio' inf: Searched 1 INFs in directory: 'C:\Windows\Drivers\Video\nVIDIA\Notebook\NV3DVisionUSB.Driver' dvi: {Build Driver List - exit(0x00000000)} 19:46:09.407 ndv: Selecting best match from Driver Store (including Device Path)... dvi: {DIF_SELECTBESTCOMPATDRV} 19:46:09.408 dvi: No class installer for 'Arduino Leonardo' dvi: Default installer: Enter 19:46:09.410 dvi: {Select Best Driver} ! dvi: Selecting driver failed(0xe0000228) dvi: {Select Best Driver - exit(0xe0000228)} ! dvi: Default installer: failed! ! dvi: Error 0xe0000228: There are no compatible drivers for this device. dvi: {DIF_SELECTBESTCOMPATDRV - exit(0xe0000228)} 19:46:09.414 ndv: {Core Device Install} 19:46:09.438 ! ndv: Installing NULL driver! dvi: Set selected driver complete. dvi: {DIF_ALLOW_INSTALL} 19:46:09.450 dvi: No class installer for 'Arduino Leonardo' dvi: Default installer: Enter 19:46:09.451 dvi: Default installer: Exit dvi: {DIF_ALLOW_INSTALL - exit(0xe000020e)} 19:46:09.453 dvi: {DIF_INSTALLDEVICE} 19:46:09.453 dvi: No class installer for 'Arduino Leonardo' dvi: Default installer: Enter 19:46:09.455 ! dvi: Installing NULL driver! dvi: Writing common driver property settings. dvi: {Restarting Devices} 19:46:09.513 dvi: Restart: USB\VID_2341&PID_8036&MI_00\7&26CA06B6&0&0000 dvi: Restart complete. dvi: {Restarting Devices exit} 19:46:09.551 dvi: Default installer: Exit dvi: {DIF_INSTALLDEVICE - exit(0x00000000)} 19:46:09.553 ndv: Device install status=0xe0000203 ndv: Performing device install final cleanup... ! ndv: Queueing up error report since device installation failed... ndv: {Core Device Install - exit(0xe0000203)} 19:46:09.556 ump: Server install process exited with code 0xe0000203 19:46:09.565 <<< Section end 2014/11/03 19:46:09.575 <<< [Exit status: FAILURE(0xe0000203)] >>> [Device Install (DiShowUpdateDevice) - USB\VID_2341&PID_8036&MI_00\7&26CA06B6&0&0000] >>> Section start 2014/11/03 19:52:07.944 cmd: "C:\Windows\system32\mmc.exe" C:\Windows\system32\devmgmt.msc dvi: {DIF_UPDATEDRIVER_UI} 19:52:07.946 dvi: No class installer for 'Arduino Leonardo' dvi: No CoInstallers found dvi: Default installer: Enter 19:52:07.950 dvi: Default installer: Exit dvi: {DIF_UPDATEDRIVER_UI - exit(0xe000020e)} 19:52:07.952 ndv: {Update Driver Software Wizard for USB\VID_2341&PID_8036&MI_00\7&26CA06B6&0&0000} inf: Opened INF: 'd:\电子diy\盒仔\表情\arduino-1.0.6-windows\arduino-1.0.6\drivers\old_arduino_drivers\arduino leonardo.inf' ([strings]) inf: {SetupCopyOEMInf: d:\电子diy\盒仔\表情\arduino-1.0.6-windows\arduino-1.0.6\drivers\old_arduino_drivers\arduino leonardo.inf} 19:52:11.582 sto: {Import Driver Package: d:\电子diy\盒仔\表情\arduino-1.0.6-windows\arduino-1.0.6\drivers\old_arduino_drivers\arduino leonardo.inf} 19:52:11.632 sto: Importing driver package into Driver Store: sto: Driver Store = C:\Windows\System32\DriverStore (Online | 6.1.7601) sto: Driver Package = d:\电子diy\盒仔\表情\arduino-1.0.6-windows\arduino-1.0.6\drivers\old_arduino_drivers\arduino leonardo.inf sto: Architecture = x86 sto: Locale Name = neutral sto: Flags = 0x00000000 sto: Copying driver package files to 'C:\temp\{6377919c-9089-4f09-96b7-1640d787da18}'. inf: Opened INF: 'd:\电子diy\盒仔\表情\arduino-1.0.6-windows\arduino-1.0.6\drivers\old_arduino_drivers\arduino leonardo.inf' ([strings]) ! inf: Could not find include INF file "layout.inf". Error = 0x00000002 ! inf: Unable to load INF: 'C:\Windows\System32\DriverStore\FileRepository\mdmcpq.inf_x86_neutral_9f203c20b6f0dabd\mdmcpq.inf'(00000003) ! inf: Error 3: The system cannot find the path specified. ! inf: Could not find include INF file "mdmcpq.inf". Error = 0x00000003 inf: Opened INF: 'd:\电子diy\盒仔\表情\arduino-1.0.6-windows\arduino-1.0.6\drivers\old_arduino_drivers\arduino leonardo.inf' ([strings]) flq: {FILE_QUEUE_COPY} flq: CopyStyle - 0x00000000 flq: SourceRootPath - 'd:\电子diy\盒仔\表情\arduino-1.0.6-windows\arduino-1.0.6\drivers\old_arduino_drivers' flq: SourceFilename - 'arduino leonardo.inf' flq: TargetDirectory- 'C:\temp\{6377919c-9089-4f09-96b7-1640d787da18}' flq: {FILE_QUEUE_COPY exit(0x00000000)} flq: {_commit_file_queue} flq: CommitQ DelNodes=0 RenNodes=0 CopyNodes=1 flq: {_commit_copy_subqueue} flq: subqueue count=1 flq: source media: flq: SourcePath - [d:\电子diy\盒仔\表情\arduino-1.0.6-windows\arduino-1.0.6\drivers\old_arduino_drivers] flq: SourceFile - [arduino leonardo.inf] flq: Flags - 0x00000000 flq: {_commit_copyfile} flq: CopyFile: 'd:\电子diy\盒仔\表情\arduino-1.0.6-windows\arduino-1.0.6\drivers\old_arduino_drivers\arduino leonardo.inf' flq: to: 'C:\temp\{6377919c-9089-4f09-96b7-1640d787da18}\SET3E19.tmp' flq: MoveFile: 'C:\temp\{6377919c-9089-4f09-96b7-1640d787da18}\SET3E19.tmp' flq: to: 'C:\temp\{6377919c-9089-4f09-96b7-1640d787da18}\arduino leonardo.inf' flq: {_commit_copyfile exit OK} flq: {_commit_copy_subqueue exit OK} flq: {_commit_file_queue exit OK} pol: {Driver package policy check} 19:52:12.052 pol: {Driver package policy check - exit(0x00000000)} 19:52:12.053 sto: {Stage Driver Package: C:\temp\{6377919c-9089-4f09-96b7-1640d787da18}\arduino leonardo.inf} 19:52:12.055 inf: Opened INF: 'C:\temp\{6377919c-9089-4f09-96b7-1640d787da18}\arduino leonardo.inf' ([strings]) ! inf: Could not find include INF file "layout.inf". Error = 0x00000002 ! inf: Unable to load INF: 'C:\Windows\System32\DriverStore\FileRepository\mdmcpq.inf_x86_neutral_9f203c20b6f0dabd\mdmcpq.inf'(00000003) ! inf: Error 3: The system cannot find the path specified. ! inf: Could not find include INF file "mdmcpq.inf". Error = 0x00000003 inf: Opened INF: 'C:\temp\{6377919c-9089-4f09-96b7-1640d787da18}\arduino leonardo.inf' ([strings]) sto: Copying driver package files: sto: Source Path = C:\temp\{6377919c-9089-4f09-96b7-1640d787da18} sto: Destination Path = C:\Windows\System32\DriverStore\Temp\{7c889485-ac51-0c57-b17b-be0f9f1af61e} flq: {FILE_QUEUE_COPY} flq: CopyStyle - 0x00000010 flq: SourceRootPath - 'C:\temp\{6377919c-9089-4f09-96b7-1640d787da18}' flq: SourceFilename - 'arduino leonardo.inf' flq: TargetDirectory- 'C:\Windows\System32\DriverStore\Temp\{7c889485-ac51-0c57-b17b-be0f9f1af61e}' flq: {FILE_QUEUE_COPY exit(0x00000000)} flq: {_commit_file_queue} flq: CommitQ DelNodes=0 RenNodes=0 CopyNodes=1 flq: {_commit_copy_subqueue} flq: subqueue count=1 flq: source media: flq: SourcePath - [C:\temp\{6377919c-9089-4f09-96b7-1640d787da18}] flq: SourceFile - [arduino leonardo.inf] flq: Flags - 0x00000000 flq: {_commit_copyfile} flq: CopyFile: 'C:\temp\{6377919c-9089-4f09-96b7-1640d787da18}\arduino leonardo.inf' flq: to: 'C:\Windows\System32\DriverStore\Temp\{7c889485-ac51-0c57-b17b-be0f9f1af61e}\SET3FAE.tmp' flq: MoveFile: 'C:\Windows\System32\DriverStore\Temp\{7c889485-ac51-0c57-b17b-be0f9f1af61e}\SET3FAE.tmp' flq: to: 'C:\Windows\System32\DriverStore\Temp\{7c889485-ac51-0c57-b17b-be0f9f1af61e}\arduino leonardo.inf' flq: {_commit_copyfile exit OK} flq: {_commit_copy_subqueue exit OK} flq: {_commit_file_queue exit OK} sto: {DRIVERSTORE_IMPORT_NOTIFY_VALIDATE} 19:52:12.135 ! sto: Driver package does not contain a catalog file, but user wants to install anyway. sto: {DRIVERSTORE_IMPORT_NOTIFY_VALIDATE exit(0x00000000)} 19:52:14.203 sto: Verified driver package signature: sto: Digital Signer Score = 0xFF000000 sto: Digital Signer Name = <unknown> sto: {DRIVERSTORE_IMPORT_NOTIFY_BEGIN} 19:52:14.206 ndv: System restore disabled by policy. Error = 0x000004EC sto: {DRIVERSTORE_IMPORT_NOTIFY_BEGIN: exit(0x00000000)} 19:52:14.207 sto: Importing driver package files: sto: Source Path = C:\Windows\System32\DriverStore\Temp\{7c889485-ac51-0c57-b17b-be0f9f1af61e} sto: Destination Path = C:\Windows\System32\DriverStore\FileRepository\arduino leonardo.inf_x86_neutral_52e105f17d85e9d9 sto: {Copy Directory: C:\Windows\System32\DriverStore\Temp\{7c889485-ac51-0c57-b17b-be0f9f1af61e}} 19:52:14.211 sto: Target Path = C:\Windows\System32\DriverStore\FileRepository\arduino leonardo.inf_x86_neutral_52e105f17d85e9d9 sto: {Copy Directory: exit(0x00000000)} 19:52:14.215 sto: {Index Driver Package: C:\Windows\System32\DriverStore\FileRepository\arduino leonardo.inf_x86_neutral_52e105f17d85e9d9\arduino leonardo.inf} 19:52:14.216 idb: Registered driver store entry 'arduino leonardo.inf_x86_neutral_52e105f17d85e9d9'. idb: Published 'arduino leonardo.inf_x86_neutral_52e105f17d85e9d9\arduino leonardo.inf' to 'C:\Windows\INF\oem32.inf' idb: Published driver store entry 'arduino leonardo.inf_x86_neutral_52e105f17d85e9d9'. sto: Published driver package INF 'oem32.inf' was changed. sto: Active published driver package is 'arduino leonardo.inf_x86_neutral_52e105f17d85e9d9'. sto: {Index Driver Package: exit(0x00000000)} 19:52:14.343 sto: {DRIVERSTORE_IMPORT_NOTIFY_END} 19:52:14.344 ndv: No system restore point was set earlier. sto: {DRIVERSTORE_IMPORT_NOTIFY_END: