[求助]这个怎么办
2023-3-10 11:34:11 [显示全部楼层]
2678浏览
查看: 2678|回复: 0
[求助] 这个怎么办
怎么换线又不能只能换按钮上面的线让它的功能反一下
const int buttonPin = 2;  // the number of the pushbutton pin
const int ledPin = 13;    // the number of the LED pin
// variables will change:
int buttonState = 0;  // variable for reading the pushbutton status
void setup() {
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
void loop() {
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed. If it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    // turn LED on:
    digitalWrite(ledPin, HIGH);
  } else {
    // turn LED off:
    digitalWrite(ledPin, LOW);
关于楼主
楼主的其它帖子
