[求助]求助大佬
2024-4-25 19:13:15 [显示全部楼层]
2015浏览
查看: 2015|回复: 2
[求助] 求助大佬
tcs230颜色识别器识别颜色,接的Arduino uno板上传代码时出现这种情况,不知道该怎么处理
Sketch uses 2796 bytes (8%) of program storage space. Maximum is 32256 bytes.
Global variables use 232 bytes (11%) of dynamic memory, leaving 1816 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Failed uploading: uploading error: exit status 1
YeezB  中级技师
发表于 2024-4-29 13:41:44
电脑连接不上Arduino,换一个USB线,电脑,重装串口驱动。
还是不行的话换个Arduino试试看。
刘骏森  初级技师
发表于 2024-10-1 15:23:48
是Arduino与电脑连接超时,不是程序问题
关于楼主
楼主的其它帖子
