bobo | NPC | 创造力: | 帖子: | 发消息 | 串个门 | 加好友 | 打招呼
2014-10-29 11:38:54 [显示全部楼层]
6313浏览
查看: 6313|回复: 2
[已解决] 台湾客户对TEL0051 测试的问题
我是用這塊板子,要如何才能達到直接撥出的功能
// Product name: GPS/GPRS/GSM Module V3.0
// # Product SKU : TEL0051
// # Version     : 0.1
// # Description:
// # The sketch for driving the gsm mode via the Arduino board
// # Steps:
// #        1. Turn the S1 switch to the Prog(right side)
// #        2. Turn the S2 switch to the Arduino side(left side)
// #        3. Set the UART select switch to middle one.
// #        4. Upload the sketch to the Arduino board
// #        5. Turn the S1 switch to the comm(left side)
// #        6. Plug the jumper caps back to GSM side
// #        7. RST the board
byte gsmDriverPin[3] = {
  3,4,5};//The default digital driver pins for the GSM and GPS mode
//If you want to change the digital driver pins
//or you have a conflict with D3~D5 on Arduino board,
//you can remove the J10~J12 jumpers to reconnect other driver pins for the module!
void setup()
//Init the driver pins for GSM function
  for(int i = 0 ; i < 3; i++){
    pinMode(gsmDriverPin,OUTPUT);
  digitalWrite(5,HIGH);//Output GSM Timing
  delay(1500);
  digitalWrite(5,LOW);
  digitalWrite(3,LOW);//Enable the GSM mode
  digitalWrite(4,HIGH);//Disable the GPS mode
  delay(2000);
  Serial.begin(9600); //set the baud rate
  delay(5000);//call ready
  delay(5000);
  delay(5000);
void loop()
   Serial.println("AT");//Send AT command
   delay(2000);
   delay(2000);
  //Make a phone call
   Serial.println("ATD15902808530;");//Change the receiver phone number
   while(1);
bobo  NPC
发表于 2014-10-29 11:41:44
void setup()
   pinMode(3,OUTPUT);
   pinMode(4,OUTPUT);
   pinMode(5,OUTPUT);
   delay(1500);
void loop()
內置圖片 2
我現在可以打電話和傳簡訊的功能,但是需要在COM中輸入AT等待同步在輸入ATD"XXX"(XXX是目的輸入號碼)
問題:我想要讓Arduino接收到觸發訊號,不需要再經由鍵盤輸入電話號碼,然後直接撥打預設的電話號碼
使用產品資料庫的打電話程式無法撥出
內置圖片 5
內置圖片 4
執行結果沒有OK,電話也沒有撥出
最後
你的產品資料庫網址有問題
正確
http://www.dfrobot.com/wiki/index.php/GPS/GPRS/GSM_Module_V3.0_(SKU:TEL0051)
錯誤
https://wiki.dfrobot.com.cn/index.php/(SKU:TEL0051)GPS/GPRS/GSM_%E6%89%A9%E5%B1%95%E6%9D%BF_V3.0
Eric  初级技神
发表于 2014-10-30 12:11:19
  1. byte gsmDriverPin[3] = {3,4,5};//The default digital driver pins for the GSM and GPS mode
  2. //If you want to change the digital driver pins
  3. //or you have a conflict with D3~D5 on Arduino board,
  4. //you can remove the J10~J12 jumpers to reconnect other driver pins for the module!
  5. void setup()
  6. {
  7. //Init the driver pins for GSM function
  8.   for(int i = 0 ; i < 3; i++){
  9.     pinMode(gsmDriverPin[i],OUTPUT);
  10.   }
  11.   digitalWrite(5,HIGH);//Output GSM Timing
  12.   delay(1500);
  13.   digitalWrite(5,LOW);
  14.   digitalWrite(3,LOW);//Enable the GSM mode
  15.   digitalWrite(4,HIGH);//Disable the GPS mode
  16.   delay(2000);
  17.   Serial.begin(9600); //set the baud rate
  18.   delay(5000);//call ready
  19.   delay(5000);
  20.   delay(5000);
  21. }
  22.
  23. void loop()
  24. {
  25.    Serial.println("AT");//Send AT command
  26.    delay(2000);
  27.    Serial.println("AT");
  28.    delay(2000);
  29.   //Make a phone call
  30.    Serial.println("ATD13564078965;");//Change the receiver phone number
  31.    while(1);
  32. }
程序需要修改一下,有一点点错误,我已经改好,可以编译通过。在下载程序时,扩展板接到主控板UNO,SIM卡、麦克、耳机插好。
USB线、外接电源接好。扩展板S1开关拨到Prog端,下载下面程序。将S1开关拨到Comm,S2开关拨到Arduino,Uart Select的拨码开关拨到中间位置,如果没有启动可以按下RST复位键,重新开启。
高级模式
