3785| 1
[教程] 【智控万物】codelab对接图灵机器人(实现语音聊天) |
【演示视频】 视频结尾处出问题在于,图灵对话机器人调用量没了(免费版适用于个人或测试使用,图灵机器人平台每天会赠送免费版用户100次调用量),每个账号可创建5个机器人。 1、下载CodeLab https://www.codelab.club/blog/codelab-download/下载页,下载后解压,运行程序codelab-adapter-win-3_1_0.exe,会在默认浏览器中打开运行页面“CodeLab Adapter v3 Web UI” 2、下载extensio_python_exec。 ![]() ![]() ![]() ![]() ![]() 看见此项,安装完成,下面修改程序代码。 ![]() ![]() 用记事本或其它Python文本编辑工具 将以下代码覆盖原有代码。 [mw_shl_code=python,false]from io import StringIO import contextlib import sys import time # import subprocess # import webbrowser from codelab_adapter.core_extension import Extension from codelab_adapter.utils import verify_token import json import urllib.request class PythonKernelExtension(Extension): def __init__(self): super().__init__() self.NODE_ID = self.generate_node_id(__file__) @contextlib.contextmanager def stdoutIO(self, stdout=None): old = sys.stdout if stdout is None: stdout = StringIO() sys.stdout = stdout yield stdout sys.stdout = old def tuling(self, code): api_url = "http://openapi.tuling123.com/openapi/api/v2" text_input = code req = { "perception": { "inputText": { "text": text_input }, "selfInfo": { "location": { "city": "张家口", "province": "河北", "street": "涿鹿" } } }, "userInfo": { "apiKey": "06c515993ed74e8e9ae1aa63a80ab9ac", "userId": "OnlyUseAlphabet" } } # print(req) # 将字典格式的req编码为utf8 req = json.dumps(req).encode('utf8') # print(req) http_post = urllib.request.Request(api_url, data=req, headers={'content-type': 'application/json'}) response = urllib.request.urlopen(http_post) response_str = response.read().decode('utf8') # print(response_str) response_dic = json.loads(response_str) # print(response_dic) intent_code = response_dic['intent']['code'] results_text = response_dic['results'][0]['values']['text'] return('图灵的回答:' + results_text) def run_python_code(self, code): try: with self.stdoutIO() as s: # 'hello world'[::-1] # import re; print(re.search('just4fun', 'blog.just4fun.site').span()) # exec(object[, globals[, locals]]) exec(code) output = s.getvalue() except Exception as e: output = e return output @verify_token def extension_message_handle(self, topic, payload): ''' 所有可能运行代码的地方,都加上验证,确认payload中代码风险和token test: import webbrowser;webbrowser.open("https://www.codelab.club") ''' self.logger.info(f'python code: {payload["content"]}') message_id = payload.get("message_id") python_code = payload["content"] #output = self.run_python_code(python_code) output =self.tuling(python_code) payload["content"] = str(output) message = {"payload": payload} self.publish(message) def run(self): "避免插件结束退出" while self._running: time.sleep(0.5) export = PythonKernelExtension [/mw_shl_code] ![]() 这"apiKey"要改成自己的。不想要“图灵的回答”,可把return('图灵的回答:' + results_text),改成return( results_text)。修改后记得重新启动extension_python_exec 。![]() 点击运行。 3、打开https://scratch3v3.codelab.club/ ![]() 这段程序要一直跟图灵说话,5秒一次,中间有一次不说,谈话就中止。 ![]() 修正1:使用标识判断,解决语音为空时(不说话的时候)。因使用默认的5秒(一句话在5秒说完,差不多),可以自己修改。 还存在两个问题,一是:不能实现静音识别——不说了作为中止,然后开始识别;二是:没有唤醒词功能,像“小度小度”那种。这两个问题都可以用App Inventor2在手机上解决。 ![]() 修正2: ![]() 此段程序实现,语音对话开始后,如果连续有超三次不说话(静音),将进入休眠状态,直到响度大于50后,再重新启动语音对话。 ![]() 【修正后演示视频】 |
