3349| 6
[求助] ESP32 C3无法安装驱动? |
今天从官网(https://www.arduino.cc/en/donate/)上下载,arduino-1.8.19-windows.exe。还是没有合适的驱动,设备管理器不停的刷新设备。 |
有没有官方的技术支持群?或者爱好者群? Arduino:1.8.19 (Windows 10), 开发板:"ESP32C3 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 40MHz, QIO, 40MHz, 4MB (32Mb), 921600, None, Disabled" D:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware D:\Program Files (x86)\Arduino\hardware -hardware C:\Users\john\AppData\Local\Arduino15\packages -tools D:\Program Files (x86)\Arduino\tools-builder -tools D:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\john\AppData\Local\Arduino15\packages -built-in-libraries D:\Program Files (x86)\Arduino\libraries -libraries C:\Users\john\Documents\Arduino\libraries -fqbn=espressif:arduino-esp32-master:esp32c3:CDCOnBoot=default,PartitionScheme=default,CPUFreq=40,FlashMode=qio,FlashFreq=40,FlashSize=4M,UploadSpeed=921600,DebugLevel=none,EraseFlash=none -vid-pid=303A_1001 -ide-version=10819 -build-path C:\Users\john\AppData\Local\Temp\arduino_build_117916 -warnings=none -build-cache C:\Users\john\AppData\Local\Temp\arduino_cache_796372 -prefs=build.warn_data_percentage=75 -verbose D:\项目\ESP32-C3\sketch_nov28a\sketch_nov28a.ino D:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware D:\Program Files (x86)\Arduino\hardware -hardware C:\Users\john\AppData\Local\Arduino15\packages -tools D:\Program Files (x86)\Arduino\tools-builder -tools D:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\john\AppData\Local\Arduino15\packages -built-in-libraries D:\Program Files (x86)\Arduino\libraries -libraries C:\Users\john\Documents\Arduino\libraries -fqbn=espressif:arduino-esp32-master:esp32c3:CDCOnBoot=default,PartitionScheme=default,CPUFreq=40,FlashMode=qio,FlashFreq=40,FlashSize=4M,UploadSpeed=921600,DebugLevel=none,EraseFlash=none -vid-pid=303A_1001 -ide-version=10819 -build-path C:\Users\john\AppData\Local\Temp\arduino_build_117916 -warnings=none -build-cache C:\Users\john\AppData\Local\Temp\arduino_cache_796372 -prefs=build.warn_data_percentage=75 -verbose D:\项目\ESP32-C3\sketch_nov28a\sketch_nov28a.ino Using board 'esp32c3' from platform in folder: D:\Program Files (x86)\Arduino\hardware\espressif\arduino-esp32-master Using core 'esp32' from platform in folder: D:\Program Files (x86)\Arduino\hardware\espressif\arduino-esp32-master cmd /c if exist "D:\\项目\\ESP32-C3\\sketch_nov28a\\partitions.csv" COPY /y "D:\\项目\\ESP32-C3\\sketch_nov28a\\partitions.csv" "C:\\Users\\john\\AppData\\Local\\Temp\\arduino_build_117916\\partitions.csv" cmd /c if not exist "C:\\Users\\john\\AppData\\Local\\Temp\\arduino_build_117916\\partitions.csv" if exist "D:\\Program Files (x86)\\Arduino\\hardware\\espressif\\arduino-esp32-master\\variants\\esp32c3\\partitions.csv" COPY "D:\\Program Files (x86)\\Arduino\\hardware\\espressif\\arduino-esp32-master\\variants\\esp32c3\\partitions.csv" "C:\\Users\\john\\AppData\\Local\\Temp\\arduino_build_117916\\partitions.csv" cmd /c if not exist "C:\\Users\\john\\AppData\\Local\\Temp\\arduino_build_117916\\partitions.csv" COPY "D:\\Program Files (x86)\\Arduino\\hardware\\espressif\\arduino-esp32-master\\tools\\partitions\\default.csv" "C:\\Users\\john\\AppData\\Local\\Temp\\arduino_build_117916\\partitions.csv" cmd /c IF EXIST "D:\\项目\\ESP32-C3\\sketch_nov28a\\bootloader.bin" ( COPY /y "D:\\项目\\ESP32-C3\\sketch_nov28a\\bootloader.bin" "C:\\Users\\john\\AppData\\Local\\Temp\\arduino_build_117916\\sketch_nov28a.ino.bootloader.bin" ) ELSE ( IF EXIST "D:\\Program Files (x86)\\Arduino\\hardware\\espressif\\arduino-esp32-master\\variants\\esp32c3\\bootloader.bin" ( COPY "D:\\Program Files (x86)\\Arduino\\hardware\\espressif\\arduino-esp32-master\\variants\\esp32c3\\bootloader.bin" "C:\\Users\\john\\AppData\\Local\\Temp\\arduino_build_117916\\sketch_nov28a.ino.bootloader.bin" ) ELSE ( "D:\\Program Files (x86)\\Arduino\\hardware\\espressif\\arduino-esp32-master/tools/esptool/esptool.exe" --chip esp32c3 elf2image --flash_mode dio --flash_freq 40m --flash_size 4MB -o "C:\\Users\\john\\AppData\\Local\\Temp\\arduino_build_117916\\sketch_nov28a.ino.bootloader.bin" "D:\\Program Files (x86)\\Arduino\\hardware\\espressif\\arduino-esp32-master\\tools\\sdk\\esp32c3\\bin\\bootloader_qio_40m.elf" ) ) ϵͳ�Ҳ���ָ����·���� exit status 1 为开发板 ESP32C3 Dev Module 编译时出错。 |
