53660浏览
查看: 53660|回复: 193
[ESP8266/ESP32] 最像Arduino Uno的ESP32开发板之WeMos D1 R32
ESP32已经集成了天线和射频balun、功率放大器、低噪声放大器、滤波器和电源管理模块。整个解决方案占用的印刷电路板面积最少。该板与双模式Wi-Fi和蓝牙芯片一起使用,安全,可扩展到各种应用。
最像Arduino Uno的ESP32开发板之WeMos D1 R32图1
驴友花雕  中级技神
发表于 2022-11-16 15:23:54
  实验一百七十七:Wemos D1 R32 ESP32开发板
  项目之四十四:esp32 NeoPixel 灯板测试程序
  1. /*
  3.   实验一百七十七:Wemos D1 R32 ESP32开发板
  4.   项目之四十四:esp32 NeoPixel 灯板测试程序
  5. */
  6. #include <Adafruit_NeoPixel.h>
  7. // Which pin on the Arduino is connected to the NeoPixels?
  8. // On a Trinket or Gemma we suggest changing this to 1:
  9. #define LED_PIN    23
  10. // How many NeoPixels are attached to the Arduino?
  11. #define LED_COUNT 256
  12. // Declare our NeoPixel strip object:
  13. Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
  14. // Argument 1 = Number of pixels in NeoPixel strip
  15. // Argument 2 = Arduino pin number (most are valid)
  16. // Argument 3 = Pixel type flags, add together as needed:
  17. //   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
  18. //   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
  19. //   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
  20. //   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
  21. //   NEO_RGBW    Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
  22. // setup() function -- runs once at startup --------------------------------
  23. void setup() {
  24.   // These lines are specifically to support the Adafruit Trinket 5V 16 MHz.
  25.   // Any other board, you can remove this part (but no harm leaving it):
  26.   //#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000)
  27.   //clock_prescale_set(clock_div_1);
  28.   //#endif
  29.   // END of Trinket-specific code.
  30.   strip.begin();           // INITIALIZE NeoPixel strip object (REQUIRED)
  31.   strip.show();            // Turn OFF all pixels ASAP
  32.   strip.setBrightness(50); // Set BRIGHTNESS to about 1/5 (max = 255)
  33. }
  34. // loop() function -- runs repeatedly as long as board is on ---------------
  35. void loop() {
  36.   // Fill along the length of the strip in various colors...
  37.   colorWipe(strip.Color(255,   0,   0), 50); // Red
  38.   colorWipe(strip.Color(  0, 255,   0), 50); // Green
  39.   colorWipe(strip.Color(  0,   0, 255), 50); // Blue
  40.   // Do a theater marquee effect in various colors...
  41.   theaterChase(strip.Color(127, 127, 127), 50); // White, half brightness
  42.   theaterChase(strip.Color(127,   0,   0), 50); // Red, half brightness
  43.   theaterChase(strip.Color(  0,   0, 127), 50); // Blue, half brightness
  44.   rainbow(10);             // Flowing rainbow cycle along the whole strip
  45.   theaterChaseRainbow(50); // Rainbow-enhanced theaterChase variant
  46. }
  47. // Some functions of our own for creating animated effects -----------------
  48. // Fill strip pixels one after another with a color. Strip is NOT cleared
  49. // first; anything there will be covered pixel by pixel. Pass in color
  50. // (as a single 'packed' 32-bit value, which you can get by calling
  51. // strip.Color(red, green, blue) as shown in the loop() function above),
  52. // and a delay time (in milliseconds) between pixels.
  53. void colorWipe(uint32_t color, int wait) {
  54.   for (int i = 0; i < strip.numPixels(); i++) { // For each pixel in strip...
  55.     strip.setPixelColor(i, color);         //  Set pixel's color (in RAM)
  56.     strip.show();                          //  Update strip to match
  57.     delay(10);                           //  Pause for a moment
  58.   }
  59. }
  60. // Theater-marquee-style chasing lights. Pass in a color (32-bit value,
  61. // a la strip.Color(r,g,b) as mentioned above), and a delay time (in ms)
  62. // between frames.
