660浏览
查看: 660|回复: 8
[项目] 【花雕学编程】Arduino动手做(249)--GC9A01屏增强版万花筒
【花雕学编程】Arduino动手做(249)--GC9A01屏增强版万花筒图1
【花雕学编程】Arduino动手做(249)--GC9A01屏增强版万花筒图2
发表于 2025-4-8 21:09:47
发表于 2025-4-8 21:17:26
发表于 2025-4-8 21:19:48
【花雕学编程】Arduino动手做(249)--GC9A01屏增强版万花筒图3
发表于 2025-4-8 21:21:38
  项目之四十二:GC9A01屏之带渐变效果的增强版万花筒
  1. /*
  4.   项目之四十二:GC9A01屏之带渐变效果的增强版万花筒
  5. */
  14. #include "SPI.h"
  15. #include "Adafruit_GFX.h"
  17. // 定义屏幕引脚
  18. #define TFT_CS 4        // 片选引脚
  19. #define TFT_DC 2        // 数据/命令引脚
  20. #define TFT_RST -1      // 重置引脚(未使用时设置为 -1)
  21. // 初始化屏幕对象
  22. Adafruit_GC9A01A tft = Adafruit_GC9A01A(TFT_CS, TFT_DC, TFT_RST);
  23. // 定义屏幕中心
  24. #define CENTER_X (tft.width() / 2)
  25. #define CENTER_Y (tft.height() / 2)
  26. #define FRAME_DELAY 30    // 帧延迟
  27. #define NUM_SECTORS 8     // 扇区数量(万花筒对称数量)
  28. #define MAX_RADIUS 120    // 图案最大半径
  29. #define ROTATION_SPEED 5  // 每帧旋转的角度(度)
  30. // 定义颜色渐变范围
  31. #define COLOR_START GC9A01A_BLUE
  32. #define COLOR_END GC9A01A_MAGENTA
  33. // 颜色插值函数,用于生成渐变效果
  34. uint16_t interpolateColor(uint16_t color1, uint16_t color2, float fraction) {
  35.     uint8_t r1 = (color1 >> 11) & 0x1F;
  36.     uint8_t g1 = (color1 >> 5) & 0x3F;
  37.     uint8_t b1 = color1 & 0x1F;
  38.     uint8_t r2 = (color2 >> 11) & 0x1F;
  39.     uint8_t g2 = (color2 >> 5) & 0x3F;
  40.     uint8_t b2 = color2 & 0x1F;
  41.     uint8_t r = r1 + fraction * (r2 - r1);
  42.     uint8_t g = g1 + fraction * (g2 - g1);
  43.     uint8_t b = b1 + fraction * (b2 - b1);
  44.     return (r << 11) | (g << 5) | b;
  45. }
  46. // 绘制多边形
  47. void drawPolygon(int centerX, int centerY, int radius, int sides, float rotationAngle, uint16_t color) {
  48.     float angleStep = 2 * 3.14159 / sides;
  49.     int prevX = centerX + radius * cos(rotationAngle);
  50.     int prevY = centerY + radius * sin(rotationAngle);
  51.     for (int i = 1; i <= sides; i++) {
  52.         float angle = rotationAngle + i * angleStep;
  53.         int x = centerX + radius * cos(angle);
  54.         int y = centerY + radius * sin(angle);
  55.         tft.drawLine(prevX, prevY, x, y, color);
  56.         prevX = x;
  57.         prevY = y;
  58.     }
  59. }
  60. // 绘制万花筒扇区
  61. void drawKaleidoscopePattern(float rotationAngle) {
  62.     for (int sector = 0; sector < NUM_SECTORS; sector++) {
  63.         float angle = sector * (360.0 / NUM_SECTORS) + rotationAngle;
  64.         float radians = angle * 3.14159 / 180;
  65.         for (int radius = 10; radius <= MAX_RADIUS; radius += 10) {
  66.             float fraction = (float)(radius - 10) / (MAX_RADIUS - 10);
  67.             uint16_t color = interpolateColor(COLOR_START, COLOR_END, fraction);
  68.             int x = CENTER_X + cos(radians) * radius;
  69.             int y = CENTER_Y + sin(radians) * radius;
  70.             drawPolygon(x, y, radius / 2, 6, radians, color); // 绘制六边形
  71.         }
  72.     }
  73. }
  74. void setup() {
  75.     Serial.begin(115200);          // 初始化串口
  76.     Serial.println("Enhanced Kaleidoscope");
  77.     tft.begin();                   // 初始化屏幕
  78.     tft.setRotation(0);            // 设置屏幕方向
  79.     tft.fillScreen(GC9A01A_BLACK); // 设置黑色背景
  80. }
  81. void loop() {
  82.     static float rotationAngle = 0; // 初始化旋转角度
  83.     // 清屏
  84.     tft.fillScreen(GC9A01A_BLACK);
  85.     // 绘制动态万花筒图案
  86.     drawKaleidoscopePattern(rotationAngle);
  87.     // 更新旋转角度,制造动态效果
  88.     rotationAngle = fmod(rotationAngle + ROTATION_SPEED, 360.0);
  89.     delay(FRAME_DELAY); // 控制帧速率
  90. }
发表于 2025-4-8 21:23:45
代码解读
1. 渐变颜色
新增了 interpolateColor() 函数,通过插值计算两个颜色之间的过渡值,生成自然的渐变效果。
每个半径层使用渐变颜色,越靠近中心颜色越接近 COLOR_START,越接近外圈颜色越接近 COLOR_END。
2. 扩展图形复杂性
将简单的圆形替换为多边形,通过 drawPolygon() 函数动态绘制六边形(或其他多边形),使图案更加丰富。
可轻松调整 sides 参数绘制不同边数的多边形(如三角形、五边形、十边形等)。
3. 动态增强
图案随着旋转角度动态变化,同时每个半径层的颜色和大小均不断更新,增加了多层次动态效果。
4. 效果
渐变颜色:图案从中心到外圈呈现平滑的渐变过渡。
多边形几何图案:六边形为主的复杂图形,多层次叠加。
动态旋转和变化:图案整体旋转,同时每层颜色、形状不断更新。
发表于 2025-4-8 21:25:33
实验场景图  动态图
发表于 2025-4-8 21:30:34
发表于 2025-4-9 10:24:15
万花筒效果
  • 通过重复对称图案来模拟万花筒的视觉效果,随着时间旋转和变换。
  • 关键点:将画布划分为多个扇区,镜像每个扇区的内容。
  1. int x1 = CENTER_X + r * cos(theta);
  2. int y1 = CENTER_Y + r * sin(theta);
  3. tft.drawPixel(x1, y1, color);
  4. // 复制到其他对称位置
