3021浏览
查看: 3021|回复: 2
【自制无人机】“辛”路历程(九)PID库
又一个通俗的介绍PID
https://www.sohu.com/a/303474526_694970
【前言】
今天桨叶回来了,有8个的桨叶尺寸太大了,我的无刷电机KV值2千多,用不了。先测试一下:
大家一定要根据PID控制做一个简单的项目,然后再慢慢研究,才会深刻理解,和灵活运用。上一贴中使用了PID算法,网上还有PID库供大家使用:
1、
Arduino PID 库函数指南
2、使用PID库,轻松搞定PID(上)使用PID库,轻松搞定PID(下)
根据以下帖子进行改进。
使用PID库,轻松搞定PID(完整版)
【PID改进】
代码:
[mw_shl_code=java,false]#define  MAX_RANG      (520)//模块测距极值为520cm(比有效最大量程值略大)
#define  ADC_SOLUTION      (1023.0)//Arduino UNO 的ADC精度为10bit
int sensityPin = A0;
int input1 = 5; // pin 5 向 input1 输出
int input2 = 6; // pin 6 向 input2 输出
int enA = 10; //pin 10 向 输出A使能端输出
int direction1 = 0;
unsigned long lastTime;
double Input, Output, Setpoint;
double ITerm, lastInput;
double kp, ki, kd;
int SampleTime=1000;
double outMin,outMax;
bool inAuto=false;
#define MANUAL 0
#define AUTOMATIC 1
void Compute()
  if(!inAuto) return;
   /*How long since we last calculated*/
   unsigned long now = millis();
  int timeChange = (now - lastTime);
  if(timeChange>=SampleTime)
   /*Compute all the working error variables*/
   double error = Setpoint - Input;
   ITerm += (ki*error);
   if(ITerm>outMax) ITerm=outMax;
   else if(ITerm<outMin) ITerm=outMin;
   double dInput = (Input - lastInput);
   /*Compute PID Output*/
   Output = kp * error +ITerm - kd * dInput;
   /*Remember some variables for next time*/
   lastInput = Input;
   lastTime = now;
  if(error<0){
    direction1=0;
   else
   direction1=1;
void SetOutputImits(double Min,double Max)
  if(Min>Max) return;
   outMin=Min;
   outMax=Max;
   if(Output>outMax) Output=outMax;
   else if(Output<outMin) Output=outMin;
void SetTunings(double Kp, double Ki, double Kd)
   double SampleTimeInSec=((double)SampleTime)/1000;
   kp = Kp;
   ki = Ki*SampleTimeInSec;
   kd = Kd/SampleTimeInSec;
void SetSampleTime(int NewSampleTime)
  if(NewSampleTime>0)
    double ratio=(double)NewSampleTime/(double)SampleTime;
    ki*=ratio;
    kd/=ratio;
    SampleTime=(unsigned long)NewSampleTime;
void SetMode(int Mode)
  bool newAuto=(Mode==AUTOMATIC);
  if(newAuto && !inAuto)
    Initialize();
  inAuto=newAuto;
void Initialize()
  lastInput=Input;
  ITerm=Output;
void setup() {
  // Serial init
  Serial.begin(9600);
   pinMode(input1,OUTPUT);
   pinMode(input2,OUTPUT);
   pinMode(enA,OUTPUT);
  Setpoint=30;
  SetMode(AUTOMATIC);
  SetTunings(2, 0.001, 0.01);
  SetOutputImits(0,200);
float dist_t, sensity_t;
void loop() {
  // read the value from the sensor:
sensity_t = analogRead(sensityPin);
  // turn the ledPin on
dist_t = sensity_t * MAX_RANG  / ADC_SOLUTION;//
Input=dist_t;
/*Serial.print(dist_t,0);*/
Compute();
if(direction1==0)
   digitalWrite(input1,HIGH); //给高电平
   digitalWrite(input2,LOW);  //给低电平
   analogWrite(enA,50-Output);
else
   digitalWrite(input1,LOW); //给高电平
   digitalWrite(input2,HIGH);  //给低电平
   analogWrite(enA,50+Output);
Serial.println(Output,0);
}[/mw_shl_code]
【自制无人机】“辛”路历程(九)PID库图1
【演示视频】
发表于 2020-3-15 09:30:06
追剧中……
gada888  版主
发表于 2020-3-25 14:37:23
算法库
