2018-10-26 15:42:17 [显示全部楼层]
11932浏览
查看: 11932|回复: 1
[求助] max30102心率血氧模块求助
最近网上买了个max30102的心率血氧模块,用卖家给的单个例程的时候数据还算准确,但是我自己把心率和血氧功能整合到了一起,过来的数据就波动比较大了,想请大神们看看,如何修改。 程序如下:#include <Wire.h>#include "MAX30105.h"
#include "heartRate.h"
#include "spo2_algorithm.h"
MAX30105 particleSensor;
#define MAX_BRIGHTNESS 255
#if defined(__AVR_ATmega328P__) || defined(__AVR_ATmega168__)
//Arduino Uno doesn't have enough SRAM to store 100 samples of IR led data and red led data in 32-bit format
//To solve this problem, 16-bit MSB of the sampled data will be truncated. Samples become 16-bit data.
uint16_t irBuffer[100]; //infrared LED sensor data
uint16_t redBuffer[100];  //red LED sensor data
#else
uint32_t irBuffer[100]; //infrared LED sensor data
uint32_t redBuffer[100];  //red LED sensor data
#endif
int32_t bufferLength; //data length
int32_t spo2; //SPO2 value
int8_t validSPO2; //indicator to show if the SPO2 calculation is valid
int32_t heartRate; //heart rate value
int8_t validHeartRate; //indicator to show if the heart rate calculation is valid
byte pulseLED = 11; //Must be on PWM pin
byte readLED = 13; //Blinks with each data read
const byte RATE_SIZE = 4; //Increase this for more averaging. 4 is good.
byte rates[RATE_SIZE]; //Array of heart rates
byte rateSpot = 0;
long lastBeat = 0; //Time at which the last beat occurred
float beatsPerMinute;
int beatAvg;
void setup()
  Serial.begin(115200); // initialize serial communication at 115200 bits per second:
  pinMode(pulseLED, OUTPUT);
  pinMode(readLED, OUTPUT);
  // Initialize sensor
  if (!particleSensor.begin(Wire, I2C_SPEED_FAST)) //Use default I2C port, 400kHz speed
    Serial.println(F("MAX30105 was not found. Please check wiring/power."));
    while (1);
  Serial.println(F("Attach sensor to finger with rubber band. Press any key to start conversion"));
  while (Serial.available() == 0) ; //wait until user presses a key
  Serial.read();
  byte ledBrightness = 60; //Options: 0=Off to 255=50mA
  byte sampleAverage = 4; //Options: 1, 2, 4, 8, 16, 32
  byte ledMode = 2; //Options: 1 = Red only, 2 = Red + IR, 3 = Red + IR + Green
  byte sampleRate = 100; //Options: 50, 100, 200, 400, 800, 1000, 1600, 3200
  int pulseWidth = 411; //Options: 69, 118, 215, 411
  int adcRange = 4096; //Options: 2048, 4096, 8192, 16384
  particleSensor.setup(ledBrightness, sampleAverage, ledMode, sampleRate, pulseWidth, adcRange); //Configure sensor with these settings
// particleSensor.setup(); //Configure sensor with default settings
  particleSensor.setPulseAmplitudeRed(0x0A); //Turn Red LED to low to indicate sensor is running
  particleSensor.setPulseAmplitudeGreen(0); //Turn off Green LED
void loop()
  bufferLength = 100; //buffer length of 100 stores 4 seconds of samples running at 25sps
  //read the first 100 samples, and determine the signal range
  for (byte i = 0 ; i < bufferLength ; i++)
    while (particleSensor.available() == false) //do we have new data?
      particleSensor.check(); //Check the sensor for new data
    redBuffer = particleSensor.getRed();
    irBuffer = particleSensor.getIR();
    particleSensor.nextSample(); //We're finished with this sample so move to next sample
  //calculate heart rate and SpO2 after first 100 samples (first 4 seconds of samples)
  maxim_heart_rate_and_oxygen_saturation(irBuffer, bufferLength, redBuffer, &spo2, &validSPO2, &heartRate, &validHeartRate);
  //Continuously taking samples from MAX30102.  Heart rate and SpO2 are calculated every 1 second
  while (1)
    //dumping the first 25 sets of samples in the memory and shift the last 75 sets of samples to the top
    for (byte i = 25; i < 100; i++)
      redBuffer[i - 25] = redBuffer;
      irBuffer[i - 25] = irBuffer;
    //take 25 sets of samples before calculating the heart rate.
    for (byte i = 75; i < 100; i++)
      digitalWrite(readLED, !digitalRead(readLED)); //Blink onboard LED with every data read
      long irValue = particleSensor.getIR();
      if (checkForBeat(irValue) == true)
    //We sensed a beat!
    long delta = millis() - lastBeat;
    lastBeat = millis();
    beatsPerMinute = 60 / (delta / 1000.0);
      //send samples and calculation result to terminal program through UART
//     Serial.print(F("red="));
//     Serial.print(redBuffer, DEC);
//     Serial.print(F(", ir="));
//     Serial.print(irBuffer, DEC);
//     Serial.print(F(", HR="));
//     Serial.print(heartRate, DEC);
//     Serial.print(F(", HRvalid="));
//     Serial.print(validHeartRate, DEC);
        Serial.print(", BPM=");
        Serial.print(beatsPerMinute);
      Serial.print(F(", SPO2="));
      Serial.print(spo2, DEC);
      Serial.print(F(", SPO2Valid="));
      Serial.println(validSPO2, DEC);
//    if (irValue < 50000)
//    Serial.println(" No finger?");
    //After gathering 25 new samples recalculate HR and SP02
串口数据
串口数据
实物图
实物图
gada888  版主
发表于 2018-10-28 10:11:42
需要你一步一步的调,看问题在哪。另外你可以画一个流程图。看逻辑顺不顺。
