 有机会试用FireBeetle 2 ESP32-S3,我在Arduino IDE安装DFRobot Firebeetle ESP32-S3主板后,示例中有“CameraWebServer”,功能比较强大。本试用项目将结合App inventor2制作手机APP监控画面。使用行空板接收FireBeetle 2 ESP32-S3的拍照画面。
 一、安装FireBeetle 2 ESP32-S3
 我将使用Arduino IDE对ESP32开发板进行编程。因此,需要安装Arduino IDE以及ESP32附加组件:
  二、修改“CameraWebServer”示例
 增加电源管理:
 #include "DFRobot_AXP313A.h"
 DFRobot_AXP313A axp;
 axp.enableCameraPower(axp.eOV2640); // 设置摄像头供电
 备注:要在原示例中修改
 三、制作手机APP复制代码#include "esp_camera.h"
#include <WiFi.h>
// WARNING!!! PSRAM IC required for UXGA resolution and high JPEG quality
//            Ensure ESP32 Wrover Module or other board with PSRAM is selected
//            Partial images will be transmitted if image exceeds buffer size
//            You must select partition scheme from the board menu that has at least 3MB APP space.
//            Face Recognition is DISABLED for ESP32 and ESP32-S2, because it takes up from 15
//            seconds to process single frame. Face Detection is ENABLED if PSRAM is enabled as well
// Select camera model
//#define CAMERA_MODEL_WROVER_KIT // Has PSRAM
//#define CAMERA_MODEL_ESP_EYE // Has PSRAM
//#define CAMERA_MODEL_ESP32S3_EYE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_PSRAM // Has PSRAM
//#define CAMERA_MODEL_M5STACK_V2_PSRAM // M5Camera version B Has PSRAM
//#define CAMERA_MODEL_M5STACK_WIDE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_ESP32CAM // No PSRAM
//#define CAMERA_MODEL_M5STACK_UNITCAM // No PSRAM
//#define CAMERA_MODEL_AI_THINKER // Has PSRAM
//#define CAMERA_MODEL_TTGO_T_JOURNAL // No PSRAM
//#define CAMERA_MODEL_XIAO_ESP32S3 // Has PSRAM
// ** Espressif Internal Boards **
//#define CAMERA_MODEL_ESP32_CAM_BOARD
//#define CAMERA_MODEL_ESP32S2_CAM_BOARD
//#define CAMERA_MODEL_ESP32S3_CAM_LCD
#define CAMERA_MODEL_DFRobot_FireBeetle2_ESP32S3 // Has PSRAM
//#define CAMERA_MODEL_DFRobot_Romeo_ESP32S3 // Has PSRAM
#include "camera_pins.h"
// Enter your WiFi credentials
const char* ssid = "*******";
const char* password = "********";
void startCameraServer();
void setupLedFlash(int pin);
void setup() {
  Serial.begin(115200);
  Serial.setDebugOutput(true);
  Serial.println();
    while (axp.begin() != 0)
    Serial.println("init error");
    delay(1000);
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sccb_sda = SIOD_GPIO_NUM;
  config.pin_sccb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.frame_size = FRAMESIZE_UXGA;
  config.pixel_format = PIXFORMAT_JPEG; // for streaming
  //config.pixel_format = PIXFORMAT_RGB565; // for face detection/recognition
  config.grab_mode = CAMERA_GRAB_WHEN_EMPTY;
  config.fb_location = CAMERA_FB_IN_PSRAM;
  config.jpeg_quality = 12;
  config.fb_count = 1;
  // if PSRAM IC present, init with UXGA resolution and higher JPEG quality
  //                      for larger pre-allocated frame buffer.
  if(config.pixel_format == PIXFORMAT_JPEG){
    if(psramFound()){
      config.jpeg_quality = 10;
      config.fb_count = 2;
      config.grab_mode = CAMERA_GRAB_LATEST;
    } else {
      // Limit the frame size when PSRAM is not available
      config.frame_size = FRAMESIZE_SVGA;
      config.fb_location = CAMERA_FB_IN_DRAM;
  } else {
    // Best option for face detection/recognition
    config.frame_size = FRAMESIZE_240X240;
#if CONFIG_IDF_TARGET_ESP32S3
#endif
#if defined(CAMERA_MODEL_ESP_EYE)
  pinMode(13, INPUT_PULLUP);
  pinMode(14, INPUT_PULLUP);
#endif
  // camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  sensor_t * s = esp_camera_sensor_get();
  // initial sensors are flipped vertically and colors are a bit saturated
  if (s->id.PID == OV3660_PID) {
    s->set_vflip(s, 1); // flip it back
    s->set_brightness(s, 1); // up the brightness just a bit
    s->set_saturation(s, -2); // lower the saturation
  // drop down frame size for higher initial frame rate
    s->set_framesize(s, FRAMESIZE_QVGA);
#if defined(CAMERA_MODEL_M5STACK_WIDE) || defined(CAMERA_MODEL_M5STACK_ESP32CAM)
  s->set_vflip(s, 1);
  s->set_hmirror(s, 1);
#endif
#if defined(CAMERA_MODEL_ESP32S3_EYE)
  s->set_vflip(s, 1);
#endif
// Setup LED FLash if LED pin is defined in camera_pins.h
#if defined(LED_GPIO_NUM)
  setupLedFlash(LED_GPIO_NUM);
#endif
  WiFi.begin(ssid, password);
