2023-12-22 21:02:50 [显示全部楼层]
2685浏览
查看: 2685|回复: 2
[求助] 怎么用按键控制WS2812灯带
灯带的功能目前都正常,但是想用一个按钮按下灯带亮工作一次,然后熄灭。
现在用while和if都试过了,按钮总是无效的。后面用红字注释的位置。
#include <FastLED.h>
#define WS_NUM_LEDS 47
//D1到D5分别5组LED
#define WS_DATA_PIN1 D1
#define WS_DATA_PIN2 D2
#define WS_DATA_PIN3 D3
#define WS_DATA_PIN4 D4
#define WS_DATA_PIN5 D5
#define WS_COLOR GRB
int duration = 20;
CRGB ws_leds[WS_NUM_LEDS];
void selectLED(int pin) {
    for(int i=0;i<WS_NUM_LEDS;i++){
    FastLED.delay(duration<50 ? duration=duration+20 : duration);
    ws_leds = CRGB::Red;
    //ws_leds = rgb[step];
    ws_leds[WS_NUM_LEDS-1-i] =CRGB::Blue;
    //ws_leds[WS_NUM_LEDS-1-i] = rgb[step];
  FastLED.show();
  delay(100);
  FastLED.clear();
// 选择5个不重复的随机LED让它们长亮
  int selectedLeds[5];
  for (int i = 0; i < 5; i++) {
    int index;
    bool duplicate;
    do {
      index = random(0,35);
      duplicate = false;
      for (int j = 0; j < i; j++) {
        if (selectedLeds[j] == index) {
          duplicate = true;
          break;
      } while (duplicate);
    selectedLeds = index;
    ws_leds[index] = CRGB::Blue;
// 选择2个不重复的随机LED让它们长亮
  int SelectedLeds[2];
randomSeed(analogRead(0));
  for (int x = 0; x < 2; x++) {
    int index;
    bool duplicate;
    do {
      index = random(35,47);
      duplicate = false;
      for (int y = 0; y < x; y++) {
        if (SelectedLeds[y] == index) {
          duplicate = true;
          break;
    SelectedLeds[x] = index;
    ws_leds[index] = CRGB::Red;
  FastLED.show();
  delay(3000);
  fill_solid(ws_leds, WS_NUM_LEDS, CRGB::Black);
  FastLED.show();
  delay(1000);
void setup() {
FastLED.setBrightness(10);
randomSeed(analogRead(A0));
pinMode(D7,INPUT_PULLUP);             //D7设为上拉输入模式
int Val = digitalRead(D7);  //将开关状态数值读取到变量中
void loop() {
while(Val == HIGH) {                           //现在是while(Val == HIGH) 灯带循环,while(Val==LOW)灯带就一直不亮,按键也没用
   //设置芯片型号,和信号引脚,以及RGB灯珠的顺序(GRB 表示绿红蓝)
  FastLED.addLeds<WS2812B, WS_DATA_PIN1, WS_COLOR>(ws_leds, WS_NUM_LEDS);
  selectLED(D1);
  FastLED.addLeds<WS2812B, WS_DATA_PIN2, WS_COLOR>(ws_leds, WS_NUM_LEDS);
  selectLED(D2);
  FastLED.addLeds<WS2812B, WS_DATA_PIN3, WS_COLOR>(ws_leds, WS_NUM_LEDS);
  selectLED(D3);
  FastLED.addLeds<WS2812B, WS_DATA_PIN4, WS_COLOR>(ws_leds, WS_NUM_LEDS);
  selectLED(D4);
  FastLED.addLeds<WS2812B, WS_DATA_PIN5, WS_COLOR>(ws_leds, WS_NUM_LEDS);
  selectLED(D5);
帅猫  高级技师
发表于 2023-12-23 22:02:21
把while改成用if实现,再把第72行int Val = digitalRead(D7);放在loop里面
小米渣  学徒
发表于 2023-12-25 16:26:24
非常靠谱
关于楼主
楼主的其它帖子
