9851浏览
查看: 9851|回复: 0
[黑科技] BPI-M5 Pro RK3576 强大的边缘计算盒子
BPI-M5 Pro RK3576 强大的边缘计算盒子图3
Overview
Banana Pi BPI-M5 Pro (Armsom Sige5) adopts the second-generation 8nm high-performance AIOT platform Rockchip RK3576, with a 6 TOPS computing power NPU and support for up to 16GB of large memory. It supports 4K video encoding and decoding, offers rich interfaces including dual gigabit Ethernet ports, WiFi 6 & BT5, and various video outputs. Compatible with multiple operating systems, it is suitable for ARM-based PCs, edge computing devices, personal mobile internet devices, and other digital multimedia applications.
BPI-M5 Pro RK3576 强大的边缘计算盒子图1BPI-M5 Pro RK3576 强大的边缘计算盒子图2
Key Parameter
  • SoC: Rockchip RK3576
  • CPU: Integrated with four Cortex-A72 cores @ 2.2GHz and four Cortex-A53 cores @ 1.8GHz, along with a separate NEON co-processor.
  • GPU: ARM Mali G52 MC3 GPU
  • NPU: Up to 6 TOPs computing power (INT8), supports INT4/INT8/INT16 mixed operations.
  • VPU/Encoding & Decoding:
    • Hardware Decoding: Supports H.264, H.265, VP9, AV1, and AVS2 up to 8K@30fps or 4K@120fps.
    • Hardware Encoding: Supports H.264 and H.265 up to 4K@60fps, high-quality JPEG encoder/decoder supports up to 4K@60fps.
  • RAM: 8/16GB 32-bit LPDDR4x, default is 16GB. RK3576 supports a maximum of 16GB.
  • Flash: 32/128GB eMMC, default is 128GB eMMC.
  • Operating Voltage: Wide input voltage range, from 4.5V to 23V (voltage error ±5%).
  • Operating Temperature: 0°C to 80°C
  • Operating Systems:
    • Official Rockchip Support: Android 14, Debian 11, Buildroot
    • Third-party Support: Armbian
  • PCB: 8-layer PCB board design
  • Weight: 43g
  • Dimensions: 92mm × 62mm
    BPI-M5 Pro RK3576 强大的边缘计算盒子图4
