2901浏览
查看: 2901|回复: 0
7X71RGB柔性屏测评第三弹:日期时间和天气
为了所立的flag不倒,硬着头皮来到第三弹。。。
一、日期
在上文中,我们通过ntp协议,更新了时间,可是并没有实现日期的功能。
本文用 time 和 Timezone 两个库,通过 ntp获取的 时间戳进行日期的更新。
代码如下:
[mw_shl_code=c,false]/ 北京时间时区
#define STD_TIMEZONE_OFFSET +8    // Standard Time offset (-7 is mountain time)
#include "Timezone.h"
#include <Time.h>
TimeChangeRule mySTD = {"", First,  Sun, Jan, 0, STD_TIMEZONE_OFFSET * 60};
Timezone myTZ(mySTD, mySTD);
// This function is called once a second
void updateDisplay(void) {
  TimeChangeRule *tcr;        // Pointer to the time change rule
  // Read the current UTC time from the NTP provider
  time_t utc = now();
  // Convert to local time taking DST into consideration
  time_t localTime = myTZ.toLocal(utc, &tcr);
  int weekdays =   weekday(localTime);
  int days    =   day(localTime);
  int months  =   month(localTime);
  int years   =   year(localTime);
  String dates = pressNum(years) + '-' + pressNum(months) + '-' + pressNum(days);
  int seconds =   second(localTime);
  int minutes =   minute(localTime);
  int hours   =   hour(localTime) ;   //12 hour format use : hourFormat12(localTime)  isPM()/isAM()
  String times = pressNum(hours) + ":" + pressNum(minutes) ;//+  ":" + pressNum(seconds);
  Serial.println( dates + "  " + times +  ":" + pressNum(seconds));
}[/mw_shl_code]
如图:
7X71RGB柔性屏测评第三弹:日期时间和天气图1
二、天气
天气信息的获取用了心知天气的api,
[mw_shl_code=c,false]  const char* host = "api.seniverse.com";
  const int httpPort = 80;
  if (!client.connect(host, httpPort)) {
    Serial.println("connection failed");
    return;
  // We now create a URI for the request
  String url = "/v3/weather/now.json?key=SS8P3IMHtZRRykScu&location=wenzhou&language=en&unit=c";
  Serial.print("Requesting URL: ");
  Serial.println(url);
  // This will send the request to the server
  client.print(String("GET ") + url + " HTTP/1.1\r\n" +
               "Host: " + host + "\r\n" +
               "Connection: close\r\n\r\n");
  delay(100);
  // Read all the lines of the reply from server and print them to Serial
  String weather_data;
  while (client.available()) {
    String line = client.readStringUntil('\r');
    weather_data += line;
  client.stop();
  Serial.println();
  Serial.println("closing connection");
  // Process weather_json
  Serial.println();
  //Serial.println("weather_data: ");
  // Serial.println(weather_data);
  // Convert to JSON
  String json_weather_data;
  int jsonIndex;
  for (int i = 0; i < weather_data.length(); i++) {
    if (weather_data == '{') {
      jsonIndex = i;
      break;
  // Get JSON data
  json_weather_data = weather_data.substring(jsonIndex);
  Serial.println();
  Serial.println("json_weather_data: ");
  Serial.println(json_weather_data);[/mw_shl_code]
就是用了 http 协议,通过心知天气的API获取其返回的json格式字符串。
7X71RGB柔性屏测评第三弹:日期时间和天气图2
7X71RGB柔性屏测评第三弹:日期时间和天气图3
因为 7*71的屏不能显示中文,所以上图1中的 Tem:19,Hum:72 分别表示温度19℃和湿度72%,
下半夜写文章,72%的湿度基本上意味着要下雨了。
上图2中的 Weather:Clear表示空气清新(暂时为晴)
三、天气格式化
天气信息的json字符串格式化用了 ArduinoJson 库。
[mw_shl_code=c,false]//利用arduinoJson库解析心知返回的json天气数据
  //可以利用 https://arduinojson.org/v5/assistant/ Arduinojson助手生成相关json解析代码  很方便!!!
  const size_t capacity = JSON_ARRAY_SIZE(1) + JSON_ARRAY_SIZE(3) + JSON_OBJECT_SIZE(1) + JSON_OBJECT_SIZE(3) + JSON_OBJECT_SIZE(6) + 3 * JSON_OBJECT_SIZE(12) + 700;
  DynamicJsonBuffer jsonBuffer(capacity);
  JsonObject& root = jsonBuffer.parseObject(json_weather_data);
  JsonObject& results_0 = root["results"][0];
  JsonObject& results_0_now = results_0["now"];
  String results_0_now_text = results_0_now["text"]; // "Clear" 天气状况
    Serial.println(results_0_now_text);
  String results_0_now_tem = results_0_now["temperature"]; // 温度
  Serial.println(results_0_now_tem);
  String results_0_now_hum = results_0_now["humidity"]; // 气温
  char chardates[dates.length()+1];
  char chartimes[times.length()+1];
  dates.toCharArray(chardates, dates.length()+1);
  times.toCharArray(chartimes, times.length()+1);
screen.setMessage(chardates);
delay(1500);
screen.setMessage(chartimes);
delay(1500);
screen.setMessage(("Weather:" + results_0_now_text).c_str());
delay(1500);
screen.setMessage(("Tem:" + results_0_now_tem + "," + "Hum:" + results_0_now_hum).c_str());
delay(1500);[/mw_shl_code]
7X71RGB柔性屏测评第三弹:日期时间和天气图4
晚上的天气,总是变化很快,已经从原来的 Clear 到了 现在的 Cloudy.
一个建议:
柔性屏的 displayBanner 函数如果有多个 Message 的时候可否带个设置延时的参数,默认好像是0.5s切换,太闪了啊。。。
所以本文,只好用 setMessage 和 delay 来代替这个功能。
貌似柔性屏的功能函数只提供了基本接口,期待后续更多API的更新。
