9291| 1
[求助] 18b20温度传到yeelink,有没有解释,和Adafruit_CC3000.h的具体内容 |
#include <OneWire.h> #include <DallasTemperature.h> #include <Adafruit_CC3000.h> #include <ccspi.h> #include <SPI.h> #define Wido_IRQ 7 //引脚定义,这三个引脚在wido中已经被定义死了,没必要改 #define Wido_VBAT 5 #define Wido_CS 10 #define ONE_WIRE_BUS 3 //定义温度传感器引脚 OneWire oneWire(ONE_WIRE_BUS); DallasTemperature sensors(&oneWire); Adafruit_CC3000 Wido = Adafruit_CC3000(Wido_CS, Wido_IRQ, Wido_VBAT, SPI_CLOCK_DIVIDER); //定义cc3000的名字和引脚 #define WLAN_SECURITY WLAN_SEC_WPA2 //加密方式 #define WLAN_SSID "Xiaomi_8898" //无线网名字 #define WLAN_PASS "anyida2015" //密码 #define TCP_TIMEOUT 3000 //#define CC3000_TINY_DRIVER #define WEBSITE "api.yeelink.net" #define API_key "1533dc46ece68df8f1524082fad83488" // Update Your API Key. To get your API Key, please check the link below // http://www.yeelink.net/user/user_profile double temp; void setup(){ temp=sensors.getTempCByIndex(0); //获取温度值,把它赋给temp sensors.begin(); //初始化总线 Serial.begin(115200); Serial.println(F("Hello, CC3000!\n")); /* wido初始化,如果wido初始化失败,那么串口返回信息进入死循环 */ Serial.println(F("\nInitialising the CC3000 ...")); if (!Wido.begin()) { Serial.println(F("Unable to initialise the CC3000! Check your wiring?")); while(1); } /* Attempt to connect to an access point */ char *ssid = WLAN_SSID; /* Max 32 chars */ Serial.print(F("\nAttempting to connect to ")); Serial.println(ssid); /* 此函数用来连接WiFi的名字如果连接失败,返回failed,进入死循环*/ if (!Wido.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) { Serial.println(F("Failed!")); while(1); } Serial.println(F("Connected!")); /* 获取动态IP地址的,是一个Boolean的函数 */ Serial.println(F("Request DHCP")); while (!Wido.checkDHCP()) { delay(100); // ToDo: Insert a DHCP timeout! } } uint32_t ip = 0; void loop(){ sensors.requestTemperatures(); temp=sensors.getTempCByIndex(0); static Adafruit_CC3000_Client WidoClient; //取名字 static unsigned long RetryMillis = 0; static unsigned long uploadtStamp = 0; static unsigned long sensortStamp = 0; if(!WidoClient.connected() && millis() - RetryMillis > TCP_TIMEOUT){ // Update the time stamp RetryMillis = millis(); Serial.println(F("Try to connect the cloud server")); WidoClient.close(); // Get Yeelink IP address Serial.print(F("api.yeelink.net -> ")); while (ip == 0) { if (!Wido.getHostByName(WEBSITE, &ip)) { // 获取基于域名的服务器IP地址 Serial.println(F("Couldn't resolve!")); } delay(500); } Wido.printIPdotsRev(ip); Serial.println(F("")); // Connect to the Yeelink Server WidoClient = Wido.connectTCP(ip, 80); // 尝试连接云服务器 } if(WidoClient.connected() && millis() - uploadtStamp > 10000){ uploadtStamp = millis(); // If the device is connected to the cloud server, upload the data every 2000ms. // Prepare Http Package for Yeelink & get length int length = 0; char lengthstr[3]; // Create Http data package char httpPackage[60] = ""; strcat(httpPackage,"{\"value\":"); itoa(temp,httpPackage+strlen(httpPackage),10); //将数据(temp)推到http数据包 strcat(httpPackage,"}"); // strcat(httpPackage,"{\"value\":");这三行是湿度的 //itoa(DHT.humidity,httpPackage+strlen(httpPackage),10); // 将数据(temp)推到http数据包 //strcat(httpPackage,"}"); length = strlen(httpPackage); // 获取数据包的长度 itoa(length,lengthstr,10); //将int转换为char数组,用于发布 Serial.print(F("Length = ")); Serial.println(length); Serial.println(F("Connected to Yeelink server.")); // Send headers Serial.print(F("Sending headers")); WidoClient.fastrprint(F("POST /v1.0/device/")); WidoClient.fastrprint(F("359840/sensor/410293/datapoints")); //请在创建后更改您的设备ID和传感器ID WidoClient.fastrprintln(F(" HTTP/1.1")); Serial.print(F(".")); WidoClient.fastrprintln(F("Host: api.yeelink.net")); Serial.print(F(".")); WidoClient.fastrprint(F("U-ApiKey: ")); WidoClient.fastrprintln(API_key); Serial.print(F(".")); WidoClient.fastrprint("Content-Length: "); WidoClient.fastrprintln(lengthstr); WidoClient.fastrprintln(""); Serial.print(F(".")); Serial.println(F(" done.")); // Send data Serial.print(F("Sending data")); WidoClient.fastrprintln(httpPackage); Serial.println(F(" done.")); /********** 获取http页面反馈 ***********/ unsigned long rTimer = millis(); Serial.println(F("Reading Cloud Response!!!\r\n")); while (millis() - rTimer < 10000) { while (WidoClient.connected() && WidoClient.available()) { char c = WidoClient.read(); Serial.print(c); } } delay(1000); // 等待1s结束数据流 WidoClient.close(); // 关闭服务连接 RetryMillis = millis(); //重置用于应用与服务的连接的计时器戳记 } } |
