17891| 39
[MP动手做] MicroPython动手做(37)——驱动LCD与图文显示 |
本帖最后由 驴友花雕 于 2020-7-3 20:11 编辑 7、五彩MixPY移动文本弹幕 [mw_shl_code=python,false]#MicroPython动手做(37)——驱动LCD与图文显示 #五彩MixPY移动文本弹幕 import mixno import lcd import image image = image.Image() while True: for i in range(240, 0, -1): image.clear() lcd.display(image.draw_string(40,i,"MicroPython",(0,255,0),5,mono_space=0)) for i in range(0, 240, 1): image.clear() lcd.display(image.draw_string(50,i,"MxiPY",(255,0,0),10,mono_space=0)) for i in range(0, 320, 1): image.clear() lcd.display(image.draw_string(i,100,"MicroPython",(250,0,250),6,mono_space=0)) for i in range(240, 0, -1): image.clear() lcd.display(image.draw_string(20,i,"MicroPython",(0,0,255),6,mono_space=0)) for i in range(0, 240, 1): image.clear() lcd.display(image.draw_string(25,i,"MxiPY",(250,250,0),12,mono_space=0)) for i in range(320, 0, -1): image.clear() lcd.display(image.draw_string(i,90,"MicroPython",(250,0,0),6,mono_space=0))[/mw_shl_code] |
13、循环变色彩虹屏幕 [mw_shl_code=python,false]#MicroPython动手做(37)——驱动LCD与图文显示 #循环变色彩虹屏幕 import time import mixno import lcd lcd.init(freq=15000000,color=(0,0,0)) mylist = [0,0,0] while True: for i in range(0, 255, 1): mylist[0] = i mylist[1] = 255 - i mylist[2] = 0 lcd.clear(tuple(mylist)) time.sleep_ms(15) time.sleep_ms(300) for i in range(255, 0, -1): mylist[0] = i mylist[1] = 0 mylist[2] = 255 - i lcd.clear(tuple(mylist)) time.sleep_ms(15) time.sleep_ms(300) for i in range(0, 255, 1): mylist[0] = 0 mylist[1] = i mylist[2] = 255 - i lcd.clear(tuple(mylist)) time.sleep_ms(15) time.sleep_ms(300)[/mw_shl_code] |
5、多行交叉移动弹幕 [mw_shl_code=python,false]#MicroPython动手做(37)——驱动LCD与图文显示 #多行交叉移动弹幕 import time import mixno import lcd import image lcd.init(freq=15000000,color=0x0000) image = image.Image() while True: for i in range(0, 320, 1): image.clear() lcd.display(image.draw_string(i,50,"MxiPY",(255,0,0),6,mono_space=0)) time.sleep_ms(1) for i in range(320, 0, -1): image.clear() lcd.display(image.draw_string(i,100,"MicroPython",(0,220,0),4,mono_space=0)) time.sleep_ms(5) for i in range(0, 320, 1): image.clear() lcd.display(image.draw_string(i,150,"MxiPY",(0,0,255),8,mono_space=0)) for i in range(320, 0, -1): image.clear() lcd.display(image.draw_string(i,80,"MicroPython",(250,250,250),5,mono_space=0))[/mw_shl_code] |
2、LCD_显示驱动(import lcd) 屏幕显示2.8‘’ LCD 240*320驱动配置 (1)初始化显示 [mw_shl_code=python,false]lcd.init(type=1, freq=15000000, color=lcd.BLACK)[/mw_shl_code] 初始化LCD屏幕显示 参数: type:LCD的类型(保留给未来使用): 0: None 1: lcd shield(默认值) freq:LCD(实际上指SPI的通讯速率) 的频率 color:LCD初始化的颜色: RGB56516 位的颜色值,比如0xFFFF RGB888元组, 比如(236, 36, 36) 系统color常量,默认lcd.BLACK 返回: None (2)注销驱动 [mw_shl_code=python,false]lcd.deinit()[/mw_shl_code] 注销LCD驱动,释放I/O引脚 参数: 无 返回: None |
(3)获取分辨率宽度 [mw_shl_code=python,false]lcd.width()[/mw_shl_code] 获取LCD的宽度(水平分辨率) 参数: 无 返回: int类型的屏幕分辨率宽度 (4)获取分辨率高度 [mw_shl_code=python,false]lcd.height()[/mw_shl_code] 获取LCD的高度(垂直分辨率) 参数: 无 返回: int类型的屏幕分辨率高度 (5)获取/设置频率 [mw_shl_code=python,false]lcd.height()[/mw_shl_code] 设置或者获取LCD(SPI) 的频率 参数: freq: LCD(SPI) 的频率 返回: int类型的屏幕 (SPI) 的频率 |