  WiFi.setSleep(false);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.print("Camera Ready! Use 'http://");
  Serial.print(WiFi.localIP());
  Serial.println("' to connect");
void loop() {
  // Do nothing. Everything is done in another task by the web server
  delay(10000);
 1.组件设计
  2.逻辑设计
  3.测试
  4.演示视频
 四、行空板接收拍照画面
 1.修改“CameraWebServer”示例
 2.行空板程序复制代码#include "esp_camera.h"
#include <WiFi.h>
#include <HTTPClient.h>
// 用于上传照片的服务器地址,行空板IP地址
const char *serverName = "http://192.168.31.71:9000/upload";
#define PWDN_GPIO_NUM -1
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 45
#define SIOD_GPIO_NUM 1
#define SIOC_GPIO_NUM 2
#define Y9_GPIO_NUM 48
#define Y8_GPIO_NUM 46
#define Y7_GPIO_NUM 8
#define Y6_GPIO_NUM 7
#define Y5_GPIO_NUM 4
#define Y4_GPIO_NUM 41
#define Y3_GPIO_NUM 40
#define Y2_GPIO_NUM 39
#define VSYNC_GPIO_NUM 6
#define HREF_GPIO_NUM 42
#define PCLK_GPIO_NUM 5
#define ONBOARD_KEY 47 // 板载按钮
#define ONBOARD_LED 21 // 板载 LED
volatile bool buttonPressed = false; // 按钮下降沿中断标志位
const char *ssid = "********";
const char *password = "*************";
void setup()
  pinMode(ONBOARD_KEY, INPUT);
  pinMode(ONBOARD_LED, OUTPUT);
  attachInterrupt(digitalPinToInterrupt(ONBOARD_KEY), buttonInterrupt, FALLING);
  Serial.println();
    delay(1000);
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.frame_size = FRAMESIZE_QVGA;   // 照片分辨率。这里默认为 FRAMESIZE_UXGA
  // config.pixel_format = PIXFORMAT_RGB565; // for face detection/recognition
  config.jpeg_quality = 12; // 63; // 照片质量。这里默认为 12
  FRAMESIZE_QVGA (320 x 240)
  FRAMESIZE_CIF (352 x 288)
  FRAMESIZE_VGA (640 x 480)
  FRAMESIZE_SVGA (800 x 600)
  FRAMESIZE_XGA (1024 x 768)
  FRAMESIZE_SXGA (1280 x 1024)
  FRAMESIZE_UXGA (1600 x 1200)
  if (config.pixel_format == PIXFORMAT_JPEG)
    if (psramFound())
      config.jpeg_quality = 12; // 63; // 照片质量。这里默认为 10
    else
      config.frame_size = FRAMESIZE_UXGA; // 照片分辨率。这里默认为 FRAMESIZE_SVGA
  else
    config.frame_size = FRAMESIZE_UXGA; // FRAMESIZE_240X240;
#endif
#endif
  // camera init
  if (err != ESP_OK)
    return;
  sensor_t *s = esp_camera_sensor_get();
  s->set_vflip(s, 1);
#endif
  s->set_vflip(s, 1);
#endif
    delay(500);
    Serial.print(".");
  Serial.println("");
void loop()
  // delay(10000);
  // 按钮按下后的逻辑
  if (buttonPressed)
    // 拍摄照片
    camera_fb_t *fb = esp_camera_fb_get();
    if (!fb)
      Serial.println("获取摄像头帧缓冲失败");
      return;
    // 建立HTTP客户端
    HTTPClient http;
    // 将照片上传到服务器
    http.begin(serverName);
    http.addHeader("Content-Type", "image/jpeg");
    int httpResponseCode = http.POST(fb->buf, fb->len);
    if (httpResponseCode > 0)
      Serial.printf("照片上传成功,服务器返回代码:%d\n", httpResponseCode);
      // 再闪一下提示上传成功
    else
      Serial.printf("照片上传失败,错误代码:%s\n", http.errorToString(httpResponseCode).c_str());
    http.end();
    // 释放帧缓冲
    esp_camera_fb_return(fb);
    // delay(1000); // 等待 1 秒后才可再次拍摄和上传
    buttonPressed = false; // 重置中断标志位
void buttonInterrupt()
  buttonPressed = true; // 设置下降沿中断标志位
 3.测试复制代码from flask import Flask, request
from unihiker import GUI
u_gui=GUI()
显图=u_gui.draw_image(image="base.png",h=320,x=0,y=0)
app = Flask(__name__)
@app.route('/upload', methods=['POST'])
def upload():
    try:
        image = request.data
        # 保存照片到指定目录
        with open('base.png', 'wb') as f:
            f.write(image)
            f.close()
        显图.config(image="base.png")
        return "照片上传成功", 200
    except Exception as e:
        print("照片上传失败:", str(e))
        return "照片上传失败", 500
if __name__ == '__main__':
    app.run(host='192.168.31.71', port=9000)
  4.演示视频
 五、GDI接口
 这次的FireBeetle 2 ESP32-S3开发板不仅提供了CAM(Camera)接口,还提供了GDI接口:
  1.TFT_eSPI配置
 TFT_eSPI、lvgl扩展库安装
 2.User_Setup_Select.h头文件控制调用哪个配置文件,User_Setups目录中则包含已经做好预配的多种配置文件。
 3.按下图FireBeetle 2 ESP32-S3开发板的GDI说明,修改“Setup70b_ESP32_S3_ILI9341.h”对应的GPIO配置:
 运行示例,正在测试,将摄像头采集的内容显示在屏幕上……复制代码#define TFT_CS   18 //     10 or 34 (FSPI CS0)
#define TFT_MOSI 15 //     11 or 35 (FSPI D)
#define TFT_SCLK 17 //     12 or 36 (FSPI CLK)
#define TFT_MISO 16 //     13 or 37 (FSPI Q)
// Use pins in range 0-31
#define TFT_DC    3
#define TFT_RST   38
//#define TOUCH_CS 12 // Optional for touch screen
