3562| 1
[教程] 树莓派/PC摄像头数据共享(方法二:Python-picamera) |
使用Python—OpenCV实现,发现传输效果并不是很理想,接下来使用Python和picamera实现树莓派/PC实时摄像头数据共享,主要也可分为服务器和客户端两部分。 服务器Demo如下: [mw_shl_code=python,false]import numpy as npimport cv2 import socket class VideoStreamingTest(object): def __init__(self, host, port): self.server_socket = socket.socket() self.server_socket.bind((host, port)) self.server_socket.listen(0) self.connection, self.client_address = self.server_socket.accept() self.connection = self.connection.makefile('rb') self.host_name = socket.gethostname() self.host_ip = socket.gethostbyname(self.host_name) self.streaming() def streaming(self): try: print("Host: ", self.host_name + ' ' + self.host_ip) print("Connection from: ", self.client_address) print("Streaming...") print("Press 'q' to exit") # need bytes here stream_bytes = b' ' while True: stream_bytes += self.connection.read(1024) first = stream_bytes.find(b'\xff\xd8') last = stream_bytes.find(b'\xff\xd9') if first != -1 and last != -1: jpg = stream_bytes[first:last + 2] stream_bytes = stream_bytes[last + 2:] image = cv2.imdecode(np.frombuffer(jpg, dtype=np.uint8), cv2.IMREAD_COLOR) cv2.imshow('image', image) if cv2.waitKey(1) & 0xFF == ord('q'): break finally: self.connection.close() self.server_socket.close() if __name__ == '__main__': # host, port h, p = "192.168.0.4", 8000 VideoStreamingTest(h, p)[/mw_shl_code] 客户端Demo如下: [mw_shl_code=python,false]import io import socket import struct import time import picamera # create socket and bind host client_socket = socket.socket(socket.AF_INET, socket.SOCK_STREAM) client_socket.connect(('192.168.2.104', 8000)) connection = client_socket.makefile('wb') try: with picamera.PiCamera() as camera: camera.resolution = (320, 240) # pi camera resolution camera.framerate = 15 # 15 frames/sec time.sleep(2) # give 2 secs for camera to initilize start = time.time() stream = io.BytesIO() # send jpeg format video stream for foo in camera.capture_continuous(stream, 'jpeg', use_video_port = True): connection.write(struct.pack('<L', stream.tell())) connection.flush() stream.seek(0) connection.write(stream.read()) if time.time() - start > 600: break stream.seek(0) stream.truncate() connection.write(struct.pack('<L', 0)) finally: connection.close() client_socket.close()[/mw_shl_code] 无论是运行速度还是画质都是比较理想的。 ![]() |
