7910浏览
查看: 7910|回复: 0
[讨论] mega2560外部EEPROM地址出错
#include <Wire.h>
void setup()
  Serial.begin(9600);
  delay(10);
  Wire.begin();
byte val = 0;
int index = 0;
void loop()
  byte a0 = 0x00;
  byte b0 = 0x00;
  write_data(0x50 ,0x00 ,0xbb);
  //write_data(0x57 ,0x00 ,0x22);
  a0 = read_data(0x50 ,0x00);
  //byte b0 = read_data(0x57 ,0x00);
  Serial.print("a=");delay(10);
  Serial.println(a0,HEX);delay(10);
  Serial.print("b=");delay(10);
  Serial.println(b0,HEX);delay(10);
  delay(2000);
void write_data(byte num ,byte add ,byte data)
  // write
  Wire.beginTransmission(int(num));
  Wire.write(add);            // send  address   ww
  Wire.write(data);            // send  data ww
  Wire.endTransmission();     //
  delay(10);  //very import ww
byte read_data(byte num ,byte add)
  // read
  Wire.requestFrom(int(num), 1);    // request 2 bytes from slave device #112
  if(1 <= Wire.available())
      val = Wire.read();  // receive high byte (overwrites previous reading)
  delay(10);
  return val;
我用AT24C02作为外部EEPROM,板子是mega2560,(SDA为Pin20,SCL为Pin21——这没错吧?)错误如下:
不管AT24C02硬件地址(A0A1A2)为多少,数据照样写入AT24C02中~
即:
write_data(0x50,0x00,0xaa);
write_data(0x57,0x00,0x11);
接着读取数据时
read_data(0x50,0x00)的值为0x11;
read_data(0x57,0x00)的值也为0x11~
我AT24C02的硬件地址为0x50~
求大神指教
