12584| 3
[ESP8266/ESP32] Arduino-ESP32 2.0安装疑难问题解决方法(附百度网盘提供文件) |
本帖最后由 HonestQiao 于 2022-6-2 20:21 编辑 在Windows上的Arduino安装Arduino-ESP32 2.0板卡支持包的时候,可能会不太顺利,文件无法成功下载,此时可以参考如下步骤: 1. 使用下载工具,下载下面的文件:
3. 正确放置文件:都在上一步找到的 Arduino 配置目录 中进行
4. 重新启动Arduino,按照如下步骤安装: ![]() ![]() ![]() ![]() ![]() |
Arduino:1.8.15 (Windows 10), 开发板:"ESP32C3 Dev Module, Enabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 160MHz (WiFi), QIO, 80MHz, 4MB (32Mb), 921600, None" D:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware D:\Program Files (x86)\Arduino\hardware -hardware C:\Users\User\AppData\Local\Arduino15\packages -tools D:\Program Files (x86)\Arduino\tools-builder -tools D:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\User\AppData\Local\Arduino15\packages -built-in-libraries D:\Program Files (x86)\Arduino\libraries -libraries D:\Users\User\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32c3:CDCOnBoot=cdc,PartitionScheme=default,CPUFreq=160,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none -vid-pid=303A_1001 -ide-version=10815 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_24977 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_198005 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mkspiffs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mklittlefs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.esptool_py.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.3.0 -prefs=runtime.tools.esptool_py-3.3.0.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.3.0 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -verbose D:\Users\User\Desktop\sketch_jun12a\sketch_jun12a.ino D:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware D:\Program Files (x86)\Arduino\hardware -hardware C:\Users\User\AppData\Local\Arduino15\packages -tools D:\Program Files (x86)\Arduino\tools-builder -tools D:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\User\AppData\Local\Arduino15\packages -built-in-libraries D:\Program Files (x86)\Arduino\libraries -libraries D:\Users\User\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32c3:CDCOnBoot=cdc,PartitionScheme=default,CPUFreq=160,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none -vid-pid=303A_1001 -ide-version=10815 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_24977 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_198005 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mkspiffs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mklittlefs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.esptool_py.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.3.0 -prefs=runtime.tools.esptool_py-3.3.0.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.3.0 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -verbose D:\Users\User\Desktop\sketch_jun12a\sketch_jun12a.ino Using board 'esp32c3' from platform in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3 Using core 'esp32' from platform in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3 cmd /c if exist "D:\\Users\\User\\Desktop\\sketch_jun12a\\partitions.csv" COPY /y "D:\\Users\\User\\Desktop\\sketch_jun12a\\partitions.csv" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977\\partitions.csv" cmd /c if not exist "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977\\partitions.csv" if exist "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\variants\\esp32c3\\partitions.csv" COPY "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\variants\\esp32c3\\partitions.csv" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977\\partitions.csv" cmd /c if not exist "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977\\partitions.csv" COPY "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\tools\\partitions\\default.csv" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977\\partitions.csv" cmd /c IF EXIST "D:\\Users\\User\\Desktop\\sketch_jun12a\\bootloader.bin" ( COPY /y "D:\\Users\\User\\Desktop\\sketch_jun12a\\bootloader.bin" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977\\sketch_jun12a.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\variants\\esp32c3\\bootloader.bin" ( COPY "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\variants\\esp32c3\\bootloader.bin" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977\\sketch_jun12a.ino.bootloader.bin" ) ELSE ( COPY /y "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\tools\\sdk\\esp32c3\\bin\\bootloader_qio_80m.bin" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977\\sketch_jun12a.ino.bootloader.bin" ) ) �Ѹ��� 1 ���ļ��� cmd /c if exist "D:\\Users\\User\\Desktop\\sketch_jun12a\\build_opt.h" COPY /y "D:\\Users\\User\\Desktop\\sketch_jun12a\\build_opt.h" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977\\build_opt.h" cmd /c if not exist "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977\\build_opt.h" type nul > "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977\\build_opt.h" Detecting libraries used... "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\riscv32-esp-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/riscv32-esp-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.1-1-gb8050b365e\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/config" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/newlib/platform_include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/freertos/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/freertos/port/riscv/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/freertos/include/esp_additions" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_hw_support/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_hw_support/include/soc" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_hw_support/include/soc/esp32c3" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_hw_support/port/esp32c3" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_hw_support/port/esp32c3/private_include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/heap/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/log/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/lwip/include/apps" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/lwip/include/apps/sntp" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/lwip/lwip/src/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/lwip/port/esp32/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/lwip/port/esp32/include/arch" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/soc/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/soc/esp32c3" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/soc/esp32c3/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/hal/esp32c3/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/hal/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/hal/platform_port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_rom/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_rom/include/esp32c3" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_rom/esp32c3" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_common/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_system/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_system/port/soc" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_system/port/include/riscv" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_system/port/public_compat" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/riscv/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/driver/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/driver/esp32c3/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_pm/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_ringbuf/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/efuse/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/efuse/esp32c3/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/vfs/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_wifi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_event/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_netif/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_eth/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/tcpip_adapter/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_phy/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_phy/esp32c3/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_ipc/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/app_trace/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_timer/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/mbedtls/port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/mbedtls/mbedtls/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/app_update/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/spi_flash/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