 【晃动灯】
 1、数字震动传感器
 本开关在静止时为开路(OFF)状态,当受到外力碰触而达到适当震动力时,或移动速度达到适当离(偏)心力时,导电接脚会发生瞬间导通(ON)状态,使电气特性改变,而当外力消失时电气特性恢复开路(OFF)状态。无方向性,任何角度均可以触发工作。
#include <Adafruit_NeoPixel.h>
#define PIN_LED 16
#define NUM_LED 1
int shake =25;
Adafruit_NeoPixel pixels(NUM_LED, PIN_LED, NEO_GRB + NEO_KHZ800);
void setup() {
  // put your setup code here, to run once:
  pixels.begin();
  pinMode(shake, INPUT);
  pinMode(16, OUTPUT);
  Serial.begin(9600);
void loop() {
  pixels.clear();
  int State = digitalRead(shake);
  Serial.println(State);
  if(State==0){
    pixels.setBrightness(200);
    pixels.setPixelColor(0, pixels.Color(int(random(0,255)), int(random(0,255)),int( random(0,255))));
    pixels.show();
    delay(2000);
    pixels.setBrightness(0);
    pixels.show();
 LIS2DW12三轴加速度计是一款超低功耗的线性加速度计,该传感器拥有两个独立的可编程中断及专用内部引擎,可实现超多功能,例如自由落体检测、纵向/横向检测、朝向检测、可配置的单击/双击识别、运动检测、运动唤醒以实现高级省电等,我们为您提供了以上功能的示例程序,方便您在项目中轻松使用。 该传感器具有±2g /±4g /±8g /±16g的用户可选全刻度,并能够以1.6 Hz至1600 Hz的输出数据速率测量加速度,它内置多种带宽的多种运行模式,您可以按需选择合适的模式。
 * @file orientation.ino
 * @brief When detecting the orientation of the module, the sensor can detect the following six events:
 * @n Positive z-axis is facing up
 * @n Positive z-axis is facing down
 * @n Positive y-axis is facing up
 * @n Positive y-axis is facing down
 * @n Positive x-axis is facing up
 * @n Positive x-axis is facing down
 * @n When using SPI, chip select pin can be modified by changing the value of macro LIS2DW12_CS
 * @copyright  Copyright (c) 2010 DFRobot Co.Ltd (http://www.dfrobot.com)
 * @licence     The MIT License (MIT)
 * @author [fengli](li.feng@dfrobot.com)
 * @version  V1.0
 * @date  2021-01-16
 * @get from https://www.dfrobot.com
 * @https://github.com/DFRobot/DFRobot_LIS
#include <DFRobot_LIS2DW12.h>
#define PIN_LED 16
#define NUM_LED 1
//When using I2C communication, use the following program to construct an object by DFRobot_LIS2DW12_I2C
 * @brief Constructor
 * @param pWire I2c controller
 * @param addr  I2C address(0x18/0x19)
DFRobot_LIS2DW12_I2C acce(&Wire,0x18);
//DFRobot_LIS2DW12_I2C acce;
//When using SPI communication, use the following program to construct an object by DFRobot_LIS2DW12_SPI
#if defined(ESP32) || defined(ESP8266)
#define LIS2DW12_CS  D3
#elif defined(__AVR__) || defined(Arduino_SAM_ZERO)
#define LIS2DW12_CS 3
#elif (defined NRF5)
#define LIS2DW12_CS 2  //The pin on the development board with the corresponding silkscreen printed as P2
#endif
 * @param cs Chip selection pinChip selection pin
 * @param spi SPI controller
//DFRobot_LIS2DW12_SPI acce(/*cs = */LIS2DW12_CS,&SPI);
//DFRobot_LIS2DW12_SPI acce(/*cs = */LIS2DW12_CS);
int lastOrientation = 0; //No event happened
void setup(void){
  pixels.begin();
  Serial.begin(9600);
  while(!acce.begin()){
     Serial.println("Communication failed, check the connection and I2C address setting when using I2C communication.");
     delay(1000);
  Serial.print("chip id : ");
  Serial.println(acce.getID(),HEX);
  //Chip soft reset
  acce.softReset();
    Set the sensor measurement range:
                   e2_g   /<±2g>/
                   e4_g   /<±4g>/
                   e8_g   /<±8g>/
                   e16_g  /< ±16g>/
  acce.setRange(DFRobot_LIS2DW12::e2_g);
   Set power mode:
       eHighPerformance_14bit         /<High-Performance Mode,14-bit resolution>/
       eContLowPwr4_14bit             /<Continuous measurement,Low-Power Mode 4(14-bit resolution)>/
       eContLowPwr3_14bit             /<Continuous measurement,Low-Power Mode 3(14-bit resolution)>/
       eContLowPwr2_14bit             /<Continuous measurement,Low-Power Mode 2(14-bit resolution)/
       eContLowPwr1_12bit             /<Continuous measurement,Low-Power Mode 1(12-bit resolution)>/
       eSingleLowPwr4_14bit           /<Single data conversion on demand mode,Low-Power Mode 4(14-bit resolution)>/