  63. void theaterChase(uint32_t color, int wait) {
  64.   for (int a = 0; a < 10; a++) { // Repeat 10 times...
  65.     for (int b = 0; b < 3; b++) { //  'b' counts from 0 to 2...
  66.       strip.clear();         //   Set all pixels in RAM to 0 (off)
  67.       // 'c' counts up from 'b' to end of strip in steps of 3...
  68.       for (int c = b; c < strip.numPixels(); c += 3) {
  69.         strip.setPixelColor(c, color); // Set pixel 'c' to value 'color'
  70.       }
  71.       strip.show(); // Update strip with new contents
  72.       delay(10);  // Pause for a moment
  73.     }
  74.   }
  75. }
  76. // Rainbow cycle along whole strip. Pass delay time (in ms) between frames.
  77. void rainbow(int wait) {
  78.   // Hue of first pixel runs 5 complete loops through the color wheel.
  79.   // Color wheel has a range of 65536 but it's OK if we roll over, so
  80.   // just count from 0 to 5*65536. Adding 256 to firstPixelHue each time
  81.   // means we'll make 5*65536/256 = 1280 passes through this outer loop:
  82.   for (long firstPixelHue = 0; firstPixelHue < 5 * 65536; firstPixelHue += 256) {
  83.     for (int i = 0; i < strip.numPixels(); i++) { // For each pixel in strip...
  84.       // Offset pixel hue by an amount to make one full revolution of the
  85.       // color wheel (range of 65536) along the length of the strip
  86.       // (strip.numPixels() steps):
  87.       int pixelHue = firstPixelHue + (i * 65536L / strip.numPixels());
  88.       // strip.ColorHSV() can take 1 or 3 arguments: a hue (0 to 65535) or
  89.       // optionally add saturation and value (brightness) (each 0 to 255).
  90.       // Here we're using just the single-argument hue variant. The result
  91.       // is passed through strip.gamma32() to provide 'truer' colors
  92.       // before assigning to each pixel:
  93.       strip.setPixelColor(i, strip.gamma32(strip.ColorHSV(pixelHue)));
  94.     }
  95.     strip.show(); // Update strip with new contents
  96.     delay(10);  // Pause for a moment
  97.   }
  98. }
  99. // Rainbow-enhanced theater marquee. Pass delay time (in ms) between frames.
  100. void theaterChaseRainbow(int wait) {
  101.   int firstPixelHue = 0;     // First pixel starts at red (hue 0)
  102.   for (int a = 0; a < 30; a++) { // Repeat 30 times...
  103.     for (int b = 0; b < 3; b++) { //  'b' counts from 0 to 2...
  104.       strip.clear();         //   Set all pixels in RAM to 0 (off)
  105.       // 'c' counts up from 'b' to end of strip in increments of 3...
  106.       for (int c = b; c < strip.numPixels(); c += 3) {
  107.         // hue of pixel 'c' is offset by an amount to make one full
  108.         // revolution of the color wheel (range 65536) along the length
  109.         // of the strip (strip.numPixels() steps):
  110.         int      hue   = firstPixelHue + c * 65536L / strip.numPixels();
  111.         uint32_t color = strip.gamma32(strip.ColorHSV(hue)); // hue -> RGB
  112.         strip.setPixelColor(c, color); // Set pixel 'c' to value 'color'
  113.       }
  114.       strip.show();                // Update strip with new contents
  115.       delay(10);                 // Pause for a moment
  116.       firstPixelHue += 65536 / 90; // One cycle of color wheel over 90 frames
  117.     }
  118.   }
  119. }
驴友花雕  中级技神
发表于 2021-7-13 18:13:03
  项目二十六:打印 ESP32 上次复位原因
  1. /*
  4.   项目二十六:打印 ESP32 上次复位原因
  5. */
  6. #include <rom/rtc.h>
  7. #define uS_TO_S_FACTOR 1000000  /* Conversion factor for micro seconds to seconds */
  8. void print_reset_reason(RESET_REASON reason){
  9.   switch ( reason) {
