 【数字RGB全彩LED】
 数字RGB全彩LED模块是一款可级联的RGB全彩单灯珠模块。与传统RGB全彩灯珠需要3根控制信号线,硬件占用资源多不同,该模块控制仅需一根信号线,符合Gravity-3P数字接口规范,配合DF各类扩展板,即插即用,可方便用于Arduino、micro:bit、ESP32、LattePanda、树莓派等各类主控平台。
 【安装Adafruit NeoPixel库】
 https://www.arduinolibraries.info/libraries/adafruit-neo-pixel
 【安装灯】
 【亮灯】
 程序
#include <Adafruit_NeoPixel.h>
#define PIN        16
#define NUMPIXELS 1
Adafruit_NeoPixel pixels(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
void setup() {
  pixels.begin();
void loop() {
  pixels.clear();
  pixels.setPixelColor(0, pixels.Color(255,0, 0));
  pixels.show();
 【SHT31-F数字温湿度传感器】
 Gravity: SHT31-F数字温湿度传感器采用业内知名的瑞士Sensirion公司推出的新一代SHT31-F温湿度传感器芯片。得益于Sensirion的CMOSens®技术,高集成度电容式测湿元件和能隙式测温元件,SHT31-F能够提供极高的可靠性和出色的长期稳定性,具有功耗低、反应快、抗干扰能力强等优点。IIC通讯,兼容3.3V/5V,可以非常容易的集成到智能楼宇、天气站、仓库存储、养殖、孵化等应用场景中。
  #include <DFRobot_SHT3x.h>
 //DFRobot_SHT3x sht3x(&Wire,/*address=*/0x45,/*RST=*/4);
    DFRobot_SHT3x   sht3x;
    void setup() {
      Serial.begin(9600);
      //Initialize the chip
      while (sht3x.begin() != 0) {
        Serial.println("Failed to Initialize the chip, please confirm the wire connection");
        delay(1000);
       * readSerialNumber Read the serial number of the chip.
       * @return Return 32-digit serial number.
      Serial.print("Chip serial number");
      Serial.println(sht3x.readSerialNumber());
       if(!sht3x.softReset()){
         Serial.println("Failed to Initialize the chip....");
      Serial.println("------------------Read adta in single measurement mode-----------------------");
    void loop() {
      Serial.print("Ambient Temperature(°C/F):");
      Serial.print(sht3x.getTemperatureC());
      Serial.print(" C/");
      Serial.print(sht3x.getTemperatureF());
      Serial.print(" F ");
      Serial.print("Relative Humidity(%RH):");
      Serial.print(sht3x.getHumidityRH());
      Serial.println(" %RH");
      DFRobot_SHT3x::sRHAndTemp_t data = sht3x.readTemperatureAndHumidity(sht3x.eRepeatability_High);
      if(data.ERR == 0){
        Serial.print(data.TemperatureC);
        Serial.print(data.TemperatureF);
        Serial.print(data.Humidity);
      delay(1000);
 【温控灯】
 扩大温度值,让灯颜色变化更加明显。
#define PIN        16
#define NUMPIXELS 1
int number=0;
void setup() {
    Serial.begin(9600);
        delay(1000);
     pixels.begin();
void loop() {
      if(data.ERR == 0){
        int number=map(int(data.TemperatureC*100),2700,3400,0,65535);
        pixels.clear();
        Serial.println(int(data.TemperatureC*100));
        Serial.println(number);
        if(number>65535){
          number=65535;
        if(number<0){
          number=0;
        int r = number >> 16;
        int g = number >> 8 & 0xFF;
        int b = number & 0xFF;
        pixels.setPixelColor(0, pixels.Color(r,g, b));
        pixels.show();
      delay(2000);