(6)显示图像 [mw_shl_code=python,false]lcd.display(image, roi=Auto)[/mw_shl_code] 在液晶屏上显示一张image(GRAYSCALE或RGB565) 参数: image:显示图像image(GRAYSCALE或RGB565) roi :一个感兴趣区域的矩形元组(x, y, w, h),若未指定,即为图像矩形 若 roi 宽度小于lcd宽度,则用垂直的黑色边框使 roi 居于屏幕中心(即用黑色填充未占用区域) 若 roi 宽度大于lcd宽度,则 roi 居于屏幕中心,且不匹配像素不会显示(即液晶屏以窗口形态显示 roi 的中心) 若 roi 高度小于lcd高度,则用垂直的黑色边框使 roi 居于屏幕中心(即用黑色填充未占用区域) 若 roi 高度大于lcd高度,则 roi 居于屏幕中心,且不匹配像素不会显示(即液晶屏以窗口形态显示 roi 的中心) 返回: None roi 是键值参数,必须在函数调用中通过写入 roi= 来显式地调用 (7)屏幕清空 [mw_shl_code=python,false]lcd.clear(color)[/mw_shl_code] 将液晶屏清空为黑色或者指定的颜色 参数: color :将屏幕清空为黑(默认值)或者指定的颜色 RGB56516 位的颜色值,比如0xFFFF RGB888元组, 比如(236, 36, 36) 系统color常量,默认lcd.BLACK 返回: None (8)设置屏幕方向 [mw_shl_code=python,false]lcd.rotation(dir)[/mw_shl_code] 设置LCD屏幕方向 参数: dir: 取值范围 [0,3], 从0到3依次顺时针旋转 返值: 当前方向,取值[0,3] |
(9)设置镜面显示 [mw_shl_code=python,false]lcd.mirror(invert)[/mw_shl_code] 设置LCD是否镜面显示 参数: invert: 是否镜面显示,True或者False 返值: 当前设置,是否镜面显示,返回True或者False (10)显示文本 [mw_shl_code=python,false]lcd.draw_string(x, y, text, text_color, color)[/mw_shl_code] 在液晶屏上显示文本字符(不支持中文) 参数: *x,y:图像中的(x, y)位置开始绘制,您可以单独传递x,y,也可以作为元组(x,y)传递 text :写入图像的字符串。\n,\r, 和\r\n结束符将光标移至下一行 text_color:文本字符颜色 RGB56516 位的颜色值,比如0xFFFF 系统color常量,默认lcd.RED color:屏幕背景颜色 RGB56516 位的颜色值,比如0xFFFF 系统color常量,默认lcd.BLACK 返回: None (11)系统默认常量color颜色: lcd.BLACK0x0000 黑色 lcd.NAVY0x000F 深蓝色 lcd.DARKGREEN0x03E0 深绿色 lcd.DARKCYAN0x03EF 深青色 lcd.MAROON0x7800 褐红色 lcd.PURPLE0x780F 紫色 lcd.OLIVE0x7BE0 橄榄色 lcd.LIGHTGREY0xC618 浅灰色 lcd.DARKGREY0x7BEF 深灰色 lcd.BLUE0x001F 蓝色 lcd.GREEN0x07E0 绿色 lcd.CYAN0x07FF 青色 lcd.RED0xF800 红色 lcd.MAGENTA0xF81F 洋红色 lcd.YELLOW0xFFE0 黄色 lcd.WHITE0xFFFF 白色 lcd.ORANGE0xFD20 橙色 lcd.GREENYELLOW0xAFE5 绿黄色 lcd.PINK0xF81F 粉红色 |
3、调整显示文本字号与颜色 [mw_shl_code=python,false]#MicroPython动手做(37)——驱动LCD与图文显示 #调整显示文本字号与颜色 import mixno import lcd import image lcd.init(freq=15000000,color=0x0000) image = image.Image() image = image.draw_string(47,30,"MicroPython",(0,220,0),5,mono_space=0) image = image.draw_string(45,100,"MixPY",(255,0,0),11,mono_space=0) lcd.display(image)[/mw_shl_code] |
本帖最后由 驴友花雕 于 2020-7-3 20:19 编辑 4、MixPY 移动文本弹幕 [mw_shl_code=python,false]#MicroPython动手做(37)——驱动LCD与图文显示 #MxiPY 移动文本弹幕 import time import mixno import lcd import image lcd.init(freq=15000000,color=0x0000) image = image.Image() while True: for i in range(0, 320, 1): image.clear() lcd.display(image.draw_string(i,100,"MicroPython",(0,220,0),4,mono_space=0)) time.sleep_ms(10)[/mw_shl_code] |
6、变幻屏幕七彩色 [mw_shl_code=python,false]#MicroPython动手做(37)——驱动LCD与图文显示 #变幻屏幕七彩色 import time import mixno import lcd import image image = image.Image() while True: lcd.init(freq=5000000,color=0xFD20) time.sleep_ms(1000) lcd.init(freq=5000000,color=0x03E0) time.sleep_ms(1000) lcd.init(freq=5000000,color=0xF81F) time.sleep_ms(1000) for i in range(320, 0, -1): image.clear() lcd.display(image.draw_string(i,100,"MicroPython",(0,255,0),5,mono_space=0)) lcd.init(freq=5000000,color=0x07F) time.sleep_ms(1000) lcd.init(freq=5000000,color=0x7BE0) time.sleep_ms(1000) lcd.init(freq=5000000,color=0x03EF) time.sleep_ms(1000) for i in range(0, 320, 1): image.clear() lcd.display(image.draw_string(i,80,"MxiPY",(255,0,0),8,mono_space=0))[/mw_shl_code] |
