18908浏览
查看: 18908|回复: 36
[MP动手做] MicroPython动手做(16)——掌控板之图片图像显示
掌控板板载1.3英寸OLED显示屏,分辨率128x64。显示图像有两种方法,一是 bmp格式的图片,可以用取模软件转换为16进制图像数据,在OLED屏显示图像。二是pbm格式的图片,在OLED屏显示图像。板内内置图片为pbm格式,相对于16进制图像数据,pbm格式占用内存更少,可以使掌控板储存更多的图片,我们也可以将自己制作的图片,转换为pbm或者bmp格式显示在掌控板上。
1、OLED屏显示心在跳动
  1. #MicroPython动手做(16)——掌控板之图片图像显示
  2. #OLED屏显示内置图像心在跳动
  3. from mpython import *
  4. import time
  5. image_picture = Image()
  6. while True:
  7.     oled.fill(0)
  8.     oled.blit(image_picture.load('face/2.pbm', 0), 32, 0)
  9.     oled.show()
  10.     time.sleep(1)
  11.     oled.fill(0)
  12.     oled.blit(image_picture.load('face/1.pbm', 0), 32, 0)
  13.     oled.show()
  14.     time.sleep(1)
驴友花雕  中级技神
发表于 2020-4-24 09:21:34
8、A、B键控制图片转换显示
  2. #A、B键控制图片转换显示
  4. import music
  5. def callback_button_a_pressed():
  6.   oled.fill(0)
  7.   bmp_wZZv = bytearray([0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfb,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xe3,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x89,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x19,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x39,0xff,0xff,0xff,0xff,0xff,0xff,0xf8,0x0,0x3f,0xff,0xff,0xff,0xff,0xff,0xfe,0x79,0xff,0xff,0xff,0xff,0xff,0xff,0xe0,0x1a,0xf,0xff,0xff,0xff,0xff,0xff,0xfe,0xf9,0xff,0xff,0xff,0x3f,0xff,0xff,0x83,0xff,0xe0,0x0,0x0,0x0,0x7f,0xff,0xfc,0xf9,0xff,0xff,0xfc,0xf,0xff,0xfe,0x0,0x7f,0xf0,0x0,0x0,0x0,0x3f,0xff,0xfc,0xf9,0xff,0xf8,0x0,0xe7,0xff,0xfc,0x7e,0xf,0xfc,0xff,0xf3,0xff,0xbf,0xff,0xfc,0xf9,0xff,0xe0,0x0,0x1,0xff,0xf9,0xff,0xc7,0xfe,0x7f,0xf3,0xff,0x9f,0xff,0xfc,0xf9,0xff,0x80,0x0,0x0,0x3,0xf3,0xff,0xc3,0xff,0x3f,0xf3,0xff,0x80,0x3f,0xfe,0xf9,0xfe,0x0,0x7,0xff,0xc0,0x73,0xff,0xc1,0xff,0x9f,0xf3,0xff,0x80,0x0,0x7e,0xf9,0xe0,0x0,0xf,0xff,0xff,0x7,0xf0,0x0,0xff,0x8f,0xf3,0xff,0x80,0x0,0x0,0xf9,0xf0,0x0,0xf,0xff,0xff,0xc7,0x80,0x30,0x7e,0xf,0xf3,0xff,0x80,0x0,0x0,0xf9,0x90,0x0,0x1f,0xbf,0xff,0xf3,0x1f,0x38,0x60,0x3f,0xf7,0xff,0x80,0x0,0x0,0xf9,0xc0,0x0,0x1f,0x3f,0xff,0xf8,0x7f,0x80,0x3,0xbf,0xff,0xff,0x80,0x0,0x0,0xf9,0xc0,0x0,0x1e,0x41,0xff,0xf8,0xff,0xc2,0x1f,0x9f,0xff,0xff,0x80,0x0,0x0,0xf9,0xe0,0x0,0x1e,0x40,0xff,0xfc,0xff,0xff,0x9f,0x9f,0xff,0xff,0x80,0x0,0x0,0xf9,0xf0,0x0,0x1c,0xb0,0xff,0xfc,0xfc,0xff,0xcf,0x9f,0xff,0xff,0x80,0x0,0x0,0xf9,0xf0,0x0,0x1c,0x90,0xff,0xfe,0x40,0x7f,0xcf,0x9f,0xff,0xff,0x80,0x0,0x0,0xf9,0xf0,0x0,0x1c,0x80,0xfd,0xfe,0x6,0x7f,0xcf,0x9f,0xff,0xff,0x80,0x0,0x0,0x1,0xe0,0x0,0x1c,0xc1,0xfc,0xfe,0x3f,0x3f,0xcf,0x9f,0xff,0xff,0x80,0x0,0x1,0x7,0xe0,0x0,0x1f,0xe3,0xfe,0x7f,0x1f,0x38,0xcf,0x9f,0xff,0xff,0x80,0x0,0xff,0xff,0xe0,0x0,0x1f,0xff,0xff,0x7f,0x3,0x80,0x4f,0x9f,0xff,0xff,0x81,0xff,0xff,0xff,0xe0,0x0,0x1f,0xff,0xff,0x3f,0x21,0x9f,0xf,0x9f,0xff,0xff,0xbf,0xff,0xff,0xff,0xe0,0x0,0x1f,0xff,0xff,0x3f,0x0,0x7f,0x9f,0x9f,0xff,0xff,0xbf,0xff,0xff,0xff,0xe0,0x0,0xf,0xff,0xff,0x3f,0x10,0x3f,0xdf,0x9f,0xff,0xff,0xbf,0xff,0xff,0xff,0xe0,0x0,0x1f,0xff,0xff,0xbf,0x39,0x0,0x1f,0x80,0x0,0x0,0x3f,0xff,0xff,0xff,0xe0,0x0,0x1f,0xff,0xff,0xbf,0x3b,0x80,0x1f,0x80,0x0,0x0,0x3f,0xff,0xff,0xff,0xe0,0x0,0x1f,0xff,0xff,0x3f,0x30,0x3f,0x9f,0x1f,0xff,0xff,0xbf,0xff,0xff,0xff,0xe0,0x0,0x1f,0xff,0xff,0x3f,0x0,0x7f,0x9f,0x1f,0xff,0xff,0xbf,0xff,0xff,0xff,0xe0,0x0,0x3f,0xff,0xff,0x3f,0x1,0x9f,0x1c,0x1f,0xff,0xff,0xbf,0xff,0xff,0xff,0xe0,0x0,0x3f,0xff,0xfe,0x7f,0x3,0x80,0x38,0x9f,0xff,0xff,0x9f,0xff,0xff,0xff,0xe0,0x0,0x7f,0xe3,0xfe,0x7f,0x1f,0x30,0xb1,0xdf,0xff,0xff,0x80,0x1f,0xff,0xff,0xf0,0x0,0x3c,0xc1,0xfc,0xff,0x3f,0x3f,0xb3,0xdf,0xff,0xff,0x80,0x0,0x1f,0xff,0xf0,0x0,0