9061浏览
查看: 9061|回复: 0
[求助问答] 代码问题,帮忙看一下。
* MindPlus
* mpython
#include <MPython.h>
#include <SimpleList.h>
#include <DFRobot_Iot.h>
#include <DFRobot_Task.h>
#include <DFRobot_HuskyLens.h>
#include<DFRobot_SpeechSynthesis.h>
// 动态变量
String             mind_s_MingZi;
volatile float     mind_n_ZiXianCheng8ShiJian, mind_n_ZiXianCheng7ShiJian, mind_n_ZiXianCheng6ShiJian,
                   mind_n_ZiXianCheng5ShiJian, mind_n_ZiXianCheng4ShiJian, mind_n_ZiXianCheng3ShiJian,
                   mind_n_ZiXianCheng2ShiJian, mind_n_ZiXianCheng1ShiJian, mind_n_YiQiDongZiXianChengGeShu;
SimpleList<String> mind_l_RenMing, mind_l_ZhiXingRenMing, mind_l_ZhiXingZiXianChengDaiMa;
// 函数声明
void onButtonAPressed();
void onButtonBPressed();
void DF_ChuShiHua();
void DF_HuoQuShiJian(String mind_s_MingZi);
newTask(loop8)
newTask(loop7)
newTask(loop6)
newTask(loop5)
newTask(loop4)
newTask(loop3)
newTask(loop2)
newTask(loop1)
// 静态常量
const String topics[5] = {"w9QhgiXGg","","","",""};
// 创建对象
DFRobot_SpeechSynthesis_I2C sstts;
DFRobot_HuskyLens           huskylens;
DFRobot_Iot                 myIot;
// 主程序开始
void setup() {
        mPython.begin();
        buttonA.setPressedCallback(onButtonAPressed);
        buttonB.setPressedCallback(onButtonBPressed);
        sstts.begin();
        DF_ChuShiHua();
void loop() {
// 子线程8程序开始
void loop8::setup() {
        mind_n_ZiXianCheng8ShiJian = 0;
void loop8::loop() {
        delay(60000);
        mind_n_ZiXianCheng8ShiJian += 1;
// 子线程7程序开始
void loop7::setup() {
        mind_n_ZiXianCheng7ShiJian = 0;
void loop7::loop() {
        delay(60000);
        mind_n_ZiXianCheng7ShiJian += 1;
// 子线程6程序开始
void loop6::setup() {
        mind_n_ZiXianCheng6ShiJian = 0;
void loop6::loop() {
        delay(60000);
        mind_n_ZiXianCheng6ShiJian += 1;
// 子线程5程序开始
void loop5::setup() {
        mind_n_ZiXianCheng5ShiJian = 0;
void loop5::loop() {
        delay(60000);
        mind_n_ZiXianCheng5ShiJian += 1;
// 子线程4程序开始
void loop4::setup() {
        mind_n_ZiXianCheng4ShiJian = 0;
void loop4::loop() {
        delay(60000);
        mind_n_ZiXianCheng4ShiJian += 1;
// 子线程3程序开始
void loop3::setup() {
        mind_n_ZiXianCheng3ShiJian = 0;
void loop3::loop() {
        delay(60000);
        mind_n_ZiXianCheng3ShiJian += 1;
// 子线程2程序开始
void loop2::setup() {
        mind_n_ZiXianCheng2ShiJian = 0;
void loop2::loop() {
        delay(60000);
        mind_n_ZiXianCheng2ShiJian += 1;
// 子线程1程序开始
void loop1::setup() {
        mind_n_ZiXianCheng1ShiJian = 0;
void loop1::loop() {
        delay(60000);
        mind_n_ZiXianCheng1ShiJian += 1;
// 自定义函数
void DF_ChuShiHua() {
        mind_n_YiQiDongZiXianChengGeShu = 0;
        mind_l_ZhiXingRenMing.clear();
        display.setCursorLine(1);
        display.printLine("正在初始化语音朗读模块......");
        display.printLine("正在初始化HuskyLens......");
        huskylens.beginI2CUntilSuccess();
        huskylens.writeAlgorithm(ALGORITHM_FACE_RECOGNITION);
        display.printLine("正在初始化网络......");
        myIot.wifiConnect("Xiaomi_701", "1234567890");
        while (!myIot.wifiStatus()) {yield();}
        display.printLine("正在初始化MQTT......");
        myIot.init("iot.dfrobot.com.cn","NUz32C_Mg","","NUkq2j_Ggz",topics,1883);
        myIot.connect();
        while (!myIot.connected()) {yield();}
        display.printLine("已完成初始化");
        delay(1000);
        display.fillScreen(0);
void DF_HuoQuShiJian(String mind_s_MingZi) {
        if ((mind_l_ZhiXingZiXianChengDaiMa[mind_l_ZhiXingRenMing.indexOf(mind_s_MingZi)-1]==1)) {
                sstts.speak((String("你好") + String((String(mind_s_MingZi) + String((String("你的工作时间是:") + String(mind_n_ZiXianCheng1ShiJian)))))));
                taskFree(loop1);
        else if ((mind_l_ZhiXingZiXianChengDaiMa[mind_l_ZhiXingRenMing.indexOf(mind_s_MingZi)-1]==2)) {
