5810浏览
查看: 5810|回复: 1
[求助] 红外遥控不成功
我复制了教程里面红外遥控灯的程序,可是上传后灯就一直亮着,重启也没用,打开串口监视器就不停地出0,0,0,0,0,0
怎么办,是判断部分代码有问题吗?
之前没有加判断部分前运行良好,监视器可以正常接收,加完判断和执行部分就不行了,为啥?
在线等大神帮助,谢谢!
for(iled=1;iled<=8;iled+=1);
                if(iled == 1);
                    analogWrite(LED1,1);
                    analogWrite(LED2,1);
                    delay(t);
                if(iled == 2);
                    analogWrite(LED1,4);
                    analogWrite(LED2,4);
                    delay(t);
                if(iled == 3);
                    analogWrite(LED1,13);
                    analogWrite(LED2,13);
                    delay(t);
                if(iled == 4);
                    analogWrite(LED1,32);
                    analogWrite(LED2,32);
                    delay(t);
                if(iled == 5);
                    analogWrite(LED1,62);
                    analogWrite(LED2,62);
                    delay(t);
                if(iled == 6);
                    analogWrite(LED1,108);
                    analogWrite(LED2,108);
                    delay(t);
                if(iled == 7);
                    analogWrite(LED1,171);
                    analogWrite(LED2,171);
                    delay(t);
                if(iled == 8);
                    analogWrite(LED1,255);
                    analogWrite(LED2,255);
                    delay(t);
雾满拦江-铜台映月  见习技师
发表于 2019-7-25 21:18:33
#include <IRremote.h>
int RECV_PIN = 11;
int ledPin = 10;                // LED – digital 10
boolean ledState = LOW;         // ledstate用来存储LED的状态
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup(){
     Serial.begin(9600);
     irrecv.enableIRIn();
     pinMode(ledPin,OUTPUT);       // 设置LED为输出状态
void loop() {
      if (irrecv.decode(&results)) {
              Serial.println(results.value, HEX);
              //一旦接收到电源键的代码, LED翻转状态,HIGH变LOW,或者LOW变HIGH
         if(results.value == 0xFD00FF){
                 ledState = !ledState;             //取反
                 digitalWrite(ledPin,ledState);    //改变LED相应状态
            irrecv.resume();
