2022-4-5 03:11:18 [显示全部楼层]
6636浏览
查看: 6636|回复: 4
[讨论] DFPlayer板后面工作的蓝灯没有亮问题出在哪以及如何解决
我用DFPlayer mini mp3模块,利用三个按键做下一首上一首和暂停/播放的效果,线路检查了好几遍,代码也正常,喇叭焊接也是成功的,但是按下按键没有声音,我发现DFPlayer板后面工作的蓝灯没有亮问题出在哪呢,以及怎么解决呀,求求大家帮帮忙,另外附上代码
#include "SoftwareSerial.h"
SoftwareSerial mySerial(10, 11);
# define Start_Byte 0x7E
# define Version_Byte 0xFF
# define Command_Length 0x06
# define End_Byte 0xEF
# define Acknowledge 0x00 //Returns info with command 0x41 [0x01: info, 0x00: no info]
# define ACTIVATED LOW
int buttonNext = 2;
int buttonPause = 3;
int buttonPrevious = 4;
boolean isPlaying = false;
void setup () {
pinMode(buttonPause, INPUT);
digitalWrite(buttonPause,HIGH);
pinMode(buttonNext, INPUT);
digitalWrite(buttonNext,HIGH);
pinMode(buttonPrevious, INPUT);
digitalWrite(buttonPrevious,HIGH);
mySerial.begin (9600);
delay(1000);
playFirst();
isPlaying = true;
void loop () {
if (digitalRead(buttonPause) == ACTIVATED)
    if(isPlaying)
      pause();
      isPlaying = false;
    }else
      isPlaying = true;
      play();
if (digitalRead(buttonNext) == ACTIVATED)
    if(isPlaying)
      playNext();
   if (digitalRead(buttonPrevious) == ACTIVATED)
    if(isPlaying)
      playPrevious();
void playFirst()
  execute_CMD(0x3F, 0, 0);
  delay(500);
  setVolume(20);
  delay(500);
  execute_CMD(0x11,0,1);
  delay(500);
void pause()
  execute_CMD(0x0E,0,0);
  delay(500);
void play()
  execute_CMD(0x0D,0,1);
  delay(500);
void playNext()
  execute_CMD(0x01,0,1);
  delay(500);
void playPrevious()
  execute_CMD(0x02,0,1);
  delay(500);
void setVolume(int volume)
  execute_CMD(0x06, 0, volume); // Set the volume (0x00~0x30)
  delay(2000);
void execute_CMD(byte CMD, byte Par1, byte Par2)
// Excecute the command and parameters
// Calculate the checksum (2 bytes)
word checksum = -(Version_Byte + Command_Length + CMD + Acknowledge + Par1 + Par2);
// Build the command line
byte Command_line[10] = { Start_Byte, Version_Byte, Command_Length, CMD, Acknowledge,
Par1, Par2, highByte(checksum), lowByte(checksum), End_Byte};
//Send the command line to the module
for (byte k=0; k<10; k++)
mySerial.write( Command_line[k]);
发表于 2022-4-5 07:24:09
首先检查连线
TANGQI  学徒
发表于 2022-4-5 12:16:29
连线我检查过好几遍了是没问题的
muzyli  管理员
发表于 2022-4-6 15:58:06
蓝灯不亮说明还没设置好。
1. 文件夹命名需要是mp3,放置在SD卡根目录下,而mp3文件命名需要是4位数字,例如"0001.mp3",放置在mp3文件夹下。
2. 建议直接使用示例代码
3. 尝试交换rxtx两根线
DFPlayer板后面工作的蓝灯没有亮问题出在哪以及如何解决图1
从前  学徒
发表于 2024-8-20 09:02:45
请问您当时解决了吗,我现在也遇到了这种问题