/bootloader_support/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/nvs_flash/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/pthread/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_gdbstub/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_gdbstub/riscv" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_gdbstub/esp32c3" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/espcoredump/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/espcoredump/include/port/riscv" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/wpa_supplicant/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/wpa_supplicant/port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/ieee802154/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/console" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/asio/asio/asio/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/asio/port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/bt/common/osi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/bt/include/esp32c3/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/bt/common/api/include/api" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/cbor/port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/unity/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/unity/unity/src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/cmock/CMock/src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/coap/port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/coap/libcoap/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/nghttp/port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-tls" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_adc_cal/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_hid/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/tcp_transport/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_http_client/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_http_server/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_https_ota/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_https_server/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_lcd/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_lcd/interface" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/protobuf-c/protobuf-c" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/protocomm/include/common" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/protocomm/include/security" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/protocomm/include/transports" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/mdns/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_local_ctrl/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/sdmmc/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_serial_slave_link/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_websocket_client/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/expat/expat/expat/lib" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/expat/port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/wear_levelling/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/fatfs/diskio" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/fatfs/vfs" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/fatfs/src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/freemodbus/common/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/idf_test/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/idf_test/include/esp32c3" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/jsmn/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/json/cJSON" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/libsodium/port_include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/mqtt/esp-mqtt/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/openssl/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/spiffs/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/wifi_provisioning/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/button/button/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/rmaker_common/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/json_parser/upstream/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/json_parser/upstream" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/json_generator/upstream" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_schedule/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_rainmaker/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/qrcode/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/ws2812_led" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/dotprod/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/support/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/windows/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/windows/hann/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/iir/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/fir/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/math/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/math/add/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/math/sub/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/math/mul/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/math/addc/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/math/mulc/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/matrix/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/fft/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/dct/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/conv/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/common/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_littlefs/src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_littlefs/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/tool" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/typedef" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/image" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/math" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/nn" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/layer" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/detect" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/model_zoo" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/fb_gfx/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/qspi_qspi/include" -march=rv32imc -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Wno-error=format= -nostartfiles -Wno-format -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -x c++ -E -CC -DF_CPU=160000000L -DARDUINO=10815 -DARDUINO_ESP32C3_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32C3_DEV\"" "-DARDUINO_VARIANT=\"esp32c3\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977/build_opt.h" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\variants\\esp32c3" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977\\sketch\\sketch_jun12a.ino.cpp" -o nul Generating function prototypes... "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\riscv32-esp-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/riscv32-esp-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.1-1-gb8050b365e\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/config" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/newlib/platform_include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/freertos/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/freertos/port/riscv/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/freertos/include/esp_additions" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_hw_support/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_hw_support/include/soc" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_hw_support/include/soc/esp32c3" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_hw_support/port/esp32c3" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_hw_support/port/esp32c3/private_include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/heap/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/log/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/lwip/include/apps" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/lwip/include/apps/sntp" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/lwip/lwip/src/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/lwip/port/esp32/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/lwip/port/esp32/include/arch" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/soc/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/soc/esp32c3" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/soc/esp32c3/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/hal/esp32c3/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/hal/