x3c,0xb0,0xfd,0xfe,0x6,0x7f,0x87,0xdf,0xff,0xff,0x80,0x0,0x0,0x1,0xf0,0x0,0x1c,0xb0,0xff,0xfe,0x40,0x73,0x87,0xdf,0xff,0xff,0x80,0x0,0x0,0x21,0xf0,0x0,0x1e,0x80,0xff,0xfe,0xfc,0xe0,0xcf,0x9f,0xff,0xff,0x80,0x0,0x0,0xf9,0xf8,0x0,0x1e,0x40,0xff,0xfc,0xff,0xcc,0xf,0x9f,0xff,0xff,0x80,0x0,0x0,0xf9,0xf8,0x0,0x1e,0x61,0xff,0xf8,0x1f,0xcc,0xf,0x9f,0xff,0xff,0x80,0x0,0x0,0xf9,0xfc,0x0,0x1f,0x3f,0xff,0xf9,0x0,0x0,0x60,0x9f,0xff,0xff,0x80,0x0,0x0,0xf9,0xfc,0x0,0x1f,0xff,0xff,0xf3,0xf0,0x70,0x78,0xf,0xf3,0xff,0x80,0x0,0x0,0xf9,0xfe,0x0,0x1f,0xff,0xff,0xc7,0xff,0xfc,0xff,0x8f,0xf3,0xff,0x80,0x0,0x0,0xf9,0xff,0x0,0x1f,0xff,0xfe,0x7,0xff,0xf9,0xff,0x9f,0xf3,0xff,0x80,0x0,0x0,0xf9,0xff,0x80,0xf,0xff,0xc0,0x73,0xff,0xf1,0xff,0x3f,0xf3,0xff,0x80,0x0,0x6,0x79,0xff,0xc0,0x0,0x0,0x3,0xf9,0xff,0xe7,0xfe,0x3f,0xf3,0xff,0x80,0xf,0xfe,0xf9,0xff,0xe0,0x0,0x3,0xff,0xf8,0xff,0xf,0xfc,0x7f,0xf3,0xff,0x9f,0xff,0xfc,0xf9,0xff,0xf8,0x0,0x67,0xff,0xfe,0x0,0x3f,0xf8,0x0,0x0,0x0,0x3f,0xff,0xfc,0xf9,0xff,0xff,0xfe,0xf,0xff,0xff,0x3,0xff,0xe0,0x0,0x0,0x0,0x3f,0xff,0xfc,0xf9,0xff,0xff,0xff,0xbf,0xff,0xff,0xc1,0xff,0x87,0xff,0xff,0xff,0xff,0xff,0xfc,0xf9,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,0x0,0x1f,0xff,0xff,0xff,0xff,0xff,0xfc,0xf9,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xe7,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xf9,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x79,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x39,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x99,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc1,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xe3,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfb,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff])
  8.   oled.Bitmap(0, 0, bmp_wZZv, 128, 64, 1)
  9.   oled.show()
  10. def callback_button_b_pressed():
  11.   oled.fill(0)
  12.   bmp_h61P = bytearray([0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xdf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc7,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x83,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x99,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x9c,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x9e,0x7f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x9f,0x7f,0xff,0xff,0xff,0xff,0xff,0xff,0xe7,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x9f,0x3f,0xff,0xff,0xff,0xff,0xff,0xf8,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0x9f,0x3f,0xff,0xff,0xff,0xff,0xff,0xe1,0xff,0x83,0xff,0xff,0xfd,0xff,0xff,0xff,0x9f,0x3f,0xff,0xfc,0x0,0x0,0x0,0x7,0xff,0xc0,0xff,0xff,0xf0,0x7f,0xff,0xff,0x9f,0x3f,0xff,0xfc,0x0,0x0,0x0,0x1f,0xfc,0x0,0x7f,0xff,0xe6,0x0,0x1f,0xff,0x9f,0x3f,0xff,0xf9,0xff,0xcf,0xfe,0x3f,0xf0,0xff,0x1f,0xff,0xc0,0x0,0x7,0xff,0x9f,0x7f,0xf0,0x1,0xff,0xcf,0xfc,0x7f,0xe7,0xff,0x9f,0xc0,0x0,0x0,0x3,0xff,0x9e,0x60,0x0,0x1,0xff,0xcf,0xfc,0xff,0x8f,0xff,0xce,0x3,0xff,0xf0,0x1,0xff,0x9f,0x0,0x0,0x1,0xff,0xcf,0xf9,0xff,0x9f,0xff,0xe0,0x7f,0xff,0xf8,0x0,0xff,0x9f,0x0,0x0,0x1,0xff,0xcf,0xf1,0xff,0x3f,0xff,0xe3,0xff,0xff,0xf8,0x0,0x7f,0x9f,0x0,0x0,0x1,0xff,0xcf,0xf0,0x1e,0xe,0xf,0xcf,0xff,0xff,0xf8,0x0,0x3f,0x9f,0x0,0x0,0x1,0xff,0xff,0xf9,0x6,0x0,0x0,0x9f,0xff,0xfc,0xf8,0x0,0x3f,0x9f,0x0,0x0,0x1,0xff,0xff,0xf9,0xf0,0x33,0xf8,0x1f,0xff,0x86,0x78,0x0,0x1f,0x9f,0x0,0x0,0x1,0xff,0xff,0xf9,0xf0,0x33,0xff,0x3f,0xff,0x2,0x78,0x0,0x1f,0x9f,0x0,0x0,0x1,0xff,0xff,0xf9,0xf3,0x7,0x3f,0x7f,0xff,0x1,0x78,0x0,0xf,0x84,0x0,0x0,0x1,0xff,0xff,0xfb,0xe1,0xce,0x2,0x7f,0xff,0xd,0x38,0x0,0