exit(0x00000000)} 19:52:14.346 sto: {Stage Driver Package: exit(0x00000000)} 19:52:14.349 ndv: Doing device matching lookup! inf: Opened INF: 'C:\Windows\System32\DriverStore\FileRepository\arduino leonardo.inf_x86_neutral_52e105f17d85e9d9\arduino leonardo.inf' ([strings]) inf: Saved PNF: 'C:\Windows\System32\DriverStore\FileRepository\arduino leonardo.inf_x86_neutral_52e105f17d85e9d9\arduino leonardo.PNF' (Language = 0804) ndv: Found device that matches new INF! ndv: Found device that matches new INF! ndv: Found device that matches new INF! sto: Driver package was staged to Driver Store. Time = 3011 ms sto: Imported driver package into Driver Store: sto: Filename = C:\Windows\System32\DriverStore\FileRepository\arduino leonardo.inf_x86_neutral_52e105f17d85e9d9\arduino leonardo.inf sto: Time = 3104 ms sto: {Import Driver Package: exit(0x00000000)} 19:52:14.748 inf: Opened INF: 'd:\电子diy\盒仔\表情\arduino-1.0.6-windows\arduino-1.0.6\drivers\old_arduino_drivers\arduino leonardo.inf' ([strings]) inf: Driver Store location: C:\Windows\System32\DriverStore\FileRepository\arduino leonardo.inf_x86_neutral_52e105f17d85e9d9\arduino leonardo.inf inf: Published Inf Path: C:\Windows\INF\oem32.inf inf: Opened INF: 'd:\电子diy\盒仔\表情\arduino-1.0.6-windows\arduino-1.0.6\drivers\old_arduino_drivers\arduino leonardo.inf' ([strings]) inf: Installing catalog CDC_vista.cat as: oem32.CAT ! inf: Failed to install catalog - error ignored ! inf: Error 2: The system cannot find the file specified. inf: OEM source media location: d:\电子diy\盒仔\表情\arduino-1.0.6-windows\arduino-1.0.6\drivers\old_arduino_drivers\ inf: {SetupCopyOEMInf exit (0x00000000)} 19:52:14.767 dvi: Searching for hardware ID(s): dvi: usb\vid_2341&pid_8036&rev_0100&mi_00 dvi: usb\vid_2341&pid_8036&mi_00 dvi: Searching for compatible ID(s): dvi: usb\class_02&subclass_02&prot_01 dvi: usb\class_02&subclass_02 dvi: usb\class_02 inf: Opened PNF: 'C:\Windows\System32\DriverStore\FileRepository\arduino leonardo.inf_x86_neutral_52e105f17d85e9d9\arduino leonardo.inf' ([strings]) sig: {_VERIFY_FILE_SIGNATURE} 19:52:14.778 sig: Key = arduino leonardo.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino leonardo.inf_x86_neutral_52e105f17d85e9d9\arduino leonardo.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino leonardo.inf_x86_neutral_52e105f17d85e9d9\CDC_vista.cat ! sig: Verifying file against specific (valid) catalog failed! (0x00000057) ! sig: Error 87: The parameter is incorrect. sig: {_VERIFY_FILE_SIGNATURE exit(0x00000057)} 19:52:14.783 sig: {_VERIFY_FILE_SIGNATURE} 19:52:14.784 sig: Key = arduino leonardo.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino leonardo.inf_x86_neutral_52e105f17d85e9d9\arduino leonardo.