2019-12-30 15:27:28 [显示全部楼层]
7521浏览
查看: 7521|回复: 1
[项目] IOT-传感发提醒短信给手机
物联网时代,IOT将无处不在,这次还是接着上篇的震动传感IOT,更深一步,为它加入事件的手机短信提醒
先简单介绍一下上一篇。
上篇用到的硬件如下
IOT-传感发提醒短信给手机图1
nodemcu
IOT-传感发提醒短信给手机图2
震动传感SM-420
IOT-传感发提醒短信给手机图3
NODEMCU 脚位
IOT-传感发提醒短信给手机图4
连线图
IOT-传感发提醒短信给手机图5
thingspeak.com登录后所见的图表
IOT-传感发提醒短信给手机图6
thingspeak建立通道
IOT-传感发提醒短信给手机图7
thingspeak api值
IOT-传感发提醒短信给手机图8
[mw_shl_code=applescript,true]//--------gada888 撸码-------------
#include <ESP8266WiFi.h>
String apiKey = "你的apikey";
const char *ssid = "你的WiFi名";
const char *pass = "你的wifi密码";
const char* server = "api.thingspeak.com";
WiFiClient client;
//--------------------SETUP---------------
void setup(){
Serial.begin(115200);
delay(10);
Serial.println("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, pass);
while (WiFi.status() != WL_CONNECTED)
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
//--------------LOOP-----------------
void loop(){
float h = analogRead(A0);
if (client.connect(server, 80))
String postStr = apiKey;
postStr += "&field1=";
postStr += String(h/1023*100);
postStr += "r\n";
client.print("POST /update HTTP/1.1\n");
client.print("Host: api.thingspeak.com\n");
client.print("Connection: close\n");
client.print("X-THINGSPEAKAPIKEY: " + apiKey + "\n");
client.print("Content-Type: application/x-www-form-urlencoded\n");
client.print("Content-Length: ");
client.print(postStr.length());
client.print("\n\n");
client.print(postStr);
Serial.print("Noise Level: ");
Serial.println(h/1023*100);
Serial.println("Data Send to Thingspeak");
client.stop();
Serial.println("Waiting...");
// thingspeak needs minimum 15 sec delay between updates.
delay(1500);
[/mw_shl_code]
接下来是pushbullet部分和thingspeak的设置
IOT-传感发提醒短信给手机图9
PC端登录pushbullet,并从主页下载pushbullet app
IOT-传感发提醒短信给手机图10
IOT-传感发提醒短信给手机图11
app上选推送,我们先来测试
IOT-传感发提醒短信给手机图12
pushbullet PC端texting选项下,发送一条短信给手机。手机号码前加国家代号。例如中国是+86,后面跟你的手机号。例如+86186xxxxxxxx
手机上会收到一条你从PC端发的短信。这样证明通讯成功。
IOT-传感发提醒短信给手机图13
最后是进行thingspeak和pushbullet的连接。
IOT-传感发提醒短信给手机图14
选择thingHTTP
IOT-传感发提醒短信给手机图15
按照上面来设置HTTP 发送
然后是React来设置应答
IOT-传感发提醒短信给手机图16
IOT-传感发提醒短信给手机图17
设置好保存
IOT-传感发提醒短信给手机图18
设置需要的pushbullet token。要保存为txt文件。以备使用。
IOT-传感发提醒短信给手机图19
这是手机短信提醒。
提示:震动传感上有个调整旋钮,可以调灵敏度。
kylinpoet  中级技神
发表于 2020-2-18 16:23:35
楼主强大,多谢分享。