       eSingleLowPwr3_14bit           /<Single data conversion on demand mode,Low-Power Mode 3(14-bit resolution)>/
       eSingleLowPwr2_14bit           /<Single data conversion on demand mode,Low-Power Mode 2(14-bit resolution)>/
       eSingleLowPwr1_12bit           /<Single data conversion on demand mode,Low-Power Mode 1(12-bit resolution)>/
       eHighPerformanceLowNoise_14bit /<High-Performance Mode,Low-noise enabled,14-bit resolution>/
       eContLowPwrLowNoise4_14bit     /<Continuous measurement,Low-Power Mode 4(14-bit resolution,Low-noise enabled)>/
       eContLowPwrLowNoise3_14bit     /<Continuous measurement,Low-Power Mode 3(14-bit resolution,Low-noise enabled)>/
       eContLowPwrLowNoise2_14bit     /<Continuous measurement,Low-Power Mode 2(14-bit resolution,Low-noise enabled)>/
       eContLowPwrLowNoise1_12bit     /<Continuous measurement,Low-Power Mode 1(12-bit resolution,Low-noise enabled)>/
       eSingleLowPwrLowNoise4_14bit   /<Single data conversion on demand mode,Low-Power Mode 4(14-bit resolution),Low-noise enabled>/
       eSingleLowPwrLowNoise3_14bit   /<Single data conversion on demand mode,Low-Power Mode 3(14-bit resolution),Low-noise enabled>/
       eSingleLowPwrLowNoise2_14bit   /<Single data conversion on demand mode,Low-Power Mode 2(14-bit resolution),Low-noise enabled>/
       eSingleLowPwrLowNoise1_12bit   /<Single data conversion on demand mode,Low-Power Mode 1(12-bit resolution),Low-noise enabled>/
  acce.setPowerMode(DFRobot_LIS2DW12::eContLowPwrLowNoise1_12bit);
    Set the sensor data collection rate:
               eRate_0hz           /<Measurement off>/
               eRate_1hz6          /<1.6hz, use only under low-power mode>/
               eRate_12hz5         /<12.5hz>/
               eRate_25hz
               eRate_50hz
               eRate_100hz
               eRate_200hz
               eRate_400hz       /<Use only under High-Performance mode>/
               eRate_800hz       /<Use only under High-Performance mode>/
               eRate_1k6hz       /<Use only under High-Performance mode>/
               eSetSwTrig        /<The software triggers a single measurement>/
  acce.setDataRate(DFRobot_LIS2DW12::eRate_200hz);
    Set the threshold of the angle when turning:
                     eDegrees80   (80°)
                     eDegrees70   (70°)
                     eDegrees60   (60°)
                     eDegrees50   (50°)
  acce.set6DThreshold(DFRobot_LIS2DW12::eDegrees60);
    Set the interrupt source of the int1 pin:
    eDoubleTap(Double click)
    eFreeFall(Free fall)
    eWakeUp(wake)
    eSingleTap(single-Click)
    e6D(Orientation change check)
  acce.setInt1Event(DFRobot_LIS2DW12::e6D);
  delay(1000);
void loop(void){
    //check Changes detected in six directions
    if(acce.oriChangeDetected()){
        DFRobot_LIS2DW12::eOrient_t orientation = acce.getOrientation();
        if(lastOrientation != orientation){
            if(orientation == DFRobot_LIS2DW12::eXDown){
             pixels.setPixelColor(0, pixels.Color(255,0,0));
             pixels.show();
            if(orientation == DFRobot_LIS2DW12::eXUp){
             pixels.setPixelColor(0, pixels.Color(255,255,0));
             pixels.show();
            if(orientation == DFRobot_LIS2DW12::eYDown){
             pixels.setPixelColor(0, pixels.Color(255,255,255));
             pixels.show();
            if(orientation == DFRobot_LIS2DW12::eYUp){
             pixels.setPixelColor(0, pixels.Color(0,255,0));
             pixels.show();
            if(orientation == DFRobot_LIS2DW12::eZDown){
             pixels.setPixelColor(0, pixels.Color(0,255,255));
             pixels.show();
            if(orientation == DFRobot_LIS2DW12::eZUp){
             pixels.setPixelColor(0, pixels.Color(0,0,255));
             pixels.show();
            lastOrientation = orientation;
 2、演示视频
