7983浏览
查看: 7983|回复: 2
[项目] Color Unit试用项目准备工作——天气预报灯
Color Unit试用项目准备工作——天气预报灯图1
屏幕上显示当天天气图标,当前温度。https://www.seniverse.com/“心知天气”提供的数据
[mw_shl_code=html,false]{"results":[{"location":{"id":"WX38NPJ1DP88","name":"张家口","country":"CN","path":"张家口,张家口,河北,中国","timezone":"Asia/Shanghai","timezone_offset":"+08:00"},"now":{"text":"小雨","code":"13","temperature":"11"},"last_update":"2020-04-19T17:31:00+08:00"}]}[/mw_shl_code]
根据“心知天气”提供的数据也显示三天的天气情况。包含以下数据:
[mw_shl_code=html,false]{"results":[{"location":{"id":"WX38NPJ1DP88","name":"张家口","country":"CN","path":"张家口,张家口,河北,中国","timezone":"Asia/Shanghai","timezone_offset":"+08:00"},"daily":[{"date":"2020-04-19","text_day":"小雨","code_day":"13","text_night":"多云","code_night":"4","high":"17","low":"2","rainfall":"3.1","precip":"","wind_direction":"西北","wind_direction_degree":"315","wind_speed":"45.00","wind_scale":"6","humidity":"64"},{"date":"2020-04-20","text_day":"晴","code_day":"0","text_night":"晴","code_night":"1","high":"8","low":"-2","rainfall":"0.0","precip":"","wind_direction":"西北","wind_direction_degree":"328","wind_speed":"45.00","wind_scale":"6","humidity":"21"},{"date":"2020-04-21","text_day":"晴","code_day":"0","text_night":"晴","code_night":"1","high":"7","low":"-3","rainfall":"0.0","precip":"","wind_direction":"西北","wind_direction_degree":"321","wind_speed":"45.00","wind_scale":"6","humidity":"32"}],"last_update":"2020-04-19T11:17:53+08:00"}]}[/mw_shl_code]
Color Unit试用项目准备工作——天气预报灯图2
参考Mpython X 的python代码,设计 M5stack的Python代码:
Color Unit试用项目准备工作——天气预报灯图3
因暂时没有实现,显示中文,所以“当前温度”用自制图片显示:
Color Unit试用项目准备工作——天气预报灯图4
天气图标使用Firework软件进行处理,背景使用纯黑。
Color Unit试用项目准备工作——天气预报灯图5
M5stack中设置背景为纯黑:setScreenColor(0x000000)
label1.setText(str( w1["results"][0]["now"]["temperature"]))
  if w1["results"][0]["now"]["code"]== "0":
      image0.changeImg("res/0.JPG")
  if w1["results"][0]["now"]["code"]== "13":
      image0.changeImg("res/13.JPG")
  if w1["results"][0]["now"]["code"]== "4":
      image0.changeImg("res/4.JPG")
只做了三张图片0.JPG为晴天;13.JPG为下雨;4.JPG为多云。
["results"][0]["now"]["code"]获取的是天气代码。对应如下表:
Color Unit试用项目准备工作——天气预报灯图6
因“知心天气”限制一分钟访问20次。还因天气数据变化缓慢,所以中间使用time.sleep(20)延时访问。
[mw_shl_code=python,false]
from m5stack import *
from m5ui import *
from uiflow import *
import wifiCfg
import json
import urequests
import time
def get_seni_weather(_url, _location):
    _url = _url + "&location=" + _location.replace(" ", "%20")+"&language=zh-Hans&unit=c"
    response = urequests.get(_url)
    json = response.json()
    response.close()
    return json
label1 = M5TextBox(201, 171, '', lcd.FONT_DejaVu24,0xFFFFFF, rotate=0)
image0 = M5Img(113, 8, "res/default.jpg", True)
image1 = M5Img(49, 164, "res/98.JPG", True)
wifiCfg.doConnect('sxs', 'smj080823')
wifiCfg.autoConnect(lcdShow = False)
while not (wifiCfg.wlan_sta.isconnected()):
  pass
label1.setText(str('NET  OK'))
while True:
  w1 = get_seni_weather("https://api.seniverse.com/v3/weather/now.json?key=SAabm-73z5YLtTaxb", "zhangjiakou")
  #w2 = get_seni_weather("https://api.seniverse.com/v3/weather/daily.json?key=SAabm-73z5YLtTaxb", "zhangjiakou")
  #w3 = get_seni_weather("https://api.seniverse.com/v3/life/suggestion.json?key=SAabm-73z5YLtTaxb", "zhangjiakou")
  time.sleep(20)
  wait_ms(2)
[/mw_shl_code]
完整代码。
Color Unit试用项目准备工作——天气预报灯图7
由于今天一直阴天刮风,时不时的下雨,温度一降再降。
Color Unit试用项目准备工作——天气预报灯图8
亮灯代码
from m5ui import *
import wifiCfg
import json
import urequests
import time
import unit
    response.close()
    return json
neopixel0 = unit.get(unit.NEOPIXEL, unit.PORTB, 10)
  pass
while True:
      neopixel0.setColorFrom(1, 10, 0xff0000)
      neopixel0.setColorFrom(1, 10, 0x00ff00)
      neopixel0.setColorFrom(1, 10, 0x0000ff0)
  time.sleep(20)
  wait_ms(2)
[/mw_shl_code]
发表于 2020-6-30 20:44:30
楼主写作的风格可以考虑更改下。
云天  中级技神
发表于 2020-7-2 08:23:24
hnyzcj 发表于 2020-6-30 20:44
楼主写作的风格可以考虑更改下。
作者态度不端正