xf,0x80,0x0,0x0,0x1,0xff,0xff,0xfb,0xe1,0xfe,0x60,0x7f,0xbf,0xd,0x3c,0x0,0xf,0xff,0xf8,0x0,0x1,0xff,0xff,0xfb,0xcd,0xfc,0xfc,0xff,0x3f,0x83,0x3c,0x0,0xf,0xff,0xff,0xf8,0x1,0xff,0xff,0xfb,0x8d,0xc,0xf8,0xfe,0x7f,0xc7,0xfe,0x0,0x7,0xff,0xff,0xff,0xf9,0xff,0xff,0xf9,0x1c,0x1,0xc0,0xfe,0x7f,0xff,0xfc,0x0,0x7,0xff,0xff,0xff,0xfd,0xff,0xff,0xf8,0x38,0xf9,0x80,0xfc,0xff,0xff,0xfc,0x0,0x7,0xff,0xff,0xff,0xfd,0xff,0xff,0xf8,0xf9,0xfe,0x0,0xfc,0xff,0xff,0xf8,0x0,0x7,0xff,0xff,0xff,0xfd,0xff,0xff,0xf8,0xf9,0xfc,0xc,0xfc,0xff,0xff,0xf8,0x0,0x7,0xff,0xff,0xff,0xfc,0x0,0x0,0x1,0xf8,0x1,0xdc,0xfd,0xff,0xff,0xf8,0x0,0x7,0xff,0xff,0xff,0xfc,0x0,0x0,0x1,0xf8,0x0,0x9c,0xfd,0xff,0xff,0xf8,0x0,0x7,0xff,0xff,0xff,0xfd,0xff,0xff,0xf9,0xfb,0xfc,0x8,0xfc,0xff,0xff,0xf0,0x0,0x7,0xff,0xff,0xff,0xfd,0xff,0xff,0xf9,0xf9,0xfe,0x0,0xfc,0xff,0xff,0xf8,0x0,0x7,0xff,0xff,0xff,0xfd,0xff,0xff,0xf9,0xf0,0xf9,0x84,0xfc,0xff,0xff,0xf8,0x0,0x7,0xff,0xff,0xff,0x81,0xff,0xff,0xf9,0xf2,0x1,0xc0,0xfe,0xff,0xff,0xf8,0x0,0x7,0xff,0xff,0x0,0x1,0xff,0xff,0xf9,0xf3,0x1c,0xf8,0xfe,0x7f,0xc7,0xf8,0x0,0x7,0xe0,0x80,0x0,0x1,0xff,0xff,0xf9,0xf3,0xfc,0xfc,0x7f,0x3f,0x83,0x38,0x0,0x7,0x80,0x0,0x0,0x1,0xff,0xff,0xf9,0xf3,0xfe,0x60,0x7f,0xbf,0x1,0x38,0x0,0xf,0x9f,0x0,0x0,0x1,0xff,0xff,0xf9,0xf3,0xfe,0x2,0x7f,0xff,0x9,0x38,0x0,0xf,0x9f,0x0,0x0,0x1,0xff,0xff,0xf9,0xf3,0xff,0x3f,0x3f,0xff,0xd,0x38,0x0,0xf,0x9f,0x0,0x0,0x1,0xff,0xff,0xf9,0xf9,0xff,0xff,0x3f,0xff,0x2,0x78,0x0,0x7,0x9f,0x0,0x0,0x1,0xff,0xff,0xf9,0xf8,0x43,0xff,0x1f,0xff,0x82,0x78,0x0,0x3,0x9f,0x0,0x0,0x1,0xff,0xff,0xfd,0xc0,0x1,0xfe,0x1f,0xff,0xfc,0xf8,0x0,0x3,0x9f,0x0,0x0,0x1,0xff,0xef,0xfc,0x6,0x1c,0xf8,0xcf,0xff,0xfd,0xf8,0x0,0x9,0x9f,0x0,0x0,0x1,0xff,0xcf,0xf0,0x7e,0xc,0x1,0xe3,0xff,0xff,0xf0,0x0,0xf,0x9f,0x0,0x0,0x1,0xff,0xcf,0xf1,0xff,0x0,0xf,0xe0,0xff,0xff,0xf0,0x0,0x7,0x9f,0x7e,0x0,0x1,0xff,0xcf,0xf9,0xff,0x83,0xff,0xce,0x3,0xff,0xe0,0x0,0x7f,0x9f,0x7f,0xfc,0x1,0xff,0xcf,0xfc,0xff,0xc3,0xff,0xcf,0xc0,0x0,0x0,0x1,0xff,0x9f,0x3f,0xff,0xf9,0xff,0xcf,0xfe,0x7f,0xe3,0xff,0x9f,0xff,0x80,0x0,0x7,0xff,0x9f,0x3f,0xff,0xfd,0xff,0xcf,0xff,0x3f,0xf0,0x7e,0x3f,0xff,0xe7,0x0,0x1f,0xff,0x9f,0x3f,0xff,0xfc,0x0,0x0,0x0,0xf,0xfe,0x0,0x7f,0xff,0xf0,0x3f,0xff,0xff,0x9f,0x3f,0xff,0xfe,0x0,0x0,0x0,0x7,0xff,0xc1,0xff,0xff,0xfc,0xff,0xff,0xff,0x9f,0x7f,0xff,0xff,0xff,0xff,0xff,0xf0,0x58,0x7,0xff,0xff,0xff,0xff,0xff,0xff,0x9e,0x7f,0xff,0xff,0xff,0xff,0xff,0xfc,0x0,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0x9c,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x98,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x91,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc7,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xdf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff])
  13.   oled.Bitmap(0, 0, bmp_h61P, 128, 64, 1)
  14.   oled.show()
  15. def on_button_a_pressed():
  16.   while True:
  17.     if button_a.value() == 0:
  18.       yield callback_button_a_pressed()
  19.     else:
  20.       yield
  21. def on_button_b_pressed():
  22.   while True:
  23.     if button_b.value() == 0:
  24.       yield callback_button_b_pressed()
  25.     else:
  26.       yield
  27. func_button_a_pressed = on_button_a_pressed()
  28. func_button_b_pressed = on_button_b_pressed()
  29. while True:
  30.   next(func_button_a_pressed)
  31.   next(func_button_b_pressed)
驴友花雕  中级技神
发表于 2020-4-23 17:24:36
  2. #OLED显示外部图片
  4. import time
  5. while True:
  6.     oled.fill(0)
