4601浏览
查看: 4601|回复: 0
[求助] arduinoSD卡模块识别不到sd卡,可能是什么原因引起的啊?
连线和代码都没问题,卡的类型和端口选择都没有问题,/*
*  Arduino SD Card Tutorial Example
*  by Dejan Nedelkovski, www.HowToMechatronics.com
#include <SD.h>
#include <SPI.h>
File myFile;
int pinCS = 53; // Pin 10 on Arduino Uno
void setup() {
  Serial.begin(9600);
  pinMode(pinCS, OUTPUT);
  // SD Card Initialization
  if (SD.begin())
    Serial.println("SD card is ready to use.");
  } else
    Serial.println("SD card initialization failed");
    return;
  // Create/Open file
  myFile = SD.open("test.txt", FILE_WRITE);
  // if the file opened okay, write to it:
  if (myFile) {
    Serial.println("Writing to file...");
    // Write to file
    myFile.println("Testing text 1, 2 ,3...");
    myFile.close(); // close the file
    Serial.println("Done.");
  // if the file didn't open, print an error:
  else {
    Serial.println("error opening test.txt");
  // Reading the file
  myFile = SD.open("test.txt");
  if (myFile) {
    Serial.println("Read:");
    // Reading the whole file
    while (myFile.available()) {
      Serial.write(myFile.read());
    myFile.close();
  else {
void loop() {
  // empty
选的2560板子,代码也没有问题,但是显示初始化失败是怎么回事呢
