2024-3-31 12:18:55 [显示全部楼层]
2395浏览
查看: 2395|回复: 4
[求助] 有没有大佬帮我看看这是怎么回事,关于sd库
以下是完整代码:
#include<SD.h>
#include<SPI.h>
#include<String.h>
unsigned long fileLength=0;//文件长度
unsigned long poipos=0;//文件指针位置
File file;
String matchPinyin(String);
String search(String,unsigned long,unsigned long);
void setup() {
  // put your setup code here, to run once:
  Serial.begin(115200);
  Serial.println(SD.begin(SPI_HALF_SPEED, 4));
  File file=SD.open("1.txt",FILE_READ);
  fileLength=file.available();
  file.close();
  Serial.println("汉字");
  Serial.println(matchPinyin("a "));
  Serial.println(matchPinyin("zuo "));
  Serial.println(matchPinyin("hao "));
  Serial.println("done");
String matchPinyin(String val)
  return search(val,0,fileLength);
String search(String val,unsigned long a,unsigned long b)//传递原值,首位,末位,识别位数
  char word=0;//缓存所取
  int sub=0;//比较下标
  unsigned long mid=a/2+b/2;
  Serial.print(a);
  Serial.print(",");
  Serial.print(b);
  Serial.print(":");
  Serial.println(mid);
  if((b-a)<2)
    return "";
  //Serial.println("front find");
  file.seek(mid);
  while(file.peek()!=10/*不是换行*/)//连续向上查询
    /*Serial.print("    ");
    Serial.print(mid);
    Serial.print(" ");
    Serial.println(file.peek());*/
    mid--;
    file.seek(mid);
  //Serial.println("back find");
  poipos=mid;
  while(file.peek()!=9/*不是空格*/)//连续向下查询
    Serial.print(file.peek());
    Serial.print(" ");
    Serial.println(char(file.peek()));*/
    file.seek(++poipos);
  while(file.seek(++poipos),(word=file.peek())!='\r'/*不是回车*/)//依次比较
    Serial.print(char(val[sub]));
    Serial.print("==");
    Serial.print(char(word));*/
    if(val[sub]==word)
      sub++;
    else if(word>val[sub])//从前寻找
      Serial.println("front");
      yield();
      file.close();
      return(search(val,a,(a+b)/2));
    else if(word<val[sub])//从后寻找
      Serial.println("back");
      yield();
      file.close();
      return(search(val,(a+b)/2,b));
  //此次选择正确
  String ret="";
  file.seek(++mid);
  while(file.peek()!=9)
    ret+=char(file.read());
  file.close();
  return ret;
void loop() {
  // put your main code here, to run repeatedly:
想做一个从SD卡里的文件用拼音查询汉字的程序,但是File file=SD.open("1.txt",FILE_READ); 这一句只能写到递归函数里,写到初始化里在递归函数里就不能操作文件了,是什么情况?怎么改进呢?
以下是打开的文件(部分)
operator  学徒
发表于 2024-3-31 12:42:59
补两张图片
有没有大佬帮我看看这是怎么回事,关于sd库图2有没有大佬帮我看看这是怎么回事,关于sd库图1
DFEDU  高级技师
发表于 2024-4-1 17:56:08
试试这样
#include <SD.h>
#include <SPI.h>
#include <String.h>
unsigned long fileLength = 0; //文件长度
unsigned long poipos = 0;    //文件指针位置
File file;
String search(String, unsigned long, unsigned long, File &);
void setup()
  file = SD.open("1.txt", FILE_READ);
  fileLength = file.available();
  file.close();
  return search(val, 0, fileLength, file);
String search(String val, unsigned long a, unsigned long b, File &file)
  char word = 0;      //缓存所取
  int sub = 0;        //比较下标
  unsigned long mid = a / 2 + b / 2;
  Serial.print(a);
  Serial.print(",");
  Serial.print(b);
  Serial.print(":");
  if ((b - a) < 2)
    return "";
  file.seek(mid);
  while (file.peek() != 10)
    mid--;
    file.seek(mid);
  poipos = mid;
  while (file.peek() != 9)
  while ((file.seek(++poipos), (word = file.peek())) != '\r')
    if (val[sub] == word)
      sub++;
    else if (word > val[sub])
      yield();
      file.close();
      return (search(val, a, (a + b) / 2, file));
    else if (word < val[sub])
      yield();
      file.close();
      return (search(val, (a + b) / 2, b, file));
  String ret = "";
  file.seek(++mid);
    ret += char(file.read());
  return ret;
void loop()
operator  学徒
发表于 2024-4-2 22:56:06
DFEDU 发表于 2024-4-1 17:56
试试这样
#include
#include
问题解决了,谢谢!但是file是全局变量,为什么在初始化里赋值不可以?
开在边缘  中级技匠
发表于 2024-4-8 12:33:07
void setup() {
  char word=0;//缓存所取
  int sub=0;//比较下标
因为你在函数里面又重新定义了一次file,所以函数里面的file就变成了函数内部的局部变量,不再是你之前定义的那个全局变量了。