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/hal/platform_port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_rom/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_rom/include/esp32c3" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_rom/esp32c3" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_common/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_system/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_system/port/soc" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_system/port/include/riscv" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_system/port/public_compat" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/riscv/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/driver/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/driver/esp32c3/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_pm/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_ringbuf/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/efuse/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/efuse/esp32c3/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/vfs/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_wifi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_event/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_netif/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_eth/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/tcpip_adapter/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_phy/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_phy/esp32c3/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_ipc/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/app_trace/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_timer/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/mbedtls/port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/mbedtls/mbedtls/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/app_update/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/spi_flash/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/bootloader_support/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/nvs_flash/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/pthread/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_gdbstub/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_gdbstub/riscv" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_gdbstub/esp32c3" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/espcoredump/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/espcoredump/include/port/riscv" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/wpa_supplicant/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/wpa_supplicant/port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/ieee802154/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/console" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/asio/asio/asio/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/asio/port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/bt/common/osi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/bt/include/esp32c3/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/bt/common/api/include/api" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/cbor/port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/unity/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/unity/unity/src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/cmock/CMock/src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/coap/port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/coap/libcoap/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/nghttp/port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-tls" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_adc_cal/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_hid/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/tcp_transport/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_http_client/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_http_server/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_https_ota/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_https_server/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_lcd/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_lcd/interface" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/protobuf-c/protobuf-c" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/protocomm/include/common" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/protocomm/include/security" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/protocomm/include/transports" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/mdns/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_local_ctrl/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/sdmmc/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_serial_slave_link/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_websocket_client/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/expat/expat/expat/lib" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/expat/port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/wear_levelling/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/fatfs/diskio" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/fatfs/vfs" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/fatfs/src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/freemodbus/common/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/idf_test/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/idf_test/include/esp32c3" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/jsmn/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/json/cJSON" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/libsodium/port_include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/mqtt/esp-mqtt/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/openssl/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/spiffs/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/wifi_provisioning/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/button/button/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/rmaker_common/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/json_parser/upstream/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/json_parser/upstream" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/json_generator/upstream" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_schedule/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_rainmaker/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/qrcode/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/ws2812_led" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/dotprod/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/support/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/windows/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/windows/hann/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/iir/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/fir/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/math/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/math/add/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/math/sub/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/math/mul/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/math/addc/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/math/mulc/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/matrix/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/fft/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/dct/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/conv/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/common/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_littlefs/src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_littlefs/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/tool" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/typedef" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/image" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/math" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/nn" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/layer" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/detect" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/model_zoo" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/fb_gfx/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/qspi_qspi/include" -march=rv32imc -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Wno-error=format= -nostartfiles -Wno-format -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -x c++ -E -CC -DF_CPU=160000000L -DARDUINO=10815 -DARDUINO_ESP32C3_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32C3_DEV\"" "-DARDUINO_VARIANT=\"esp32c3\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977/build_opt.h" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\variants\\esp32c3" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977\\sketch\\sketch_jun12a.ino.cpp" -o "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977\\preproc\\ctags_target_for_gcc_minus_e.cpp" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977\\preproc\\ctags_target_for_gcc_minus_e.cpp" 正在编译项目... "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\riscv32-esp-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/riscv32-esp-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.1-1-gb8050b365e\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/config" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/newlib/platform_include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/freertos/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/freertos/port/riscv/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/freertos/include/esp_additions" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_hw_support/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_hw_support/include/soc" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_hw_support/include/soc/esp32c3" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_hw_support/port/esp32c3" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_hw_support/port/esp32c3/private_include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/heap/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/log/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/lwip/include/apps" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/lwip/include/apps/sntp" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/lwip/lwip/src/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/lwip/port/esp32/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/lwip/port/esp32/include/arch" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/soc/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/soc/esp32c3" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/soc/esp32c3/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/hal/esp32c3/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/hal/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/hal/platform_port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_rom/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_rom/include/esp32c3" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_rom/esp32c3" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_common/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_system/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_system/port/soc" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_system/port/include/riscv" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_system/port/public_compat" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/riscv/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/driver/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/driver/esp32c3/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_pm/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_ringbuf/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/efuse/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/efuse/esp32c3/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/vfs/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_wifi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_event/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_netif/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_eth/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/tcpip_adapter/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_phy/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_phy/esp32c3/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_ipc/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/app_trace/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_timer/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/mbedtls/port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/mbedtls/mbedtls/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/app_update/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/spi_flash/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/bootloader_support/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/nvs_flash/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/pthread/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_gdbstub/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_gdbstub/riscv" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_gdbstub/esp32c3" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/espcoredump/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/espcoredump/include/port/riscv" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/wpa_supplicant/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/wpa_supplicant/port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/ieee802154/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/console" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/asio/asio/asio/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/asio/port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/bt/common/osi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/bt/include/esp32c3/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/bt/common/api/include/api" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/cbor/port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/unity/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/unity/unity/src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/cmock/CMock/src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/coap/port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/coap/libcoap/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/nghttp/port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-tls" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_adc_cal/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_hid/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/tcp_transport/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_http_client/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_http_server/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_https_ota/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_https_server/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_lcd/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_lcd/interface" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/protobuf-c/protobuf-c" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/protocomm/include/common" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/protocomm/include/security" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/protocomm/include/transports" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/mdns/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_local_ctrl/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/sdmmc/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_serial_slave_link/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_websocket_client/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/expat/expat/expat/lib" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/expat/port/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/wear_levelling/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/fatfs/diskio" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/fatfs/vfs" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/fatfs/src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/freemodbus/common/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/idf_test/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/idf_test/include/esp32c3" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/jsmn/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/json/cJSON" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/libsodium/port_include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/mqtt/esp-mqtt/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/openssl/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/spiffs/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/wifi_provisioning/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/button/button/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/rmaker_common/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/json_parser/upstream/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/json_parser/upstream" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/json_generator/upstream" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_schedule/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_rainmaker/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/qrcode/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/ws2812_led" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/dotprod/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/support/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/windows/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/windows/hann/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/iir/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/fir/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/math/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/math/add/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/math/sub/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/math/mul/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/math/addc/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/math/mulc/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/matrix/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/fft/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/dct/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/conv/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/common/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_littlefs/src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp_littlefs/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/tool" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/typedef" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/image" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/math" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/nn" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/layer" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/detect" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/esp-dl/include/model_zoo" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/include/fb_gfx/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/qspi_qspi/include" -march=rv32imc -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Wno-error=format= -nostartfiles -Wno-format -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -MMD -c -DF_CPU=160000000L -DARDUINO=10815 -DARDUINO_ESP32C3_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32C3_DEV\"" "-DARDUINO_VARIANT=\"esp32c3\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977/build_opt.h" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\variants\\esp32c3" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977\\sketch\\sketch_jun12a.ino.cpp" -o "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977\\sketch\\sketch_jun12a.ino.cpp.o" Compiling libraries... Compiling core... Using precompiled core: C:\Users\User\AppData\Local\Temp\arduino_cache_198005\core\core_6b60e6c0516acd2e36a3661bed662785.a Linking everything together... "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\riscv32-esp-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/riscv32-esp-elf-g++" "-Wl,--Map=C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977/sketch_jun12a.ino.map" "-LC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/lib" "-LC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/ld" "-LC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/sdk/esp32c3/qspi_qspi" -T memory.ld -T sections.ld -T esp32c3.rom.ld -T esp32c3.rom.api.ld -T esp32c3.rom.libgcc.ld -T esp32c3.rom.newlib.ld -T esp32c3.rom.version.ld -T esp32c3.rom.newlib-time.ld -T esp32c3.rom.eco3.ld -T esp32c3.peripherals.ld -nostartfiles -march=rv32imc --specs=nosys.specs -Wl,--cref -Wl,--gc-sections -fno-rtti -fno-lto -u _Z5setupv -u _Z4loopv -u esp_app_desc -u pthread_include_pthread_impl -u pthread_include_pthread_cond_impl -u pthread_include_pthread_local_storage_impl -u pthread_include_pthread_rwlock_impl -u include_esp_phy_override -u start_app -u __ubsan_include -u __assert_func -u vfs_include_syscalls_impl -Wl,--undefined=uxTopUsedPriority -u app_main -u newlib_include_heap_impl -u newlib_include_syscalls_impl -u newlib_include_pthread_impl -u newlib_include_assert_impl -u __cxa_guard_dummy -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -Wl,--start-group "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977\\sketch\\sketch_jun12a.ino.cpp.o" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_cache_198005\\core\\core_6b60e6c0516acd2e36a3661bed662785.a" -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lriscv -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lasio -lbt -lcbor -lunity -lcmock -lcoap -lnghttp -lesp-tls -lesp_adc_cal -lesp_hid -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lesp_https_server -lesp_lcd -lprotobuf-c -lprotocomm -lmdns -lesp_local_ctrl -lsdmmc -lesp_serial_slave_link -lesp_websocket_client -lexpat -lwear_levelling -lfatfs -lfreemodbus -ljsmn -ljson -llibsodium -lmqtt -lopenssl -lspiffs -lwifi_provisioning -lbutton -lrmaker_common -ljson_parser -ljson_generator -lesp_schedule -lesp_rainmaker -lqrcode -lws2812_led -lesp-dsp -lesp_littlefs -lfb_gfx -lasio -lcbor -lcmock -lunity -lcoap -lesp_lcd -lesp_websocket_client -lexpat -lfreemodbus -ljsmn -llibsodium -lesp_adc_cal -lesp_hid -lfatfs -lwear_levelling -lopenssl -lspiffs -lesp_rainmaker -lesp_local_ctrl -lesp_https_server -lwifi_provisioning -lprotocomm -lbt -lbtdm_app -lprotobuf-c -lmdns -ljson -lrmaker_common -lmqtt -ljson_parser -ljson_generator -lesp_schedule -lqrcode -lcat_face_detect -lhuman_face_detect -lcolor_detect -lmfn -ldl -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lriscv -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lriscv -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lriscv -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lriscv -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lriscv -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lriscv -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lphy -lbtbb -lesp_phy -lphy -lbtbb -lesp_phy -lphy -lbtbb -lm -lnewlib -lstdc++ -lpthread -lgcc -lcxx -lapp_trace -lgcov -lapp_trace -lgcov -lc -Wl,--end-group -Wl,-EL -o "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977/sketch_jun12a.ino.elf" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\3.3.0/esptool.exe" --chip esp32c3 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977/sketch_jun12a.ino.bin" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977/sketch_jun12a.ino.elf" esptool.py v3.3 Creating esp32c3 image... Merged 2 ELF sections Successfully created esp32c3 image. "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3/tools/gen_esp32part.exe" -q "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977/partitions.csv" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977/sketch_jun12a.ino.partitions.bin" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\riscv32-esp-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/riscv32-esp-elf-size" -A "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_24977/sketch_jun12a.ino.elf" 项目使用了 193310 字节,占用了 (14%) 程序存储空间。最大为 1310720 字节。 全局变量使用了9412字节,(2%)的动态内存,余留318268字节局部变量。最大为327680字节。 C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.3.0/esptool.exe --chip esp32c3 --port COM15 --baud 921600 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size 4MB 0x0 C:\Users\User\AppData\Local\Temp\arduino_build_24977/sketch_jun12a.ino.bootloader.bin 0x8000 C:\Users\User\AppData\Local\Temp\arduino_build_24977/sketch_jun12a.ino.partitions.bin 0xe000 C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/partitions/boot_app0.bin 0x10000 C:\Users\User\AppData\Local\Temp\arduino_build_24977/sketch_jun12a.ino.bin esptool.py v3.3 Serial port COM15 Connecting....Traceback (most recent call last): File "esptool.py", line 458, in command File "esptool.py", line 421, in write File "serial\serialwin32.py", line 325, in write serial.serialutil.SerialTimeoutException: Write timeout During handling of the above exception, another exception occurred: Traceback (most recent call last): File "esptool.py", line 5387, in <module> File "esptool.py", line 5380, in _main File "esptool.py", line 4687, in main File "esptool.py", line 115, in get_default_connected_device File "esptool.py", line 664, in connect File "esptool.py", line 629, in _connect_attempt File "esptool.py", line 519, in sync File "esptool.py", line 484, in command File "serial\serialutil.py", line 372, in timeout File "serial\serialwin32.py", line 222, in _reconfigure_port serial.serialutil.SerialException: Cannot configure port, something went wrong. Original message: PermissionError(13, '����ϵͳ�ϵ��豸û�з������á�', None, 31) [10012] Failed to execute script 'esptool' due to unhandled exception! 选择的串口 [10012] Failed to execute script 'esptool' due to unhandled exception! 不存在或开发板没有连接 |
hmilycheng 发表于 2022-6-12 05:46 首次下载前,需要进行如下操作: 1. 断开USB,也就是断电 2. 请将D9与对角线的GND连接 3. 再接上USB 4. 现在就可以正常下载了 下载成功以后,需要进行如下的操作: 1. 断开USB,也就是断电 2. 断开D9与GND的链接 3. 再接上USB 4. 现在就能正常运行了 后续再次下载,就不需要再将D9接GND了,可以直接下载了 |
编辑选择奖
