6140| 4
[资源] 基于python的飞机大战 |
今天在这里和大家分享一下简易的python飞机大战 如果没有安装树pygame的库,请执行这个代码 [mw_shl_code=python,false]pip install pygame[/mw_shl_code] 如果是使用的树莓派,系统里面可能会包含这个库文件,所以如果这一步没有执行成功,也可以尝试直接运行这个里面的代码。 整个代码: [mw_shl_code=python,false]#Import pygame import pygame, sys, time import random #Pygame init pygame.init() size=width,height=400,500 win=pygame.display.set_mode(size) pygame.display.set_caption('Pygame 游戏之旅') clock=pygame.time.Clock() class hostplayer: def __init__(self,x,y,width,height): self.xPos=x self.yPos=y self.widthValue=width self.heightValue=height self.bulletHoder=[] class bullet: def __init__(self,x,y,width,height): self.xPos=x self.yPos=y self.widthValue=width self.heightValue=height class enemyplayer: def __init__(self,x,y,width,height): self.xPos=x self.yPos=y self.widthValue=width self.heightValue=height def drawGame(playerArray,enemyArray): pygame.draw.rect(win,(255,255,255),(0,0,width,height)) for i in playerArray: pygame.draw.rect(win,(255,0,0),(i.xPos,i.yPos,i.widthValue,i.heightValue)) for q in i.bulletHoder: pygame.draw.rect(win,(0,255,0),(q.xPos,q.yPos,q.widthValue,q.heightValue)) for k in enemyArray: pygame.draw.rect(win,(0,0,255),(k.xPos,k.yPos,k.widthValue,k.heightValue)) pygame.display.update() def bulletjunction(playerArray,enemyArray): for player in playerArray: m=0 for bulletTemp in player.bulletHoder: for e_player in enemyArray: n=0 if bulletTemp.xPos>=e_player.xPos and bulletTemp.xPos<=e_player.xPos+25 and bulletTemp.yPos>=e_player.yPos and bulletTemp.yPos<=e_player.yPos+25: playerArray[m].bulletHoder.pop(playerArray[m].bulletHoder.index(bulletTemp)) enemyArray[n].xPos=random.randint(0,375) enemyArray[n].yPos=0 print("you win") if bulletTemp.yPos<=0: playerArray[m].bulletHoder.pop(playerArray[m].bulletHoder.index(bulletTemp)) n+=1 m+=1 def getStartFunction(): player1=hostplayer(0,height-25,25,25) last_shoot1=0 playerArray=[player1] k=0 enemyArray=[] enemyXpos=random.randint(0,375) enemyYpos=0 enemy=enemyplayer(enemyXpos,enemyYpos,25,25) enemyArray.append(enemy) while True: for event in pygame.event.get(): if event.type==pygame.QUIT: sys.exit() keys=pygame.key.get_pressed() if(keys[pygame.K_LEFT]): playerArray[0].xPos-=5 #参数可调 if playerArray[0].xPos<=0: playerArray[0].xPos=0 if(keys[pygame.K_RIGHT]): playerArray[0].xPos+=5 #参数可调 if playerArray[0].xPos>=width-25: playerArray[0].xPos=width-25 if (keys[pygame.K_UP]): now1=pygame.time.get_ticks() if now1-last_shoot1>500: playerArray[0].bulletHoder.append(bullet(playerArray[0].xPos+10,playerArray[0].yPos+10,5,5)) last_shoot1=now1 for player in playerArray: for bulletTemp in player.bulletHoder: bulletTemp.yPos-=5 #参数可调 for e_player in enemyArray: e_player.yPos+=2 #参数可调 if e_player.yPos>height: e_player.xPos=random.randint(0,375) e_player.yPos=0 print("you lost") bulletjunction(playerArray,enemyArray) drawGame(playerArray,enemyArray) getStartFunction()[/mw_shl_code] 下面我们就来读读代码吧 窗口设置和初始化 [mw_shl_code=python,false]#Import pygame import pygame, sys, time import random #Pygame init pygame.init() size=width,height=400,500 win=pygame.display.set_mode(size) pygame.display.set_caption('Pygame 游戏之旅') clock=pygame.time.Clock()[/mw_shl_code] 生成和控制主机和敌机,并分别对其进行控制 [mw_shl_code=python,false]def getStartFunction(): player1=hostplayer(0,height-25,25,25) last_shoot1=0 playerArray=[player1] k=0 enemyArray=[] enemyXpos=random.randint(0,375) enemyYpos=0 enemy=enemyplayer(enemyXpos,enemyYpos,25,25) enemyArray.append(enemy) while True: for event in pygame.event.get(): if