2110| 4
[ESP8266/ESP32] esp32-C3的求助 |
上传中... 使用平台的 ‘esp32c3’ 开发板,在列出的文件夹中:D:\BaiduNetdiskDownload\mixly2.0\Arduino-cli\Arduino15\packages\esp32\hardware\esp32\2.0.7 使用平台的 ‘esp32’ 代码,在列出的文件夹中:D:\BaiduNetdiskDownload\mixly2.0\arduino-cli\Arduino15\packages\esp32\hardware\esp32\2.0.7 cmd /c if exist "D:\\BaiduNetdiskDownload\\mixly2.0\\testArduino\\partitions.csv" COPY /y "D:\\BaiduNetdiskDownload\\mixly2.0\\testArduino\\partitions.csv" "D:\\BaiduNetdiskDownload\\mixly2.0\\mixlyBuild\\partitions.csv" cmd /c if not exist "D:\\BaiduNetdiskDownload\\mixly2.0\\mixlyBuild\\partitions.csv" if exist "D:\\BaiduNetdiskDownload\\mixly2.0\\arduino-cli\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.7\\variants\\esp32c3\\partitions.csv" COPY "D:\\BaiduNetdiskDownload\\mixly2.0\\arduino-cli\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.7\\variants\\esp32c3\\partitions.csv" "D:\\BaiduNetdiskDownload\\mixly2.0\\mixlyBuild\\partitions.csv" cmd /c if not exist "D:\\BaiduNetdiskDownload\\mixly2.0\\mixlyBuild\\partitions.csv" COPY "D:\\BaiduNetdiskDownload\\mixly2.0\\arduino-cli\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.7\\tools\\partitions\\default.csv" "D:\\BaiduNetdiskDownload\\mixly2.0\\mixlyBuild\\partitions.csv" esptool.py v4.5 Creating esp32c3 image... Merged 1 ELF section Successfully created esp32c3 image. cmd /c if exist "D:\\BaiduNetdiskDownload\\mixly2.0\\testArduino\\build_opt.h" COPY /y "D:\\BaiduNetdiskDownload\\mixly2.0\\testArduino\\build_opt.h" "D:\\BaiduNetdiskDownload\\mixly2.0\\mixlyBuild\\build_opt.h" cmd /c if not exist "D:\\BaiduNetdiskDownload\\mixly2.0\\mixlyBuild\\build_opt.h" type nul > "D:\\BaiduNetdiskDownload\\mixly2.0\\mixlyBuild\\build_opt.h" 正在检测使用的库。。。 In file included from d:\baidunetdiskdownload\mixly2.0\arduino-cli\arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\esp-2021r2-patch5-8.4.0\riscv32-esp-elf\include\c++\8.4.0\string:41, from d:\baidunetdiskdownload\mixly2.0\arduino-cli\arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\esp-2021r2-patch5-8.4.0\riscv32-esp-elf\include\c++\8.4.0\stdexcept:39, from d:\baidunetdiskdownload\mixly2.0\arduino-cli\arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\esp-2021r2-patch5-8.4.0\riscv32-esp-elf\include\c++\8.4.0\array:39, from d:\baidunetdiskdownload\mixly2.0\arduino-cli\arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\esp-2021r2-patch5-8.4.0\riscv32-esp-elf\include\c++\8.4.0\tuple:39, from d:\baidunetdiskdownload\mixly2.0\arduino-cli\arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\esp-2021r2-patch5-8.4.0\riscv32-esp-elf\include\c++\8.4.0\functional:54, from D:\BaiduNetdiskDownload\mixly2.0\arduino-cli\Arduino15\packages\esp32\hardware\esp32\2.0.7\cores\esp32/HardwareSerial.h:49, from D:\BaiduNetdiskDownload\mixly2.0\arduino-cli\Arduino15\packages\esp32\hardware\esp32\2.0.7\cores\esp32/Arduino.h:184, from D:\BaiduNetdiskDownload\mixly2.0\mixlyBuild\sketch\testArduino.ino.cpp:1: d:\baidunetdiskdownload\mixly2.0\arduino-cli\arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\esp-2021r2-patch5-8.4.0\riscv32-esp-elf\include\c++\8.4.0\bits\allocator.h:46:10: fatal error: bits/c++allocator.h: No such file or directory #include <bits/c++allocator.h> // Define the base class to std::allocator. ^~~~~~~~~~~~~~~~~~~~~ compilation terminated. bits/c++allocator.h 的替代方案:[] ResolveLibrary(bits/c++allocator.h) -> 候选: [] 构建时出错:exit status 1 已使用的平台 版本 路径 esp32:esp32 2.0.7 D:\BaiduNetdiskDownload\mixly2.0\arduino-cli\Arduino15\packages\esp32\hardware\esp32\2.0.7 ==上传失败== 最近买了一个esp32C3,这种的 |