  10.     case 1 : Serial.println ("POWERON_RESET"); break;         /**<1,  Vbat power on reset*/
  11.     case 3 : Serial.println ("SW_RESET"); break;              /**<3,  Software reset digital core*/
  12.     case 4 : Serial.println ("OWDT_RESET"); break;            /**<4,  Legacy watch dog reset digital core*/
  13.     case 5 : Serial.println ("DEEPSLEEP_RESET"); break;       /**<5,  Deep Sleep reset digital core*/
  14.     case 6 : Serial.println ("SDIO_RESET"); break;            /**<6,  Reset by SLC module, reset digital core*/
  15.     case 7 : Serial.println ("TG0WDT_SYS_RESET"); break;      /**<7,  Timer Group0 Watch dog reset digital core*/
  16.     case 8 : Serial.println ("TG1WDT_SYS_RESET"); break;      /**<8,  Timer Group1 Watch dog reset digital core*/
  17.     case 9 : Serial.println ("RTCWDT_SYS_RESET"); break;      /**<9,  RTC Watch dog Reset digital core*/
  18.     case 10 : Serial.println ("INTRUSION_RESET"); break;      /**<10, Instrusion tested to reset CPU*/
  19.     case 11 : Serial.println ("TGWDT_CPU_RESET"); break;      /**<11, Time Group reset CPU*/
  20.     case 12 : Serial.println ("SW_CPU_RESET"); break;         /**<12, Software reset CPU*/
  21.     case 13 : Serial.println ("RTCWDT_CPU_RESET"); break;     /**<13, RTC Watch dog Reset CPU*/
  22.     case 14 : Serial.println ("EXT_CPU_RESET"); break;        /**<14, for APP CPU, reseted by PRO CPU*/
  23.     case 15 : Serial.println ("RTCWDT_BROWN_OUT_RESET"); break; /**<15, Reset when the vdd voltage is not stable*/
  24.     case 16 : Serial.println ("RTCWDT_RTC_RESET"); break;     /**<16, RTC Watch dog reset digital core and rtc module*/
  25.     default : Serial.println ("NO_MEAN");
  26.   }
  27. }
  28. void verbose_print_reset_reason(RESET_REASON reason){
  29.   switch ( reason){
  30.     case 1  : Serial.println ("Vbat power on reset"); break;
  31.     case 3  : Serial.println ("Software reset digital core"); break;
  32.     case 4  : Serial.println ("Legacy watch dog reset digital core"); break;
  33.     case 5  : Serial.println ("Deep Sleep reset digital core"); break;
  34.     case 6  : Serial.println ("Reset by SLC module, reset digital core"); break;
  35.     case 7  : Serial.println ("Timer Group0 Watch dog reset digital core"); break;
  36.     case 8  : Serial.println ("Timer Group1 Watch dog reset digital core"); break;
  37.     case 9  : Serial.println ("RTC Watch dog Reset digital core"); break;
  38.     case 10 : Serial.println ("Instrusion tested to reset CPU"); break;
  39.     case 11 : Serial.println ("Time Group reset CPU"); break;
  40.     case 12 : Serial.println ("Software reset CPU"); break;
  41.     case 13 : Serial.println ("RTC Watch dog Reset CPU"); break;
  42.     case 14 : Serial.println ("for APP CPU, reseted by PRO CPU"); break;
  43.     case 15 : Serial.println ("Reset when the vdd voltage is not stable"); break;
  44.     case 16 : Serial.println ("RTC Watch dog reset digital core and rtc module"); break;
  45.     default : Serial.println ("NO_MEAN");
  46.   }
  47. }
  48. void setup() {
  49.   // put your setup code here, to run once:
  50.   Serial.begin(115200);
  51.   delay(2000);
  52.   Serial.println("CPU0 reset reason:");
  53.   print_reset_reason(rtc_get_reset_reason(0));
  54.   verbose_print_reset_reason(rtc_get_reset_reason(0));
  55.   Serial.println("CPU1 reset reason:");
  56.   print_reset_reason(rtc_get_reset_reason(1));
  57.   verbose_print_reset_reason(rtc_get_reset_reason(1));
  58.   // Set ESP32 to go to deep sleep to see a variation
  59.   // in the reset reason. Device will sleep for 5 seconds.
