12078浏览
查看: 12078|回复: 1
[求助问答] 用MIND+给arduino上传程序,为什么总是用着用着就烧录失败
用MIND+给Arduino上传程序,为什么总是用着用着就烧录失败。所有传感器都拔了,没有接任何东西了,还是不行.
Writing | ################################################## | 100% 0.13s
avrdude: 710 bytes of flash written
avrdude: verifying flash memory against C:\Users\Administrator\AppData\Local\DFScratch\build\dfrobot.ino.hex:
avrdude: load data flash data from input file C:\Users\Administrator\AppData\Local\DFScratch\build\dfrobot.ino.hex:
avrdude: input file C:\Users\Administrator\AppData\Local\DFScratch\build\dfrobot.ino.hex contains 710 bytes
avrdude: reading on-chip flash data:
Reading | ########avrdude: stk500_recv(): programmer is not responding
avr_read(): error reading address 0x0000
    read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
avrdude done.  Thank you.
烧录失败
ilwjx  见习技师
发表于 2023-3-29 20:05:12
如果上传到98%提示烧录失败,其实已经上传成功了,这也许是一个bug。你试试就知道了
