11990浏览
查看: 11990|回复: 3
[求助问答] 上传出错,请教如何解决
板子是Model1.5。新买的,实时模式没有问题。但是上传模式从来没有上传成功过
使用 Chrom 网页版的Mind+, 上传出错信息是:
Error: ENOENT: no such file or directory, open 'C:\Users\qlzho\AppData\Local\Temp\Mind+_Link_cache\cache_1617777733354\dfrobot.ino.hex'
下载安装Windows版的Mind+ V1.7.0 RC2.0,一键安装串口驱动都正常。上传程序仍然出错。错误和截屏如下。请教如何解决。
F5\mbed-classic\targets\hal\TARGET_NORDIC\TARGET_MCU_NRF51822\Lib\nordic_sdk\components\libraries\crc16 -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\mbed-classic\targets\hal\TARGET_NORDIC\TARGET_MCU_NRF51822\Lib\nordic_sdk\components\libraries\scheduler -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\mbed-classic\targets\hal\TARGET_NORDIC\TARGET_MCU_NRF51822\Lib\nordic_sdk\components\libraries\util -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\mbed-classic\targets\hal\TARGET_NORDIC\TARGET_MCU_NRF51822\Lib\s110_nrf51822_8_0_0 -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\mbed-classic\targets\hal\TARGET_NORDIC\TARGET_MCU_NRF51822\Lib\s130_nrf51822_1_0_0 -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\mbed-classic\targets\hal\TARGET_NORDIC\TARGET_MCU_NRF51822\TARGET_NRF51_MICROBIT -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\DFmicrobit -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\microbit-dal -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\mbed-classic -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\ble -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\ble-nrf51822 -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF51-sdk -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\DFmicrobit\inc -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\microbit-dal\inc\core -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\microbit-dal\inc\types -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\microbit-dal\inc\drivers -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\microbit-dal\inc\bluetooth -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\microbit-dal\inc\platform -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\mbed-classic\api -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\mbed-classic\hal -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\mbed-classic\targets\hal -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\mbed-classic\targets\cmsis -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\ble-nrf51822\source\btle -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\ble-nrf51822\source\btle\custom -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\ble-nrf51822\source\common -DUSE_LFRC -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5 -I C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\variants\BBCmicrobit -I  -I c:\program files (x86)\mind+\arduino\hardware\dfrobot\nrf5\cores\nrf5 -I c:\program files (x86)\mind+\arduino\hardware\dfrobot\nrf5\variants\bbcmicrobit -I c:\program files (x86)\mind+\arduino\libraries\microbit_matrix C:\Users\qlzho\AppData\Local\DFScratch\cache\dfrobot.ino.cpp -o C:\Users\qlzho\AppData\Local\DFScratch\cache\dfrobot.ino.o
C:\Program Files (x86)\Mind+\Arduino\hardware\tools\nRF5\gcc-arm-none-eabi\bin\arm-none-eabi-g++ -L C:\Users\qlzho\AppData\Local\DFScratch\build -Os -Wl,--gc-sections -save-temps -L C:\Program Files (x86)\Mind+\Arduino\hardware\dfrobot\nRF5\cores\nRF5\mbed-classic\targets\cmsis\TARGET_NORDIC\TARGET_MCU_NRF51822\TOOLCHAIN_GCC_ARM -TNRF51822.ld -Wl,-Map,C:\Users\qlzho\AppData\Local\DFScratch\build\dfrobot.ino.map --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0 -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o C:\Users\qlzho\AppData\Local\DFScratch\build\dfrobot.ino.elf C:\Users\qlzho\AppData\Local\DFScratch\cache\dfrobot.ino.o c:\program files (x86)\mind+\arduino\static\libraries\microbit_matrix\microbit\microbit_matrix.cpp.o -Wl,--start-group -lm C:\Program Files (x86)\Mind+\Arduino\static\core\microbit\core.a -Wl,--end-group
c:/program files (x86)/mind+/arduino/hardware/tools/nrf5/gcc-arm-none-eabi/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .heap by 4 bytes
c:/program files (x86)/mind+/arduino/hardware/tools/nrf5/gcc-arm-none-eabi/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .stack_dummy by 4 bytes
"C:\Program Files (x86)\Mind+\Arduino\hardware\tools\nRF5\gcc-arm-none-eabi\bin\arm-none-eabi-objcopy" -O ihex "C:\Users\qlzho\AppData\Local\DFScratch\build\dfrobot.ino.elf" "C:\Users\qlzho\AppData\Local\DFScratch\build\dfrobot.ino.hex"
"C:\Program Files (x86)\Mind+\Arduino\hardware\tools\nRF5\gcc-arm-none-eabi\bin\arm-none-eabi-objcopy" -O binary "C:\Users\qlzho\AppData\Local\DFScratch\build\dfrobot.ino.elf" "C:\Users\qlzho\AppData\Local\DFScratch\build\dfrobot.ino.bin"
项目使用了97084字节,占用了(37%)程序存储空间,余留165060字节,最大为262144字节。
全局变量使用了2084字节,(13%)的动态内存,余留14300字节局部变量,最大为16384字节。
U盘设备写入出错
上传出错
上传出错
设备管理器
设备管理器
Micro:bit 板子
Micro:bit 板子
Forgotten  版主
发表于 2021-4-7 18:10:19
可以把microbit背面拍照发一下
Black_Mamba  学徒
发表于 2021-4-7 23:20:35
Forgotten 发表于 2021-4-7 18:10
可以把microbit背面拍照发一下
多谢版主。我把原帖编辑了一下上传了mirco:bit 背面的照片。
Forgotten  版主
发表于 2021-4-8 10:36:48
看起来可能是系统问题,可以加入Mind+官方QQ群(671877416)找技术支持远程看一下是什么情况
关于楼主
楼主的其它帖子