  60.   esp_sleep_pd_config(ESP_PD_DOMAIN_RTC_PERIPH, ESP_PD_OPTION_OFF);
  61.   Serial.println("Going to sleep");
  62.   esp_deep_sleep(5 * uS_TO_S_FACTOR);
  63. }
  64. void loop() {
  65.   // put your main code here, to run repeatedly:
  66. }
  67. /*
  68.   Example Serial Log:
  69.   ====================
  70.   rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
  71.   configsip: 0, SPIWP:0x00
  72.   clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
  73.   mode:DIO, clock div:1
  74.   load:0x3fff0008,len:8
  75.   load:0x3fff0010,len:160
  76.   load:0x40078000,len:10632
  77.   load:0x40080000,len:252
  78.   entry 0x40080034
  79.   CPU0 reset reason:
  80.   RTCWDT_RTC_RESET
  81.   RTC Watch dog reset digital core and rtc module
  82.   CPU1 reset reason:
  83.   EXT_CPU_RESET
  84.   for APP CPU, reseted by PRO CPU
  85.   Going to sleep
  86.   ets Jun  8 2016 00:22:57
  87.   rst:0x5 (DEEPSLEEP_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
  88.   configsip: 0, SPIWP:0x00
  89.   clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
  90.   mode:DIO, clock div:1
  91.   load:0x3fff0008,len:8
  92.   load:0x3fff0010,len:160
  93.   load:0x40078000,len:10632
  94.   load:0x40080000,len:252
  95.   entry 0x40080034
  96.   CPU0 reset reason:
  97.   DEEPSLEEP_RESET
  98.   Deep Sleep reset digital core
  99.   CPU1 reset reason:
  100.   EXT_CPU_RESET
  101.   for APP CPU, reseted by PRO CPU
  102.   Going to sleep
  103.   ets Jun  8 2016 00:22:57
  104.   rst:0x5 (DEEPSLEEP_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
  105.   configsip: 0, SPIWP:0x00
  106.   clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
  107.   mode:DIO, clock div:1
  108.   load:0x3fff0008,len:8
  109.   load:0x3fff0010,len:160
  110.   load:0x40078000,len:10632
  111.   load:0x40080000,len:252
  112.   entry 0x40080034
  113.   CPU0 reset reason:
  114.   DEEPSLEEP_RESET
  115.   Deep Sleep reset digital core
  116.   CPU1 reset reason:
  117.   EXT_CPU_RESET
  118.   for APP CPU, reseted by PRO CPU
  119.   Going to sleep
  120. */
驴友花雕  中级技神
发表于 2021-7-14 12:24:16
  项目三十三:OLED屏显示矢量图片
  实验接脚: 0.96寸OLED液晶屏SDA接22, SCL接21
  1. /*
  4.   项目三十三:OLED屏显示矢量图片
  5.   实验接脚: 0.96寸OLED液晶屏SDA接22, SCL接21
  6. */
  7. #include "ssd1306.h"
  8. const uint8_t Owl [] PROGMEM = {
  9. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  10. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  11. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  12. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  13. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  14. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06,
