1068| 2
[ESP8266/ESP32] esp32 |
有不有好心人帮我看看,我已经打包上传了,报错的我实在看不懂 In file included from c:\Users\Lenovo\Documents\Arduino\libraries\ESP32-A2DP-main\src\BluetoothA2DPSinkQueued.h:3, from c:\Users\Lenovo\Documents\Arduino\libraries\ESP32-A2DP-main\src\BluetoothA2DPSinkQueued.cpp:2: c:\Users\Lenovo\Documents\Arduino\libraries\ESP32-A2DP-main\src\BluetoothA2DPSink.h: In member function 'virtual void BluetoothA2DPSink::set_avrc_rn_play_pos_callback(void (*)(uint32_t), uint32_t)': c:\Users\Lenovo\Documents\Arduino\libraries\ESP32-A2DP-main\src\BluetoothA2DPSink.h:233:30: error: 'max' was not declared in this scope 233 | this->notif_interval_s = max(notif_interval,(uint32_t)1); | ^~~ c:\Users\Lenovo\Documents\Arduino\libraries\ESP32-A2DP-main\src\BluetoothA2DPSink.h:233:30: note: suggested alternatives: In file included from c:\users\lenovo\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-12.2.0_20230208\xtensa-esp32-elf\include\c++\12.2.0\algorithm:61, from c:\Users\Lenovo\Documents\Arduino\libraries\ESP32-A2DP-main\src\SoundData.h:19, from c:\Users\Lenovo\Documents\Arduino\libraries\ESP32-A2DP-main\src\BluetoothA2DPCommon.h:58, from c:\Users\Lenovo\Documents\Arduino\libraries\ESP32-A2DP-main\src\BluetoothA2DPSink.h:17: c:\users\lenovo\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-12.2.0_20230208\xtensa-esp32-elf\include\c++\12.2.0\bits\stl_algo.h:5756:5: note: 'std::max' 5756 | max(initializer_list<_Tp> __l, _Compare __comp) | ^~~ In file included from c:\users\lenovo\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-12.2.0_20230208\xtensa-esp32-elf\include\c++\12.2.0\algorithm:63: c:\users\lenovo\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-12.2.0_20230208\xtensa-esp32-elf\include\c++\12.2.0\bits\ranges_algo.h:3011:29: note: 'std::ranges::max' 3011 | inline constexpr __max_fn max{}; | ^~~ In file included from c:\Users\Lenovo\Documents\Arduino\libraries\ESP32-A2DP-main\src\BluetoothA2DPSink.cpp:16: c:\Users\Lenovo\Documents\Arduino\libraries\ESP32-A2DP-main\src\BluetoothA2DPSink.h: In member function 'virtual void BluetoothA2DPSink::set_avrc_rn_play_pos_callback(void (*)(uint32_t), uint32_t)': c:\Users\Lenovo\Documents\Arduino\libraries\ESP32-A2DP-main\src\BluetoothA2DPSink.h:233:30: error: 'max' was not declared in this scope 233 | this->notif_interval_s = max(notif_interval,(uint32_t)1); | ^~~ c:\Users\Lenovo\Documents\Arduino\libraries\ESP32-A2DP-main\src\BluetoothA2DPSink.h:233:30: note: suggested alternatives: In file included from c:\users\lenovo\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-12.2.0_20230208\xtensa-esp32-elf\include\c++\12.2.0\algorithm:61, from c:\Users\Lenovo\Documents\Arduino\libraries\ESP32-A2DP-main\src\SoundData.h:19, from c:\Users\Lenovo\Documents\Arduino\libraries\ESP32-A2DP-main\src\BluetoothA2DPCommon.h:58, from c:\Users\Lenovo\Documents\Arduino\libraries\ESP32-A2DP-main\src\BluetoothA2DPSink.h:17: c:\users\lenovo\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-12.2.0_20230208\xtensa-esp32-elf\include\c++\12.2.0\bits\stl_algo.h:5756:5: note: 'std::max' 5756 | max(initializer_list<_Tp> __l, _Compare __comp) | ^~~ In file included from c:\users\lenovo\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-12.2.0_20230208\xtensa-esp32-elf\include\c++\12.2.0\algorithm:63: c:\users\lenovo\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-12.2.0_20230208\xtensa-esp32-elf\include\c++\12.2.0\bits\ranges_algo.h:3011:29: note: 'std::ranges::max' 3011 | inline constexpr __max_fn max{}; | ^~~ exit status 1 Compilation error: exit status 1 |
397 Bytes, 下载次数: 2368
