709浏览
查看: 709|回复: 6
[项目] 【花雕学编程】Arduino动手做(249)--GC9A01半环温度进度条
【花雕学编程】Arduino动手做(249)--GC9A01半环温度进度条图2
【花雕学编程】Arduino动手做(249)--GC9A01半环温度进度条图1
发表于 2025-4-14 09:42:56
发表于 2025-4-14 09:44:31
发表于 2025-4-14 09:46:25
  项目之八十七:GC9A01园屏之半圆环温度进度条
  1. /*
  4.   项目之八十七:GC9A01园屏之半圆环温度进度条
  5. */
  14. #include "SPI.h"
  15. #include "Adafruit_GFX.h"
  17. #include "math.h"
  18. #define TFT_CS 4
  19. #define TFT_DC 2
  20. #define TFT_RST -1
  21. Adafruit_GC9A01A tft = Adafruit_GC9A01A(TFT_CS, TFT_DC, TFT_RST);
  22. #define SCREEN_WIDTH 240
  23. #define SCREEN_HEIGHT 240
  24. #define CENTER_X SCREEN_WIDTH / 2
  25. #define CENTER_Y SCREEN_HEIGHT - 20  // **进度条底部中心**
  26. #define RADIUS 100  // **半圆进度条半径**
  27. #define SPEED 2  // **温度变化速度**
  28. #define MAX_TEMP 100  // **最大温度(对应半圆填充 100%)**
  29. int temperature = 0;
  30. void setup() {
  31.     Serial.begin(115200);
  32.     tft.begin();
  33.     tft.setRotation(2);
  34. }
  35. void loop() {
  36.     tft.fillScreen(tft.color565(0, 0, 0));
  37.     // **绘制半圆外框**
  38.     for (int angle = 0; angle <= 180; angle += 5) {
  39.         float radian = angle * M_PI / 180;
  40.         int x1 = CENTER_X + RADIUS * cos(radian);
  41.         int y1 = CENTER_Y - RADIUS * sin(radian);
  42.         int x2 = CENTER_X + (RADIUS - 5) * cos(radian);
  43.         int y2 = CENTER_Y - (RADIUS - 5) * sin(radian);
  44.         tft.drawLine(x1, y1, x2, y2, tft.color565(255, 255, 255));  // **模拟半圆外框**
  45.     }
  46.     // **计算填充进度**
  47.     int progressAngle = (temperature * 180) / MAX_TEMP;  // **转换成角度**
  48.
  49.     for (int angle = 0; angle < progressAngle; angle += 5) {
  50.         float radian = angle * M_PI / 180;
  51.         int x1 = CENTER_X + RADIUS * cos(radian);
  52.         int y1 = CENTER_Y - RADIUS * sin(radian);
  53.         int x2 = CENTER_X + (RADIUS - 5) * cos(radian);
  54.         int y2 = CENTER_Y - (RADIUS - 5) * sin(radian);
  55.         tft.drawLine(x1, y1, x2, y2, tft.color565(255, 0, 0));  // **填充红色温度进度**
  56.     }
  57.     // **显示温度百分比**
  58.     tft.setTextColor(tft.color565(255, 255, 255));
  59.     tft.setTextSize(2);
  60.     tft.setCursor(CENTER_X - 20, CENTER_Y - RADIUS - 20);
  61.     tft.print((temperature * 100) / MAX_TEMP);
  62.     tft.print("%");
  63.     // **更新温度进度**
  64.     temperature += SPEED;
  65.     if (temperature >= MAX_TEMP) {
  66.         temperature = 0;
  67.     }
  68.     delay(100);
  69. }
发表于 2025-4-14 09:49:01
这段代码的核心功能是 模拟半圆形温度进度条,通过动态填充红色区域,并实时显示顶部百分比,直观反映温度的变化过程。以下是简要解读:
代码结构1️⃣ 初始化屏幕
  • 使用 Adafruit_GC9A01A 控制 TFT 显示屏,设置黑色背景和旋转方向。
2️⃣ 绘制半圆外框
  • 使用循环和 drawLine() 方法绘制 由多条短线段拼接成的半圆,模拟外框。
3️⃣ 动态填充进度条
  • 根据当前温度计算填充角度,并通过 drawLine() 将红色短线段逐步填充在半圆内,形成进度效果。
4️⃣ 实时显示百分比
  • 通过计算 (temperature * 100) / MAX_TEMP,将温度的百分比显示在半圆顶部。
5️⃣ 更新温度进度
  • 每次循环温度增加 SPEED,在达到最大值后重置为 0,形成循环动画。
最终效果半圆形温度进度条动态增长,模拟温度变化过程
顶部显示实时百分比,信息清晰直观
黑色背景 + 白色边框 + 红色填充 + 白色百分比,界面对比鲜明
发表于 2025-4-14 09:57:25
实验场景图  动态图
发表于 2025-4-14 09:59:49
