634浏览
查看: 634|回复: 6
[项目] 【花雕学编程】Arduino动手做(249)--GC9A01模拟三色圆饼图
【花雕学编程】Arduino动手做(249)--GC9A01模拟三色圆饼图图2
【花雕学编程】Arduino动手做(249)--GC9A01模拟三色圆饼图图1
发表于 2025-4-14 15:57:40
发表于 2025-4-14 16:00:09
发表于 2025-4-14 16:01:38
  项目之八十九:GC9A01园屏之动态模拟三色百分比圆饼图
  1. /*
  4.   项目之八十九:GC9A01园屏之动态模拟三色百分比圆饼图
  5. */
  14. #include "SPI.h"
  15. #include "Adafruit_GFX.h"
  17. #include "math.h"
  18. #define TFT_CS 4
  19. #define TFT_DC 2
  20. #define TFT_RST -1
  21. Adafruit_GC9A01A tft = Adafruit_GC9A01A(TFT_CS, TFT_DC, TFT_RST);
  22. #define SCREEN_WIDTH 240
  23. #define SCREEN_HEIGHT 240
  24. #define CENTER_X SCREEN_WIDTH / 2
  25. #define CENTER_Y SCREEN_HEIGHT / 2
  26. #define RADIUS 80  // **饼图半径**
  27. #define SPEED 5  // **数据变化速度**
  28. int data1 = 40;  // **数据块 1**
  29. int data2 = 30;  // **数据块 2**
  30. int data3 = 30;  // **数据块 3**
  31. void drawSector(int startAngle, int endAngle, uint16_t color) {
  32.     for (int angle = startAngle; angle < endAngle; angle += 3) {
  33.         float radian1 = angle * M_PI / 180;
  34.         float radian2 = (angle + 3) * M_PI / 180;
  35.         int x1 = CENTER_X + RADIUS * cos(radian1);
  36.         int y1 = CENTER_Y + RADIUS * sin(radian1);
  37.         int x2 = CENTER_X + RADIUS * cos(radian2);
  38.         int y2 = CENTER_Y + RADIUS * sin(radian2);
  39.         tft.fillTriangle(CENTER_X, CENTER_Y, x1, y1, x2, y2, color);
  40.     }
  41. }
  42. void setup() {
  43.     Serial.begin(115200);
  44.     tft.begin();
  45.     tft.setRotation(2);
  46. }
  47. void loop() {
  48.     tft.fillScreen(tft.color565(0, 0, 0));
  49.     int total = data1 + data2 + data3;
  50.     int angle1 = (data1 * 360) / total;
  51.     int angle2 = (data2 * 360) / total;
  52.     int angle3 = (data3 * 360) / total;
  53.     drawSector(0, angle1, tft.color565(255, 0, 0));  // **红色数据块**
  54.     drawSector(angle1, angle1 + angle2, tft.color565(0, 255, 0));  // **绿色数据块**
  55.     drawSector(angle1 + angle2, 360, tft.color565(0, 0, 255));  // **蓝色数据块**
  56.     // **显示数值**
  57.     tft.setTextColor(tft.color565(255, 255, 255));
  58.     tft.setTextSize(2);
  59.     tft.setCursor(CENTER_X - 30, CENTER_Y - 80);
  60.     tft.print((data1 * 100) / total);
  61.     tft.print("%");
  62.     tft.setCursor(CENTER_X - 80, CENTER_Y + 20);
  63.     tft.print((data2 * 100) / total);
  64.     tft.print("%");
  65.     tft.setCursor(CENTER_X + 40, CENTER_Y + 20);
  66.     tft.print((data3 * 100) / total);
  67.     tft.print("%");
  68.     // **更新数据**
  69.     data1 = random(20, 50);
  70.     data2 = random(20, 50);
  71.     data3 = random(20, 50);
  72.     delay(2000);
  73. }
发表于 2025-4-14 16:03:07
这段代码的核心功能是 动态圆饼图,它会根据数据变化调整不同颜色的扇形区域,同时在图表上 显示百分比数值,形成动态的可视化效果。
代码结构
1️⃣ 初始化屏幕
• 使用 Adafruit_GC9A01A 控制 TFT 显示屏,并设置黑色背景。
2️⃣ 绘制圆饼图扇形区域
• 使用 drawSector() 方法,利用 fillTriangle() 绘制 多个扇形块,形成完整的饼图。
• 通过 cos() 和 sin() 计算扇形角度,确保图形正确绘制。
3️⃣ 显示数值百分比
• print() 方法在每个扇形内显示 对应百分比数值,提高数据可视化效果。
4️⃣ 动态更新数据
• 每次循环 数据随机变化,影响扇形大小,使饼图不断更新。
• delay(2000); 让数据变化有明显视觉效果,并保持平滑动画。
最终效果
屏幕上显示红、绿、蓝三色圆饼图,不断变化,模拟动态数据更新
百分比实时显示,使数据更直观易懂
黑色背景 + 三色扇形块 + 白色数值,提高视觉清晰度
发表于 2025-4-14 16:06:29
实验场景图  动态图
发表于 2025-4-14 16:12:51