                sstts.speak((String("你好") + String((String(mind_s_MingZi) + String((String("你的工作时间是:") + String(mind_n_ZiXianCheng2ShiJian)))))));
                taskFree(loop2);
        else if ((mind_l_ZhiXingZiXianChengDaiMa[mind_l_ZhiXingRenMing.indexOf(mind_s_MingZi)-1]==3)) {
                sstts.speak((String("你好") + String((String(mind_s_MingZi) + String((String("你的工作时间是:") + String(mind_n_ZiXianCheng3ShiJian)))))));
                taskFree(loop3);
        else if ((mind_l_ZhiXingZiXianChengDaiMa[mind_l_ZhiXingRenMing.indexOf(mind_s_MingZi)-1]==4)) {
                sstts.speak((String("你好") + String((String(mind_s_MingZi) + String((String("你的工作时间是:") + String(mind_n_ZiXianCheng4ShiJian)))))));
                taskFree(loop4);
        else if ((mind_l_ZhiXingZiXianChengDaiMa[mind_l_ZhiXingRenMing.indexOf(mind_s_MingZi)-1]==5)) {
                sstts.speak((String("你好") + String((String(mind_s_MingZi) + String((String("你的工作时间是:") + String(mind_n_ZiXianCheng5ShiJian)))))));
                taskFree(loop5);
        else if ((mind_l_ZhiXingZiXianChengDaiMa[mind_l_ZhiXingRenMing.indexOf(mind_s_MingZi)-1]==6)) {
                sstts.speak((String("你好") + String((String(mind_s_MingZi) + String((String("你的工作时间是:") + String(mind_n_ZiXianCheng6ShiJian)))))));
                taskFree(loop6);
        else if ((mind_l_ZhiXingZiXianChengDaiMa[mind_l_ZhiXingRenMing.indexOf(mind_s_MingZi)-1]==7)) {
                sstts.speak((String("你好") + String((String(mind_s_MingZi) + String((String("你的工作时间是:") + String(mind_n_ZiXianCheng7ShiJian)))))));
                taskFree(loop7);
        else {
                sstts.speak((String("你好") + String((String(mind_s_MingZi) + String((String("你的工作时间是:") + String(mind_n_ZiXianCheng8ShiJian)))))));
                taskFree(loop8);
// 事件回调函数
void onButtonAPressed() {
        sstts.speak("请将脸靠近摄像头");
        while (!huskylens.isAppearDirect(HUSKYLENSResultBlock)) {
                huskylens.request();
                yield();
        if ((huskylens.readBlockCenterParameterDirect().ID>0)) {
                mind_s_MingZi = mind_l_RenMing[huskylens.readBlockCenterParameterDirect().ID-1];
                sstts.speak((String((String("欢迎") + String(mind_s_MingZi))) + String("来宁波市江北区实验小学做义工,让我们一起来劳动吧")));
                display.printLine((String((String("欢迎") + String(mind_s_MingZi))) + String("来宁波市江北区实验小学做义工,让我们一起来劳动吧")));
                delay(1000);
                sstts.speak("现在开始计时");
                display.printLine("现在开始计时");
                mind_l_ZhiXingRenMing.push_back(mind_s_MingZi);
                mind_l_ZhiXingZiXianChengDaiMa.push_back((String((mind_n_YiQiDongZiXianChengGeShu + 1))));
                mind_n_YiQiDongZiXianChengGeShu += 1;
                if ((mind_n_YiQiDongZiXianChengGeShu==1)) {
                        taskStart(loop1);
                else if ((mind_n_YiQiDongZiXianChengGeShu==2)) {
                        taskStart(loop2);
                else if ((mind_n_YiQiDongZiXianChengGeShu==3)) {
                        taskStart(loop3);
                else if ((mind_n_YiQiDongZiXianChengGeShu==4)) {
                        taskStart(loop4);
                else if ((mind_n_YiQiDongZiXianChengGeShu==5)) {
                        taskStart(loop5);
                else if ((mind_n_YiQiDongZiXianChengGeShu==6)) {
                        taskStart(loop6);
                else if ((mind_n_YiQiDongZiXianChengGeShu==7)) {
                        taskStart(loop7);
                else {
                        taskStart(loop8);
void onButtonBPressed() {
                yield();
        if (mind_l_ZhiXingRenMing.contains(mind_s_MingZi)) {
                DF_HuoQuShiJian(mind_s_MingZi);
        else {
                sstts.speak("你按错了");
帮我看看哪里错了?
2021创客大赛.sb3
547.07 KB, 下载次数: 1768
程序代码,原创作品,严禁抄袭
关于楼主
楼主的其它帖子