  15. 0x0A, 0x05, 0x0D, 0x01, 0x01, 0x03, 0x87, 0xFE, 0xFE, 0xFC, 0xF8, 0xF0, 0x00, 0x00, 0x00, 0x00,
  16. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  17. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  18. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  19. 0x00, 0x00, 0x00, 0x80, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  20. 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  21. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  22. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x0E,
  23. 0x08, 0x0C, 0x0C, 0x0C, 0x0E, 0x0F, 0x0F, 0x07, 0x07, 0x03, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00,
  24. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  25. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  26. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xE0, 0x30,
  27. 0x98, 0xDE, 0xE6, 0xE7, 0xF7, 0xD7, 0xD6, 0x56, 0x56, 0xD7, 0xD7, 0x5F, 0xDF, 0x3F, 0x3F, 0x2F,
  28. 0x9F, 0xD7, 0xDF, 0x6F, 0x6B, 0x6B, 0x7F, 0xF7, 0xF3, 0xF3, 0xE0, 0xEC, 0x98, 0x30, 0xE0, 0x80,
  29. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x60, 0x70, 0x70, 0x60,
  30. 0x40, 0x60, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xC0, 0xC0, 0xE0, 0xF0, 0xE0, 0x40, 0x00,
  31. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  32. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  33. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  34. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFB, 0xE0,
  35. 0xDF, 0xB1, 0xEF, 0x5F, 0xB9, 0xB0, 0xA0, 0xE6, 0x6E, 0x2E, 0xB6, 0xB9, 0x9F, 0xAF, 0xA0, 0xA7,
  36. 0xBF, 0x99, 0xB6, 0xB6, 0xA6, 0xA6, 0xB0, 0xB0, 0xA9, 0xDF, 0xCF, 0xF0, 0x7F, 0x77, 0xFD, 0x01,
  37. 0x80, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x08, 0xEE, 0xB3, 0x7D, 0xBE, 0x7F, 0xC7, 0x87, 0xB7,
  38. 0xB7, 0xB7, 0xCD, 0x7D, 0x83, 0x93, 0xFB, 0xCD, 0xB5, 0x35, 0xA5, 0x87, 0xCE, 0xFE, 0x1C, 0xF9,
  39. 0xC3, 0x1C, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  40. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  41. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  42. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x1F, 0x3F, 0x3C, 0x73,
  43. 0xEF, 0x9E, 0x7E, 0xFD, 0xFD, 0xED, 0xAD, 0xFD, 0xDD, 0xFF, 0xBF, 0xFF, 0x5F, 0xDF, 0xEF, 0xFF,
  44. 0xFF, 0xFF, 0x6F, 0xFF, 0xDF, 0xEF, 0xFD, 0xDD, 0xFD, 0xBC, 0xFE, 0x7E, 0xBF, 0xEF, 0x7B, 0x3E,
  45. 0x1F, 0x0F, 0x07, 0x00, 0x00, 0x0E, 0x1F, 0x3C, 0x77, 0x5F, 0x3D, 0x7D, 0xFB, 0xFB, 0x7A, 0xFA,
  46. 0xFE, 0xFE, 0xFE, 0xFE, 0xFF, 0xFF, 0x7E, 0xFE, 0xBF, 0xFD, 0xF5, 0xF5, 0xF6, 0xFA, 0xFB, 0xDF,