  7.     oled.Bitmap(0, 0, bytearray([0XFF,0XFF,0XFF,0XFF,0X00,0X0F,0XFF,0XFF,0XFF,0XFF,0XF0,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0X00,0X1F,0XFF,0XFF,0XFF,0XFF,0XF0,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0X00,0X3C,0X00,0X00,0X00,0X00,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0X00,0X7C,0X00,0X00,0X00,0X00,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0X00,0XEC,0X03,0XFF,0XFF,0XFF,0XFF,0XFC,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0X01,0XCC,0X07,0XFF,0XFF,0XFF,0XFF,0XFE,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0X03,0X8C,0X06,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0X07,0X0C,0X06,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0X0E,0X0C,0X06,0X7F,0X87,0X06,0X3F,0XC3,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0X1C,0X0C,0X06,0X7F,0XC7,0X8E,0X7F,0XE3,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0X38,0X0C,0X06,0X60,0XE7,0X9E,0X70,0X73,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0X70,0X0C,0X06,0X60,0X67,0XFE,0X70,0X33,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFC,0X06,0X60,0X66,0XF6,0X70,0X33,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFC,0X06,0X7F,0XE6,0X66,0X7F,0XE3,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X06,0X7F,0XC6,0X26,0X7F,0XE3,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X06,0X60,0XE6,0X06,0X70,0X03,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X40,0X06,0X60,0X66,0X06,0X70,0X03,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0XC0,0X06,0X60,0X66,0X06,0X70,0X03,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XC4,0X40,0X06,0X7F,0XE6,0X06,0X70,0X03,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X06,0X7F,0XC6,0X06,0X70,0X03,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X06,0X7F,0X06,0X02,0X20,0X03,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X00,0X06,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X00,0X06,0X00,0X00,0X00,0X00,0X07,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X07,0XFF,0XFF,0XFF,0XFF,0XFE,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X01,0XFF,0XFF,0XFF,0XFF,0XFC,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCF,0XFF,0XFF,0XFF,0XFF,0XFE,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCF,0XFF,0XFF,0XFF,0XFF,0XFE,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X00,0X00,0X00,0X00,0X06,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X00,0X03,0XF8,0X00,0X06,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X00,0X07,0XFE,0X00,0X06,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X00,0X1E,0X07,0X00,0X06,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X00,0X38,0X03,0X80,0X06,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X00,0X30,0X01,0XC0,0X06,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X00,0X70,0X00,0XC0,0X06,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X00,0X60,0X00,0XE0,0X06,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X00,0X60,0X00,0X60,0X06,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X00,0XE0,0X00,0X60,0X06,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X00,0XE0,0X00,0X60,0X06,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X00,0X60,0X00,0X60,0X06,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X00,0X60,0X00,0X60,0X06,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X00,0X60,0X00,0XC0,0X06,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X00,0X30,0X01,0XC0,0X06,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X00,0X38,0X01,0X80,0X06,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X00,0X1C,0X07,0X80,0X06,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