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino leonardo.inf_x86_neutral_52e105f17d85e9d9\CDC_vista.cat ! sig: Verifying file against specific Authenticode(tm) catalog failed! (0x80092003) ! sig: Error 0x80092003: An error occurred while reading or writing to a file. sig: {_VERIFY_FILE_SIGNATURE exit(0x80092003)} 19:52:14.788 dvi: Selected driver installs from section [DriverInstall] in 'c:\windows\system32\driverstore\filerepository\arduino leonardo.inf_x86_neutral_52e105f17d85e9d9\arduino leonardo.inf'. dvi: Class GUID of device changed to: {4d36e978-e325-11ce-bfc1-08002be10318}. dvi: Set selected driver complete. dvi: {Plug and Play Service: Device Install for USB\VID_2341&PID_8036&MI_00\7&26CA06B6&0&0000} ump: Creating Install Process: DrvInst.exe 19:52:14.809 ndv: Infpath=C:\Windows\INF\oem32.inf ndv: DriverNodeName=arduino leonardo.inf:DeviceList:DriverInstall:5.1.2600.0:usb\vid_2341&pid_8036&mi_00 ndv: DriverStorepath=C:\Windows\System32\DriverStore\FileRepository\arduino leonardo.inf_x86_neutral_52e105f17d85e9d9\arduino leonardo.inf ndv: Building driver list from driver node strong name... dvi: Searching for hardware ID(s): dvi: usb\vid_2341&pid_8036&rev_0100&mi_00 dvi: usb\vid_2341&pid_8036&mi_00 dvi: Searching for compatible ID(s): dvi: usb\class_02&subclass_02&prot_01 dvi: usb\class_02&subclass_02 dvi: usb\class_02 inf: Opened PNF: 'C:\Windows\System32\DriverStore\FileRepository\arduino leonardo.inf_x86_neutral_52e105f17d85e9d9\arduino leonardo.inf' ([strings]) sig: {_VERIFY_FILE_SIGNATURE} 19:52:14.932 sig: Key = arduino leonardo.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino leonardo.inf_x86_neutral_52e105f17d85e9d9\arduino leonardo.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino leonardo.inf_x86_neutral_52e105f17d85e9d9\CDC_vista.cat ! sig: Verifying file against specific (valid) catalog failed! (0x00000057) ! sig: Error 87: The parameter is incorrect. sig: {_VERIFY_FILE_SIGNATURE exit(0x00000057)} 19:52:14.955 sig: {_VERIFY_FILE_SIGNATURE} 19:52:14.955 sig: Key = arduino leonardo.inf sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino leonardo.inf_x86_neutral_52e105f17d85e9d9\arduino leonardo.inf sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino leonardo.inf_x86_neutral_52e105f17d85e9d9\CDC_vista.cat ! sig: Verifying file against specific Authenticode(tm) catalog failed! (0x80092003) ! sig: Error 0x80092003: An error occurred while reading or writing to a file. sig: {_VERIFY_FILE_SIGNATURE exit(0x80092003)} 19:52:14.960 dvi: Selected driver installs from section [DriverInstall] in 'c:\windows\system32\driverstore\filerepository\arduino leonardo.inf_x86_neutral_52e105f17d85e9d9\arduino leonardo.inf'. dvi: Class GUID of device changed to: {4d36e978-e325-11ce-bfc1-08002be10318}. dvi: Set selected driver complete. ndv: {Core Device Install} 19:52:14.965 inf: Opened INF: 'C:\Windows\INF\oem32.inf' ([strings]) inf: Saved PNF: 'C:\Windows\INF\oem32.PNF' (Language = 0804) dvi: {DIF_ALLOW_INSTALL} 19:52:14.998 dvi: Using exported function 'PortsClassInstaller' in module 'C:\Windows\system32\MsPorts.Dll'. dvi: Class