 7197| 11
 | [官方教程] Mx-yolov3 |
| 模型转换时出现错误 Fatal: Layer Pad is not supported: Only paddings of [[0,0],[1,1],[1,1],[0,0]] is supported NnCase.Converter.Converters.LayerNotSupportedException: Layer Pad is not supported: Only paddings of [[0,0],[1,1],[1,1],[0,0]] is supported at NnCase.Converter.Converters.TfLiteToGraphConverter.ConvertPad(Operator op) in D:\Work\Repository\nncase\src\NnCase.Converter\Converters\TfLiteToGraphConverter.cs:line 129 at NnCase.Converter.Converters.TfLiteToGraphConverter.ConvertOperator(Operator op) in D:\Work\Repository\nncase\src\NnCase.Converter\Converters\TfLiteToGraphConverter.cs:line 99 at System.Linq.Enumerable.SelectEnumerableIterator`2.ToList() at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source) at NnCase.Converter.Converters.TfLiteToGraphConverter.Convert() in D:\Work\Repository\nncase\src\NnCase.Converter\Converters\TfLiteToGraphConverter.cs:line 34 at NnCase.Cli.Program.Main(String[] args) in D:\Work\Repository\nncase\src\NnCase.Cli\Program.cs:line 113 at NnCase.Cli.Program.<Main>(String[] args) |
| ryAZ937V 发表于 2021-3-10 16:30 这个问题请检查CUDA版本和Cudnn版本是否对应;Mx-yolov3对应的CUDA和Cudnn版本为:CUDA==10.0,Cudnn==7.6.4 |
 沪公网安备31011502402448