event.type==pygame.QUIT: sys.exit() keys=pygame.key.get_pressed() if(keys[pygame.K_LEFT]): playerArray[0].xPos-=5 #参数可调 if playerArray[0].xPos<=0: playerArray[0].xPos=0 if(keys[pygame.K_RIGHT]): playerArray[0].xPos+=5 #参数可调 if playerArray[0].xPos>=width-25: playerArray[0].xPos=width-25 if (keys[pygame.K_UP]): now1=pygame.time.get_ticks() if now1-last_shoot1>500: playerArray[0].bulletHoder.append(bullet(playerArray[0].xPos+10,playerArray[0].yPos+10,5,5)) last_shoot1=now1 for player in playerArray: for bulletTemp in player.bulletHoder: bulletTemp.yPos-=5 #参数可调 for e_player in enemyArray: e_player.yPos+=2 #参数可调 if e_player.yPos>height: e_player.xPos=random.randint(0,375) e_player.yPos=0 print("you lost") bulletjunction(playerArray,enemyArray) drawGame(playerArray,enemyArray)[/mw_shl_code] 通过调节对应位置的参数,可以控制主机的左右运行速度 [mw_shl_code=python,false] if(keys[pygame.K_LEFT]): playerArray[0].xPos-=5 #参数可调 if playerArray[0].xPos<=0: playerArray[0].xPos=0 if(keys[pygame.K_RIGHT]): playerArray[0].xPos+=5 #参数可调 if playerArray[0].xPos>=width-25: playerArray[0].xPos=width-25[/mw_shl_code] 这里的500是对每两个子弹之间的响应时间的控制 [mw_shl_code=python,false] if (keys[pygame.K_UP]): now1=pygame.time.get_ticks() if now1-last_shoot1>500: playerArray[0].bulletHoder.append(bullet(playerArray[0].xPos+10,playerArray[0].yPos+10,5,5)) last_shoot1=now1[/mw_shl_code] 通过调节这里的变量可以控制子弹的上行速度 [mw_shl_code=python,false] for player in playerArray: for bulletTemp in player.bulletHoder: bulletTemp.yPos-=5 #参数可调[/mw_shl_code] 通过控制这里的变量可以控制敌机的下行速度 [mw_shl_code=python,false] for e_player in enemyArray: e_player.yPos+=2 #参数可调[mw_shl_code=python,false]def bulletjunction(playerArray,enemyArray): for player in playerArray: m=0 for bulletTemp in player.bulletHoder: for e_player in enemyArray: n=0 if bulletTemp.xPos>=e_player.xPos and bulletTemp.xPos<=e_player.xPos+25 and bulletTemp.yPos>=e_player.yPos and bulletTemp.yPos<=e_player.yPos+25: playerArray[m].bulletHoder.pop(playerArray[m].bulletHoder.index(bulletTemp)) enemyArray[n].xPos=random.randint(0,375) enemyArray[n].yPos=0 print("you win") if bulletTemp.yPos<=0: playerArray[m].bulletHoder.pop(playerArray[m].bulletHoder.index(bulletTemp)) n+=1 m+=1[/mw_shl_code] if e_player.yPos>height: e_player.xPos=random.randint(0,375) e_player.yPos=0 print("you lost")[/mw_shl_code] 将子弹和敌机进行相应的判断和对溢出的子弹进行清除 [mw_shl_code=python,false]def bulletjunction(playerArray,enemyArray): for player in playerArray: m=0 for bulletTemp in player.bulletHoder: for e_player in enemyArray: n=0 if bulletTemp.xPos>=e_player.xPos and bulletTemp.xPos<=e_player.xPos+25 and bulletTemp.yPos>=e_player.yPos and bulletTemp.yPos<=e_player.yPos+25: playerArray[m].bulletHoder.pop(playerArray[m].bulletHoder.index(bulletTemp)) enemyArray[n].xPos=random.randint(0,375) enemyArray[n].yPos=0 print("you win") if bulletTemp.yPos<=0: playerArray[m].bulletHoder.pop(playerArray[m].bulletHoder.index(bulletTemp)) n+=1 m+=1[/mw_shl_code] 画出相应的主机敌机以及子弹 [mw_shl_code=python,false]def drawGame(playerArray,enemyArray): pygame.draw.rect(win,(255,255,255),(0,0,width,height)) for i in playerArray: pygame.draw.rect(win,(255,0,0),(i.xPos,i.yPos,i.widthValue,i.heightValue)) for q in i.bulletHoder: pygame.draw.rect(win,(0,255,0),(q.xPos,q.yPos,q.widthValue,q.heightValue)) for k in enemyArray: pygame.draw.rect(win,(0,0,255),(k.xPos,k.yPos,k.widthValue,k.heightValue)) pygame.display.update()[/mw_shl_code] 运行结果(视频): ![]() |
lkk255 发表于 2020-11-4 17:28 是的,通过Mobaxterm。这个是操作步骤。https://mc.dfrobot.com.cn/thread-307477-1-1.html#pid473066 |