  47. 0x67, 0x78, 0x3C, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x00, 0x00,
  48. 0x60, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  49. 0x00, 0x00, 0x00, 0xC0, 0x80, 0x00, 0x00, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  50. 0x00, 0x40, 0x00, 0x10, 0x38, 0x80, 0x00, 0x00, 0x80, 0xC0, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00,
  51. 0x00, 0x00, 0x01, 0x00, 0x00, 0x81, 0x83, 0x83, 0x87, 0xE7, 0xEF, 0xEF, 0xEB, 0xFF, 0xF7, 0xDF,
  52. 0xFA, 0xFE, 0xFF, 0xEB, 0xEE, 0xEE, 0xE7, 0x67, 0x63, 0x61, 0x60, 0x60, 0x60, 0xE0, 0xE0, 0xE0,
  53. 0x60, 0x60, 0x60, 0x60, 0x60, 0x60, 0x70, 0x70, 0x70, 0x70, 0x70, 0x70, 0x70, 0x71, 0x73, 0x7B,
  54. 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7E, 0x7F, 0x77, 0x76, 0x73, 0x73, 0x71, 0x71, 0x70, 0x71, 0x70,
  55. 0x70, 0x70, 0x70, 0x70, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF1, 0xF1, 0xF1, 0xE0, 0xE0,
  56. 0xE8, 0xEC, 0xEE, 0xE7, 0xE2, 0xE4, 0xE8, 0xD0, 0xE0, 0xE0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0,
  57. 0x10, 0x10, 0x10, 0x10, 0x1F, 0x13, 0xA1, 0xAD, 0xC8, 0x49, 0x47, 0x42, 0x40, 0xC0, 0xDC, 0x78,
  58. 0x60, 0x60, 0x20, 0x21, 0x31, 0x30, 0x11, 0x1A, 0x1B, 0x0B, 0x0D, 0x0C, 0x04, 0x06, 0x06, 0x06,
  59. 0x03, 0x03, 0x03, 0x13, 0x31, 0x71, 0x71, 0x61, 0x81, 0x81, 0x41, 0x20, 0x26, 0x0C, 0x1C, 0x30,
  60. 0x78, 0x00, 0x00, 0x84, 0xC4, 0x84, 0x84, 0x0C, 0x04, 0x02, 0x02, 0x01, 0x01, 0x07, 0x0E, 0x0E,
  61. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  62. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0xE0, 0xE0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
  63. 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0xE0, 0xC0, 0xC0, 0x00, 0x00, 0x81, 0x81, 0x81, 0x41, 0x41,
  64. 0x21, 0x21, 0x13, 0x13, 0x13, 0x03, 0x0B, 0x0B, 0x0B, 0x0F, 0x0F, 0x07, 0x07, 0x07, 0x07, 0x07,
  65. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x01, 0x01, 0x00, 0x00, 0x06, 0x07, 0x03, 0x03, 0x00,
  66. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x0C, 0x40, 0xEE, 0x79,
  67. 0x35, 0x02, 0x08, 0x08, 0x04, 0x04, 0x02, 0x1F, 0x3D, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04,
  68. 0x04, 0x24, 0x00, 0x0D, 0x30, 0x31, 0x01, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  69. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x82, 0xC6, 0xC6, 0x36, 0x68, 0x44,
  70. 0xB4, 0xA0, 0x52, 0x62, 0x02, 0x02, 0x02, 0x00, 0x01, 0x03, 0x32, 0x7A, 0x3E, 0x1A, 0x02, 0x02,
  71. 0x02, 0x02, 0x02, 0x02, 0x02, 0x00, 0x1D, 0x3D, 0x1D, 0x01, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00,
  72. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
