3029浏览
查看: 3029|回复: 0
[用户分享] TinkerNode NB-IoT 物联网开发板 测评第三弹 物联网初体验
在了解了NB板的基本功能后,我们现在来试试它的物联网功能吧。
如果想了解前面的内容,请访问:
TinkerNode NB-IoT 物联网开发板 测评第二弹 功能全览
TinkerNode NB-IoT 物联网开发板 测评第一弹 开箱即用
本文假设你已经配置好NB板的相关开发环境,如果还没有请先看 第一弹
我们打开Arduino IDE在相应位置找到示例代码,这里要吐槽下,NB板的MQTT代码里面,
竟然没有自己的 IoT服务器  https://iot.dfrobot.com.cn 相关的代码文件。
TinkerNode NB-IoT 物联网开发板 测评第三弹 物联网初体验图1
那我们只能选择这个,手工修改下代码。[mw_shl_code=c,false]/*!
* @file Subscript_Topic.ino
* @brief Subscribe to a Topic. When the Topic receives the message,
* @brief it will execute a callback function to print out the message of the Topic.
* @copyright   Copyright (c) 2010 DFRobot Co.Ltd (http://www.dfrobot.com)
* @licence     The MIT License (MIT)
* @author      [Wuxiao](xiao.wu@dfrobot.com)
* @version  V1.0
* @date  2019-02-20
* @get from https://www.dfrobot.com
#include <WiFi.h>
#include <PubSubClient.h>
#include "DFRobot_Iot.h"
/*Set WIFI name and password*/
const char * WIFI_SSID     = "WIFI_SSID";
const char * WIFI_PASSWORD = "WIFI_PASSWORD";
/*Configure device certificate information*/
String ProductID = "you_ProductID";
String DeviceId  = "you_DeviceId";
String ApiKey    = "you_ApiKey";
/*Configure the domain name and port number*/
String ONENET_SERVER = "mqtt.heclouds.com";
uint16_t PORT = 6002;
/*Set the Topic you need to subscribe to*/
const char * subTopic = "you_subscribe_Topic";
DFRobot_Iot myIot;
WiFiClient espClient;
PubSubClient client(espClient);
void connectWiFi(){
  Serial.print("Connecting to ");
  Serial.println(WIFI_SSID);
  WiFi.begin(WIFI_SSID,WIFI_PASSWORD);
  while(WiFi.status() != WL_CONNECTED){
    delay(500);
    Serial.print(".");
  Serial.println();
  Serial.println("WiFi connected");
  Serial.print("IP Adderss: ");
  Serial.println(WiFi.localIP());
void callback(char * topic, byte * payload, unsigned int len){
  Serial.print("Recevice [");
  Serial.print(topic);
  Serial.print("] ");
  for (int i = 0; i < len; i++){
    Serial.print((char)payload);
  Serial.println();
void ConnectCloud(){
  while(!client.connected()){
    Serial.print("Attempting MQTT connection...");
    /*A device connected to the cloud platform based on an automatically calculated username and password*/
    if(client.connect(myIot._clientId, myIot._username, myIot._password)){
      Serial.println("connected");
      client.subscribe(subTopic);
    }else{
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      delay(5000);
void setup(){
  Serial.begin(115200);
  /*Connect to WIFI*/
  connectWiFi();
  /*Initialize the configuration of OneNet*/
  myIot.init(ONENET_SERVER, ProductID, DeviceId, ApiKey);
  client.setServer(myIot._mqttServer,PORT);
  /*Set the callback function to execute the callback function when receiving the subscription information*/
  client.setCallback(callback);
  /*Connect to the cloud platform*/
  ConnectCloud();
void loop(){
  if(!client.connected()){
    ConnectCloud();
  client.loop();
}[/mw_shl_code]
TinkerNode NB-IoT 物联网开发板 测评第三弹 物联网初体验图2
TinkerNode NB-IoT 物联网开发板 测评第三弹 物联网初体验图3
相应的修改内容,请参考 DFROBOT的IoT服务器上相应的配置信息。因为还不能使用流量卡,我们这里用的是WIFI模式的物联。
现在让我们愉快地刷入,然后打开串口看看:
TinkerNode NB-IoT 物联网开发板 测评第三弹 物联网初体验图4
注意设置好波特率115200,然后我们在dfrobot的IoT web端输入信息:
TinkerNode NB-IoT 物联网开发板 测评第三弹 物联网初体验图5
已然正确连通了信息。接下来我们再修改下代码,通过IoT的Web端信息发送,点亮NB板上自带的小灯吧。
开始之前我们需要修改下 MQTT的 callback回调函数,你可参照我的代码进行覆盖。
[mw_shl_code=c,false]void callback(char * topic, byte * payload, unsigned int len){
  Serial.print("] ");
  Serial.println();
  uint8_t LED_PIN = 2;
  pinMode(LED_PIN, OUTPUT);
  if((char)payload[0]=='1'){
    digitalWrite(LED_PIN, HIGH);
  else if((char)payload[0]=='0'){
    digitalWrite(LED_PIN, LOW);
  else{
     Serial.println((char)payload[0]);
}[/mw_shl_code]
完成后,我们重新刷入代码,BINGO,测试成功!
TinkerNode NB-IoT 物联网开发板 测评第三弹 物联网初体验图6
