3004浏览
查看: 3004|回复: 1
[问题求助] Maixdock sipeed转接板+7寸显示屏白屏问题(已解决)
硬件:Maixdock ,sipeed转接板,导航7寸显示屏(7寸 40针 800*480分辨率)
问题:连接后7寸显示屏不能正常运行,成暗白屏状态
程序:
  1. from Maix import GPIO, I2S
  2. from fpioa_manager import fm
  3. import lcd
  4. import video
  5. import time
  6. lcd.init(type=5, lcd_type = 3)
  7. AUDIO_PA_EN_PIN = 32
  8. i2s = I2S(I2S.DEVICE_0)
  9. i2s.channel_config(i2s.CHANNEL_1, I2S.TRANSMITTER, resolution=I2S.RESOLUTION_16_BIT,
  10.                        cycles=I2S.SCLK_CYCLES_32, align_mode=I2S.RIGHT_JUSTIFYING_MODE)
  11. if AUDIO_PA_EN_PIN:
  12.     fm.register(AUDIO_PA_EN_PIN, fm.fpioa.GPIO1, force=True)
  13.     wifi_en = GPIO(GPIO.GPIO1, GPIO.OUT)
  14.     wifi_en.value(1)
  15. fm.register(34,  fm.fpioa.I2S0_OUT_D1, force=True)
  16. fm.register(35,  fm.fpioa.I2S0_SCLK, force=True)
  17. fm.register(33,  fm.fpioa.I2S0_WS, force=True)
  18. def Video_Play():
  19.     v = video.open("/sd/badapple.avi")
  20.     print(v)
  21.     v.volume(50)
  22.     while True:
  23.         if v.play() == 0:
  24.             print("play end")
  25.             break
  26.     v.__del__()
  27. if __name__=='__main__':
  28. while(True):
  29.     Video_Play()
Maixdock sipeed转接板+7寸显示屏白屏问题(已解决)图1
DFrkXo40MNd  学徒 来自手机
发表于 2021-3-20 09:50:20
问题:连接后7寸显示屏不能正常 ...
不说程序问题,光这个屏幕耗电就不一定是它能带起来的,大屏幕耗电很厉害