X00,0X7F,0XFF,0XC0,0X06,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X03,0XFF,0XFF,0XF8,0X06,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X07,0XDC,0X07,0X3E,0X06,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X0E,0X0C,0X07,0X07,0X06,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X1C,0X0E,0X0E,0X03,0X86,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X38,0X07,0XFC,0X01,0X86,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X30,0X03,0XF8,0X01,0XC6,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X70,0X00,0X60,0X00,0XC6,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X60,0X00,0X00,0X00,0XC6,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X61,0X80,0X00,0X30,0XC6,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X61,0X80,0X00,0X30,0XC6,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCC,0X61,0XC0,0X00,0X30,0XC6,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCF,0XFF,0XFF,0XFF,0XFF,0XFE,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XCF,0XFF,0XFF,0XFF,0XFF,0XFE,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X70,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,0X00,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,0X00,0XFF,0XFF,0XFF,0XFF,]), 128, 64, 1)
  8.     oled.show()
  9.     time.sleep(1)
  10.     oled.fill(0)
  11.     oled.Bitmap(0, 0, bytearray([0X00,0X00,0X00,0X00,0XFF,0XF0,0X00,0X00,0X00,0X00,0X0F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0XFF,0XE0,0X00,0X00,0X00,0X00,0X0F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0XFF,0XC3,0XFF,0XFF,0XFF,0XFF,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0XFF,0X83,0XFF,0XFF,0XFF,0XFF,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0XFF,0X13,0XFC,0X00,0X00,0X00,0X00,0X03,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0XFE,0X33,0XF8,0X00,0X00,0X00,0X00,0X01,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0XFC,0X73,0XF9,0XFF,0XFF,0XFF,0XFF,0XFC,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0XF8,0XF3,0XF9,0XFF,0XFF,0XFF,0XFF,0XFC,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0XF1,0XF3,0XF9,0X80,0X78,0XF9,0XC0,0X3C,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0XE3,0XF3,0XF9,0X80,0X38,0X71,0X80,0X1C,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0XC7,0XF3,0XF9,0X9F,0X18,0X61,0X8F,0X8C,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X8F,0XF3,0XF9,0X9F,0X98,0X01,0X8F,0XCC,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X00,0X03,0XF9,0X9F,0X99,0X09,0X8F,0XCC,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X00,0X03,0XF9,0X80,0X19,0X99,0X80,0X1C,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X3F,0XFF,0XF9,0X80,0X39,0XD9,0X80,0X1C,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X3F,0XFF,0XF9,0X9F,0X19,0XF9,0X8F,0XFC,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XBF,0XF9,0X9F,0X99,0XF9,0X8F,0XFC,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0X3F,0XF9,0X9F,0X99,0XF9,0X8F,0XFC,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X3B,0XBF,0XF9,0X80,0X19,0XF9,0X8F,0XFC,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X3F,0XFF,0XF9,0X80,0X39,0XF9,0X8F,0XFC,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X3F,0XFF,0XF9,0X80,0XF9,0XFD,0XDF,0XFC,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XFF,0XF9,0XFF,0XFF,0XFF,0XFF,0XFC,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XFF,0XF9,0XFF,0XFF,0XFF,0XFF,0XF8,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X3F,0XFF,0XF8,0X00,0X00,0X00,0X00,0X01,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