5554浏览
查看: 5554|回复: 5
[求助] 求助esp32上传不了温湿度到阿里云
esp32连接上了阿里云但是就是温湿度传不进去
温室读获取是正常的串口显示的是这种东西,应该是传输的问题
/*这是我的代码*/麻烦大佬看看下,我用的是商城给的库
#include <WiFi.h>
#include <PubSubClient.h>
#include <ArduinoJson.h>
#include "DFRobot_Aliyun.h"
#include "DFRobot_DHT11.h"
#define DHT11_PIN  14
/*配置WIFI名和密码*/
const char * WIFI_SSID     = "fdb";
const char * WIFI_PASSWORD = "331700918";
/*配置设备证书信息*/
String ProductKey = "a1XcjmmmPnM";
String ClientId = "12345";
String DeviceName = "sensor";
String DeviceSecret = "5a5a9134ebb440bec294f78986a63f27";
/*配置域名和端口号*/
String ALIYUN_SERVER = "iot-as-mqtt.cn-shanghai.aliyuncs.com";
uint16_t PORT = 1883;
/*需要操作的产品标识符(温度和湿度两个标识符)*/
String TempIdentifier = "temp_1";
String HumiIdentifier = "Humi_1";
/*需要上报和订阅的两个TOPIC*/
const char * subTopic = "/sys/a1XcjmmmPnM/${deviceName}/thing/service/property/set";//****set
const char * pubTopic = "/sys/a1XcjmmmPnM/${deviceName}/thing/event/property/post";//******post
DFRobot_Aliyun myAliyun;
WiFiClient espClient;
PubSubClient client(espClient);
DFRobot_DHT11 DHT;
void connectWiFi(){
  Serial.print("Connecting to ");
  Serial.println(WIFI_SSID);
  WiFi.begin(WIFI_SSID,WIFI_PASSWORD);
  while(WiFi.status() != WL_CONNECTED){
    delay(500);
    Serial.print(".");
  Serial.println();
  Serial.println("WiFi connected");
  Serial.print("IP Adderss: ");
  Serial.println(WiFi.localIP());
void callback(char * topic, byte * payload, unsigned int len){
  Serial.print("Recevice [");
  Serial.print(topic);
  Serial.print("] ");
  for (int i = 0; i < len; i++){
    Serial.print((char)payload);
  Serial.println();
void ConnectAliyun(){
  while(!client.connected()){
    Serial.print("Attempting MQTT connection...");
    /*根据自动计算的用户名和密码连接到Alinyun的设备,不需要更改*/
    if(client.connect(myAliyun.client_id,myAliyun.username,myAliyun.password)){
      Serial.println("connected");
      client.subscribe(subTopic);
    }else{
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      delay(5000);
void setup(){
  Serial.begin(115200);
  /*连接WIFI*/
  connectWiFi();
  /*初始化Alinyun的配置,可自动计算用户名和密码*/
  myAliyun.init(ALIYUN_SERVER,ProductKey,ClientId,DeviceName,DeviceSecret);
  client.setServer(myAliyun.mqtt_server,PORT);
  /*设置回调函数,当收到订阅信息时会执行回调函数*/
  client.setCallback(callback);
  /*连接到Aliyun*/
  ConnectAliyun();
uint8_t tempTime = 0;
void loop(){
  if(!client.connected()){
    ConnectAliyun();
  /*一分钟上报两次温湿度信息*/
  if(tempTime > 10){
    tempTime = 0;
    DHT.read(DHT11_PIN);
    Serial.print("DHT.temperature=");
    Serial.println(DHT.temperature);
    Serial.print("DHT.humidity");
    Serial.println(DHT.humidity);
    client.publish(pubTopic,("{\"id\":"+ClientId+",\"params\":{\""+TempIdentifier+"\":"+DHT.temperature+",\""+HumiIdentifier+"\":"+DHT.humidity+"},\"method\":\"thing.event.property.post\"}").c_str());
  }else{
    tempTime++;
    delay(500);
  client.loop();
muzyli  管理员
发表于 2022-3-9 09:42:42
把需要上报和订阅的两个TOPIC改下:
const char * subTopic = "/sys/a1XcjmmmPnM/sensor/thing/service/property/set";//****set
const char * pubTopic = "/sys/a1XcjmmmPnM/sensor/thing/event/property/post";//******post
njwy1978  学徒
发表于 2022-6-1 15:55:05
我也是存在这个问题。阿里云IoT套件能够顺利的连接WiFi,但Web界面不能实时显示传送的温湿度数据。即使按照如下修改上报和订阅的两个TOPIC:
const char * pubTopic = "/sys/a1XcjmmmPnM/sensor/thing/event/property/post";//******post依然不能够实时在阿里云的Web界面上实时显示曲线。不知道怎么解决。
星辰大海://。,  中级技师
发表于 2022-8-28 17:17:48
看一下阿里云的日志服务,到底是阿里云物模型解析不到,还是没有发上去
hellonhy  初级技师
发表于 2022-9-2 16:22:22
看看你定义的标识符数据类型
纯鹿人  学徒
发表于 2023-4-11 20:04:39
你好,在吗,我想请教一下为啥我的激活不了设备o(╥﹏╥)o
关于楼主