installer == MsPorts.Dll,PortsClassInstaller dvi: No CoInstallers found dvi: Class installer: Enter 19:52:15.015 dvi: Class installer: Exit dvi: Default installer: Enter 19:52:15.016 dvi: Default installer: Exit dvi: {DIF_ALLOW_INSTALL - exit(0xe000020e)} 19:52:15.018 ndv: Installing files... dvi: {DIF_INSTALLDEVICEFILES} 19:52:15.039 dvi: Class installer: Enter 19:52:15.039 dvi: Class installer: Exit dvi: Default installer: Enter 19:52:15.041 dvi: {Install FILES} inf: Opened PNF: 'c:\windows\system32\driverstore\filerepository\arduino leonardo.inf_x86_neutral_52e105f17d85e9d9\arduino leonardo.inf' ([strings]) inf: {Install Inf Section [DriverInstall.NT]} inf: CopyFiles=DriverCopyFiles.nt (arduino leonardo.inf line 28) cpy: Open PnpLockdownPolicy: Err=2. This is OK. Use LockDownPolicyDefault flq: QueueSingleCopy... flq: Inf : 'c:\windows\system32\driverstore\filerepository\arduino leonardo.inf_x86_neutral_52e105f17d85e9d9\arduino leonardo.inf' ! flq: Missing SourceDisksFiles/SourceDisksNames information from INF. ! flq: Default INBOX source locations pulled from pre-built DrvIndex flq: SourceRootPath: 'C:\Windows\System32\DriverStore\FileRepository\mdmcpq.inf_x86_neutral_9f203c20b6f0dabd' flq: {FILE_QUEUE_COPY} flq: CopyStyle - 0x00002000 flq: {FILE_QUEUE_COPY} flq: CopyStyle - 0x00002000 flq: SourceRootPath - 'C:\Windows\System32\DriverStore\FileRepository\mdmcpq.inf_x86_neutral_9f203c20b6f0dabd' flq: SourcePath - '\' flq: SourceFilename - 'usbser.sys' flq: TargetDirectory- 'C:\Windows\system32\DRIVERS' flq: TargetFilename - 'usbser.sys' flq: {FILE_QUEUE_COPY exit(0x00000000)} flq: {FILE_QUEUE_COPY exit(0x00000000)} inf: {Install Inf Section [DriverInstall.NT] exit (0x00000000)} dvi: Processing co-installer registration section [DriverInstall.NT.CoInstallers]. inf: {Install Inf Section [DriverInstall.NT.CoInstallers]} inf: {Install Inf Section [DriverInstall.NT.CoInstallers] exit (0x00000000)} dvi: Co-installers registered. dvi: {Install INTERFACES} dvi: Installing section [DriverInstall.NT.Interfaces] dvi: {Install INTERFACES exit 00000000} dvi: {Install FILES exit (0x00000000)} dvi: Default installer: Exit dvi: {DIF_INSTALLDEVICEFILES - exit(0x00000000)} 19:52:15.085 ndv: Pruning file queue... dvi: {_SCAN_FILE_QUEUE} flq: ScanQ flags=620 flq: SPQ_SCAN_PRUNE_COPY_QUEUE flq: SPQ_SCAN_FILE_COMPARISON flq: SPQ_SCAN_ACTIVATE_DRP flq: ScanQ number of copy nodes=1 ! sig: GetNameSDInfo ! sig: Error 0: The operation completed successfully. flq: ScanQ action=200 DoPruning=32 flq: ScanQ end Validity flags=620 CopyNodes=1 dvi: {_SCAN_FILE_QUEUE exit(0, 0x00000000)} ndv: Committing file queue... flq: {_commit_file_queue} flq: CommitQ DelNodes=0 RenNodes=0 CopyNodes=1 flq: {SPFILENOTIFY_STARTQUEUE} flq: {SPFILENOTIFY_STARTQUEUE - exit(0x00000001)} flq: {_commit_copy_subqueue} flq: subqueue count=1 flq: {SPFILENOTIFY_STARTSUBQUEUE} flq: {SPFILENOTIFY_STARTSUBQUEUE - exit(0x00000001)} flq: source media: flq: SourcePath - [C:\Windows\System32\DriverStore\FileRepository\mdmcpq.inf_x86_neutral_9f203c20b6f0dabd] flq: SourceFile - [usbser.sys] flq: Flags - 0x00000000 flq: {SPFQNOTIFY_NEEDMEDIA} flq: {SPFILENOTIFY_NEEDMEDIA} flq: {SPFILENOTIFY_NEEDMEDIA - exit(0x00000000)} flq: {SPFQNOTIFY_NEEDMEDIA - returned 0x00000000} !!! flq: source media: SPFQOPERATION_ABORT. !!! flq: Error 2: The system cannot find the file specified. flq: {_commit_copy_subqueue exit(0x00000002)} !!! flq: FileQueueCommit aborting! !!! flq: Error 2: The system cannot find the file specified. flq: {SPFILENOTIFY_ENDQUEUE} flq: {SPFILENOTIFY_ENDQUEUE - exit(0x00000001)} flq: {_commit_file_queue exit(0x00000002)} ndv: Device install status=0x00000002 ndv: Performing device install final cleanup... ! ndv: Queueing up error report since device installation failed... ndv: {Core Device Install - exit(0x00000002)} 19:52:15.116 dvi: {DIF_DESTROYPRIVATEDATA} 19:52:15.117 dvi: Class installer: Enter 19:52:15.118 dvi: Class installer: Exit dvi: Default installer: Enter 19:52:15.119 dvi: Default installer: Exit dvi: {DIF_DESTROYPRIVATEDATA - exit(0xe000020e)} 19:52:15.120 ump: Server install process exited with code 0x00000002 19:52:15.125 ump: {Plug and Play Service: Device Install exit(00000002)} ndv: Device Install failed for new device...installing NULL driver. dvi: {Plug and Play Service: Device Install for USB\VID_2341&PID_8036&MI_00\7&26CA06B6&0&0000} ump: Creating Install Process: DrvInst.exe 19:52:15.150 ! ndv: Installing NULL driver! dvi: Set selected driver complete. dvi: {DIF_ALLOW_INSTALL} 19:52:15.200 dvi: No class installer for 'Arduino Leonardo' dvi: No CoInstallers found dvi: Default installer: Enter 19:52:15.202 dvi: Default installer: Exit dvi: {DIF_ALLOW_INSTALL - exit(0xe000020e)} 19:52:15.204 dvi: {DIF_INSTALLDEVICE} 19:52:15.204 dvi: No class installer for 'Arduino Leonardo' dvi: Default installer: Enter 19:52:15.206 ! dvi: Installing NULL driver! dvi: Writing common driver property settings. dvi: {Restarting Devices} 19:52:15.237 dvi: Restart: USB\VID_2341&PID_8036&MI_00\7&26CA06B6&0&0000 dvi: Restart complete. dvi: {Restarting Devices exit} 19:52:15.283 dvi: Default installer: Exit dvi: {DIF_INSTALLDEVICE - exit(0x00000000)} 19:52:15.286 ump: Server install process exited with code 0x00000000 19:52:15.292 ump: {Plug and Play Service: Device Install exit(00000000)} ndv: {Update Driver Software Wizard exit(00000002)} <<< Section end 2014/11/03 20:00:46.068 <<< [Exit status: FAILURE(0x00000002)] |
典型的精简版系统,所以肯定安装失败! 精简版、GHOST版win7,arduino驱动安装失败的解决方法 将mdmcpq.inf复制到c:\windows\inf 将usbser.sys复制到c:\windows\system32\drivers 详见: http://www.arduino.cn/forum.php?mod=viewthread&tid=2350 参考: https://mc.dfrobot.com.cn/forum. ... &extra=page%3D1 |
Youyou 发表于 2014-11-3 23:21 http://www.arduino.cn/forum.php?mod=viewthread&tid=2350 他说的我试过 可能是因为他提供的是64位吧,另外的那个网址貌似瘫痪了:'( |
