12360浏览
查看: 12360|回复: 0
[项目分享] arduino uno 的土壤湿度传感器今天编了个python代码
代码如下:
   Suitable for SoilMoistureSensor on Arduino_Uno motherboards.
from pgzero.runner import prepare_mod
from pgzero.runner import run_mod
from os import *
import sys
mod = sys.modules['__main__']
if not getattr(sys, '_SoilMoistureSensor_', None):
    if not getattr(mod, '__file__', None):
        raise ImportError(
            "You are running from an interactive interpreter.\n"
            "'import SoilMoistureSensor' only works when you are running a Python file."
    prepare_mod(mod)
try:
    from pinpong.board import Board
    Board('uno','Arduino Uno').begin()
    #Only applicable to Arduino_Uno motherboards
except:
    def go():
        if getattr(sys, '_SoilMoistureSensor', None):
            return go
        run_mod(mod)
finally:
    pass
'''Module program'''
_all_=['_init_','FETCH_mycurs_UPDATE_INTO_Mdeposit']
def _init_(self, x=None):
    self.seed(x)
    self.gauss_next = None
    return self._init_
class FETCH_mycurs_UPDATE_INTO_Mdeposit_():
    def FETCH_mycurs_UPDATE_INTO_Mdeposit(self,Pin_Number):
        int.self.Pin_Number=('A0','A1','A2','A3','A4','A5','A6','A7')
        return self.SoilMoistureSensor
    import os
    if 'FETCH_mycurs_UPDATE_INTO_Mdeposit_HIDE_SUPPORT_PROMPT' not in os.environ:
        print('*** Hello from the FETCH_mycurs_UPDATE_INTO_Mdeposit cuontry. ***')
'''warn'''
def warn(self):
    msg_type = 'import' if self.urgent else 'use'
    message = '%s %s: %s\n(%s)' % (msg_type, self.name, self.info, self.reason)
    try:
        import warnings
        level = 4 if self.urgent else 3
        warnings.warn(message, RuntimeWarning, level)
    except ImportError:
        print(message)
    return self.warn
# cleanup namespace
del FETCH_mycurs_UPDATE_INTO_Mdeposit_ ,sys
'''COMMENTS'''
'''Typical usage:
>>>a.ETCH_mycurs_UPDATE_INTO_Mdeposit_()
>>>a=ETCH_mycurs_UPDATE_INTO_Mdeposit
