3262| 1
[教程] [入门教程]zero玩树莓派4 按钮开灯 |
学习过LED模块之后,通常要开始按钮的学习,今天测试了,DF的按钮和ZERO库的兼容性实验,有点不一样。 一、实验目的 按钮控制LED灯的开关 二、实验设备 1.树莓派 *1 https://www.dfrobot.com.cn/goods-1976.html 2.树莓派扩展板*1 https://www.dfrobot.com.cn/goods-2041.html 3.LED模块*1 (gpio17号口) https://www.dfrobot.com.cn/goods-72.html 4.数字大按钮模块 黄色*1 (gpio17号口) https://www.dfrobot.com.cn/goods-78.html 三、代码实现 测试代码1.用print()命令打印按钮的状态,示例代码库中的代码,意思是按下按钮提示“”Button is pressed“”松开按钮提示“”Button is not pressed“” 但是实际运行效果相反,松开按钮提示“”Button is pressed“”按下按钮提示“”Button is not pressed“” from gpiozero import Button button = Button(16) while True: if button.is_pressed: print("Button is pressed") else: print("Button is not pressed") ![]() 此处查阅了df的wiki,咨询了李工,按钮分为两种类型,一种是按下高电平,松开为低电平;另一种洽洽相反; ZERO的库设置时可能正好和我用的模块相反; ![]() ![]() gpiozero 库参考资料 如果您手头有案例中的配件,请测试一下看看效果。 ![]() 测试代码2 from gpiozero import Button from signal import pause def say_hello(): print("Hello!") button = Button(16) button.when_pressed = say_hello pause() ![]() 测试代码3 from gpiozero import Button from signal import pause def say_hello(): print("Hello!") def say_goodbye(): print("Goodbye!") button = Button(16) button.when_pressed = say_hello button.when_released = say_goodbye pause() ![]() 测试代码4 按钮控制LED亮灭 from gpiozero import LED, Button from signal import pause led = LED(17) button = Button(16) button.when_pressed = led.on button.when_released = led.off pause() |