X3F,0XFF,0XFE,0X00,0X00,0X00,0X00,0X03,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X30,0X00,0X00,0X00,0X00,0X01,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X30,0X00,0X00,0X00,0X00,0X01,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XFF,0XFF,0XFF,0XFF,0XF9,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XFF,0XFC,0X07,0XFF,0XF9,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XFF,0XF8,0X01,0XFF,0XF9,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XFF,0XE1,0XF8,0XFF,0XF9,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XFF,0XC7,0XFC,0X7F,0XF9,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XFF,0XCF,0XFE,0X3F,0XF9,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XFF,0X8F,0XFF,0X3F,0XF9,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XFF,0X9F,0XFF,0X1F,0XF9,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XFF,0X9F,0XFF,0X9F,0XF9,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XFF,0X1F,0XFF,0X9F,0XF9,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XFF,0X1F,0XFF,0X9F,0XF9,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XFF,0X9F,0XFF,0X9F,0XF9,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XFF,0X9F,0XFF,0X9F,0XF9,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XFF,0X9F,0XFF,0X3F,0XF9,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XFF,0XCF,0XFE,0X3F,0XF9,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XFF,0XC7,0XFE,0X7F,0XF9,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XFF,0XE3,0XF8,0X7F,0XF9,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XFF,0X80,0X00,0X3F,0XF9,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XFC,0X00,0X00,0X07,0XF9,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XF8,0X23,0XF8,0XC1,0XF9,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XF1,0XF3,0XF8,0XF8,0XF9,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XE3,0XF1,0XF1,0XFC,0X79,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XC7,0XF8,0X03,0XFE,0X79,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0XCF,0XFC,0X07,0XFE,0X39,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0X8F,0XFF,0X9F,0XFF,0X39,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0X9F,0XFF,0XFF,0XFF,0X39,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0X9E,0X7F,0XFF,0XCF,0X39,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0X9E,0X7F,0XFF,0XCF,0X39,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X33,0X9E,0X3F,0XFF,0XCF,0X39,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X30,0X00,0X00,0X00,0X00,0X01,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X30,0X00,0X00,0X00,0X00,0X01,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0X8F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X0F,0XFF,0X00,0X00,0X00,0X00, 0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X0F,0XFF,0X00,0X00,0X00,0X00,]), 128, 64, 1)
  12.     oled.show()
  13.     time.sleep(1)
驴友花雕  中级技神
发表于 2020-4-23 18:52:11
  2. #二只小象
  4. while True:
  5.     oled.fill(0)
  6.     oled.Bitmap(0, 0, bytearray([0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFC,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFC,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X4B,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X69,0X00,0X0F,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X68,0X07,0XE6,0X0F,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X48,0X3C,0X39,0XB7,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X48,0XC7,0X98,0X0B,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X50,0X39,0X3A,0X01,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC7,0XFF,0XFE,0XD0,0X7F,0XDE,0X05,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X03,0XFF,0XFE,0X90,0XFF,0XDE,0X02,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X43,0XFF,0XFC,0XBA,0XCF,0XEE,0X12,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XEF,0XFF,0XE2,0X81,0XFF,0XFC,0XB8,0XC6,0X6F,0X19,0X7F,0XFF,0XFF, 