[《Huskylens趣味AI入门》]二哈识图无法上传
2023-8-23 15:35:52 [显示全部楼层]
1978浏览
查看: 1978|回复: 2
[《Huskylens趣味AI入门》] 二哈识图无法上传
求助大神
为什么用mind+写程序上传报错,是程序逻辑有误吗
二哈识图无法上传图1
报错:
E:\Mind+\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I E:\Mind+\Arduino\hardware\arduino\avr\cores\arduino -I E:\Mind+\Arduino\hardware\arduino\avr\variants\eightanaloginputs -I E:\Mind+\Arduino\hardware\arduino\avr\cores\arduino -I E:\Mind+\Arduino\hardware\arduino\avr\variants\standard C:\Users\ASUS\AppData\Local\DFScratch\cache\dfrobot.ino.cpp -o C:\Users\ASUS\AppData\Local\DFScratch\cache\dfrobot.ino.cpp.o
E:\Mind+\Arduino\hardware\tools\avr\bin\avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o C:\Users\ASUS\AppData\Local\DFScratch\build\dfrobot.ino.elf C:\Users\ASUS\AppData\Local\DFScratch\cache\dfrobot.ino.cpp.o E:\Mind+\Arduino\static/core/uno/core.a -lm
"E:\Mind+\Arduino\hardware\tools\avr\bin\avr-objcopy" -O ihex -R .eeprom "C:\Users\ASUS\AppData\Local\DFScratch\build\dfrobot.ino.elf" "C:\Users\ASUS\AppData\Local\DFScratch\build\dfrobot.ino.hex"
项目使用了1470字节,占用了(5%)程序存储空间,余留30786字节,最大为32256字节。
全局变量使用了194字节,(9%)的动态内存,余留1854字节局部变量,最大为2048字节。
E:\Mind+\Arduino\hardware\tools\avr\bin\avrdude -CE:\Mind+\Arduino/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM10 -b115200 -D -Uflash:w:C:\Users\ASUS\AppData\Local\DFScratch\build\dfrobot.ino.hex:i
avrdude: Version 6.3-20171130
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "E:\Mind+\Arduino/hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : COM10
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: ser_open(): can't open device "\\.\COM10": �ܾ����ʡ�
avrdude done.  Thank you.
烧录失败
阿泽  初级技师
发表于 2023-8-23 18:01:43
端口问题,尝试以下方法:一键安装驱动、重新拔插主控、换根USB接口、换根USB线,以上方法尝试不能解决问题,添加技术支持账号:QQ 2124609059  微信 DFRobot_TS
HF-CGH  中级技师
发表于 2024-10-4 14:44:03
有点绕
但如果否则换成如果,直接四个叠一起就好了。
关于楼主
楼主的其它帖子