  73. };
  74. const uint8_t Soba [] PROGMEM = {
  75. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  76. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  77. 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x80,
  78. 0x09, 0x00, 0x00, 0x00, 0xc0, 0x0c, 0x00, 0x00,
  79. 0x00, 0x60, 0x06, 0x00, 0x00, 0x00, 0x30, 0x03,
  80. 0x00, 0x00, 0x00, 0x98, 0x01, 0x00, 0xf8, 0x00,
  81. 0xcc, 0x00, 0x00, 0xde, 0x03, 0x66, 0x00, 0x80,
  82. 0x07, 0x0f, 0x33, 0x00, 0xc0, 0x01, 0x9c, 0x19,
  83. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe0, 0xff,
  84. 0xff, 0xff, 0x07, 0xe0, 0xff, 0xff, 0xff, 0x07,
  85. 0xe0, 0xff, 0xff, 0xff, 0x07, 0xe0, 0xff, 0xff,
  86. 0xff, 0x07, 0xe0, 0xff, 0xff, 0xff, 0x07, 0xc0,
  87. 0xff, 0xff, 0xff, 0x03, 0xc0, 0xff, 0xff, 0xff,
  88. 0x03, 0x80, 0xff, 0xff, 0xff, 0x01, 0x80, 0xff,
  89. 0xff, 0xff, 0x01, 0x00, 0xff, 0xff, 0xff, 0x00,
  90. 0x00, 0xfe, 0xff, 0x7f, 0x00, 0x00, 0xfc, 0xff,
  91. 0x3f, 0x00, 0x00, 0xf8, 0xff, 0x1f, 0x00, 0x00,
  92. 0xf0, 0xff, 0x0f, 0x00, 0x00, 0xc0, 0xff, 0x03,
  93. 0x00, 0x00, 0x80, 0xff, 0x01, 0x00, 0x00, 0x00,
  94. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
  95. };
  96. void setup(){
  97.     ssd1306_128x64_i2c_init();
  98. }
  99. void loop(){
  100.     ssd1306_clearScreen( );
  101.     ssd1306_drawBitmap(0, 0, 128, 64, Owl);
  102.     delay(2000);
  103.     ssd1306_clearScreen( );
  104.     ssd1306_drawXBitmap(0, 0, 40, 32, Soba);
  105.     delay(2000);
  106. }
驴友花雕  中级技神
发表于 2021-6-29 19:03:10
ESP32芯片
(包括:ESP32- d0wd、ESP32- d0wdq6、ESP32- d2wd、ESP32- s0wd)集成了Wi-Fi和双模式蓝牙。根据型号差异,ESP32包含一个或两个低功耗Xtensa®32位LX6微处理器(s),最大时钟速度240 MHz(通常是160 MHz)和Xtensa RAM / ROM,本地内存和JTAG接口。
驴友花雕  中级技神
发表于 2021-6-29 19:10:36
最像Arduino Uno的ESP32开发板之WeMos D1 R32图2
驴友花雕  中级技神
发表于 2021-6-30 06:38:00
  • 处理器:
    • 主处理器: Tensilica Xtensa 32位LX6微处理器
      • 核心: 2 或 1(取决于变化)除ESP32-S0WD为单核外,ESP32系列所有芯片均为双核。
      • 时钟频率:高达 240 MHz
      • 性能:高达 600 DMIPS
    • 超低功耗协处理器: 允许您在深度睡眠时进行 ADC 转换、计算和电平阈值。
  • 无线连接:
    • 的Wi-Fi: 802.11 B / G / N / E / I(802.11n标准@ 2.4GHz的高达150兆比特/秒)
    • 蓝牙: v4.2 BR/EDR 和蓝牙低功耗 (BLE)
  • 记忆:
    • 内部存储器:
      • ROM: 448 KiB用于启动和核心功能。
      • SRAM: 520 KiB用于数据和指令。
      • RTC 快速 SRAM: 8 KiB用于从深度睡眠模式进行 RTC 启动期间的数据存储和主 CPU。
      • RTC 慢速 SRAM: 8 KiB用于深度睡眠模式下的协处理器访问。
      • 电子保险丝 1 Kibit其中 256 位用于系统(MAC 地址和芯片配置),其余 768 位保留用于客户应用,包括 Flash-Encryption 和 Chip-ID。
      • 嵌入式闪存:Flash 通过 ESP32-D2WD 和 ESP32-PICO-D4 上的 IO16、IO17、SD_CMD、SD_CLK、SD_DATA_0 和 SD_DATA_1 内部连接。
        • 0 MiB(ESP32-D0WDQ6、ESP32-D0WD 和 ESP32-S0WD 芯片)
        • 2 MiB(ESP32-D2WD 芯片)
        • 4 MiB(ESP32-PICO-D4 SiP 模块)