0XFF,0XFF,0XFF,0X33,0X00,0X1C,0X81,0XFF,0XF8,0XBC,0X46,0X6F,0X1C,0X9F,0XFF,0XFF, 0XFF,0XFF,0XFE,0X9A,0X7F,0X00,0XB3,0XFF,0XFC,0X9E,0X00,0XDF,0X1E,0X5F,0XFF,0XFF, 0XFF,0XFF,0XFD,0X05,0XC2,0X00,0XAF,0XFF,0XFC,0XDF,0XFF,0X1C,0X1F,0XEF,0XFF,0XFF, 0XFF,0XFF,0XFA,0X05,0X9F,0XE0,0XAF,0XFF,0XDE,0XDF,0XFF,0XBF,0X1F,0XEF,0XFF,0XFF, 0XFF,0XFF,0XF2,0X07,0XC0,0X10,0XA0,0X7F,0XDF,0X4F,0XFF,0XBF,0X9F,0XEF,0XFF,0XFF, 0XFF,0XFF,0XE4,0X87,0XBF,0XE0,0XA7,0X8F,0XC7,0X67,0XFF,0XFF,0XDF,0XDF,0XFF,0XFF, 0XFF,0XFF,0XC9,0X8F,0X7F,0XE8,0XB3,0XE7,0XC3,0XB3,0XFF,0X9F,0XCF,0X3F,0XFF,0XFF, 0XFF,0XFF,0X93,0X8F,0X7F,0XF0,0XB1,0XFB,0XC3,0X98,0XE0,0X03,0XCE,0X7F,0XFF,0XFF, 0XFF,0XFE,0X4F,0X0F,0X46,0X31,0X95,0XFD,0XC3,0XCE,0X07,0XEB,0XC8,0XFF,0XFF,0XFF, 0XFF,0XFE,0XFF,0X1F,0X47,0X31,0XB5,0XFE,0XE3,0XE0,0XC3,0XE3,0XC3,0XFF,0XFF,0XFF, 0XFF,0XFE,0XFF,0X1F,0X70,0X63,0XB1,0XFE,0X73,0XF1,0XF4,0X03,0XDF,0XFF,0XFF,0XFF, 0XFF,0XFE,0XFF,0X0F,0X8F,0X9F,0XB3,0XFF,0X73,0XFA,0X0C,0X07,0X9F,0XFF,0XFF,0XFF, 0XFF,0XFF,0X7F,0X3F,0XBF,0XFF,0XA7,0XFF,0X23,0XFD,0XC0,0X0E,0X2F,0XFF,0XFF,0XFF, 0XFF,0XFF,0XBF,0X7F,0XBF,0XFF,0X27,0XFF,0X87,0XFC,0X60,0X10,0X6F,0XFF,0XFF,0XFF, 0XFF,0XFF,0XDE,0X7F,0XFF,0XFF,0X6F,0XFF,0X8F,0XC0,0X00,0X21,0XF7,0XFF,0XFF,0XFF, 0XFF,0XFF,0XEE,0XFF,0X7F,0XFE,0X0F,0XFF,0XDF,0X9E,0X00,0X0F,0XFB,0XFF,0XFF,0XFF, 0XFF,0XFF,0XF0,0XFA,0X39,0XFC,0XDF,0XFF,0XDF,0XAE,0X20,0X0F,0XFD,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFE,0X71,0XC1,0XE1,0X3F,0XFF,0XDF,0XA7,0X31,0XFF,0XFE,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0X79,0XF8,0X0E,0X3F,0XFD,0XDF,0XBF,0X3B,0X3F,0XFF,0X7F,0XFF,0XFF, 0XFF,0XFF,0XFF,0X78,0X00,0X3C,0X7F,0XFD,0XDF,0X3F,0X3B,0X7B,0XDF,0X3F,0XFF,0XFF, 0XFF,0XFF,0XFF,0X9C,0X1F,0XE0,0XFF,0XFD,0XDF,0XBF,0X33,0XF9,0X9F,0XBF,0XFF,0XFF, 0XFF,0XFF,0XFF,0X84,0X00,0X01,0XFF,0XF9,0XDF,0XBF,0X33,0XF9,0X1F,0XDF,0XFF,0XFF, 0XFF,0XFF,0XFF,0X82,0X00,0XE7,0XFF,0XF9,0XDF,0X1F,0X17,0XF8,0X3F,0XDF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XD1,0X01,0X0F,0XFF,0XF9,0XBF,0X01,0X17,0XF8,0X3F,0XDF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XDD,0X80,0X3F,0XFF,0XFB,0XBF,0X84,0X53,0XF0,0XFF,0XDF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XDE,0X41,0XFF,0XFF,0XFB,0XBF,0XF7,0XD4,0X70,0XFF,0XDF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XEF,0X03,0XFF,0XFF,0XF3,0X3F,0XFF,0XD9,0X50,0X3F,0XDF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XEB,0XC1,0XFF,0XFF,0XE7,0X7F,0XFF,0X8C,0X07,0XBF,0XDF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XED,0XE0,0X7F,0XFF,0XC7,0X7F,0XFF,0X0F,0X9F,0XDF,0XDE,0X7F,0XFF, 0XFF,0XFF,0XFF,0XED,0XDF,0XFE,0XFF,0X8E,0XFF,0XFF,0X67,0X3F,0XFF,0X98,0X7F,0XFF, 0XFF,0XFF,0XFF,0XE6,0X93,0XFC,0XFF,0X0E,0XFF,0XFE,0XF3,0X7F,0XFF,0XB8,0XFF,0XFF, 0XFF,0XFF,0XFF,0XF6,0X33,0X9C,0XF8,0X1D,0XFF,0XFE,0XF0,0X7F,0XFF,0X30,0XFF,0XFF, 0XFF,0XFF,0XFF,0XF4,0X3F,0XD8,0X00,0X79,0XFF,0XFE,0XF8,0X7F,0XBC,0X70,0XFF,0XFF, 0XFF,0XFF,0XFF,0XF0,0XBF,0XC0,0X00,0X7B,0XFF,0XFE,0XFC,0X7F,0XB8,0X01,0XFF,0XFF, 0XFF,0XFF,0XFF,0XF7,0XBF,0XC0,0X02,0X3B,0XFF,0XFE,0X9C,0X7F,0X80,0X07,0XFF,0XFF, 0XFF,0XFF,0XFF,0XF7,0XBF,0XC0,0X03,0XFD,0XFF,0XFF,0X7C,0X67,0X87,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XF7,0XBF,0XD0,0X03,0XFD,0XFF,0XFF,0X7C,0X63,0X9F,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XE7,0X83,0XD0,0X01,0XFD,0XFF,0XFF,0X3C,0X3F,0X9F,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XE3,0XB8,0X9C,0X0D,0XFD,0XFF,0XFF,0X0C,0X3F,0X9F,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XE8,0X00,0X3F,0XF8,0X0D,0XFF,0XFF,0X20,0X1F,0X9F,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XF2,0X8F,0XFF,0XFC,0X43,0XFF,0XFF,0X80,0X83,0X9F,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFE,0X7F,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0X88,0X9F,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X3F,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF, 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,]), 128, 64, 1)
  7.     oled.show()
驴友花雕  中级技神
发表于 2020-4-22 09:44:00
mPython 图形编程
MicroPython动手做(16)——掌控板之图片图像显示图1
驴友花雕  中级技神
发表于 2020-4-22 09:47:32
驴友花雕  中级技神
发表于 2020-4-23 10:45:29
  1. <b>2、流动的时间</b>
  2. #MicroPython动手做(16)——掌控板之图片图像显示
  3. #流动的时间
  4. from mpython import *
  5. import time
  6. image_picture = Image()
  7. while True:
  8.     oled.fill(0)
  9.     oled.blit(image_picture.load('face/Progress/Timer 0.pbm', 0), 32, 0)
  10.     oled.show()
  11.     time.sleep(1)
  12.     oled.fill(0)
  13.     oled.blit(image_picture.load('face/Progress/Timer 1.pbm', 0), 32, 0)
  14.     oled.show()
  15.     time.sleep(1)
  16.     oled.fill(0)
  17.     oled.blit(image_picture.load('face/Progress/Timer 2.pbm', 0), 32, 0)
  18.     oled.show()
  19.     time.sleep(1)
  20.     oled.fill(0)
  21.     oled.blit(image_picture.load('face/Progress/Timer 3.pbm', 0), 32, 0)
  22.     oled.show()
  23.     time.sleep(1)
  24.     oled.fill(0)
  25.     oled.blit(image_picture.load('face/Progress/Timer 4.pbm', 0), 32, 0)
  26.     oled.show()
驴友花雕  中级技神
发表于 2020-4-23 10:50:28
mPython 图形编程
驴友花雕  中级技神
发表于 2020-4-23 11:03:41
驴友花雕  中级技神
发表于 2020-4-23 11:06:53
3、变幻的人脸
  2. #变幻的人脸
  4. import time
  6. while True:
  7.     oled.fill(0)
  8.     oled.blit(image_picture.load('face/8.pbm', 0), 32, 0)
  9.     oled.show()
  10.     time.sleep(1)
  11.     oled.fill(0)
  12.     oled.blit(image_picture.load('face/9.pbm', 0), 32, 0)
  13.     oled.show()
  14.     time.sleep(1)
  15.     oled.fill(0)
  16.     oled.blit(image_picture.load('face/12.pbm', 0), 32, 0)
  17.     oled.show()
  18.     time.sleep(1)
  19.     oled.fill(0)
  20.     oled.blit(image_picture.load('face/3.pbm', 0), 32, 0)
  21.     oled.show()
  22.     time.sleep(1)
  23.     oled.fill(0)
  24.     oled.blit(image_picture.load('face/4.pbm', 0), 32, 0)
  25.     oled.show()
  26.     time.sleep(1)
驴友花雕  中级技神
发表于 2020-4-23 11:18:24
mPython 图形编程
驴友花雕  中级技神
发表于 2020-4-23 11:23:46
驴友花雕  中级技神
发表于 2020-4-23 15:29:16
4、OLED显示外部图片
OLED屏幕只能显示颜色深度为1或者就是黑白模式的bmp格式,可以使用Photoshop、“画图”或者其他图片显示软件进行转换。转换好格式的图片需要使用取模工具对图片进行取模,转换的图片大小应该为128*64,也就是掌控板屏幕的大小。所选的图片线条要分明,且颜色不能太过丰富。
(1)选择一张图片
驴友花雕  中级技神
发表于 2020-4-23 15:32:27
(2)用在线PS打开图片,这里使用 https://www.uupoop.com/
驴友花雕  中级技神
发表于 2020-4-23 15:37:09
(3)调整为128*64规格,另存为bmp格式
驴友花雕  中级技神
发表于 2020-4-23 16:55:28
(4)安装小图片取模工具Image2Lcd
下载地址:
http://7dx.0098118.com/wwb5/image2lcd32.zip
驴友花雕  中级技神
发表于 2020-4-23 17:15:32
(5)去头去尾要中间(取模数据)
驴友花雕  中级技神
发表于 2020-4-23 17:21:15
(6)将复制的16进制图像数据粘贴在下列指令的空格处。
描述:OLED绘制16进制数组图像。将16进制数据转换成图像显示在oled屏幕的指定位置处。尝试将程序搭建好,将图片显示出来。
mPython 图形编程
驴友花雕  中级技神
发表于 2020-4-23 17:50:27
驴友花雕  中级技神
发表于 2020-4-23 18:39:38
5、尝试转换显示一张网络图片
驴友花雕  中级技神
发表于 2020-4-23 18:43:12
在线转换为bmp格式
驴友花雕  中级技神
发表于 2020-4-23 18:48:38
小图片取模工具Image2Lcd来取模(通过调整亮度选取合适图案)
12下一页