    • 外部闪存和 SRAM: ESP32 最多支持四个 16 MiB 外部 QSPI闪存和 SRAM,具有基于 AES 的硬件加密,以保护开发人员的程序和数据。ESP32 可以通过高速缓存访​​问外部 QSPI flash 和 SRAM。
      • 高达 16 MiB 的外部闪存被内存映射到 CPU 代码空间,支持 8 位、16 位和 32 位访问。支持代码执行。
      • 多达 8 MiB 的外部闪存/SRAM 存储器映射到 CPU 数据空间,支持 8 位、16 位和 32 位访问。闪存和 SRAM 支持数据读取。SRAM 支持数据写入。
      带有嵌入式 flash 的 ESP32 芯片不支持外部 flash 和外设之间的地址映射。
  • 外设输入/输出:带有 DMA 的丰富外设接口,包括电容式触摸、ADC(模数转换器)、DAC(数模转换器)、I²C(内部集成电路)、UART(通用异步接收器/发送器) )、CAN 2.0(控制器局域网)、SPI(串行外设接口)、I²S(集成 IC 间声音)、RMII(简化的媒体独立接口)、PWM(脉宽调制)等。
  • 安全:
    • 支持 IEEE 802.11 标准安全功能,包括 WFA、WPA/WPA2 和 WAPI
    • 安全启动
    • 闪存加密
    • 1024位OTP,客户最高768位
    • 加密硬件加速:AES、SHA-2、RSA、椭圆曲线加密(ECC)、随机数生成器(RNG)
驴友花雕  中级技神
发表于 2021-6-30 06:47:21
ESP32的主要参数:
从ESP32的芯片参数可以看出,它的功能非常强大;另外一条也也很重要:它非常便宜。这两个要素决定了:它非常适合目前流行的物联网开发,也非常适合学习嵌入式开发。
驴友花雕  中级技神
发表于 2021-6-30 08:00:07
Wemos D1 ESP32 WiFi蓝牙4MB4闪存UNO R32开发板模块  UNO D1 R32(ESP32)开发板   兼容Arduino
电原理图
驴友花雕  中级技神
发表于 2021-6-30 08:02:52
驴友花雕  中级技神
发表于 2021-6-30 08:10:24
搜到的不同版本的引线接脚图
驴友花雕  中级技神
发表于 2021-6-30 08:11:12
驴友花雕  中级技神
发表于 2021-6-30 08:11:47
驴友花雕  中级技神
发表于 2021-6-30 08:12:51
驴友花雕  中级技神
发表于 2021-6-30 08:13:29
驴友花雕  中级技神
发表于 2021-6-30 09:05:19
安装Windows驱动
驴友花雕  中级技神
发表于 2021-6-30 09:45:53
1、利用官方途径进行下载安装
(1)首先在Arduino中添加 esp32 开发板地址:
打开Arduino后选择:文件 > 首选项 > 附加开发板管理器网址中加入Arduino for esp32包的地址:
https://dl.espressif.com/dl/package_esp32_index.json
驴友花雕  中级技神
发表于 2021-6-30 10:19:56
(2)IDE——工具——开发板——开发板管理器——搜索“ESP32”——安装
驴友花雕  中级技神
发表于 2021-6-30 10:22:24
(3)安装成功
驴友花雕  中级技神
发表于 2021-6-30 10:34:39
2、直接下载esp32数据包的压缩包,手动解压并添加,下载地址:
(1)https://github.com/espressif/arduino-esp32
驴友花雕  中级技神
发表于 2021-6-30 10:35:27
(2)百度云下载链接:https://pan.baidu.com/s/1mC-DGFKhKsS4kjKz50mung
        提取码:86le
驴友花雕  中级技神
发表于 2021-6-30 10:47:23
(3)解压后,将压缩文件里的内容复制到如下路径(需要新建一个espressif文件夹):Arduino > hardware > espressif > esp32 ,最后放到esp32文件夹下。
驴友花雕  中级技神
发表于 2021-6-30 11:03:22
此时再打开Arduino IDE 编译器,工具 > 开发板 已经可以找到ESP32相关开发板
驴友花雕  中级技神
发表于 2021-6-30 11:13:51
编译环境现已设置完毕,可以上传一个测试程序。
实验一百七十七:Wemos D1 ESP32 WiFi蓝牙4MB4闪存UNO R32开发板模块  UNO D1 R32(ESP32)开发板   兼容Arduino
项目之一:编译一个Blink程序
  1. /*
  2. 【Arduino】168种传感器模块系列实验(资料代码+仿真编程+图形编程)
  3. 实验一百七十七:Wemos D1 ESP32 WiFi蓝牙4MB4闪存UNO R32开发板模块  UNO D1 R32(ESP32)开发板   兼容Arduino
  4. 项目之一:编译一个Blink程序
  5. */
  6. void setup() {
  7.   // initialize digital pin LED_BUILTIN as an output.
  8.   pinMode(LED_BUILTIN, OUTPUT);
  9. }
  10. void loop() {
  11.   digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
  12.   delay(1000);                       // wait for a second
  13.   digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
  14.   delay(1000);                       // wait for a second
  15. }
